Alienex Posté(e) 3 novembre 2012 Share Posté(e) 3 novembre 2012 (modifié) || || INSTRUCTIONS, 1. UPDATE RECOVERY 2. FACTORY RESET 3. INSTALL ROM, GAPPS 4. WIPE CACHE & DALVIK CACHE 5. REBOOT PA 3+ UPDATES DO NOT NEED A FACTORY RESET, BUT YOU NEED TO INSTALL GAPPS ASWELL. ParanoidAndroid ROM 3 Review, Tips and Complete Walkthrough: Droidviews ReviewCREDITS, AOSP/Google, Cyanogenmod, Goo, XDA, Krebsmilk, giannisgx89, imilka, beerbong, Liquid, AOKP, our users, supporters and donators, everyone who's helped us in the past, heartfelt thanks to all of you! DONATIONS, to molesarecoming to D4rKn3sSyS to jaybob413 to aaronpoweruser BANNERS Bug List Bluetooth car connection can cause crashes (only certain models) Please post logcat for me and Tilak to look at this issues. FM Radio: unsupported. Use Spirit FM Radio from Play Store instead TV Out: unsupported, will never work (proprietary, undocumented) No exFAT support (proprietary, Microsoft) Change Log 10.06.2013 PA & CM latest sources Halo built from source Reverted back to musicfx.apk Tested compiling using 03 and linaro routines in PA build script 09.06.2013 PA & CM latest sources 04.06.2013 - Tilak spent time porting halo. Say thanks to him! PA & CM 4th June Sources HALO -10 featured ported from the nexus 4 ROM. HALO feature fully working WiFi tethering issue fixed 03.06.2013 PA & CM latest sources Removed DSP manager and testing AOSP equaliser instead. Post results please. Added latest N7100 PA-GAPPS Still really 3.15. Halo should be coming soon. Sources have been released to carbonrom devs to beta test. Once all merge conflicts are sorted it will be pushed to jellybean-legacy.Cannot wait! :D 25.05.2013 PA & CM latest sources Revert modified hosts file Added latest N7100 PA-GAPPS 20.05.2013 PA & CM latest sources Version number says 3.55 but its really still 3.15 added new N7100 specific PA-GAPPS No Halo!! sources not available yet Goo OTA updates (not tested yet) MD5=ED6A4447B883FED2BB724609456EA92B 10.05.2013 PA & CM latest sources Version number says 3.5 but its really still 3.15 Removal of CM phone.apk as we want AOSP not CM Removal of example video to save space added N7100 specific PA-GAPPS so camera does not get wiped. 03.05.2013 Fix camera touch focus lockup\crash Included later phone app (bluetooth fix thanks Tilak. Untested by me may need further tweaking) Bluetooth driver update PA & CM latest sources Dalvik and further performance modifications (experimental) 22.04.2013 Updated Cm10.1 and PA Sources to latest Looking into GPS and bluetooth car issues (no changes yet) 22.04.2013 Updated Cm10.1 and PA Sources to latest Audio Cleanup and Dock Enabled (thanks to Victoratorfor taking the time to merge the commits. Volume boost removal (the distortion is just too much) Added CM notifications and ringtones 17.04.2013 Updated Cm10.1 and PA Sources to latest Wifi Powersave modifications Deep Sleep modification Volume boosts (still experimenting to find gold threshold between loudness and distortion) 12.04.2013 Nothing really to fix or change as the rom works perfect. So this is a minor update while we wait for new PA with Pie2 Updated Cm10.1 and PA Sources to latest 05.04.2013 Updated Cm10.1 and PA Sources to latest Clean PA build 02.04.2013 NFC Fix Updated Cm10.1 and PA Sources to latest SIO Scheduler added (thanks Daniel Hillenbrand) Clean PA build 28.03.2013 Wifi Fixed in default kernel Full default working CLEAN kernel at last!!! Compiled from latest sources (CM10.1 and PA) New Paprefs, Hybrid Toggles,Popup, Removal of Aroma installer no longer needed. We are running clean PA3+ New Paprefs,Popup, Compiled from latest sources Aroma fine tuning 23.03.2013-Be_Vigilant Updated to PA 3.15 Compiled from latest sources RedPill added as an option in Aroma 22.03.2013-Be_Vigilant Compiled from latest sources Added advanced aroma installer 19.03.2013-victorator Fresh compile from today's sources (16:20 CET) Still NEAK kernel until wifi works with default kernel Updated ParanoidPreferences.apk (I don't know what's changed) 15.03.2013 Built from updated sources Fixed the occasional bootloop thanks to apascual89 14.03.2013 Built from updated sources Added 2 versions. 1 with default kernel in which wifi doesnt work. But you can chose to flash your own 3rd party kernel. 