matmutant Posté(e) 1 avril 2012 Posté(e) 1 avril 2012 (modifié) MiniCM9 is custom-built' date=' based on CyanogenMod 9, running Android IceCream Sandwich on top of the nAa kernel.[/color'] Notes: To cookers: If you want to use parts or all of this ROM for your custom cooks, read this first. To everyone: Please don't mirror this ROM MiniCM9 is built for the X8 / x10mini / x10minipro range. It is in ALPHA state but quite stable and it's the most feature-complete ICS ROM perfect for day to day use This is a team work by DaRk_dOg and me For Troubleshooting common issues visit: http://code.google.c...Troubleshooting FAQs (Many thanks to matmutant) If you have a question, please READ THIS before posting and also use the SEARCH button at the top right -> If you want a more relaxed chat, or have issues with MiniCM, you can use the following chat server (Thanks to SafiXS for setting this up!) MiniCM chat Before posting an issue wipe (factory reset) via CWM at least once. Not Working: Features: Built for LDPI Full hardware acceleration (the ICS way) Opengl rendering MiniCM Update notifications via c2dm (Settings -> System -> Update notifications) App2sd / Dalvik2sd compatible with 2.1 app2sd (storing to ext2/3/4 pre-existing partition is detected and mounted as such) Android's native App2sd (move to sdcard, storing to fat) In kernel ClockworkMod recovery v5.0.2.3 and option to reboot into Recovery Modular Undervolting handled Settings -> Performance menu (by default not active) KSM support Extra Settings display option for Ultra brightness, also handled via notification bar icons ;) Smooth 2D scrolling in menus Native Wifi Hotspot Native USB tethering Native Bluetooth tethering Bugs: (Please use the project's tracker for reporting bugs. Please file them properly following the template or they will be discarded.) Requirements: Latest 2.1.1.A.0.6/2.1.1.C.0.0 SE firmware / Baseband: M76XX-TSNCJOLYM-53404015 Unlocked bootloader Latest version of the ICS nAa kernel Instructions: Download the MiniCM9-xxx.zip from the release link that follows Backup your /data contents: contacts, apps, sms, etc. or backup via recovery Move the MiniCM9-xxx.zip to the root folder of your sdcard. Download the suggested Google Apps for CM9 from here (check http://goo-inside.me/gapps/ if you want to experiment with other gapps versions) Make sure you are using the nAa-ics kernel Enter CWM and:- Select 'backup and restore -> Backup'- Select 'wipe data/factory reset' (MUST DO)- Flash the MiniCM9-xxx.zip. To do this, Select 'install zip from sdcard -> choose zip from sdcard' and select the MiniCM9-xxx.zip- Flash gapps in the same way Reboot (first boot will take ~2 mins) Once your device has booted, you can use the nAa notification to register for upcoming updates. This way you can get update notifications on new versions of MiniCM9 and the nAa-ics kernel! Please make sure you followed the above steps before reporting any issues, especially 'wipe data/factory reset' Downloads: do NOT mirror x10mini (robyn): http://minicm.google...3.0.5-robyn.zip http://minicm.google...-nAa-ics-04.ftf x10miniPRO (mimmi): http://minicm.google...3.0.5-mimmi.zip http://minicm.google...-nAa-ics-04.ftf Donate: If you are enjoying my work please consider donating: . Donations are voluntary but allow me to spend more time on this project. Disclaimer: I can't be held responsible if this ROM bricks your device or makes it explode in your hands! Use it at your own risk! Changelog: - 1/4/12 MiniCM9 3.0.0 build . changelog : Build Changelog: . ### MiniCM9-3.0.2 * MiniCM9 theme - to be used only with the MiniCM9 ROM * Kernel bootlogo animation now finishes before MiniCM9 boot animation starts * Autobrightness levels fixed * Recovery version in Settings -> About Phone * Updates for camerahal * camera: barcode scanners fix * camcoder: 352x288 resolution (higher resolution is possible but has audio/video sync issues due to missing codecs) * FM Radio app now enables bluetooth when it starts * SmartassV2 governor as default * Many fixes from CM: theme manager, lockscreen icons, Apollo, etc. * Fixed reboot hanging issues (when rebooting from power button) ### MiniCM9-3.0.1 * Functional Camera (SEMC libcamera, camcorder not working) * Many fixes from CM * libcopybit (shakira) * Fixed banding issues * Bluetooth a2dp * Ultra brightness setting is