[RECOVERY] TWRP 2.6.0.0
Salut !
J'ouvre ce petit topic qui recense les majs de notre recovery !
Version 2.3.3 Recommandée
Download :
http://www.teamw.in/project/twrp2/100
ou
http://techerrata.co...wse/twrp2/ville
Installation :
- flasher avec le android SDK dans platform-tools
- redémarrer en fastboot usb
- ouvrir la fenêtre de commande (shift + clic droit) et taper
fastboot flash recovery nomdevotrerecovery.img
ou utiliser mon tuto pour flasher facilement un recovery : http://forum.frandro...ery-facilement/
voila !
https://forum.frandroid.com/topic/152100-recovery-switcher-v1/ : recovery switcher (changer de recovery facilement)
http://forum.xda-dev...d.php?t=1677670
A+ :lol:
Modifié par FlyinGrub
  • 2 months later...
  • 1 month later...
Merci :)
CHANGELOG for 2.4.0.0:
-Using libtar instead of busybox's tar for better control over tar file creation and breaking the 2GB barrier that busybox imposes (thanks to bigbiff)
-Support for exFAT formatted sdcards (also thanks to bigbiff)
-Support for decrypting Samsung TouchWiz encrypted devices including internal and external storage (special thanks to a3955269 for figuring it out)
-Improvements to OpenRecoveryScript including displaying a proper GUI while the script is running
-Added wipe cache and dalvik after ADB Sideload
-Replaced many system calls with their native C counterparts
-Fixed bugs in file manager where it would display an empty list after moving or deleting a folder
-Fixed AOSP recovery commands to run after decryption on encrypted devices
-Improvements for building TWRP in CM10.1
-Other minor bugfixes and improvements
NOTE: 2.4.0.0 is, as always, still compatible with your older backups!
Modifié par monpseudo
2.4.1.0 dispo
CHANGELOG for 2.4.1.0:
-Fixed a problem with mkdosfs that formatted sdcards to 2GB
-Fixed handoff between vfat and exFAT on devices where blkid didn't detect vfat (fixes some issues with mounting sdcards)
-Fixed problems with changing working directory on MD5 creation/checking that may have prevented unmounting
-Backups will now store a copy of the backup log after the backup is completed (only if backup is successful)
  • 3 weeks later...
le One S est a mon bof, il a des problèmes avec: les gens l'appellent et au bout d'un moment ils ne l'entendent plu.
alors je l'ai trafiqué dans tous les sens, puis desimlocké pour le tester sur autre opérateur (là ça marchait)
puis lui avait toujours le soucis.
je lui ai fait changer de SIM, toujours pareil
j'ai changé de radio de ROM...etc... toujours pareil.
là il revient du s.a.v. où ils ont juste remis le ruu ICS (que j'avais fais avant de le renvoyer pfff), il a fait la mise a jour JB
et toujours pareil.
du coup il le prête a ma femme pour tester (et il marche nikel)
je lui ai mis ViperS et j'ai vu le topic S-OFF j'ai sauter sur l'occaz , là il est tout dévérouillé quoi
Modifié par superjey
