[ROM] RCS Touch v2.0
Features:
  • Fits into internal memory thanx Coolexe ! *New
  • Rom is cleaned of bloatware, all T-Mobile stuff should be gone.
  • Base - Latest Nandroid 1.17.531.2 FRG83 2.2.1 froyo.
  • Rom is now 100% Multilangual. WWE + Asian languages added by Capychimp. see notes.
  • Languages are now auto detecting
  • Rearranged homes, so the clock is there by default
  • Deodexed, thanx SEO for that.
  • RCMixHD kernel, lightning fast, #39 Thx Coutts and Neo ! *New
  • Overclock with SetCpu
  • Changed to updater-script *New
  • All apk/jpg/png files optimized *New
  • Some totaly useless files removed *New
  • (eg. some thumbnails, so first time wallpaper and theme thumbnails is shown they will be created, that may take a second.)
  • Camcorder 720p and streaming media fixes included, Thanks to ownhere *New
  • Wifi Calling Removed *New
  • Screen on Smartass 245-998 MHz *New
  • Screen off Powersave 245-368 MHz *New
  • Updated optimization scripts thanks Neo *New
  • Updated many apps to latest versions.
  • Apps ported from HD rom: *New
  • Locations (navigation), Mediacenter, Music app, Gallery, USB menu + HTC Sync, this widgets ->Music, FMRadio, Locations, Autorotate, Background data, Data roaming, Data strip, Power strip, Calculator, Profile, Ringtone, Screen brightness, Screen Timeout.
  • Advanced Power Menu fixed.
  • Busybox, Root, Superuser...
  • Cyanogen A2SD script, moves both apps and dalvik to ext
  • Ownheres newest Data2Ext script v8.2 (not v2.0 yet)
  • Automatic ZipAlign by Wes Garner.
  • ext4, tun, cif, etc... all modules are there. Insmod when needed.
  • New HTC IME (Keyboard), the same options as in Desire Z keyboard. *Default
  • Dragon Dictation (Keyboard)
  • Gingerbread IME (Keyboard)
  • Custom RCS Theme with semitransparent lockscreen.
  • Genie widget (news and weather)
  • Rom Manager
  • Added APN List
  • Host file Updated December-04-2010
  • Languages supported:
  • Code:
  • WWE + ASIA
NOTE: Not everything is translated yet, but 99% is ;)
Notes: *Read this part!!
RCS Touch v07 D2EXT uses ownheres data2ext v8.2 script, recommended partition layout is:
Fat + 1GB Ext4 + 0.3GB Ext4 + 0.1GB Swap
The first boot takes long time due the data2ext setup process, it stays on the first splash screen (why so serious or htc) for couple of minutes, stay calm
Overclock with SetCpu, Overclock widget seems not working... at least for me
There may be some slowdowns at the begining due the rom is restoring and syncing all apks and settings.
If you have problems installing the rom, try to repartition your sd card, make a full wipe and try to install it again.
Restoring a titanium backup may cause some FC, use with caution.
Known bugs:
You tell me...
Requirement:
Full wipe required due different structure of the rom.
A2SD version - Fat + Ext/2/3/4 partition. 0.5-1.5GB recommended.
D2EXT version - Fat + Ext4 + Ext4 + Swap (fat+1GB+0.3GB+0.1GB)
Changelog:
v2.0 (A2SD)
RCMixHD kernel, lightning fast, #39 Thx Neo !
Some totaly useless files removed (some thumbnails, so first time wallpaper and theme thumbnails is shown they will be created, that may take a second.)
v07
LIST[*]Apps ported from HD rom: *New
[*]Ownheres Video stream fix v2 *New[*]Advanced Power Menu fixed.
Downloads:
RCS Touch v2.0 Test A2SD+ - Fast link
MD5:bf45ca68bdacae8facc2d2784efe1a73
RCS Touch v07 Data2ext - Fast link *Read requirements and notes!!
MD5:4820ca9381bad0f2c5bc1a9d90532ca0
Replace hardware Search button with Genius button
Revert to original Search button
LIEN XDA
Voila, je viens de découvrir cette superbe Rom qui va remplacer ma DHD baadnwz je penses !
Beaucoup d'option très sympa, je vous laisse faire le tour de cette rom !
Je crois qu'il y avait un topic sur cette rom déjà, mais j'ai rien trouvé et de plus elle à changée de nom.
Modifié par Clément
Bah en tout cas pour le moment tout roule chez moi.
Il y a des bugs sur d'autre DHD qui ne sont pas présent ici. Comme l'ajout de widget qui se mettent à la suite, ici il se met bien sous le doigt.
v2.0 (A2SD)
Donc à priori, non elle n'est pas data2sd ^^
EDIT : et c'est quoi cette appli contact ? (j'ai pas encore testé la ROM, c'est pour ca que je demande, ca a l'air plutôt classe).
Modifié par Kiiv
Je viens de l'installer également.
Elle me fait un effet bizarre. Elle est effectivement très customizées, on sent que ya du taff derrière, mais elle me laisse comme un effet de pas complètement fignolée.
Ca a l'air d'être un mix entre le dernier Sense et la version précédente. Genre le menu des widgets c'est pas le dernier, il ne semble pas y avoir HTCSense et HTCHub (ou j'ai mal regardé), par contre il y a la gestion des thèmes et les dernières applis dans la barre de notif.
Pour l'instant, je lui trouve quelques lag de plus que la Baadnwz, je vais voir à l'usage.
Sinon j'aime beaucoup le fait d'avoir une image différente pour le lockscreen et l'écran d'accueil.
Elle est data2ext ? Parce qu avec ma pauvre carte SD ça va pas le faire :-(
Il y a les deux versions disponible à télécharger.
Sinon moi c'est l'inverse de vous, celle-ci ne lague pas d'un point contrairement à la baadnwz.
Bonjour, voila je voudrais bien installer cette rom (la version D2EXT), mais voila le problème c'est que je n'arrive pas a créer la 2ème partition ext4, j'ai pour l'instant une partiton fat32+ext4+ext2+swap, mais je n'arrive pas a convertir la partition ext2 en ext4, quelqu'un pourrait il me dire comment le faire.
Merci pour votre aide bonne journée
Petit retour sur cette rom : une catastrophe pour moi ! Je précise que j'ai utilisé la version A2SD
Des lags de partout notamment au démarrage où il faut attendre plusieurs minutes pour avoir un tel utilisable !
Les zips en plus à installer qui ne fonctionnent pas
Bug d'affichage, notamment quand on appui sur power et qu'il ouvre le menu pour les reboot ou extinction du mobile, bien il me manque l'icône vibreur, j'ai qu'un espèce de gros carré blanc dégueu.
Reboot intempestifs aussi.
C'est dommage car graphiquement elle est très jolie.
Moi je n'ai pas tous ses problèmes, juste un peu de lag après le réveil du telephone.
Mon seul soucis c'est que je n'ai plus mes applis dans mes téléchargements dans le market. J'ai tout testé mais rien n'y fait. En plus je viens de télécharger 2 applis, et elles apparaissent dans mes téléchargement mais c'est marqué 'gratuit' au lieu de 'installée'.
Je pige pas là !