now persistent on boot * Sim and timezone fixes are included * Fixed power draining issues * Kernel update ### MiniCM9-3.0.0 * CM9 - Android 4.0.4 code baseline * Full Hardware Acceleration with Adreno ICS libs * For use with nAa-ics kernel line only * Built for MDPI - shakira, LDPI - robyn, mimmi * MiniCM9 theme * GSM/SMS/Data(3G, EDGE) * Wifi * Wifi Tethering * Usb mass storage * Usb tethering * Bluetooth * Bluetooth Tethering * FM Radio * Flash led (Torch app) * ADB at boot * Sensors * OpenGL Rendering for gui * Libaudio from sources * Software Video decoder * Vibration * GPS * App2sd (storing to ext4. Detect ext4 partition and swap and usingmount as such) * Native android moving apps to sdcard * Flash led (Torch app) (for robyn, mimmi) * Stock SE T9 keyboard (for robyn, mimmi) * Offline charging * Reboot menu - boot into Recovery * Gallery, Browser, Live Wallpapers and Gmail are fully working * OTA Update notifications for both kernel and ROM * Network stats via Settings -> Data usage * Undervolting via Settings -> Performance menu * Ultra brightness via Settings -> Display menu Modifié 4 novembre 2012 par matmutant 4 Citer
matmutant Posté(e) 2 avril 2012 Auteur Posté(e) 2 avril 2012 suite à quelques problemes, la version pour mini et pro va se faire attendre ... Citer
matmutant Posté(e) 3 avril 2012 Auteur Posté(e) 3 avril 2012 (modifié) les plus gros bugs sont résoluts, voici les screenshots : ;) Modifié 3 avril 2012 par matmutant Citer
Konao Posté(e) 3 avril 2012 Posté(e) 3 avril 2012 Sympa sympa les screens ! J'espère que la version sera bientôt prête ! (J'attend impatiemment cette version depuis que j'ai vu le premier post d'ICS sous nos mobiles ! :D) Citer
matmutant Posté(e) 4 avril 2012 Auteur Posté(e) 4 avril 2012 par contre la gestion de l'autonomie est horrible : perdu 50% de batterie dans la nuit sans rien faire ... pour le reste, elle est géniale :-) Citer
ricolevengeur Posté(e) 4 avril 2012 Posté(e) 4 avril 2012 Idem, hâte de la voir arriver cette jolie ROM! J'aimerai bien changer de celle que j'ai actuellement! Citer
Wap A KrOo Posté(e) 9 avril 2012 Posté(e) 9 avril 2012 perso j'ai tenté ça il y à une petite semaine: http://forum.xda-developers.com/showthread.php?t=1365683 Quelle déception... pour sélectionner un simple code pin c'était déjà pourri, j'avais un rond que je devais déplacer au bon endroit pour pouvoir ensuite sélectionner. Bizarre comme truc, tellement bizarre que dur de décrire. Sur la page d’accueil idem... je décide de désinstaller.. et la c'est le drame. j'avais fait un backup avant l'installer de la CM9. Et impossible de revenir sur la CM7 grâce au backup. Et tout mes backup de titanium pro ne marchais plus. J'étais reparti pour tout reconfigurer de a à z... Voilà mon expérience CM9. Je vais attendre sagement du coup. Citer
matmutant Posté(e) 9 avril 2012 Auteur Posté(e) 9 avril 2012 c'est pas le meme niveau de qualité là ;) Citer
Wap A KrOo Posté(e) 11 avril 2012 Posté(e) 11 avril 2012 Bah heureusement j'ai envie de dire. =) Mais comme je suis un peu bébête :P je vais attendre que tout soit bien stable ect avec un joli résumer me disant quoi DL exactement. Je suis une taupe en anglais et sur xda je me perd facilement... bah ouai.. ouuuhh Citer
matmutant Posté(e) 11 avril 2012 Auteur Posté(e) 11 avril 2012 aucun probleme :) de toute façon, quelques petits détails nous interdisent une sortie de rom pour mini et pro pour l'instant ça devrait etre rapidement réglé tout de meme ;) Citer
Konao94 Posté(e) 16 avril 2012 Posté(e) 16 avril 2012 J'viens de voir ça : http://forum.xda-developers.com/showthread.php?t=1575094 C'pour bientôt ? :D Citer
ricolevengeur Posté(e) 24 avril 2012 Posté(e) 24 avril 2012 Coucou, des nouvelles sur ta rom? As tu résolu ton pb de batterie? Citer
matmutant Posté(e) 24 avril 2012 Auteur Posté(e) 24 avril 2012 (modifié) hmm C po ma rom :P pour le bleme de batterie je suspecte de plus en plus un probleme venant de mon tel plus que des builds que m'envoi régulièrement nAa, (nous sommes actuellement au build de test 3.0.1.6 le 6 représentant le 6eme build testé de cette version majeure) en fait je fais des tests de plus en plus ciblés : soit la veille gsm consomme beaucoup plus qu'avant, soit la batterie n'est plus capable de fournir la meme intensité de courant et donc décroit plus vite en tension... nous ne sommes donc toujours pas en mesure de faire une sortie publique de la rom, nAa refusant cette idée tant qu'il n'aura pas résolu le probleme d'encodage/décodage matériel pour la vidéo ainsi que les ressources ldpi pour l'application appareil photo ... Modifié 24 avril 2012 par matmutant Citer
