GalaxyUser Posté(e) 9 mars 2012 Share Posté(e) 9 mars 2012 (modifié) Salut, Il faut extraire ce fichier /system/app/LatinIME.apk du zip du theme puis le mettre dans le zip de ton autre rom. Ou pour l'envoyer dans ton portable avec adb: adb remount adb push LatinIME.apk /system/app/ @+ Modifié 9 mars 2012 par GalaxyUser Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
aureldelp Posté(e) 11 mars 2012 Share Posté(e) 11 mars 2012 Merci galaxy pour la manip.!!! Envoyé depuis mon Nexus S avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
davandroid Posté(e) 15 mars 2012 Auteur Share Posté(e) 15 mars 2012 CHANGELOG ### 1.5.5 * DO NOT USE THEMES OR MODS MADE FOR ANY OTHER VERSION. ONLY USER THEMES OR MODS MADE FOR 1.4.0 *YOU MUST DO A FULL WIPE. Wipe cache & data/factory reset *Report bugs only after you confirm bug by having nothing else installed besides ROM. Use the BUG TRACKER. *GApps are now included. Basic version of GApps. common: a lot of menu re-organization to give and even better user experience common: lockscreen is now split into to seperat menus: style and options common: custom text color on the lockscreen (JBirdVegas) common: ability to set cutom profiles (David van Tonder - switchable for the power menu if turned on in the power menu settings and from the settings menu) common: new customizable signal bar settings (Robert Burns) common: configurable size of the navigation bar (romanbb) common: added the centered stock lockscreen layout to the lockscreen settings common: ability to set transparency for the statusbar (JBirdVegas) common: new fully configurable rotation animations (Robert Burns) common: T9 is now turned off by default in the dialpad settings common: ability to show/hide homescreen icon labels (kyle ladd) common: added the propmodder (JBirdVegas - the ability the make changes to your build.prop with a user interface - Settings -> Advanced Testing) common: ability to exit to the homescreen after a call (Zaphod-Beeblebrox) common: ability to enable the use of the status bar during a call (Zaphod-Beeblebrox) common: added end call button to notification curtain (Zaphod-Beeblebrox) common: updated the speaker promitiy for ICS (codenamedroid) common: settings for alowing users to switch between the sdcard and internal storage (rmcc - Settings -> Storage) common: added the option to toggle fast charging mode (JBirdVegas) common: made sure that the powermenu nav actions are always hidden on the tablet builds common: added more languages to the keyboard common: updated the apn lists (sixstringsg) common: fixes chrome install for all builds common: fixes any issues with volume wake and the flashlight toggle common: added support for the 3G variant of the EEE Pad Transformer Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
reno1983 Posté(e) 16 mars 2012 Share Posté(e) 16 mars 2012 Merci David d'avoir posté la mise à jour. Des retours sur cette dernière? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
davandroid Posté(e) 16 mars 2012 Auteur Share Posté(e) 16 mars 2012 le seul bug que j'ai remarqué c'est la barre de statut quand on la déroule desfois elle devient invisible...un peu bizarre qoé !! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
reno1983 Posté(e) 16 mars 2012 Share Posté(e) 16 mars 2012 Ah, cool, je vais donc faire mes backups et installer tout ça... Tu es passé par un wipe complet? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
davandroid Posté(e) 16 mars 2012 Auteur Share Posté(e) 16 mars 2012 oui il y as beaucoup de changement :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
reno1983 Posté(e) 16 mars 2012 Share Posté(e) 16 mars 2012 Merci chef testeur B) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
davandroid Posté(e) 16 mars 2012 Auteur Share Posté(e) 16 mars 2012 :D tu vas voir dans les paramètre pas mal de nouveauté mais ça manque de traduction française Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
reno1983 Posté(e) 17 mars 2012 Share Posté(e) 17 mars 2012 (modifié) Bon, elle tourne vraiment pas mal cette petite nouvelle version. Du coup, je suis passé par une simple mise à jour et pas de problème :) Par contre, je ne suis pas sur que le kernell matr1x 18 soit le plus économe en batterie :( je vais partir en quête d'un kernell économe ou revenir à l'ancien (ICS-NS). Pour ceux qui hésite, cette rom toune vraiment bien (au moins aussi bien qu'avant si ce n'est pas mieux) Modifié 17 mars 2012 par reno1983 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KeeG Posté(e) 27 mars 2012 Share Posté(e) 27 mars 2012 D'autre retours sur cette nouvelle version? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
