micky51100 Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 (modifié) Voiçi une nouvelle ROM qui viens de voir le jour aujourd'hui même sur XDA => http://forum.xda-dev...d.php?t=1426339 Si quelqu'un à quelques screnshot de cette ROM sa sera sympa. Merci d'avance Alors cette ROM est basé sur : +Base: 3.14.405.1 HTC bravo Gingerbread Sense 1+HTC "stock" kernel +cpufreq available: smartass, powersave, interactive, ondemand +perflock disabled +CPU during boot: min 383 Mhz, max 998 Mhz - ondemand (could be changed by user - for example Set-CPU) +no undervolt or overclocking +init.d support +data/app support +fix: /data-space loss +advanced power menu +modded stock battery with % +green overscroll glowing +sd-speed fix +cache2sd + ramdisk +zipalign on startup +vacuuming databases on startup +fix: big applications are lost after reboot +system-apps odexed +framework odexed +hosts on /data/data for easy update +SU binary and app +busybox 1.19.0 +Adobe Flashplayer +Apps: Titanium Backup, Adfree, RomManager, FileExpert Et voici le lien de la ROM : +[data++]AN-Droid 2.0.0 data++: https://rapidshare.com/files/9205855...2.0.0_data.zip md5: 04458d88336099ad3ef8c8926933c700 +[stock]AN-Droid 2.0.0 stock: https://rapidshare.com/files/3483458....0.0_stock.zip md5: 4dd705a00063ee0252dc833efb3395df changelog : An-Droid 2.0.0: +completely rebuild! +removed File Expert +added Es File Explorer - root access possible, enable in settings +smooth scroll - mod (Thanks AndroidON) +increased volume steps for every volume. Now from 0-20 steps! - After the flash check your volume-settings! - See picture here (Thanks AndroidON) +CRT ON/OFF Animation (Thanks bananacakes) +update RomManager +update Titanium back +update Voice Search +update Google Search +update hosts +update Google Maps +minor changes +set slightly less agressive proximity sensor value than last version (time till phone comes out of the black screen) Cause of the fact, the ROM is a completely NEW BUILD (new odexed), a few mods don't work at the moment with this: - Remove %-battery and green overscroll glowing (like stock ROM) - done, available - see post 2 - QuickSettings mod - done, available - see post 2 - Black HTC Clock-Widget - done, available - see post 2 - Neverupdate Market --> i will update this mods soon. The other mods will work with version 2.0.0 A few more things to know to this release: - I recommend to do a full wipe flash. - A update flash should work too... if you get problems, do a full wipe flash - Don't use a UOT-Mod from the 1.x ROM, make it new with the files from the new 2.0.0 ROM An-Droid 1.1.0a +bugfix: Wrong version number (no need to update, if you are on 1.1.0 + patch) An-Droid 1.1.0 +File Expert updated +Titanium updated +RomManager updated +Google maps updated +system/bin updated +hosts updated +Incredicontroll app added +Removed teeter.apk - install as user app if you want it +Removed flashlight.apk - install as user app if you want it +Camera autobrightness fixed (camera app uses (auto-)brightness-setting of the phone and no longer Max-Brightness) +more speed tweaks added +fixed small bug in build.prop +changed kernel to -snq's bravo-2.6.35.8-snq-111118 kernel - Thanks to -snq! +brightness-levels fix +2 way call record support (for example with rVoix) +governors: interactive, conservative, ondemand, powersave, smartassV2, performance (ondemand set) - can be changed with for example SetCPU +under- /overvolt possible (800 - 1350mV) - use build in "incredicontrol-app" - don't set voltage too low, try it before set on boot! +ext3 and ext4 supported - all my mods support ext4 mount (if you get a unsuccessful flash, try to mount sd-ext in recovery before flash) +modules build in +modded WiFi-driver - better reception +cpu freqency: 128 - 1190 Mhz possible (384 - 998 Mhz set) - can be changed with for example SetCPU - do this on your own risc and be careful! +Trackpad2Wake&Unlock full working +tweaked autobrightness (dark+) - see here for more informations - now full working +battery improvements! +Fixed space/PVT4 issue