usoska Posté(e) 16 septembre 2009 Share Posté(e) 16 septembre 2009 nouvelle version (1.1.0.65, 16 septembre 2009) Areas of Change * Encryption! Sprite Backup is the only product on the market that can encrypt your backup. You can now use AES-128 encryption (the US government encryption standard) to add extra protection to your data. Use the Settings menu to turn it on. Using encryption will increase your backup/restore times slightly, but it's a small price to pay for the extra security. Be warned, remember to keep your password safe, as we cannot recover it. * Smaller files - We've managed to reduce the size of your backup files by up to 70%, freeing up more valuable space on your phone * German Language Support Issues Fixed from Previous Releases * Some users were experiencing problems booting backup when a large number of third party apps were installed. This has now been fixed. Big thanks to Tony for his help. * Fixed a bug when restoring photos to Hero would fail. * When restoring media files, the progress bar now gives greater feedback to indicate your progress. * General bug fixes and enhancements. Known Issues * Contacts that sync with Google will no longer sync after a restore. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 18 septembre 2009 Share Posté(e) 18 septembre 2009 hehe ils ont remonter mes bugs :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 15 octobre 2009 Share Posté(e) 15 octobre 2009 (modifié) mise a jour du 15 octobre version 1.2.0.71 Areas of Change * Full support for Contacts - Another first for Sprite, no other Android backup product supports Google sync when working with your contacts. We now backup and restore only the contacts that aren't synced anywhere. There isn't much point in backing up stuff if Google or HTC Sync already does it for you is there? Are half your contacts synced and the other half not? No problem, you'll get back what you need. * HTC Hero Scene Support - You spend a lot of time customizing your home screens, so we now back them up too, even down to the Stock widget settings. Everything will be captured if you select 'System Settings' * HTC Hero Application Settings - If you're using HTC's Twitter, Plurks and Footprints apps we now capture those settings (and your Footprint data) as part of 'Application Settings'. * Instant Messenger Settings - For those IM users, 'Application Settings' now captures all your account details. * APN Settings - Have you rooted your phone? Do you live on the bleeding edge of Android development? If so, entering APN settings can be a real chore. 'System Settings' now captures and restores APN settings. * Multiple screen resolutions - There are a load of new Android devices coming out in the next few months (even some Netbooks!) and for the first time Android will be appearing on different screen sizes to ones you've seen so far. To get ready we've updated backup so it will work perfectly, no matter what size of screen you have. * Contacts Updated - HTC have a different way of dealing with some contact fields, so we've updated to stay compatible with them. Issues Fixed * General bug fixes and enhancements. Known Issues * You will need to reboot your device for restored Hero scenes to become visible if... o you restored 'System Settings' after performing a hard reset o you restored 'System Settings' with a different number of custom Scenes Modifié 15 octobre 2009 par johndoe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 15 octobre 2009 Share Posté(e) 15 octobre 2009 ça fait plaisir de voir un changelog comme ça :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
usoska Posté(e) 21 octobre 2009 Auteur Share Posté(e) 21 octobre 2009 Encore une nouvelle release qui tue ! Avec l'ajout de la traduction FR, youpi ! 1.3.0.75 (21/10/09) Areas of Change * Calendar - Synced or un-synced, we can back them up and then bring them all back safely onto your phone * French Language Support - We now ship in French. A big thanks to MartinB (www.monandroid.fr) for his help. * HTC Voice Recorder - If you use the Voice Recorder on your Hero, we now backup your recordings as part of 'Music'. Issues Fixed * Pressing the back button on the loading screen would cause a force close. * Occasional issue restoring SMS on Hero would place a SIM symbol next to received messages. Thanks to MartinG in helping us track that one down. * General bug fixes and enhancements. Known Issues * You will need to reboot your device for restored Hero scenes to become visible if... o you restored 'System Settings' after performing a hard reset o you restored 'System Settings' with a different number of custom Scenes Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 21 octobre 2009 Share Posté(e) 21 octobre 2009 lol j'cherchais le thread pour mettre a jour Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