davandroid Posté(e) 29 mars 2012 Auteur Share Posté(e) 29 mars 2012 (modifié) ### 1.6.0 * new devices: Samsung Galaxy S2/S2 ATT, Droid Incredible, Droid Incredible 2, Acer Iconia ]* common: full korean translations (SoHyunSeop) * common: much nicer looking statusbar power widget (syaoran, kejar, codenamedroid) * common: Quiet Hours has been moved to the top of the settings menu * common: added new time range preference to Quiet Hours (DvTonder) * common: switched to new tabs layout for Profiles (DvTonder)[/background] * common: long press statusbar settings icon to enable/disable statusbar power widget (syaoran) * common: ability to add extra volume options to the volume rocker (Stevespear426, tmoskowie) * common: added zoom with volume option to the camera (MrDomopanda, Stevespear426) * common: navigation button transparency (romanbb) * common: added back the power menu nav actions logic from 1.5.0 * common: added haptic feedback conformation on long-hold over trash to delete an application (nebkat) * common: updated apns for showcase and mesmerize MMS (sixstringsg) * common: added support for Virgin Mobile MMS (wtogami) * common: updated to the latest google apps[/background] * common: Start-Up Tweaks has been update to a fragment and is now available on the tablet builds (codenamedroid) * common: reverted some of the sound cleanup from 1.5.5 (no more duplicate sounds, only ICS sounds and ringtones included) * common: fixed quick pin unlock issue with password and pins greater than 8 characters (Danesh) * common: fixed the editing of the apn settings * common: fixed issue with a few photo editing effects * common: fixed the display of contractions in the email app Modifié 29 mars 2012 par davidnexussdroid Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
reno1983 Posté(e) 30 mars 2012 Share Posté(e) 30 mars 2012 Dommage qu'ils ne soient pas passés sur la 4.0.4! Pour le coup je vais paut-être aller chez cyano moi! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dvorak Posté(e) 30 mars 2012 Share Posté(e) 30 mars 2012 Ouais pareil, dommage... ça sera pour une 1.6.5 peut être ? @reno1983 : Cyano a sorti une version en 4.0.4 ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KeeG Posté(e) 30 mars 2012 Share Posté(e) 30 mars 2012 J'avoue que cette rom me plaisait, mais impatient de tester cette 4.0.4! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
reno1983 Posté(e) 30 mars 2012 Share Posté(e) 30 mars 2012 En fait, ils sont en train de fusionner CNA avec la nouvelle Build 4.0.4.. Par ailleurs, il semble que cette 1.6.0 pose des problème de wifi. Pou passer outre, il suffit de mettre le kernell matr1x Et concernant la cyano, elle n'est pas encore en 4.0.4 mais je trouvais qu'ils étaient un peu plus réactive que la Team CNA ces derniers temps, mais au final les 2 sont à peu près au même points Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
davandroid Posté(e) 13 avril 2012 Auteur Share Posté(e) 13 avril 2012 (modifié) ]### 2.0.0 * update to 4.0.4 Check full changelog at link below FEATURE LIST Power Menu personnalisable (reboot, les profils, capture d'écran, mode avion, la torche, la barre de navigation à bascule, et silencieux à bascule) La barre d'état d'alimentation du Widget: (appuyez longuement sur le bouton Paramètres d'état pour activer / désactiver - Sommeil bascule, boutons de médias, mode avion, bluetooth, luminosité, GPS, lampe de poche LED, LTE, MobileData, Sound, Sync WiFi, WiFi AP, et WiMAX) État de la batterie personnalisable (style de l'icône de la batterie et d'un bar miui style) Horloge personnalisable (style d'horloge, radio am / pm le style, la couleur d'horloge, et toggleable icône de l'horloge d'alarme) L'état du signal personnalisable (style) Nombre de cibles personnalisable lockscreen [ Personnalisable mise lockscreen Personnalisable couleur du texte lockscreen Configurable papier peint lockscreen [ Aptitude à débloquer avec le menu Broche rapide de déverrouillage (déverrouiller avec la goupille / mot de passe sans appuyer sur ok) LockScreen avant de déverrouillage (lockscreen supplémentaire avant lockscreen le verrou face de la broche, le motif ou mot de passe) Possibilité d'activer la rotation sur le lockscreen Son bascule pour la caméra (remplace la cible de déverrouillage caméra avec un pour basculer les réglages sonores) Sillage du volume (du robinet soit la clé ordown augmentation du volume de réveiller votre téléphone à partir de sommeil) Contrôles de la musique Volume (longues touches de volume pour sauter des pistes de presse) Attendre pour verrouiller l'écran (androïdes utilisation de délai d'attente après avoir fixer manuellement extinction de l'écran) [ Barre de navigation personnalisable la visibilité et l'emplacement bouton de menu - Nombre de boutons de navigation - Ordre des boutons de navigation - La couleur des boutons de navigation - Taille de la barre de navigation - La vitesse d'animation sur le bouton lueur - La transparence sur le bouton de navigation Les paramètres personnalisés de rétro-éclairage automatique Modes de rotation personnalisables Écran personnalisable sur les animations / Off Personnalisable LED Pulse (Durée et couleur) Mode USB Fast Charge Possibilité d'activer les options de volume supplémentaires (en appuyant sur le volume s'ouvre curseurs pour sonnerie, les alarmes, les notifications, et les sons médiatiques) Étiquette personnalisable Transporteur personnalisé Transparence d'état personnalisable Option Style de WebOS Récents Liste Paramètres