Les raccourcis claviers
Linou
Yop,
Je l'ai cherché pendant un paquet de temps, mais je n'ai pas trouvé de source officiel...néanmoins voici une liste des raccourcis clavier :
At the home screen:
Menu + W = change wallpaper
Menu + M = manage applications
Menu + N = show notifications
Menu + A = add item to homescreen
Menu + S = new search (or you can just start typing)
Menu + P = open settings
Home + B (or Search + B) = open browser
Home + C (or Search + C) = open contacts
Home + L = open calendar
Home + Esc = exit back to homescreen
In the browser:
Menu + N (or Ctrl + T) = new tab
Menu + I (or Ctrl + I) = zoom-in on page
Menu + O (or Ctrl + O) = zoom-out on page
Menu + J = open download manager
Menu + L = open search bar
Menu + R (or Ctrl + R) = refresh current page
Menu + F = find on page
Menu + B = open bookmarks
Menu + H = view browsing history
Menu + D = add bookmarks
Menu + S (or Ctrl + S) = open social network sharing menu
Menu + G = page info
Menu + E = select text
Menu + P = open browser settings
Menu + W (or Ctrl + W) = closes the current open tab
FN + Tab = toggle browser toolbar on/off when it's hidden
Ctrl + Shift = select input method (universal outside of browser also)
In Gmail:
C = compose new message
L = go to Label menu
X = check message in Inbox
V = add Label to current message
M = delete highlighted or checked messages
Alt + Up = go to top of Inbox
Alt + Down = go to bottom of Inbox.
General:
Shift + Backspace = Forward delete (like a full keyboard "Delete" key)
Ctrl + X = Cut
Ctrl + C = Copy
Ctrl + V = Paste
Hold ALT + TAB = Show recent apps window and cycle in forward order(may not work in certain apps due to tab focus on certain elements in app) - (Only for HoneyComb 3.2 And Above)
Hold ALT + Shift + TAB = Show recent apps window and cycle in reverse order(may not work in certain apps due to tab focus on certain elements in app) - (Only for HoneyComb 3.2 And Above)
Source : http://www.transform...board-dock.html
A droite de la barre d'espace, entre Alt Gr/Alt et Ctrl.
Par contre, la plupart des combinaisons ne marchent pas chez moi ...
At the home screen:
Menu + W = change wallpaper => OK
Menu + M = manage applications => OK
Menu + P = open settings => OK
Mais :
Menu + N = show notifications / Menu + A = add item to homescreen / Menu + S = new search (or you can just start typing)
Home + B (or Search + B) = open browser / Home + C (or Search + C) = open contacts / Home + L = open calendar
=> Tout cela lance la recherche, en ajoutant en plus le caractère saisi (A, S, etc ...) au début
Je ne pense pas que cela soit dû au type de clavier car d'après Pheldwyn les combinaisons MENU+W et MENU+M fonctionnent alors que ces touches sont différentes sur les 2 types de clavier et que les combinaisons avec des lettres comme B, L ou C ne fonctionnent pas alors que ces lettres sont les même sur les 2 types de claviers.
Après moi je dis ça c'est juste pour passer le temps car je n'ai toujours pas la bête entre les mains pour tester :'( et dieu sait à quel point je préférerai pouvoir constater qu'un raccourcis ne fonctionne pas, que de ne pas pouvoir constater que plein d'autre choses marchent très bien ;-)
  • 4 weeks later...
Bonjour... J'ai la Prime depuis quelques jours et je me penche aussi sur la question des raccourcis clavier (du clavier physique), et l'utilisation qu'on peut en avoir pour le traitement de texte (sur Polaris par exemple) et la rédaction sur le net.
Et il y a 2 fonctions qui me manquent (ou que je n'ai pas su trouver) :
1) - l'équivalent de la touche Supprimer : "Shift + Backspace = Forward delete (like a full keyboard "Delete" key)"... bah ça ne fonctionne pas :s ! Alors y aurait-il une option possible pour arriver à retrouver la touche "sup" ?
2) - et l'édition des caractères spéciaux (certains caractères, comme les guillemets "«»", ou le "œ"), qui manquent au clavier du dock de la transformer... et que je n'arrive pas à retrouver via les raccourcis clavier classiques (codes ascii)... absence de clavier numérique oblige ? Ou mauvaise combinaison de touche de ma part ?
Je précise que l'a prime est ma première tablette ET mon premier netbook... donc pas encore bien familiarisé avec la bête et ce genre de clavier. ^^
Merci de vos réponses ;-)
Modifié par lhomville
Vous savez si en rootant la tablette, il est possible de mieux custom le comportement des touches ? J'aimerai beaucoup avoir un vrai bouton de switch d'app...
Bonne question, si tu trouves des infos je suis preneur.