usoska Posté(e) 23 octobre 2009 Auteur Share Posté(e) 23 octobre 2009 1.3.0.77 (23/10/2009) Areas of Change * None Issues Fixed o Restore produces duplicate fields in HTC Contact Card. o Occasional issue restoring SMS messages to G1. o General bug fixes and enhancements. Known Issues o You will need to reboot your device for restored Hero scenes to become visible if... + you restored 'System Settings' after performing a hard reset + you restored 'System Settings' with a different number of custom Scenes Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Taniya Posté(e) 23 octobre 2009 Share Posté(e) 23 octobre 2009 Je comprends pas , j'ai cette application ! quand j'avais fait un backup et restaurer, deux fois je lai fait, deja mes contacts je les avait plus, ni les applications téléchargées, ni les sms !!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 11 décembre 2009 Share Posté(e) 11 décembre 2009 j'remonte un peu le topic car ils proposent sprite a 0.99$ pour noel et que 2 grosses mises a jours sont dispo la possibilité de schedule les sauvegardes est vraiment un plus pour ceux qui oublient d'y faire :D 1.4.0.99 (11 December 2009) Areas of Change * Scheduled Backups. Note scheduled backups are only available in English right now. We're getting the translations done over the next few days, and will put out an update when they're done. Don't forget, if you want to help translate backup into your language, let us know. * We've increased the characters you can use in your filename to 'a-z A-Z 0-9 - _ [space]'. * As more people are using encryption, we've reorganized of the Setting list, to bring encryption closer to the top. * A new background! We thought scheduling called for a celebration, so we've put in a new background. Issues Fixed * Occasional SMS restore fail. * When restoring an encrypted file a screen refresh was needed to display the file contents. * Restore file list would sometimes show a file out of chronological order. * General bug fixes and enhancements. Known Issues * Restoring MMS data to the Droid from a non-Droid phone does not work. We're working on it and will have a fix out soon. * You will need to reboot your device for restored Hero scenes to become visible if... o you restored 'System Settings' after performing a hard reset o you restored 'System Settings' with a different number of custom Scenes 1.3.1.85 (19 November 2009) * Backup and Restore have now been fully tested and verfied to work on the Motorola Droid. Android 2.0 changed a lot of stuff at the backend so we've had to go through and retest the whole application. Getting a Droid to New Zealand was our biggest challenge (we have the only one in the country!) but once we had it things were plain sailing. Areas of Change * Added phone make, model and Android version to log files that are emailed in. Issues Fixed * Occassional issue of SMS/MMS messages restoring in an incorrect order. * Occasional issue affecting contacts, causing the restore to fail. * General bug fixes and enhancements. Known Issues * Restoring MMS data to the Droid from another device does not work. We're working on it and will have a fix out soon. * You will need to reboot your device for restored Hero scenes to become visible if... o you restored 'System Settings' after performing a hard reset o you restored 'System Settings' with a different number of custom Scenes Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 23 décembre 2009 Share Posté(e) 23 décembre 2009 mise a jour de noel 1.4.1.101 (24 December 2009) Overview * Just in time for the holiday season, here's another update. We've spent some time cleaning up the code, ready for some exciting features in the new year. Have a fantastic holiday season and thanks for choosing Sprite! Areas of Change * French language support for Scheduled backups * Spanish language support for Scheduled backups * Korean language support for Scheduled backups * Simplified Chinese language support for Scheduled backups * Traditional Chinese language support for Scheduled backups * Improved calendar support. * Improved contact group membership support. Issues Fixed * In certain circumstances a scheduled backup would fail to start. * Scheduled backup status bar notification no longer remains in the status bar after a backup. * Scheduled backup logs would not show the backup file size. * General bug fixes and enhancements. Known Issues * Restoring MMS data to the Droid from a non-Droid phone does not work. * You will need to reboot your device for restored Hero scenes to become visible if... o you restored 'System Settings' after