de performance: - Démarrage Astuces (réglages configurables qui s'exécutent au démarrage - Applications zipalign, permettent coup de pouce pour carte SD, fixent l'autorisation, cache transparent, permettant sysctl, permettre à des tâches planifiées) Vitesse du processeur (cpu gouverneur changement et la vitesse d'horloge) La tension du processeur (CPU voltage changements de chaque fréquence) [- Gestion de la mémoire (personnaliser l'utilisation de la mémoire à modifier le système performance0 - Désactiver l'animation de démarrage (passer l'animation de démarrage pour un démarrage plus rapide) Profils personnalisés (attribuer des profils différents pour modifier le comportement de votre téléphone à votre convenance) Heures tranquilles (la possibilité de définir quand et comment les sons de notification, haptique lumière de rétroaction, les vibrations et la notification fonctionnera entre un certains moments, par exemple "heures creuses") Lanceur personnalisé: (à l'origine construit au large de la Trebuchet) - Nombre personnalisable de homescreens - Écran d'accueil personnalisable par défaut - Barre de recherche amovible [ - Possibilité de redimensionner n'importe quel widget - Possibilité de masquer l'icône lablels - Des effets de transition configurables - Capacité à permettre la rotation Aptitude à dissocier les volumes et les États muets Possibilité de désactiver la notification de débogage USB BAD sur le réseau (enable TCP / IP sur le débogage des interfaces réseau (WiFi, USB réseaux)) Un accès root configurable (handicapés, les applications seulement, la BAD seulement, ou Applis et la BAD) Facultatif Retour Presse longue pour tuer Apps Tests avancés: Build.Prop configurable - - Pièces de rechange Paramètres - Paramètres de développement Paramètres d'essai - ca parait etre du lourd !!! Modifié 13 avril 2012 par davidnexussdroid Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
davandroid Posté(e) 13 avril 2012 Auteur Share Posté(e) 13 avril 2012 (modifié) Codename-Android-(MOD)-2-041212-SNAPSHOTNS.zip MD5 = 758481f9663147bbb9fb50506c7971e2 GApps HERE Filename gapps_ics_404_06042012.zip MD5sum 391221c6b3ceb537ea4b59baf4131410 CNA ROM Utility - Click HERE Update to server info, no other changes. FLASHING INSTRUCTIONS 1. Make a backup 2. wipe data/factory reset in recovery 3. flash the rom 4. reboot 5. sign in 6. wait for the phone to restore all your apps 7. reboot Modifié 13 avril 2012 par davidnexussdroid Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
funk Posté(e) 13 avril 2012 Share Posté(e) 13 avril 2012 (modifié) Pas mal,discréte (je n'ai mis que l'heure et la circle battery en statusbar) Mais : - Impossible de mettre un wallpaper en lockscreen (il n'est pas pris en compte) -Impossible de régler le CPU -la transparence de la statusbar ne fonctionne pas -pas de sortie de veille par bouton volume -pas de réglage du drawer en vertical (je vais mettre Apex ou Adw ex) -le disable boot ne fonctionne pas -j'ai fait un screenshot et n'apparait pas a l'écran du PC -reste a voir avec le théme black infinitum,mais je crois que ma vieille rom est encore + compléte (désolé mais c'est pas un troll) merci David Modifié 13 avril 2012 par Funk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
davandroid Posté(e) 13 avril 2012 Auteur Share Posté(e) 13 avril 2012 oui j'ai remarqué tout ca aussi funk ;) + pas possible de mettre les boutons virtuel il y as les réglages mais pas pour les activés ! a moins que je n'ai pas trouvé... j'aime bien les économiseurs d'écrans....parametre >affichage Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
funk Posté(e) 15 avril 2012 Share Posté(e) 15 avril 2012 J'ai réessayé un coup ce matin. la status bar transparente fonctionne (mais avec un léger trait,c'est dommage. le changement de wallpaper pour le lockscreen déconne toujours. C'est dommage car je crois que c'est celle qui a le + gros potentiel en modifs..........attendons une Maj ^_^ PS : trébuchet est vraiment limité.faudrait essayer avec Apex et aussi charger "setCpu" pour vraiment avoir la main sur l'overclock (ou down,pour moi,lol) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Snouki Posté(e) 15 avril 2012 Share Posté(e) 15 avril 2012 avec launcher xperia c'est top;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Labatterie08 Posté(e) 15 avril 2012 Share Posté(e) 15 avril 2012 Mais serieusement, à quoi ça sert d'oc, parce que les seules fois où je l'ai fais, j'ai pas vu beaucoup de changements... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
funk Posté(e) 15 avril 2012 Share Posté(e) 15 avril 2012 bah : -se la péter (je monte a 1576 Mhz que pour les tests quadrant) -faire tourner une appli ou jeu gourmand -Ou descendre a 800 Mhz comme moi pour gagner de la batterie sans altérer la fluidité ( environ 2 % par heure .....au pif) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Labatterie08 Posté(e) 15 avril 2012 Share Posté(e) 15 avril 2012 Ah ouai j'avais pas pensé qu'on pouvais aussi baisser le CPU pour gagner de batterie, bien vu ;-) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
