JELLAXY
JELLAXY
introduction:
Bon comme vous le savez Maclaw est parti. heureusement une sacré Team c'est formée la Team JELLAXY.
Cette Rom est très belle très fluide et il se démène pour qu'on puisse avoir l'appareil photo et pourquoi pas bientôt une AOKP JB.
AOKP JB:
http://www.jellaxy.com/AOKP
La Rom:
CHANGELOG
CyanogenMod 10 *( nightly – 18/09/2012 ~ ?pm GMT+3 )
  • completely compiled from sources by 'erikcas'
  • Removed Google Apps
  • Compressed arsc to free space in /system. Now you can flash gapps without deleting anything.
  • Youtube reboots should be fixed
  • BLN working (not fully tested with 3'rd party apps. Just check...)
  • Trebuchet Autorotation fixed
  • Removed duplicate camera icon
  • CRT animation now working ( = no flicker when screen is turning off )
  • Removed some things to free some space ( Video editor, ROM Manager, some pico tts languages = ~175MB system size)
  • Added ad-hoc support
  • Fixed KSM
  • Enabled WebGL
  • Fixed IO scheduler selection
  • Fully enabled triple frame buffer
  • Lot’s of changes by CM
CyanogenMod 10 *( nightly – 15/09/2012 ~ ?pm GMT+3 )
Fixed KSM
Enabled WebGL
CyanogenMod 10 *( nightly – 12/09/2012 ~ 8m GMT+3 )
Fixed audio
CyanogenMod 10 *( nightly – 10/09/2012 ~ 8m GMT+3 )
Switched to new RIL class, which should fix “Unknown call”
CyanogenMod 10 *( nightly – 07/09/2012 ~ 6m GMT+3 )
Several optimalizations and cleanups by Marcin
Fixed camcorder (still laggy)
Fixed boot logo
Improved camera preview
Video should work in YouTube (If you have problem with app, use m.youtube.com)
Added modified amarullz script by default, so it’s recommended to have ext3/ext4 partition on sdcard
Using erikcas RIL class ( on Mini)
Compressed arsc to save ~15MB in /system. Now you can flash gapps (from 3rd post) without deleting anything.CyanogenMod 10 ( nightly – 02/09/2012 ~ 5m GMT+3 )
CyanogenMod 10 ( nightly – 31/08/2012 ~ 8pm GMT+3 )
Fixed ADB
Fixed UMS
Added sd-ext support
Added ipv6 support in the kernel
Re-enabled triple frame buffer
CyanogenMod 10 ( nightly – 30/08/2012 ~ 11pm GMT+3 )
UMS now enabled by default (adb should be fixed in next release)
Full OpenGL support
Video streaming should be fixed (if not, remove hwcomposer.msm7x27.so from /system/lib/hw/)
Added FileManager
CyanogenMod 10 ( nightly – 27/08/2012 ~ 11pm GMT+3 )
Partially fixed camera (can take pictures, video recording and panaroma in stock app will come later)
Added correct permissions for sdcard, so apps can access it.
Optimized boot animation performance
UMS should be working now. If it’s not:
try rebooting the device
Open terminal emulator; run this command “setprop persist.sys.usb.config mass_storage,adb” (without ” of course) and reboot
NOTE: I did some “experiments” in the kernel (long story short, increased graphics memory) so in this build we have only 269MB of accessible RAM. It’s also possible to reduce graphics memory to get more RAM, but I think that is not such a good idea.
CyanogenMod 10 ( nightly – 23/08/2012 ~ 5pm GMT+3 )
This is basically re-upload because of previous download problems
There are some changes but mainly for testing/experimenting/developing purposes
Screenshots:
p43trgm14zi02h18kknv.pngli9jlpya9iz6wpibukn.pngjr443bfqjg1bg8uezef.pngrtiay0tc5w8lpyvcz39.png
bon j'écris tout sa mais où est le lien?
http://www.jellaxy.c...soit 18.09.2012
Appareil Photo:
l'appareil photo d'origine ne fonctionne pas, vous devez télécharger "Camera illusion" et "vidéocam illusion" depuis le Play Store.
Gapps:
http://api.viglink.com/
BONUS:
Softkey: www.mediafire.com
Softkey off: www.mediafire.com
Script amarullz!(à flasher obligatoirement!): mediafire
Swap! (conseillez si vous savez ce que c'est!): xda-developers
Modifié par Diablo (madinina)
petite question: est ce que le tethering fonctionne avec la dernière version?
Pour ce qui est de l'appareil photo, j'avais testé une version du 08/09 (peut être de Maclaw ? je ne sais plus) mais l'application http://goo.gl/gNgQb voulait bien prendre des photos. Il me semble aussi que l'application http://goo.gl/fwY96 fonctionnait pour les vidéos, d'après un commentaire, mais je ne suis plus sûr..
Je l'essayerai dans la semaine.
pire que sa oui! (tu peux mettre le script de amarullz qui lie direct ta partition a la memoire interne! en gros ton tel affiche 1,5(ou +) Go de memoire interne!) du coup plus d'ennuies!!!
et justement je ne sais pas pour le tethering.. et d'ici 3semaine j'en aurait absolument besoins! donc test steplé et renvoi des retours!
Ah' tu me dit quelque chose d'interressant , il y aurait t'il un lien pour ce fameux script ? A ce que je comprend ma seconde partition de ma carde sd est liée au téléphone et la détecte belle et bien dans les gestionnaires ? :D
Pour le tethering usb, tu peux toujours uiliser http://code.google.com/p/android-wired-tether/ .Je l'utilise sur ma rom actuelle (la CM 7.2 Appocalypse, car le tethering usb ne fonctionne pas [il se désactive instantanément]). Elle fonctionne peut être avec la CM10, avec un peu de chance.