performing a hard reset o you restored 'System Settings' with a different number of custom Scenes Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 8 janvier 2010 Share Posté(e) 8 janvier 2010 1.4.2.104 (8 January 2010) Areas of Change * Update Notifications - Android isn't very good at telling you if we have an update, so we've put in our own system. The good news is it doesn't matter where you bought your copy of backup, the notification system will still work. It will check for an update every seven days. We plan on having another update next week (we're very excited about that one) so you should see the notification system in action then. Issues Fixed * Flashing icon during scheduled backup does not disappear when the backup is finished. * General bug fixes and enhancements. Known Issues * Restoring MMS data to the Droid from a non-Droid phone does not work. * You will need to reboot your device for restored Hero scenes to become visible if... o you restored 'System Settings' after performing a hard reset o you restored 'System Settings' with a different number of custom Scenes Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 8 janvier 2010 Share Posté(e) 8 janvier 2010 Très pratique à l'usage pour passer de ROM rapidement ! Je recommande à l'usage ! :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tranquiliste Posté(e) 19 janvier 2010 Share Posté(e) 19 janvier 2010 Ne marche pas chez moi (hero et version 1.4.2.104) depuis les dernières mises à jour il me sort un message d'erreur après l'acceptation des CG et quand je veux sauver il n'arrête pas de dire que le nom de la sauvegarde ne doit comporter que des lettres ou chiffres (ce qui est le cas). Ca fait 15 jours que je me dit que je dois leur envoyer un mail. A noter que j'acheté l'appli car tout le monde en disait beaucoup de bien mais la seul fois où j'ai eu à faire un restore ça n'a marché qu'à moitié (version d'il y a 2 mois). Bref vraiment déçu/ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
wolwerine69 Posté(e) 11 février 2010 Share Posté(e) 11 février 2010 j'ai un problème je viens de réinstaller la rom modaco 3.1 et lorsque je veux réinstaller srite backup que j'ai acheté il y'a bien longtemps déja ça installé la version 1.0.0.51 sur le market !! du coup je ne peux pas restauré ma sauvegarde... quelqu'un peux m'aider ?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 11 février 2010 Share Posté(e) 11 février 2010 j'vois pas comment ça peux t'installer une si vieille version si tu prends du market Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 24 mai 2010 Share Posté(e) 24 mai 2010 j'fait remonter un peu juste parce que c'est désormais compatible avec dropbox 2.1.0.136 (24 May 2010) Areas of Change * We've cleared the slate of all exsiting issues. If you find any new ones let us know at helpdesk@spritesoftware.com * We've been working with our new friends at Dropbox to allow you to store your backup files on their servers. Dropbox is really clever. If you have their client installed on your Windows, Mac or Linux PC then within a few seconds of your backup completing, the file is not only safely uploaded to the Dropbox servers, but is also copied onto your PC. Even better still, is that Dropbox offer 2GB of online storage for FREE! That's 2GB of space to store your photos, video, music and all the other stuff you keep on your phone. If you need more, simply upgrade your Dropbox account to whatever you need. Head on over to www.dropbox.com to get started. * The online upload system has also been updated, making uploading your files even more reliable. * Our first major overhaul of Android Backup and it's a big one. It's taken a couple of months, but we've designed a completely new interface making Backup even easier to use. We've also partnered up with Box.net to give you 1GB of FREE online storage for your backup files. For more details of what has changed see the list below. New Features * Online backup. Signup with Box.net for 1GB of FREE online storage. Should you need more, they can provide you with whatever you need. Check it out atwww.box.net. * New user interface. Adding online backup was a big change to we designed a new experience around it. Creating new backups and managing your existing ones is now even easier. * Even better support for 2.0+, so all you Droid and Nexus One users can get perfect restores every time. * Over 50+ languages supported. Whether you speak German or Swahili we're localized for you. * Manual backup may fail after a scheduled backup has occured. General bug fixes and enhancements. * Changed restore flow, to be more intuitive. * General bug fixes and enhancements. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
