[ROM] kX10 - High performance SE replacement ROM [2.1]
Bonsoir à tous.
Voici une nouvelle rom basé sur une version 2.1 généric basé sur la dernière maj Sony-Ericsson qui est la 2.0.2.A.0.24.
Je tiens à précisé que c'est une rom modifié et optimisé.
Lien XDA: http://forum.xda-developers.com/showthread.php?t=913610
Modifications
•2.1 Generic Firmware (2.0.2.A.024);
•Rooted with xRecovery, JIT v2, SuperUser, and busybox installed;
•SuperCircle Battery mod;
•Reboot option mod;
•Nexus S boot animation;
•Ubuntu system fonts;
•Emoji support (display only)
•All APKs zipaligned;
•All non-essential system APKs moved to /data/app for easy uninstall and apps2sd support
build.prop Modifications
•windowsmgr.max_events_per_sec=220 - Makes scrolling smoother
•wifi.supplicant_scan_interval=180 - Slows down the WiFi scan to every 3 minutes, saves battery
•dalvik.vm.heapsize=26m - Optimal heapsize for most X10s
•mot.proximity.delay=150 - Makes the screen off/on proximity sensor more responsive
Removed
Timescape, Playnow, TrackID, CrashSMS, Backup and Restore, Chinese / Japanese / Korean IMEs, EManual / userguide, Moxiermail, SE PC Companion, SEMCHomeL, WisePiolot, Quadrapop
Pre-Installed APKs
*** I know this is a lot of apps, but these have all been zipaligned. If you use these apps, they will perform better than market versions. If not, delete them! **
•LauncherPro, adbWireless, Adobe Reader
•AndroZIP, Angry Birds, AppBrain
•Barcode Scanner, Barnacle WiFi Tether, Battery Doctor
•CamScanner, City Caller ID, Dialer One
•Documents to Go, Dolphin Browser, drocap2
•Dropbox, Facebook, Gallery3D
•Google Goggles, Google Sky Map, Handcent
•K-9 Mail, LinkPush, Linpack for Android
•Neocore, No Lock, OI File Manager
•Pandora, Quadrant Standard, Rage Faces
•RWiimote, Shazam, ShootMe
•Smart Keyboard Trial, SMS Backup+, Spare Parts
•Stumble Upon, SwiFTP, Terminal Emulator
•Titanium Backup, Video Player, Vlingo
•Voice, Voice Dialer, Voice Search
•Wallpaper Set & Save, WiFi Browser Login, Winamp
•Work Email, XDA Developers App, Yelp
•Zedge
post-15580-0-41461800-1295044705_thumb.jpost-15580-0-88048200-1295044741_thumb.jpost-15580-0-13068000-1295044792_thumb.j
Installation
1.Be on a rooted 2.1 2.0.2.A.0.24 ROM
2.Flash the attached file with xRecovery
3.After the first launch, select "Setup Guide" (See third screenshot).
Check out this link after installation for tips on LauncherPro: http://androinica.com/2010/08/23/11-...f-launcherpro/
I recommend at least changing the opening Speeds to 10 (Prefrences > Advanced Settings > Opening speed). That makes the phone feel a lot more responsive.
Changelog
Alpha (Not Released)
JIT v2, Root, build.prop mods
Release 1 Build 005 (Current)
- Added 3rd party APKs
- Removed stock apps
- SuperCircle / Reboot Option mod
- All APKs zipaligned
- Moved non-essential system apps to /data/app
Future Plans
- Modified UI / Theme work
- More optimization (optipng?)
- Whatever is requested
Downloads:
R1B005 Full - 191.64MB - http://www.multiupload.com/915JPO040W
R1B005 Lite - Coming Soon (No 3rd Party APKs)
Zipaligned APK Pack - 84.53 MB - http://www.multiupload.com/0HJEJ5GZWV (All the APKs from R1B005 Full)
Credits
A huge thanks to:
zdzihu for xRecovery, JIT enabler v2, and rooting the Generic 2.0.2.A.0.24 firmware; and
MrRusch for framework-res work
Modifié par eroye
  • Réponses 64
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
C'est du beau, c'est du looooooouuuuuuuuuuuuurrrrrrrd !!!! :emo_im_money_mouth:
Allez, je vais faire parti des pigeons qui va tester ça... mais demain ! ;)
EDIT : SETUP GUIDE
Modifié par gaja
@ Eroye : Chiche ? Demain alors ! Car ça va faire un tabac. Mais peut-être je ferai le tuto, en aucun cas je ne l'installerai (pas encore au point).
@ kikir9 : OK je te suis... dans mon sommeil ! :|
EDIT : Sur XDA, l'auteur dit qu'il faut absolument être en ROM 24 rooté pour pouvoir installer sa précieuse ROM.
Modifié par gaja
"HS : sur un autre topic, il y a un gars qui a réussi à porter la ROM HTC Sense Gingerbread 2.3 sur notre x10 ! :o :o :o "
C'est là 2.1 part1 je l'ai installé mais ma carte sim n'est pas reconnue même après 1h d'attente comme préconisé
Modifié par Azru
A Quadrant: 736 Sous rom Eminence avec JIT version 2, je fais beaucoup mieux :emo_im_undecided: .
Neocore: 27.5
Linpack: 30.016
Edit: Essai peu concluant pour la rom HTC Sense 00001, dés que je passe le lockscreen, ma carte sd se retire et n'est plus reconnue par le tél ce qui me laisse un font d'écran blanc avec HTC écrit en vert au centre de l'écran et ce, 3 fois de suite après l'avoir éteind et rallumé. :mad:
Edit 2: C'est bon pour la carte sd, ça fonctionne par contre, ma carte sim n'est pas détecté :mad: .
Finalement, je retourne sous rom Eminence, pas moyen que ma carte sim soit détecté. :emo_im_undecided:
Modifié par eroye
