PhilippeLesage Posté(e) 27 février 2011 Share Posté(e) 27 février 2011 (modifié) Tout est dans le titre ^^ ROM FEATURES JMK Base Rom Overcome Kernel v2.1.2 Included (OC/UV-capable) No Modem is included - due to a variety of personal preference I decided to leave that a la carte Fully Deodexed Fully Zipaligned Rooted with busybox installed Reboot/Recovery/Download options added to the power menu GPS Fix from KA1 Battery icon modified to a colorful circle with percentage Smoked notification background Blur removed across system (i.e. behind power option menu) - significantly improves performance Power Off confirmation disabled Modified stock browser to allow selection of UAString - default is Desktop Replaced system fonts with fonts from Armani Captivate Added AppWidgetPicker CSC set to XEU Ads Blocked Updated Market to 2.3.4 Updated Maps to 5.2.1 Updated Flash Player to 10.2 Updated GMail to 2.3.4 Updated YouTube to 2.1.6 Updated SamsungApps Updated Thinkfree Office Suite Fixed Swype keyboard to show full screen Removed Startup/Shutdown sounds Cool boot animation A2DP Bluetooth Connection Fix Integrated WPA_Supplicant replaced to allow ad-hoc wifi connections "Fugutweak" integrated (two system bin's from Gingerbread - helps with overall smoothness) KERNEL FEATURES Support RFS/EXT2/EXT3/EXT4 OC/UV with these steps: 1.4ghz, 1.2ghz, 1ghz, 800mhz, 600mhz, 400mhz, 200mhz, 100mhz Compiled using Codesourcery 2010.09: Faster and more battery efficient Replaced kernel jhash2 with jhash3 Adjusted kernel HZ value to improve smoothness Updated ext4 code in kernel from http://www2.kernel.org/pub/linux/ker.../ext4-patches/ Properly working Tiny RCU patch for better speed and efficiency Patched lowmemorykiller for compatibility with Tiny RCU Optimized compiler flags Voodoo Sound v7 Voodoo Lagfix Overcome CwM Recovery v3.0.2.4 (Custom built Clockworkmod v3.0.2.4) Kernel tweaks to VM and Scheduler for better performance Built in CIFS/TUN/SlowWork support Full support of internal/external SD cards in Recovery RAM and Touchscreen Undervolting (courtesy Koxudaxi) LED patched to work with LED Flashlight apps (courtesy Koxudaxi) SCREENSHOTS ***See Attached*** ROM INSTALL INSTRUCTIONS It is HIGHLY RECOMMENDED that you flash back to stock with a repartition before installing Overcome ROM. This solves a multitude of random issues that people experience. You can find instructions on doing this below under "if your Tab doesn't boot..." Also, for Titanium Backup users, ONLY backup user applications and data, NOT system apps and system data. Restoring system apps and system data causes a host of issues. Follow this excellent guide by Corodius! http://forum.xda-developers.com/show...php?p=11713685 KERNEL INSTALL INSTRUCTIONS If you already have Clockworkmod Recovery, grab the flashable zip from this post and Install through clockwork. If you do NOT have Clockworkmod Recovery, grab the tar from this post and flash with ODIN. NEITHER of these installation methods will affect your data, although it is always wise to have a backup in the unlikely event of disaster If you have the desire to UV your kernel, please use this version of Voltage Control: http://www.mediafire.com/?m2ybg2v4oqdtknn (Credit Koxudaxi) IF your Tab does not boot after flashing the kernel and hangs at the Samsung Galaxy Tab screen, you must follow the following procedure Get a stock rom package (any of Rotohammer's firmwares will work) Get P1_add_hidden.zip attached to this post and extract the P1_add_hidden.pit file Using Odin 1.7, put stock rom (Roto-JME-Full-v4.tar for example) in PDA slot. Put P1_add_hidden.pit in Pit slot Check repartition box Put Tab in download mode by holding Volume Down and Power, connect to the computer, and press start. After this, the Tab will reboot normally. Shut it down and return to download mode. Open