Kamui Posté(e) 27 mars 2011 Share Posté(e) 27 mars 2011 Ah ok merci :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ruptor Posté(e) 28 mars 2011 Share Posté(e) 28 mars 2011 Comment refaire marcher Track ID sur la rom floyo15 ? quand je remets l'apk et que je lance l'appli ca plante... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kamui Posté(e) 29 mars 2011 Share Posté(e) 29 mars 2011 (modifié) MAJ Updated 28-Mar-2011 : Update: voice search fixed (libspeech.so), reuploaded. 2.3.3 CM-RC3 HACKDROID Legend Download : 2.3.3-CM-RC3 This is a manual patched port from Legend nightly, latest RC3 from 28-march-2011. Sense theme installed, HTC keyboard, LauncherPro and system panel (as in all my roms)+x8gesture module by doixanh I use gears (ES2/eclair+) to benchmark, this rom gives steady 60fps and it feels smooth finally! If upgrading from other CM7 rom, use advanced restore->only system partition, than you will keep all your settings. Bugs : camera (disabled completely),FMRadio Apps tested: AngryBirds, Ninjump, Aura, Compass, Skype, RagingThunder2, RecklessRacing, etc. Wipe workaround : to boot after wipe you need to rename /system/lib/hw/sensors.default.so, follow these steps: A. if you have ADB SHELL! 1. adb shell mv /system/lib/hw/sensors.default.so /system/lib/hw/sensors.default.so.1 2. Settings->Privacy->Factory data reset 3. Once phone boots, disable autobrightness (Settings->Display->Brightness) 4. adb shell mv /system/lib/hw/sensors.default.so.1 /system/lib/hw/sensors.default.so 5. reboot once again, and you have working sensors and no problems with screen. B. if you don't have ADB SHELL! 1. use root explorer to rename /system/lib/hw/sensors.default.so to /system/lib/hw/sensors.default.so.1 2. Settings->Privacy->Factory data reset 3. Once phone boots, disable autobrightness (Settings->Display->Brightness) 4. use root explorer to rename /system/lib/hw/sensors.default.so.1 back to /system/lib/hw/sensors.default.so 5. reboot once again, and you have working sensors and no problems with screen. To have skype,gtalk,market working properly, you will have to do a wipe..(to generate unique device-id) This rom has many new languages supported (Hebrew,Arabic,Thai,Chinese,Korean,etc) please report if all is fine bonne nouvelle il dit qu'il arrive presqu'à la version finale de la rom. Par contre si je viens de la version officiel j'ai besoin de faire ce qu'il demande avec ADB? Pis je pense que je vais vraiment passer à cette ROM si elle est stable étant donné qu'on peut la mettre à jour sans perte de donné Modifié 29 mars 2011 par Kamui Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ruptor Posté(e) 29 mars 2011 Share Posté(e) 29 mars 2011 Comment mettre à jour son baseband si on est en 2.3.1 ?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
HoM3r17 Posté(e) 29 mars 2011 Auteur Share Posté(e) 29 mars 2011 Je ne suis pas la pour voler le travail de qui que ce soit , j'informe juste sur la nouveauté. Par conséquent, je suis pour le fait que Homer ajoute cette rom a son topic si bien commençé ;) Peut être juste revoir l'organisation du post :emo_im_angel: Je teste la ROM en ce moment même , j'en ferais surement un petit retour sur le post ;) c'est surtout que comme je ne posséde pas ce téléphone je passe rarement ici... je met ça à jour ce soir ;) mais si vous voulez m'aider on peux toujours faire un document Google doc et je vous laisse aux intéressé un mdp pour updater quand je ne suis pas la... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yochi376 Posté(e) 29 mars 2011 Share Posté(e) 29 mars 2011 vraiment pas mal l'idée du google doc ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Mino62 Posté(e) 29 mars 2011 Share Posté(e) 29 mars 2011 J'hadere bonne idée Sent from my X8 using Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kamui Posté(e) 29 mars 2011 Share Posté(e) 29 mars 2011 Oui très bonne idée Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
HoM3r17 Posté(e) 30 mars 2011 Auteur Share Posté(e) 30 mars 2011 BBon je vous ai un peu oubliés hier soir je ré fais ce soir... envoyez moi des mp si c'est pas fait à 16h ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tsusama29 Posté(e) 31 mars 2011 Share Posté(e) 31 mars 2011 moi je dit que mettre a jour les topics c'est pas voler le travail de celui qui la construit c'est juste rendre service a l'autre :P moi yochi a plusieur fois mis a jour c'est pas pour autant que je pense qu'il a piquer mon travail Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yochi376 Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 Updated 4-Apr-2011 : 2.3.3 CM-RC4 HACKDROID Legend (the FAST one!) reuploaded with fixes, see changelog below Download : 2.3.3-CM-RC4 Bugs: Camera (disabled), FMradio Changelog : wifiN enabled, adhoc-connect enabled, usb-mount fixed, voicesearch and voice input in keyboard fixed, proximity sensor works. Extrêmement fluide, mais des problèmes avec ma carte µSD (au début, elle n'était pas détectée donc j'ai du formater. Maintenant elle est détectée, mais je n'arrive pas à la monter en stockage de masse sur un pc) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