Konao94 Posté(e) 25 avril 2012 Posté(e) 25 avril 2012 Ah ok ^^ C'est normal de sa part de vouloir faire une version débugué avant de sortir la rom je trouve ^^ 1 Citer
ricolevengeur Posté(e) 25 avril 2012 Posté(e) 25 avril 2012 Tout a fait d'accord. surtout que la première version mise en ligne donne souvent la plus grosse des impressions sur l'envie de tester les maj suivantes [color=red]qd[/color] il y en a. Hate de voir ce que cela donne en tout cas! Bon courage a vous en tout cas pour le dev. 1 Citer
matmutant Posté(e) 25 avril 2012 Auteur Posté(e) 25 avril 2012 (modifié) Ah ok ^^ C'est normal de sa part de vouloir faire une version débugué avant de sortir la rom je trouve ^^ c'est pas l'avis de tous sur xda ça :P PS : pourquoi 2 konao? Modifié 25 avril 2012 par matmutant Citer
Konao94 Posté(e) 26 avril 2012 Posté(e) 26 avril 2012 Ni le miens , mais c'est compréhensif x) Petit problème d'email , compte invalide .. (J'ai fais la demande de changement d'email , mais oublié d'aller la valider sur l'ancienne email avant de supprimer l'adresse .. x)) 1 Citer
matmutant Posté(e) 26 avril 2012 Auteur Posté(e) 26 avril 2012 ok :) te voila de nouveau newbie :P Citer
Trichelieu Posté(e) 27 avril 2012 Posté(e) 27 avril 2012 Ralalalala que du bon en perspective. Depuis que j'ai installé coolflame je ne repasserai pour rien au monde sur stock rom mais par contre une petite android 4.0 avec possibilité d'installer les dernières applis, je ne dis pas non! J'attend ça avec impatiente Matmutant! Citer
Konao94 Posté(e) 27 avril 2012 Posté(e) 27 avril 2012 (modifié) ok :) te voila de nouveau newbie :P xD Cela me dérange pas x) "Ralalalala que du bon en perspective. Depuis que j'ai installé coolflame je ne repasserai pour rien au monde sur stock rom mais par contre une petite android 4.0 avec possibilité d'installer les dernières applis, je ne dis pas non! J'attend ça avec impatiente Matmutant!" Franchement , j'ai du repassé sous stock pour un problème de batterie , j'y suis resté coincé pendant une semaine (Pas de pc windows) , je peut te dire que c'était juste l'enfer x) En plus j'ai remarqué que la maj de l'android market se faisait pas , après une semaine le Google play était pas apparu x) (pas gênant mais bon) Modifié 27 avril 2012 par Konao94 Citer
Geofreezz Posté(e) 27 avril 2012 Posté(e) 27 avril 2012 (modifié) Ralalalala que du bon en perspective. Depuis que j'ai installé coolflame je ne repasserai pour rien au monde sur stock rom mais par contre une petite android 4.0 avec possibilité d'installer les dernières applis, je ne dis pas non! J'attend ça avec impatiente Matmutant! Idem ^^ ICS me fais de l'oeil, alors GintoCream Xtrem ou MiniCM9, je verrais lequel est le plus simple à installer, je crois avoir compris qu'il faut ZP Kernel pour Xtrem et je suis sur nAa alors bon ... ^^ Modifié 27 avril 2012 par Geo97186 Citer
matmutant Posté(e) 27 avril 2012 Auteur Posté(e) 27 avril 2012 j'étudie une nouvelle piste pour l'autonomie, plus le temps passe et je me dis que l'undervolt ne marche plus; j'ai donc fait 1/2jour déactivé, et 1/2jour activé : meme profil de décharge (donc il semble que ça marche pas) nAa m'a refait un petit kernel (nAa-ics02.4) pour voir, normalement demain ou après demain on saura si il y a une amélioration ou pas j'espère vraiment qu'on va améliorer ça, nAa ne publiera jamais une rom qui a moins de 20h d'autonomie 1 Citer
Trichelieu Posté(e) 27 avril 2012 Posté(e) 27 avril 2012 (modifié) Yop. @Konao: Ouais pour la batterie c'est relou j'avoue. Perso en ce moment je peux recharger mon portable quand je veux, donc pas de problèmes mais je comprend que ça puisse déranger. (Genre quand t'as écran au max, wifi et flash player activé tu vois les pourcentages de ta batterie diminuer à vue d'oeil xD) @Geo: Je suis les deux aussi ^^. Ok pour l'autonomie, plus 20h ce serait cool quand même aussi :P. Edit: Mais, mais j'ai mal lu! C'est pour x10 mini, pas le pro! Une compatibilité serait envisageable? *Se met à plasmodier dans une langue inconnue* Modifié 27 avril 2012 par Trichelieu 1 Citer