Odin 1.7 and reconnect the Tab. In the PDA slot, choose the Overcome Kernel v2.0 tar file for use with Odin. Press start It will flash the kernel then reboot. Upon reboot, you should hear the sexy robot voices informing you of the status of the EXT4 conversion. Once done, the Tab will boot normally. At this point you can load Overcome Rom (or any other Rom of your choosing) If you have Battery Life issues, try this first: Turn the Tab off and charge to 100% Unplug from charger and immediately boot into recovery by holding volume up & power button Navigate to Advanced In the Advanced menu, choose Wipe Battery Stats Reboot Tab normally and Enjoy a freshly calibrated battery NOTE - Having the tab off is important...I notice that even if I charge to full while tab is on, once I turn it off it continues charging for another 10 minutes or so before hitting 100%. I believe the sensor determining what is a full battery is different in the off position and will allow you to get the fullest charge. KNOWN ISSUES Throws an error when performing certain operations in clockwork recovery that involve mounting drives. For example, nandroid backup and restore. However, this does not affect the performance or the execution of said activity. Since CwM 3.x generates mount points on the fly from the recovery.fstab file, I need it to consider both RFS and EXT4 file systems. The errors it generates are it failing to mount as either RFS or EXT4 (depending on which FS you actually have). So say you're converted to EXT4 and do a nandroid backup, you will see failed mounts for all the partitions as RFS, because obviously your system isn't RFS. However, the backup and restores both work beautifully regardless of junk errors. In-call volume is low - THIS IS FIXED BY JMF MODEM. Please flash the JMF modem if you are experiencing low in-call volume DOWNLOAD Overcome v1.4.2 Full Install - This will wipe all applications and settings! (Not SD-Cards though) http://www.multiupload.com/E3MD1OQ8I7 Overcome v1.4.2 Updater - No data wipe - This is ONLY for users on 1.4.x and higher. If you have anything lower You MUST install the full download w/wipe. http://www.multiupload.com/L9K9YEVP8R JMF Modem - For all GSM tabs except T-Mobile US! http://www.multiupload.com/ARA6XCE3B7 T-Mobile US Stock Modem http://www.multiupload.com/0K7XSXOPBQ Chinese Input Additions http://www.multiupload.com/V8V4PKL7V5 Overcome Kernel Source and initramfs v2.1.1 http://www.multiupload.com/XQTYI7NDJ0 Fancy Animations Due to popular demand, starting with Overcome ROM v1.0.3, the stock Android animations are now standard. If you were one of the few that enjoyed the modified animations, you can check out this thread on how to modify the framework-res yourself. http://forum.xda-developers.com/showthread.php?t=774738 Removed Apps No apps have been removed from stock JMK rom. The first boot will take a VERY long time due to being deodexed but don't panic. Reboots after that are very fast The best is yet to come! La suite se trouve ici : http://forum.xda-developers.com/showthread.php?t=932082 Modifié 30 mars 2011 par Feelhip Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ppito Posté(e) 27 février 2011 Share Posté(e) 27 février 2011 heu... super merci, mais du copier coller ... je trouve que ça sers à rien ... Et limite, tu aurai pu le mettre dans le topic Overcome existant. Sans compter que tu dis rien dessus. Donc on sais pas si elle est mieux que la version précédente. Sinon le traduire (et je parle pas d'un google trad), là ça aurai été super pour les anglophobes. