Cronos Ginger 2.3.1 - V0.0.9 Bêta -
philos64
Voici les screens de la Cronos Ginger 2.3.1 que Feeyo est en train de compiler afin que notre Hero ne soit pas laissé à la traîne.
Il ne reste plus grand chose à faire pour que cette rom sorte en version normale.
La rom est en phase finale de test Bêta
I have updated the build.
21 Jan 2011 | Cronos Ginger version 0.0.9
* Repacked all the patches for 0.0.8
* Camera Fixed by SteelBytes! awesome work man!
09 Jan 2011 | Cronos Ginger version 0.0.8
* Full new Compile.
* Incorporated A2SD into boot.img (Thanks to Elelinux)
* Correct QComEGL 1.1 version string (Thanks to l0st.prophet)
* Updated Graphics (Thanks to l0st.prophet)
* Fixed CM Extra Options.
* Incorporated VOIP. WiFi/G/3G (Thanks Aeonflux75)
* Updated EGL and SKIA.
* Added Music3 (Hope Gani is happy now).
* Fix for Caller Bug? (Not tested myself yet).
Cronos Ginger version 0.0.7
* Fixed sensors
* Fixed Compass
* Running OpenGLES 1.1
* Running OpenSLES
* Added CM Extra menu.
* Added Elelinux,Erasmux A2SD patch to download links.
Cronos Ginger version 0.0.6
* Added CM Notification bar.
* Compiled with a few more optimization flags.
* GPS Semi Fix: By Elelinux
* USB/SDCARD Fix: By Elelinux
* Bluetooth Fix: By elelinux
Cronos Ginger version 0.0.5
* EGL should now be fully working Gingerbread style.
* Fixed gapps library exceptions.
* Default GB Launcher included.
* Lights semi working.
Cronos Ginger version 0.0.4
* Improved speed on EGL.
* Improved WiFi Speed.
* Improved quality of the Official Gingerbread Theme.
* Recompiled sources with latest fixes.
* Fully Odexed.
* No need to wipe system with manually commands ;)
ROM: Cronos Ginger 0.0.9 Bêta
MD5SUM: 22c62005830728b907150ce0d90cb56b
LibCamera* Fix4.
CG-0.0.9-LibCamera_fix4
LibCamera Fix5:
CG-0.0.9 - LibCamera_Fix5(By Drdre)
GAPPS: Gapps mdpi 20101225
HTC IME By Elelinux:
Htc IME
Not working:
* Nothing!
Processus d'installation:
Flash Bêta 0.0.9
reboot
Flash patch Gapps
reboot
Flash LibCamera* Fix4
reboot
Flash HTC IME By Elelinux
reboott
Dans le cas d'un lien mort ou mauvais, envoyez-moi un MP. ;)
Dans peu de temps, le Hero va renaître grâce au travail de Feeyo et de son équipe de Dev, qui sortira bientôt une Version Gingerbread Custom avant même certains autres androphones :D
Y'en a qui vont baver :P
Modifié par philos64
  • Réponses 169
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Feeyo l'a mise en ligne afin que ceux qui veulent la tester, peuvent le faire.
ROM: Rom Cronos Ginger 0.0.1
GAPPS: Fichier GAPPS
Voici ce que écrit Feeyo sur sa version Bêta:
Please post anything you want but do not ask for support. This is just a preview release and very beta.
Please note this is a first build. It will only get better.
* Camera/Recorder NOT working.
* Very slow GUI.
Attendons de savoir ce que Feeyo va nous sortir de son chapeau magique de Dev ;)
J'ai testé la 0.0.3, ca rame un peu mais c'est largement acceptable. Pas de FC, hormis pour le clavier chinois mais bon c'est un clavier chinois donc voila ^^ Une fois le clavier français défini par défaut, plus aucun problème.
Le nouveau copier/coller est enfin vraiment utilisable facilement.
Bon par contre pour tous les jours, ca reste pas totalement confortable, faut attendre un peu encore je pense.
Modifié par sssweat
Non tu veux pas rajouter ce lien ? Ou bien il n'y a pas de post?
Il est présent dans la première ligne du post de Philos !
Mais je te le mets quand même ;) http://www.cronosproject.org/forum/viewtopic.php?f=63&t=620&utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+CronosAndroidAndroidOnSteroids+%28Cronos+Android%2C+Android+on+Steroids!%29#p21892
Il n'y était pas jusqu'à 18h ;) Merci :)
Désolé @Morak, mais il y était bien avant 18h, mais j'ai mis mon post à jour en 2 fois. Et 18h03 (puisque tu as remarqué cette heure) était la fin de ma seconde mise à jour et des corrections graphiques de mon post :P
Les liens sont surlignés, je l'aurai grillé direct, en plus je passe ma sourie partout :( 'fin je laisse le bénéfice du doute, j'suis pas omniscient ^^ Merci, je pourrais suivre l'évolution si jamais tu devais t'absenter une heure ou deux hehe
@benoitkmn,
je ne saurais te dire, il faudrait voir le screen d'un androphone sous Ginger...je vais essayé de voir.
Mais au premier abord se serait un widget à la Feeyo. ;)
