Billouetaudrey Posté(e) 16 juillet 2012 Share Posté(e) 16 juillet 2012 (modifié) Hello, Voici une app et ce, gratuitement. App a installer avec l'apk Trickster MOD app is a tweaking tool to change various settings included in your kernel and other tweaks to your phone. It was made by me and my friend. It has abilities to do the following Zipalign and sqlite DB optimization at boot Some android properties tweaks with mobile network speed tweak Screen state optimization for kernel task scheduler and virtual memory management (ch33kybutt) Set I/O scheduler, read ahead buffer, CPU scaling governor, min and max CPU speed Following features depend on kernel support Color (applied by default), contrast and gamma tweaks Generic hotplug CPU Temp limit Minimal SmartReflex voltage of Core, IVA, and MPU domains Nominal SmartReflex voltage for Core, IVA, and MPU domains Regulator voltages GLaDOS live OC of Core, GPU and MPU WIFI mode for screen off (power saving or full speed) Vibrator strength Headset volume boost High performance sound Force fast charge Battery live extender Touch wake and touch wake duration fsync control And more... Download Trickster MOD Script 20120716 CWM zip Trickster MOD App 20120709 Changelog For everything I have done regarding the Galaxy Nexus, including older versions of what posted here: LINK Requirements CWM for now but not in the future App requires sdcard write permission to edit Trickster MOD config files on sdcard This app does not need root for now but it will in the future Installation/Update instructions Reboot to CWM recovery Do a nandroid if you're scared (recommended in case you have problem) Install CWM zip from sdcard Reboot the phone If you see /sdcard/trickster directory with configuration files inside then this mod installed successfully Install the app Usage By default Trickster color and some android property regarding UI smoothness are applied. If you want to change additional settings then either use the app or go to /sdcard/trickster directory, you'll see at most four following configuration files, depending on kernel features: color.conf: color related tweak general.conf: generic tweaks like zipalign, sqlite, and screenstate optimization kern_general.conf: generic kernel tweaks like CPU speed, governor, IO scheduler and readahead buffer kern_specific.conf: specific kernel features like sound control, WIFI power, fast charge... Edit any above file to change the settings you want using app like ES Explorer, Root Explorer..., instructions included inside Settings are automatically applied when user saves any of these files Some changes require restarting your phone To check log to see if it works use "logcat|grep Trickster" from adb/terminal Reinstall boot service, Reset settings, Removal instructions If you install a new kernel that includes ramdisk (boot.img format like franco or leanKernel), you can either reinstall Trickster MOD, run "tricks install" from adb root shell or terminal, or apply this CWM zip from recovery. You can delete a configuration file, files, or entire /sdcard/trickster directory to reset to default settings for a file, files or all configuration respectively If you mess up and can't boot, say aggressive OC/UV , use this CWM zip to reset If you want to uninstall, use this CWM zip There are still a lot of things I wanna do, read the changelog, still If you want to report bug, please provide a detailed steps to reproduce the issues and logcat You can ask for new features or if you have any ideas to improve the GUI, please do tell Credits Google Our great kernel devs chainfire for SuperSU and su stericson for busybox ch33kybutt's for his brilliant idea on screen state optimizations grilledbacon for your beautiful icon Beta testers for your dedication in testing this nexus.prime for his unintallation script phone_user for init.d CWM zip Anyone I learnt from Disclaimer: This is provided with NO GUARANTY whatsoever. Use your common sense source : http://rootzwiki.com/index.php?/topic/30068-[APP]-Trickster-MOD-[2012-07-09]-[Kernel-Settings-and-Tweaks] Envoyé depuis mon Transformer TF101 avec Tapatalk Modifié 29 décembre 2012 par Billouetaudrey Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Yann Swano Posté(e) 29 décembre 2012 Share Posté(e) 29 décembre 2012 Hello, quelqu'un peut m'éclairer sur la fonction high performance du wifi ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 29 décembre 2012 Auteur Share Posté(e) 29 décembre 2012 Hello, quelqu'un peut m'éclairer sur la fonction high performance du wifi ? C'est pour pas réduire le débit tel en veille quand activer... Mais bouffe plus de batterie en veille de ce fait... Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Yann Swano Posté(e) 29 décembre 2012 Share Posté(e) 29 décembre 2012 Ok mais si on a activé "toujours actif en veille" dans les paramètres wifi, ça sert à quoi cette fonction de performance ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Billouetaudrey Posté(e) 30 décembre 2012 Auteur Share Posté(e) 30 décembre 2012 Ok mais si on a activé "toujours actif en veille" dans les paramètres wifi, ça sert à quoi cette fonction de performance ? Lol Actif en veille ne coupe pas le wifi Performance WIfi activer ne coupe pas le wifi et le laisse a puissance max en veille ( utile pour le streaming en veille ) Performance wifi desactiver ne coupe pas le wifi mais réduit la performance et donc le débit Envoyé depuis mon Transformer TF101 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
