Lag GS
Vincent34
pour ma part le lagfix 2.2+ apparait bien en vert, mais quand je le lance, voilà ce que j'obtiens :
Wed Dec 08 12:07:59 HNEC 2010: Remounting /system as rw
Wed Dec 08 12:08:03 HNEC 2010: Enabling Flight Mode and killing all running apps.
Wed Dec 08 12:08:14 HNEC 2010: Initializing boot support
Wed Dec 08 12:08:17 HNEC 2010: Calculating sizes...
Wed Dec 08 12:08:17 HNEC 2010: Mounting RFS /data onto /dbdata/rfsdata
Wed Dec 08 12:08:18 HNEC 2010: Creating 940 MB file to store data inside. This could take a long time...
Wed Dec 08 12:08:19 HNEC 2010: Running command: dd if=/dev/zero of=/dbdata/rfsdata/ext2/linux.ex2 bs=1M count=0 seek=940
Wed Dec 08 12:08:50 HNEC 2010: Creating loopback device
Wed Dec 08 12:08:50 HNEC 2010: Linking loopback to the file store
Wed Dec 08 12:08:50 HNEC 2010: Creating the EXT2 filesystem
Wed Dec 08 12:08:50 HNEC 2010: Mounting Device
Wed Dec 08 12:08:50 HNEC 2010: Hit an error, undoing lagfix!
Wed Dec 08 12:08:52 HNEC 2010: OneClickLagFix V2.2+ failed with error: Could not mount loopback device /dev/loop5! mount: Device or resource busy
Est-ce que quelqu'un a rencontré le même problème ???
oui et la seule solution faire un lagfix via SuperOneClick :(
