zzz999 Posté(e) 26 novembre 2010 Share Posté(e) 26 novembre 2010 Par défaut Swype est installé en version 2.6.47.11856 au cas où vous n'êtes pas au courant il existe actuellement la version 2.10.52.13753 beta qui fonctionne très bien voici le ! New in swype 2.10: * Added microphone button (QWERTY only. Requires Google Voice Search be pre-integrated in your phone’s ROM) * Added French & EXPERIMENTAL Chinese Pinyin languages * Modified new word priority defaults. The word-choice-window will now be ordered more intelligently when encountering custom dictionary words * Fixed a bug where an extra space would be added when replacing a word by Swyping after opening the word choice window * Improved the "Hidden-Word" dialog handling so it doesn't show up as often (more improvements to this next time) * Improved prediction when handling various path collisions * Added Double-Tap-to-Edit and Cursor Restore * Lots of minor bug fixes Google saura vous aider pour trouver cette beta voici donc la marche à suivre pour faire la maj qui fonctionne I'm using Titanium Backup (the free version should be work fine). 1) First change to another keyboard to be safe. 2) Press the Backup/Restore tab at the top, scroll to Swype. Click on it. 3) To be safe, make a backup of Swype. Then Wipe Data and Delete it. It should be dimmed and marked out after deletion. 4) Using Root Explorer, delete \system\lib\libSwypeCore.so. To be safe, make a copy of it to ur sdcard in case anything goes south. 5) Reboot. 6) Now you should be able to install the latest Swype beta without any problems, you will need to enable it in settings after that to use it. Did not experience any force closes or quirks so far....hope it works for u guys too. In case of any problems, going backwards to restore libSwypeCore.so and Swype via Titanium Backup shouldn't be too hard. c'est tout :) PS ne vous trompez pas de version, pour le GS c'est la WVGA (480x800) qu'il faut et non pas la HVGA (320x480) ou la WVGA854 X10/Milestone (480x854) Lien vers le commentaire Partager sur d’autres sites More sharing options...
stephh Posté(e) 27 novembre 2010 Share Posté(e) 27 novembre 2010 Pourquoi ne pas avoir mis dans la section des tuto ? :) Lien vers le commentaire Partager sur d’autres sites More sharing options...
zzz999 Posté(e) 27 novembre 2010 Auteur Share Posté(e) 27 novembre 2010 me suis rendu compte trop tard si un modo veut bien faire la démarche ... ;) Lien vers le commentaire Partager sur d’autres sites More sharing options...
stephh Posté(e) 27 novembre 2010 Share Posté(e) 27 novembre 2010 Je comprends pas, ils ont ajouté le français ? Ca veut dire quoi ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
zzz999 Posté(e) 27 novembre 2010 Auteur Share Posté(e) 27 novembre 2010 pas compris non plus, il me semble qu'il y à une meilleure gestion des : j'ai, j'.... mais n'en suis pas suis pas trop sur je n'ai pas trop d'exp swype pour juger les 2 versions Lien vers le commentaire Partager sur d’autres sites More sharing options...
stephh Posté(e) 27 novembre 2010 Share Posté(e) 27 novembre 2010 Je vais attendre la version finale :) Lien vers le commentaire Partager sur d’autres sites More sharing options...