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PhilippeLesage Posté(e) 27 février 2011 Auteur Share Posté(e) 27 février 2011 (modifié) heu... super merci, mais du copier coller ... je trouve que ça sers à rien ... Et limite, tu aurai pu le mettre dans le topic Overcome existant. Sans compter que tu dis rien dessus. Donc on sais pas si elle est mieux que la version précédente. Sinon le traduire (et je parle pas d'un google trad), là ça aurai été super pour les anglophobes. heu... super merci, de tes remarques donc n'hésite pas, fais le ... et au plaisir de te lire ^^ Sujet clos ps : dsl aux modos du forum, j'ai zappé le topic existant sur l'overcome dont je viens d'en lire les posts :) vous pouvez effacer ce post vu qu'il n'a pas d'utilité d'après Ppito Modifié 27 février 2011 par Feelhip Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ppito Posté(e) 27 février 2011 Share Posté(e) 27 février 2011 heu... super merci, de tes remarques donc n'hésite pas, fais le ... et au plaisir de te lire ^^ Sujet clos ps : dsl aux modos du forum, j'ai zappé le topic existant sur l'overcome dont je viens d'en lire les posts :) vous pouvez effacer ce post vu qu'il n'a pas d'utilité d'après Ppito Bah c'est surtout que c'est un copier coller d'un autre forum sans rien d'autre comme information donc bon ... Encore on aurai ton avis sur la ROM, ok je dis pas mais la non. Je dis pas ça méchamment, mais bon si tu te mets à la place de quelqu'un d'autre ça fait bizarre de voir un topic pareil. Et désolé si tu l'as pris mal, mais je voulais que tu comprennes qu'on est pas sur XDA et qu'un copier collé complet sans rien dire, bah ca reviens au même que d'aller sur XDA et moi ca ma choqué. Donc dsl si mes propos était un peu sec. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
iSlash75 Posté(e) 27 février 2011 Share Posté(e) 27 février 2011 (modifié) voila une ptit traductyion a la google pour ceux qui veulent - AVERTISSEMENT: Vous connaissez le refrain, je ne suis pas responsable si le chargement de ce fait votre rom Tab fondre, exploser, se désintégrer, ou faire de mal à personne près de lui. (Je n'en suis pas assez certain de ce qui se passera si) Cette ROM a été en cours d'élaboration pour les semaines dernières. J'ai d'abord commencé en s'appuyant sur KA2, en essayant de le mod factoryfs.rfs fichier autant que possible, mais toujours frapper les murs en ce qui concerne la taille des fichiers système et les nuances général des images du système RFS. Une fois que nous avons obtenu un noyau personnalisé à partir de quelques sources qui comprenait MCG, et JMG surface j'ai décidé qu'il était temps de passer au format zip MCG - beaucoup plus flexible et facile à travailler. Pour ces derniers jours, j'ai travaillé avec diligence pour faire de ce fait de mieux Galaxy Tab expérience, sans exception. J'ai été faire fonctionner sans problème jusqu'à présent. Sans plus tarder, je vous présente vaincre. Change log in second poste. PRE-REQUIS NE PAS UTILISER de Koush EXT4 ClockworkMod noyau ... c'est grave cassée et pas de plaisir à jouer avec CARACTERISTIQUES ROM Rom Base JMI Aucun modem est inclus - en raison d'une variété de préférences personnelles, j'ai décidé de quitter ce à la carte Entièrement Deodexed Entièrement Zipaligned Enracinée avec busybox installé Reboot / récupération / options Télécharger ajouté au menu de puissance L'icône de batterie modification à un cercle coloré avec un pourcentage fond notification fumé les polices système remplacées par des polices d'Armani Captivate Ajouté AppWidgetPicker Remplacé la galerie avec Galerie de PSBA (rapide WICKED, l'utilisation de piston inférieur, moins de consommation de la batterie) Le SCC s'est fixé à XEU Annonces bloqués Mise à jour du marché à 2.3.2 Mise à jour des cartes à 5.1.0 Mise à jour Flash Player pour 10.1.106.16 Mise à jour 2.3.4 pour GMail Correction du clavier Swype pour voir en plein écran Suppression de démarrage / arrêt des sons animation de démarrage personnalisée (crédit pour la conception va à GLa'DOS dans la section Thèmes Android de XDA) Enlevée les applications suivantes: