[ROM] Miui Special Edition ICS V1.1 (2.3.20) [21/03]
Screenshots
screenshot2012032120391.pngscreenshot2012032120392.pngscreenshot2012032120373.pngscreenshot2012032120385.pngscreenshot2012032120401.png
Caractéristiques v1.1:
Miui 4.0.3 (2.3.20)
Modem XXLPQ
Kernel XXLPH
Added Languages: dutch - english - french - german - hungarian - italian - korean - polish - portugesse - russian - spanish - turkish
+/- 80% Translated
Added Apex LauncherFixed & Changed Keyboard
Fixed FC on Volume Selection
Fixed FC on Gallery Wallpaper Selection
Fixed FC on Display Brightness
Fixed FC on Contact Rotation
Fixed Lag Issue when applying wallpaper to lockscreen
Added New Icons
Dalvik2Preload
Improved boot time
Beats Audio&Xloud
Added CWMManager
Increased video Quality
3D Gallery with Motion Zoom
SDCard Read Ahead Speed Fix Applied
Improved UI Smoothness and Menu Access
Zippaligning and Verify-Bytecode tweak!More free and Less RAM usage
Implemented LPQ Baseband
Wireless speed increases
Better video streaming
Improved WIFI Scanning and Obtaining I.P Times
Corrected issues where Bluetooth would FC phone on connection
System processes priority tweaks
New boot animation
Battery life Tweaks
Build.prop Tweaks
And Some More System Tweaks
And more...
Installation Miui Special Edition ICS V1.1:
1.placer la rom sur votre carte SD interne
2. allumez votre téléphone en mode recovery
3. wipe cache/partition
4. dans mode avancée / wipe dalvik cache
5. wipe data / factory reset
6. dans mount and storage / format system
7. installer le zip sur la sdcard ,une fois l'installation terminée,faites un reboot.
8. profitez de Miui Special Edition :D
Téléchargements
Download_1:https://hotfile.com/...Signed.zip.html
Download_2:http://www.putlocker...1577204D9721F41
Download_3:http://minus.com/mSP_ICS
source : MIUI Nederland
Modifié par android1
bonjour et merci :-)
pourquoi toute ces étapes :?
7. installer le zip sur la sdcard (attendre le redémarrage du système)
Superbe rom !!!
deux questions : comment avoir le fond d'écran gris map monde avec fuseau horaire comme sur les screenshot ?
et comment avoir la météo de ma ville DU WIDGET car la fonction GPS ne me trouve pas ?
Merci d'avance
NohN
Salut, j'ai voulu tester cette rom, après tous les wipes, et le format system, j'ai fait install zip from sd card, le zip s'installe, ça me marque install from sd card complete, mais le tel ne reboote pas tout seul, dois je redemarer par la commande du recovery ou attendre longtemps?
Je suis à 2 minutes d'attente et le tel n'as pas commencé à rebooter
Modifié par joebar71
C'est ce que je viens de faire, avant de voir ton message, j'en avais marre d'attendre, lol merci.
et donc, ne mettez pas attendre le redémarrage du tel!!!!! lol
T'as raison,je corrige ^_^
Cette ROM ne se met tjr pas a jour par OTA comme pour la MIUI officiel ?
Pas à ma connaissance...
1 dans PicSpeed wallpapers dispo sur le market
2 on ne peux pas malheureusement,il faut en installer un autre.
bon ,je laisse un peut de cotés mon andyx 6.1 pour tester cette rom qui m'intrigue .
au niveaux fluidités et tactile sa donne quoi?
alors première impression a chaud .
ya de tres bonne idée et même d’excellente comme dans la recherche d'application en mode alphabétique c'est vraiment top !
juste un truc qui manque je trouve ,le fancy rotation (pour la rotation de l’écran style iphone ) et que dans le launcher on ne puisse pas cacher la barre de notification .
sinon elle a l'air bien geek ;) donc pour l'insant c'est fun et plaisant B)
EDIT:bon et bien que dire ...je suis de plus en plus conquis ,je n'ai jamais vu mon galaxy s2 aussi fluide et rapide ,je peut TOUT changer dans le thème de mon phone ! je sens que je vais bien m'amuser avec :)
merci pour se partage ^_^
EDIT 2:c'est possible d'ajouter ceci?http://forum.xda-developers.com/showthread.php?t=1362354
Modifié par alessa
punaise,ca fais quelques temps que j essaye plusieurs miui mais au redémarrage.....KERNEL PANIC ! !
ca m'gonfle grave.
j ai tt essayé.....tt les wipes,venir de gb ou ics,rien a faire,tjrs ce p****n de kernel panic.
une idee les amis?
Merci beaucoup pour l'info....
Comme j'ai bien galéré à le trouver je partage le chemin : Diversity/diversity2
NohN
RE,
Arrivez vous à utiliser l'application E-mail, pour ma part lorsque je rentre le compte et qu'il actualise il reste bloqué en actualisation et donc j'ai pas de mails... il tourne en rond si vous préférez... :geek:
Je suis preneur d'une solution possible car j'utilise pour mail pro et mail privé (en plus de Gmail qui fonctionne bien lui... ;) )
MERCI d'avance
NohN
je pense que non ,c'est icompatible avec la miui .
"je peut mettre le kernel phenomenal?"
il faut l'essayer...je te conseil de flasher Samsung Kernel Cleaning Script 2.1 avant toute chose.(flash en recovery)
Samsung Kernel Cleaning Script 2.1: http://www.mediafire...3782bp7l0ln600i
pour se qui est du kernel phenomenal ,j'ai flasher "normalement " sans kernel cleaning et sa nevoulait pas booter ... je vais demander sur xda c'est moins risquer .
sinon ,cette rom est vraiment bien ,j'ai juste eu quelque reebot se matin mais la c'est stable plus rien ...
et quand on glisse la barre de notif' ,c'est normal que l'on ne voit pas l'icone batterie ?
EDIT: pour le kernel phenomenal c'est impossible car il n'est compatible que avec les rom a base samsung .
Modifié par alessa
la connexion USB ne fonctionne pas
le thème dans "Mon thème" se désactive à chaque redémarrage malgré une sauvegarde
Personnellement j'ai testé, ma connexion USB est ok, tout fonctionne, et le thème après redémarrage est toujours actif.. J'ai le débogage activé..
Sinon super ROM ! Ultra personnalisable, tout fonctionne, j'aime beaucoup, la batterie je n'ai pas assez de recul pour m'exprimer sur le sujet, j'ai installé cette ROM ce soir .. En tout cas merci du partage !
Modifié par kainingawekk
