[ROM] Android Revolution HD 18.0 | High Quality & Performance | XXDME6 | Jelly Bean
Proudly presenting you...
A propos de cette ROM :
System details:
  • Android 4.1.2 (Jelly Bean) - latest official Samsung N7100XXDME6 firmware
  • This is improved version of stock ROM - no visual changes!
  • Very fast, clean & stable!
  • Full Samsung TouchWiz Interface
  • Multi-language (WWE)
  • For Samsung Galaxy Note 2 (N7100)
  • Thanks to Samsung for the base firmware
  • Video Review by ikylilboy
Comment flasher:
ROM details:
  • Removed software (CPU) rendering - full Exynos 4 Quad (GPU) rendering
  • Fully optimized and tweaked
  • Root access
  • Unsecured boot.img
  • Newest BusyBox
  • RAM optimizations
  • System signatures check enabled for system security and safety
  • Improved virtual memory management
  • Speed optimizations
  • Enabled GPU UI rendering
  • Data, cache and system partitions mounting tweaks
  • Bloatware applications removed
  • All /system applications updated to latest available
  • All /data applications updated to latest available
  • Improved CPU governors performance
  • Most optimal system scheduler
  • Disabled kernel debugging for better performance
  • Zipaligned (Improved RAM management)
  • Zipalign on boot (for user applications on data partition)
  • Fully de-odexed
  • init.d scripts (BusyBox run-parts) support
  • Auto init.d permissions set on boot
  • sysro/sysrw commands support
  • Excellent battery life!
  • Improved EXT4 performance
  • OpenVPN support
  • Most up-to-date system files permissions
  • Adobe Flash Player support
  • Support almost 24h a day
  • ...and many more!
Included kernel details:
  • Stock kernel (the most stable)
System details:
  • Téléchargez la ROM et placez la dans votre carte mémoire externe
  • Téléchargez "Super Wipe" et placez le dans votre SD card (optionnel si vous êtes déjà sous Android Revolution, obligatoire si vous venez d'un firmware Stock ou d'une autre Rom)
  • Allumez votre téléphone en mode recovery (vol up + home + power)
  • Dans le menu, selectionnez "install zip from sdcard"
  • Selectionnez "choose zip from sdcard" et allez là ou vous avez mis "Super Wipe" script
  • Ensuite recommencez "choose zip from sdcard" et allez là ous vous avez mis Android Revolution ROM
  • Après le Flash, redémarrez
--- release date: 26 June 2013 ---
  • Based on latest official Samsung N7100XXDME6 firmware
  • Re-designed and updated AROMA installer
  • Zipaligned using SDK r22
  • Other minor changes and fixes
  • Included and updated components:
    --- Data partition ---
    Adobe Flash Player 11.1.115.58 (For Android 4.0+)
    Adobe Flash Player 11.1.111.50 (For Android 2.0+)
    Adobe Reader 10.6.0
    Dropbox 2.3.8
    ES File Explorer 3.0.4
    Facebook 3.3
    Maxthon 4.0.4.1000
    Twitter 4.1.1
    --- System partition ---
    Google Play 4.1.10
    Gmail 4.5 (For Android 4.1+)
    Gmail 2.3.6 (For Android 2.3.5)
    GmsCore 3.1.36
    SuperUser 1.0.1.8
    SuperSU 1.30 (Only Samsung devices)
    --- Aroma installer ---
    Google Hangouts 1.0.2.695251
    Google Maps 6.14.4
    Google Plus 4.0.1.47928040
    Google Street 1.8.1.1
    Google YouTube 4.5.17
    Google TalkBack 3.3.1
    Google Chrome 27.0.1453.90
    Google Music 5.0.1052J.707098
    Google Keep 1.0.79
    Google Search 2.5.8.675703 (For Android 4.1+)
    Google Search 1.4.1.338691 (For Android 4.0.3)
    Google Search 1.1.2.64376 (For Android 2.3.5)
    --- MD5 Checksum: F6A836363C555CFD3C7EB0542D1F01D6 ---
    http://android-revolution-hd.blogspot.com/p/android-revolution-hd-mirror-site-var.html
Un merci ne coûte rien !