ClockAndWeatherWidget ClockDateWeatherWIdget DLNA ALLSHARE DualClock MusicODC Protips Fonctionnalités du noyau RFS soutien, EXT2, EXT3, EXT4, JFS OC / UV avec ces étapes: 1,4 GHz, 1,2 GHz, 1 GHz, 800MHz, 400MHz, 200MHz, 100MHz (sauf si vous définissez autre chose, freq par défaut est stock) Remplacé noyau jhash2 avec jhash3 Ajusté noyau HZ valeur afin d'améliorer la douceur Mise à jour ext4 code dans le noyau de http://www2.kernel.o..../ext4-patches/ Fonctionne correctement Tiny RCU patch pour plus de rapidité et d'efficacité lowmemorykiller Patch de compatibilité avec Tiny RCU drapeaux du compilateur optimisé:-O2-mcpu = Cortex-A8-mfpu = néon mfloat-abi = softfp Voodoo Sound SCREENSHOTS *** *** Voir ci-joint INSTRUCTIONS INSTALLATION Première sauvegarde! (Le script d'installation effacera votre partition de données, mais pas votre carte SD) ROM copie de la carte SD. Redémarrez en MCG Choisissez Installer zip depuis la carte SD zip Choisissez depuis la carte SD Installer et redémarrer! Si vous êtes système n'était pas déjà ext4, sur le redémarrage en mode récupération et la conversion automatique de votre système de fichiers qui va se passer PROBLÈMES CONNUS Aucun pour le moment Modifié 28 février 2011 par iSlash75 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
new-era-boy Posté(e) 28 février 2011 Share Posté(e) 28 février 2011 bon je quite avec regret la cianogen 7 sous gingerbeard pour tester celel ci instalation assez complexe ' mais je vous fait un retour ce soir :)) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PhilippeLesage Posté(e) 28 février 2011 Auteur Share Posté(e) 28 février 2011 bon je quite avec regret la cianogen 7 sous gingerbeard pour tester celel ci instalation assez complexe ' mais je vous fait un retour ce soir :)) Tiens je l'essaierais bien à l'occas la 7 vu que je ne veux pas le faire sur mon desire Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
new-era-boy Posté(e) 28 février 2011 Share Posté(e) 28 février 2011 tout compte fait , cette rom est genial ' mais je me suis trop habituer a la ciano 7 , donc je retourne dessu ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
iSlash75 Posté(e) 28 février 2011 Share Posté(e) 28 février 2011 une question toute bete mais je suis en jmi officiel rooté avec superclick, je peux le faire direct de la sd ? ou y a des truc a preparer avant ?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ratapoil Posté(e) 4 mars 2011 Share Posté(e) 4 mars 2011 Bonjour; perso j'ai un gros problème : je viens de racheter une tab et elle est sous cette rom Overcome 1.2 apparemment. Et la tab ne reconnait pas la carte sim, comme s'il n'y avait aucune sim dans la tab. Elle ne demande pas de code pin au démarrage, et j'ai un icone de rond barré à la place de l'icone réseau... C'est normal docteur ?? Merci de votre aide ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ratapoil Posté(e) 4 mars 2011 Share Posté(e) 4 mars 2011 (modifié) Bon, j'ai relu le changelog et apparemment il n'y a pas de modem inclus dans cette rom Overcome. C'est peut être pour ça que j'ai pas de réseau... J'ai essayé d'installer le modem de la rotoJME depuis le recovery mais il me donne un message "installation aborted". Du coup j'ai fini par reflasher la rotoJME v3 que j'avais encore sur mon pc, avec Odin, et tout est ok. Dommage pour le modem : elle a l'air pas mal cette rom Overcome... Modifié 4 mars 2011 par ratapoil Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
