[ROM] base XWJV1 Gingerbread Included CWM et LAGFIX
Puisque personne n'en parle je met le lien pour une custom rom basé sur Gingerbread (beta) mais qui fonctionne nickel, est stable et très fluide !
Merci à Juwe11 pour cette rom ainsi que les personnes qui aident à son développement !
Ici pour les infos concernant l'installation :
http://forum.xda-developers.com/showthread.php?t=964672
Vidéo-tuto de l'installation à partir d'une JV1 beta stock
Version 2.5.1
http://forum.xda-developers.com/showpost.php?p=12236196&postcount=557
Changelog v2.5.1
Supercurio's hacked kernel - thanks to supercurio
-Included Clockworkmod
-Lagfix
Modem DXJPB
Added Superuser.apk
Reworked framework
Reworked and improved theme
New animations
Improved look for Android unlock screen
Fixed icon in status bar for battery charging
Reworked SystemUI (new icons in status bar, etc., more in black&white style)
Reworked MediaProvider
Fonts now more in black&white style
Added Gingerbread keyboard
Fixed RAM - big thanks to Darky
Added folder "ramtweak" on intSD (You must NOT delete it!)
Added init.d
Added bash (more stability and flexibility)
Added fstab
Completely reworked update-script
Added app Advanced Task Killer (use this app for more RAM)
Added app SGS Tools
Added app Screen Filter
Added app Titanium Backup
Added app Circular battery
Modded 3DGallery by me (now fast and smoothness)
Modded Browser by Steven1811 (20 tabs, etc.) - thanks to Steven1811
Implemented Fugu tweaks (More smoothness and faster system) - thanks to nikademus
Added new busybox (now compatabile with apps which need root)
Added strace (/system/xbin)
Added ipctool (/system/xbin)
Added vfp-crasher (system/xbin)
Added appwidgetpicker.apk
Added new Juwe's wallpapers
If you want CRT display animation (go to settings/display/animations/all)
More stable system
Faster system
Changelog v2.5
* New Supercurio's hacked kernel - Thanks to supercurio
* -Included Clockworkmod
* -Lagfix
* Added Superuser.apk
* Reworked framework
* Reworked and improved theme
* New animations
* Improved look for Android unlock screen
* Fixed icon in status bar for battery charging
* Reworked SystemUI (new icons in status bar, etc., more in black&white style)
* Reworked MediaProvider
* Fonts now more in black&white style
* Added Gingerbread keyboard
* Fixed RAM (added rambooster) - big thanks to Darky
* Added init.d
* -zipalign, complete, sysctl
* Added bash (more stability and flexibility)
* Added fstab
* Completely reworked update-script
* Added app Advanced Task Killer (use this app for more RAM)
* Added app SGS Tools
* Added app Screen Filter
* Added app Titanium Backup
* Added app Circular battery
* Modded 3DGallery by me (now fast and smoothness)
* Implemented Fugu tweaks (More smoothness and faster system) - thanks to nikademus
* Added new busybox (now compatabile with apps which need root)
* Added strace (/system/xbin)
* Added ipctool (/system/xbin)
* Added vfp-crasher (system/xbin)
* Added appwidgetpicker.apk
* Added new Juwe's wallpapers
* If you want CRT display animation (go to settings/display/animations/all)
* More stable system
* Faster system
Graffy
Modifié par graffy
tu pourrais au moins detailler la rom quoi changelog .....
Il est dans me premier lien...mais je l'ai rajouté ;)
Voilà ! ;).. j'attends vos avis.... !!!! :)
Modifié par graffy
Salut !!!
J'ai voulu l'installer pour tester hier et j'avais un soucis avec le boot : un rectangle bleu et vert sur tout l'écran. Ca démarre puis quand je veux ouvrir un écran pour une application, de nouveau cet écran puis ouverture de l'application.
Je laisse béton pour le moment car j'y arrive pas.
PS : je voulais la tester car les icônes en blancs sur fond noir me palissent pas mal. J'avais réussi sous CM7 à avoir un thème avec ce genre d'icônes
Ou trouver radio JV1 ?
Modifié par hack
Salut !!!
Je vais tester la nouvelle version car la 2.5 avait un problème. Le Dev vient de mettre en ligne la 2.5.1 qui corrige un gros problème de mémoire. En tout cas, sa version 1.9 (XWJS8) est une véritable petite bombe avec le paramétrage qui va bien au niveau du kernel ;)
Je ferais un retour sur la dernière version (2.5.1) : je vous dirais si elle vaut le coup ou pas puis faudra la tester sur plusieurs jours
Salut !!!
Nouvelle version 2.5.1 et vidéo-tuto de l'installation à partir d'une JV1 stock (beta)
Voilà, c'est fait : une réussite !!! je parle de l'installation ;)
C'est très fluide. Il y a un petit raté dans la thème : les flèches réseaux sont rouge et verte alors que sous la 1.9 tout est blanc. Dommage que je ne puisse pas posté sur xda :( j'aurais fait un commentaire pour le dev ;)
Concernant les jeux : ça donne sans soucis et pas de lags en vue sur let's golf2
Maintenant, je vais tester la batterie sur plusieurs jours, voir si ça tient ou pas
cool ;)
Salut !!!
Bon, ben de retour sous la version 1.9 lus fluide et plus réactive que la version 2.5.1. Certaines applications mettent du temps à réagir. De plus, quand le portable fut charger (100%), je le débranche et là, rien reste figer sur l'écran lock puis réagit quelques secondes après. Pour le jeu let's golf2 : une fois sur 3, le générique de départ se lance puis le jeu plante. Ca reste jouable
Je dois dire que le taf est bien fait mais que ça reste sur la base d'une béta donc affaire à suivre ;)
Là, il va falloir suivre son post de prêt. Mais bon, sa version 1.9 avec lagfix activé est d'une fluidité à en couper le souffle. J'en ai testé des roms et celle-là : wouaaaaa (attention : avis perso)
Je vais suivre de prêt sa rom en attendant une version stable d'androïd 2.3.3 ;) (version officielle)
C'est vrai que la 1.9 "dépote" même sans lagfix ;) (a mon avis le K13C y est pour pas mal !)... sinon vivement la 2.3.3
Oh fait as tu testé ce jeu et si oui tu arrives a te connecter ?
http://www.runes-mmorpg.com/
Edit : le serveur est out c'est pour ça !
Modifié par graffy
  • 3 weeks later...