Modifié par alienex
Bonjour je suis nouveau dans le monde android et oui j'avais un iphone 4 avant.
Je possède un galaxy note 2 et je me pose différentes questions sur le flash de mon joujou.
J'ai bien regardé les faqs pour connaître les différents termes utilisés (rom, flash, rom custom etc. ), mais je suis tout de même perdu.
je suis interréssé par la rom android revolution HD puisqu' elle semble optimiser le proc, la ram et elle paraît stable.
- Je voudrais savoir si je cours un risque en l'installant, j'ai entendu parler de "bricks".
- Qu'est ce que" custom recovery" ? J'en ai apparemment besoin pour flasher le téléphone. j'ai regardé sur le net je ne trouve pas de reelles réponses,.
merci
Salut, je suis dessus depuis que j'ai mon Gnote 2 et je dois dire qu'il est hyper stable. J'ai envie de changer juste pour comparer comme je n'ai pour l'instant connu que ça mais c'est une très bonne base. Aucun soucis avec. Concernant le recovery, pour moi c'est comme le bios sur le pc. C'est un menu administrateur avancé où t'as le contrôle total de ton phone. Tu peux tout modifié et tout sauvegardé par exemple.
Envoyé depuis mon GT-N7100 avec Tapatalk
Pour l'installation de cette rom as-tu suivi la methode indiquée ?
Il ne parle pas de custom recovery pour l'install, c'est pour cela que je suis un peu perdu.
-Si c'est une sorte de bios cela veut-il dire que je l'ai nativement sur mon GN2?
-Le custom recovery c'est ce qui permet d'etre en mode recovery?
j'ai trouvé ça sur un autre forum et ils n'en parlent pas ici:
From the path “Settings > Applications > Development > USB debugging”, enable the USB Debugging, ensure that the USB debugging option is ticked. Additionally, disable / uninstall all the security suites as these tools may interrupt the process of firmware update process.
Modifié par yanoubts
J'ai d'abord rooter le mien dès l'achat et ensuite installé le custom recovery que j'ai pris dans le sujet d'une autre rom avec Odin pc ! Effectivement il y a un recovery d'origine et le custom qui est une version modifiée. Moi j'avais une sauvegarde de mes applications et réglages de mon Gnote 1 donc j'ai installé la rom et tout récupéré avec Titanium Back Up. Certaines procédures de root t'installe aussi le custom recovery. T'as suivi quel tuto pour ton root ?
Salut pour l'instant je n'ai pas rooté le tel, car j'ignorais qu'il fallait le faire!
Je déménage cette semaine, donc pas d'internet jusqu'à ce que mon FAI me recâble la liaison. Je vais donc attendre d'avoir ma ligne et surtout avoir tous les renseignements pour être sur de ne pas faire de con.... :emo_im_lips_are_sealed:
Merci encore pour les réponses :)
Possesseur d'un GN2 depuis 2 heures j'ai hâte de pouvoir installer cette ROM, mais en tan qu'ancien utilisteur d'HTC DHD je m'y perd un peu.
Si je comprend bien maintenant le compteur de flash est plus "chiant" mais on peut le remettre à 0.
Ma question est de savoir si la manip pour installer cette ROM permet également de passer en mode ROOT et ainsi pourvoir avoir les accès ROOT des applis et si cette manip permet auss de faire des BackUp via le recovery ???
Merci pour vos réponses.
  • 3 weeks later...
J'ai un petit problème avec le wifi ! en effet j'ai l'impression que les apps installé n'arrive pas a détecter ma connexion wifi
exemple teamviewer fonctionne en 3g mais pas en wifi ( connexion impossible direct )
application mail fonctionne en 3g mais connexion impossible en wifi...
je suis bien connecté a internet , google chrome fonctionne etc...
quelqu'un a t'il rencontré ce problème ?
merci