thomas59 Posté(e) 5 mars 2011 Share Posté(e) 5 mars 2011 Ratapoil essaye de flasher avec le modem JK5 il est moin capricieu est ne pose pas de problème en général =) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ratapoil Posté(e) 5 mars 2011 Share Posté(e) 5 mars 2011 (modifié) Ben, là je suis donc avec la JME, le modem apparemment (baseband) est le JMA, et j'avoue que j'ai un peu la trouille de flasher juste le modem. Quand j'étais en rom Overcome 1.2 sans modem, j'ai essayé de flasher le modem de la rotoJME depuis le recovery et comme dit plus haut ça n'a pas marché mais en plus ma tab ne voulait plus démarrer : elle restait bloquée sur le logo samsung... Là tout fonctionne bien et j'ai un peu peur de m'y remettre. Surtout que changer juste le modem ça m'aurait intéressé pour garder la rom Overcome, mais maintenant que je suis en JME j'ai pas trop envie de reflasher l'Overcome et un modem à part : jusqu'à présent cette manip ne m'a pas trop réussi... Une question d'ailleurs : ceux qui ont flashé l'Overcome, vous avez été obligés de flasher aussi un modem, ou bien le fait de flasher l'Overcome n'a pas effacé le modem que vous aviez déjà? C'est ça que je trouve bizarre chez moi : pourquoi je n'avais plus de modem ? Le fait de flasher la rom n'efface pas le modem en principe... Modifié 5 mars 2011 par ratapoil Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
JimmyBarbin Posté(e) 6 mars 2011 Share Posté(e) 6 mars 2011 Hello! Juste un petit coucou pour vous signaler que le post de XDA a été mis a jour et que nous somme passé a la OVERCOME 1.2.1. A+ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ratapoil Posté(e) 6 mars 2011 Share Posté(e) 6 mars 2011 (modifié) Ben oui, c'est ce qu'il me semblait : le fait de flasher une rom qui n'inclut pas de modem ne devrait pas "écraser" le modem déjà installé. C'est pour ça aussi que j'ai galéré, parce que avant d'installer un modem je voulais comprendre pourquoi l'Overcome avait supprimé le modem existant. J'ai même essayé d'installer le modem de la roto JME (qu'on trouve séparément sur xda et qui fait partie des fichiers de la roto JME quand on l'installe via Odin), mais j'ai voulu faire l'install via le recovery (puisque mon vendeur m'a installé le CWM recovery 3.0) mais ça n'a pas fonctionné : le recovery lançait bien l'install mais me sortait un message "installation aborted". C'est comme ça que j'ai fini par tout reflasher avec Odin (sauf le CSC parce que je n'en ai pas trouvé sur le serveur d'upload de rotohammer). Et heureusement tout fonctionne à présent, mais je me suis bien pris la tête et fait une bonne frayeur... Modifié 6 mars 2011 par ratapoil Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ratapoil Posté(e) 6 mars 2011 Share Posté(e) 6 mars 2011 (modifié) Oui, c'est vrai que j'aurais pu insister et tenter l'install du modem via Odin. Elle me plaisait bien l'Overcome, j'ai eu la tab avec cette rom quand je l'ai achetée et avant de finir par reflasher la roto JME j'ai bien aimé ce que j'ai vu. Mais en ce moment je serais plutôt tenté par la roto JMI ou la Modaco. Je lis (laborieusement, l'anglais n'étant pas mon fort) les sujets correspondant sur xda, vu qu'il n'y a que sur ce forum qu'on trouve vraiment de l'info et des retours en quantité. Mais j'avoue que maintenant à chaque flashage j'hésite longtemps à cause des soucis que j'ai eus à plusieurs reprises avec le flashage sur la Gtab... et je me documente longuement avant de bouger! D'autant que la roto JME chez moi est très bonne, aussi bien niveau fluidité qu'accroche réseau, gps, etc... Modifié 6 mars 2011 par ratapoil Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PhilippeLesage Posté(e) 6 mars 2011 Auteur Share Posté(e) 6 mars 2011 Hello! Juste un petit coucou pour vous signaler que le post de XDA a été mis a jour et que nous somme passé a la OVERCOME 1.2.1. A+ Oups, Merci j'avais oublié d'updater le post ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ratapoil Posté(e) 6 mars 2011 Share Posté(e) 6 mars 2011 Est ce que ceux d'entre vous qui ont flashé cette rom se sont retrouvés sans connection réseau après le flash ? Genre, la tab se comporte comme s'il n'avait carrément pas sim dans la tab, ne demande pas de code pin au démarrage, a un icone en forme de rond barré ou d'avion dans la barre réseau, etc... Merci de vos retours! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LionelGourpil Posté(e) 6 mars 2011 Share Posté(e) 6 mars 2011 Est ce que ceux d'entre vous qui ont flashé cette rom se sont retrouvés sans connection réseau après le flash ? Genre, la tab se comporte comme s'il n'avait carrément pas sim dans la tab, ne demande pas de code pin au démarrage, a un icone en forme de rond barré ou d'avion dans la barre réseau, etc... Merci de vos retours! Salut! euh, je ne sais pas comment tu l'as flashée mais il n'y a pas de fichier modem dans cette rom (choix du dev) donc c'est à toi de choisir ton fichier modem (d'une autre rom par exemple...). Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ratapoil Posté(e) 6 mars 2011 Share Posté(e) 6 mars 2011 Mais justement c'est ça qui m'étonne et que j'essaye d'éclaircir : le fait de flasher cette rom ne supprime pas le modem s'il y en avait un avant le flash normalement. Donc j'étais surpris de voir que je n'avais plus de réseau. Le modem qui était installé avant l'Overcome n'aurait pas dû disparaitre. Si je me sens le courage je la reflasherai et je verrai bien si le modem de ma rom actuelle est toujours présent... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
JimmyBarbin Posté(e) 10 mars 2011 Share Posté(e) 10 mars 2011 Bon ben... cela va etre difficile de suivre la cadence... En effet je voici deja une nouvelle mise a jour. La version Overcome ROM v1.2.2 est de sortie. A+ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ratapoil Posté(e) 11 mars 2011 Share Posté(e) 11 mars 2011 Oui, et le dev a aussi mis à jour le kernel de sa rom, qu'on peut d'ailleurs flasher séparément. Et il parait que les perfs sont très bonnes. Elle fait partie des roms parmi lesquelles j'hésite pour mon prochain flash. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ballou85 Posté(e) 11 mars 2011 Share Posté(e) 11 mars 2011 Oui moi aussi j’hésite un petit tuto pour l'instal sa serait parfait car moi l'anglais pas comprendre lol Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
thomas59 Posté(e) 11 mars 2011 Share Posté(e) 11 mars 2011 Pour flasher uniquement le modem il faut passé par Heimdall. Peu etre que l'overcome fait une repartition et donc vous perdez le modem. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ratapoil Posté(e) 11 mars 2011 Share Posté(e) 11 mars 2011 (modifié) Je le pense aussi parce que la Gtab que j'ai je l'ai eue d'occase déjà sous Overcome 1.2 et il n'y avait pas de modem (aucune fonction tél ou data hors wifi, pas de demande de code pin alors que la sim était bien dans la tab). J'avais essayé de flasher un modem en utilisant le recovery mais l'install a foiré et j'ai pas pensé à essayer par Odin. Du coup j'ai reflasher une rotoJME et j'ai tout retrouvé nickel. Mais du coup je sais pas trop comment flasher l'Overcome, kernel compris, pour avoir des fonctions gsm complètes. Et dans le topic sur xda il n'est pas question de ces problèmes de modem, c'est pour cela que j'ai trouvé mon cas bizarre. Après j'ai vu des posts de gars qui semblaient avoir le même problème que moi et qui ont dû reflasher un modem via Odin. Je vais bien finir par me lancer, mais j'avoue que j'ai un peu la trouille : je flashe depuis longtemps et c'est la première fois que j'ai autant de soucis avec le flashage. La Gtab est capricieuse. Mais bon, jusqu'à présent j'ai toujours pu récupérer la tab comme il faut. Un truc que je ne suis pas sûr d'avoir compris : si on flashe la rom complète, il y a le kernel inclus ou il faut vraiment le flasher à part? C'est pas clair dans le sujet sur xda et mon anglais n'est pas terrible... Modifié 11 mars 2011 par ratapoil Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