for the stock build +Added a lot of locales** **If you update the ROM without full wipe: - Menu -> Settings -> Applications -> Manage Applications -> All - Search: Customization Settings Provider -> Clear DATA, Force Stop - After that your language listing will be full An-Droid 1.0.4 - 1.0.9 unreleased test-builds An-Droid 1.0.3 +Market back to 2.3.4 --> fix FC +Trackpad 2 wake&unlock enabled - thanks to snq and bananacakes! +added HTC Teeter app - thanks beartiger! +added HTC Torchlight app - thanks beartiger! +updated hosts --> please read this! An-Droid 1.0.2 +Browser patched to manage up to 15 tabs :D +Market updatet to 2.3.6 -> see post 2 for old/new market or "Neverupdate-Patch" +Titanium Backup updated +FileExpert updated +VoiceSerach updated +a few smaller optimizations +Drag & drop Rosie (thanks to bananacakes) +added massive APN-List +updated system/apps odexed :D +updated hosts An-Droid 1.0.1 +build completely new +updated Titanium Backup, FileExpert, Youtube +latest flashplayer +latest SU (app+binary) +fix some reboot problems Modifié 29 janvier 2012 par micky51100 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
morganbzh Posté(e) 4 janvier 2012 Share Posté(e) 4 janvier 2012 Je comprends pas bien l'intérêt de cette rom par rapport à ce qui existait déjà... mais peut être que je me trompe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bertrand13 Posté(e) 18 janvier 2012 Share Posté(e) 18 janvier 2012 C'est une Rom simple sans gadget sous sense ancienne version Tout a fait adaptée à la puissance du desire Devenue depuis une semaine ma rom de tous les jours venant de Leedroid HD qui n'évolue plus An-Droid est bien plus stable et rapide De plus le developpeur est très reactif et à l'écoute Je recommande VIVEMENT !! A+ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
joyfrag Posté(e) 27 janvier 2012 Share Posté(e) 27 janvier 2012 Je crois que je vais me laisser tenter par cette rom, car j'en ai marre des Roms qui même avec une classe 10 rament! C'est bien sense 3-3.5,c 'est beau...mais c'est pas fait pour nos joujoux, même sur les téléphones pour lesquelles ils ont été développer, ça rame, j'en ai encore vu un ce week-end... Vu que pour le moment ce n'est pas encore trop ça pour la version ICS, je vais tester et je vous tiens au courant! Pour les screen, anderl78 en a rajouter sur XDA : Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
joyfrag Posté(e) 29 janvier 2012 Share Posté(e) 29 janvier 2012 Bon petit retour, elle est très fluide, franchement j'en suis super content. Par contre le seul problème que je rencontre est la perte du réseau de temps à autre...seul solution un reboot....Est-ce que quelqu'un a eu ce problème avec cette Rom? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
alpha62 Posté(e) 30 janvier 2012 Share Posté(e) 30 janvier 2012 Idem, je viens de l'installer sur le désire de ma fille, aussi des pertes de réseau bon c'est free donc je vais la faire patienter un peu, c'est la première fois que je modifie le désire, avant il était sur Orange Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bobatomix Posté(e) 30 janvier 2012 Share Posté(e) 30 janvier 2012 C'est quelle version de Gingerbread? je n'ai rien trouvé à ce sujet. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 30 janvier 2012 Auteur Share Posté(e) 30 janvier 2012 Cette version est basé sur Android 2.2 et sense 2.1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bobatomix Posté(e) 30 janvier 2012 Share Posté(e) 30 janvier 2012 C'est du froyo ! J'espère au moins que les failles de sécurités ont été patchées sur cette version froyo. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
t-minik Posté(e) 30 janvier 2012 Share Posté(e) 30 janvier 2012 (modifié) meuuh non, c'est à base de la GB officielle HTC, donc du android 2.3.3 + Sense 1.9. Modifié 30 janvier 2012 par t-minik Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bobatomix Posté(e) 30 janvier 2012 Share Posté(e) 30 janvier 2012 @t-minik :C'est rassurant Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