rayji Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 En gros c'est le même problème qu'avant, c'est la ROM que j'attends le plus, mais pour l'instant je suis sur la floyo depuis 2 semaines, c'est à mon avis la plus fonctionnelle en ce moment... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yochi376 Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 Elle marche nickel, est super stable, très rapide, toutes les applications marchent (même root explorer, oui !) mais le gros bémol du moment c'est la carte SD qui n'arrive pas à rester montée 5 min ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kamui Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 Monté sur l'ordi ou dans le tel? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yochi376 Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 Les deux en fait. Elle se démonte toute seule du téléphone, c'est invivable. Impossible de consulter le moindre fichier sans qu'elle ne se démonte. De même, impossible de monter la carte sur pc, car une fois démontée du téléphone, elle ne se monte plus sur le pc ... Je suis déçu par cette version ... elle n'est pas encore au point, malgré sa rapidité ... je retourne sur ma version d'avant. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kamui Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 Tu as testé avec une seule partition ? Si oui, il reste plus qu'à patienter encore un peu. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yochi376 Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 j'ai essayé avec une seule partition FAT32, une seule partition EXT2, une seule partition EXT3 ... avec une partition FAT32 et une partition EXT2 ... rien n'y fait =/ D'ailleurs, je n'arrive toujours pas à faire marcher l'app2SD natif des ROM ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
spider1163 Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 Je crois avoir rencontré ce problème avec la Hackdroid ce soir Yochi, j'ai désinstallé L2SD et formaté, ça marche au poil ... Ça p-e pure coïncidence aussi ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kamui Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 Faudrait que quelqu'un d'autre test mais bon faut faire backup de la rom et de la sd. Enfin je sais pas trop comment ça marche si on format la partie ext2 et on remet tout en fat32 si ensuite on veut revenir en arrière. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yochi376 Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 je n'ai plus L2SD quand je vais sur une autre ROM, donc mon problème ne vient pas de là Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
haleesham Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 savez vous comment je peux resoudre le soucis du gps des que je le met en marche , le telephone s'eteint.... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
spider1163 Posté(e) 4 avril 2011 Share Posté(e) 4 avril 2011 je n'ai plus L2SD quand je vais sur une autre ROM, donc mon problème ne vient pas de là Je n'avais plus L2SD non plus mais la partition dont il se servait était toujours la pour moi. Enfin j'te raconte juste comment j'ai résolu le pb, ca p-e etre 2 causes bien disctinctes Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yochi376 Posté(e) 5 avril 2011 Share Posté(e) 5 avril 2011 Ha oui oui la partition ext était toujours là ! C'est pourquoi je me suis dis que j'allais supprimer toutes mes partitions en en faisant plus qu'une seule, pour voir si ma carte était mieux gérée ... et finalement après plusieurs essais (une unique partition FAT32, une unique partition EXT ...) rien ne semblait régler le problème =/ Donc je pense que c'est la ROM qui n'est pas encore au point de ce côté là (à savoir que ce problème est récurant sur les 3 X8 de mon entourage) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kamui Posté(e) 5 avril 2011 Share Posté(e) 5 avril 2011 Il ne reste plus qu'à patienter alors. C'est dommage qu'il n'y ai que ce bug de vraiment notable. Quelles sont les grosses différences par rapport à la floyo V0,15? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ChromeShady Posté(e) 5 avril 2011 Share Posté(e) 5 avril 2011 Moi avec la première RC4 (j'ai bien dit la première RC4 , pas la 2ème ) ma batterie ne tenait pas une journée , c'est simple , je perdait 4% toute les dix minutes , et tout désactivé , luminosité , internet (carrément coupé) , etc ... Donc je suis retourné en RC3 , et là je vois que les bugs sur la RC4 continue avec yochi par exemple , donc je reste sur RC3 . Je précise aussi que pour l'installation de la RC4 , j'avais mis a jour juste "system" , donc je ne sais pas si ça a peut-être un rapport mais je tiens à le signaler quand même . Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