2. With N.E.A.K 1.7 included Fixed the mouse pointer cursor when using S-Pen 11.03.2013 Fixed audio recording errors Updated to 12.03.2012 sources Every kernel I build still has wifi that will not turn on. I am still learning about compiling roms from source and kind of stuck here. If anyone can gtalk me or PM me with some advice that would be great. As for now still having to package in the N.E.A.K kernel. So many thanks to Simone201 Download Links N7100 PA Google Apps Google Drive Mirror pa_n7100-3.60-10JUN2013 Google Drive Mirror Source : http://forum.xda-dev...d.php?t=2182259 Maintenant j'ai un galaxy S4 donc, je ne suis plus le fil de discussion du Note 2 si il y as des Maj signalez moi par MP et je mettrai le topic à jour. Modifié 14 juin 2013 par alienex Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Claymore Posté(e) 3 novembre 2012 Share Posté(e) 3 novembre 2012 niveau perf elle aporte quoi en plus ? et en ce qui concerne miui <<Ma rom favorite>> des nouvelles ? svp ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 3 novembre 2012 Share Posté(e) 3 novembre 2012 Cette ROM est basée sur CyanogenMod 10, elle est débarassée de touchwizz et niveau perf il y a pas mieux. CM est basé sur du pur AOSP et optimisé par la suite, beaucoup de tweak et personnalisation sont intégré en natif, elle est déodex pour flasher les personnalisations ou mod dont tu as envie. J'ai tourner dessus assez longtemps sur mon Nexus, et niveau personnalisation c'est la plus poussée. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jdosson Posté(e) 3 novembre 2012 Share Posté(e) 3 novembre 2012 (modifié) Si y avait touchWizz je l'aurais installé! Je l'avais sur mon O2x et c'était ultra confortable! La taille des apps icônes (etc.) de base sont trop grosse pour un écran aussi grand ça prend trop de place pour rien alors qu'avec cette rom... On redécouvre l'utilisation d'un grand écran! Edit: PAs de touchwizz= Pas de S pen(et tout ce qui va avec)? Modifié 3 novembre 2012 par jdosson Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 3 novembre 2012 Share Posté(e) 3 novembre 2012 Non rien pure AOSP, ca viendra peut etre un jour. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
djadja Posté(e) 3 novembre 2012 Share Posté(e) 3 novembre 2012 (modifié) Ces le manque de ces applications. Qui nous enleve. utilité. Du stylet. Car les roms panaroid sont super fluide ces dommage. On attend. Avec impatience. Que les gars xda nous font une super rom avec toute les applications. Le mode tablette la fluidité. Des roms stunner. Panaroid Modifié 3 novembre 2012 par djadja Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
warrior Posté(e) 3 novembre 2012 Share Posté(e) 3 novembre 2012 Arreter un peut. La rom sammy avec touchwizz est hyper stable et fluide..... Envoyé depuis mon GT-N7100 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
V47 Posté(e) 3 novembre 2012 Share Posté(e) 3 novembre 2012 C'est sur, pour les gens qui veulent une bonne ROM avec tout les avantages de Sammy, foncez sur HyperNote v0.4 :) 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
carmelo42 Posté(e) 4 novembre 2012 Share Posté(e) 4 novembre 2012 La rom Sammy ? Qu'est ce que c'est ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KanaCatz Posté(e) 4 novembre 2012 Share Posté(e) 4 novembre 2012 Sammy = Samsung ;-) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 4 novembre 2012 Share Posté(e) 4 novembre 2012 Petite remarque, dans le titre il y a rom aokp: paranoid n'est pas basée sur aokp mais CM. Ensuite dans le premier post il y a marqué qu'elle est basée sur pure Android aokp: c'est pure Android aosp, qui veut dire Android open source project. AOKP est une rom custom basée sur aosp, et elle signifie Android open kang project. Juste pour dire, pour que personne ne se trompe. depuis mon Nexus Prime Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alienex Posté(e) 4 novembre 2012 Auteur Share Posté(e) 4 novembre 2012 (modifié) Paranoid est bien une AOKP (verifie sur leur page XDA à credit), cynogenmod est une AOSP AOKP : Android Open Kang Project Basée sur le code de l'AOSP, l'AOKP intègre des fonctionnalités jugés manquantes par certains développeurs. on y retrouve les MIUI notamment qui sont assez légère et très épurée façon Iphone un peu. AOSP : Android Open Source Project C'est la version d'android développée par son créateur google avec les fonctionnalités qui lui sont propres Modifié 4 novembre 2012 par Alienex Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 5 novembre 2012 Share Posté(e) 5 novembre 2012 THIS ROM IS BASED ON EXPERIMENTAL CM10 BRANCH extrait du thread dispo sur XDA Paranoid est sur base CM (cyanogenmod) et pas AOKP (android open kang project). CM et AOKP sont des rom différentes toute deux basées sur AOSP AOSP est la base google, les rom custom comme CM, AOKP ou ARHD prennent pour base l'AOSP et ajoute leur modif. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sinji Posté(e) 5 novembre 2012 Share Posté(e) 5 novembre 2012 Elle est enorme cette rom. La rom tw est très bonne mais l'affichage est grossié... un vrai telephone de malvoyant. Je l'utilise depuis 3 jrs. Aucun fc reboot ou autre bug. Tt fonctionne pour moi( photo, video...) Duré de vie la baterie est au moin aussi bonne. Et bon sang que c'est bien fait les parametre paranoid. Incroyable que ce soit aussi parfait une cm10 après un petit moi d'existance du note 2. :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alienex Posté(e) 5 novembre 2012 Auteur Share Posté(e) 5 novembre 2012 (modifié) THIS ROM IS BASED ON EXPERIMENTAL CM10 BRANCH extrait du thread dispo sur XDA Paranoid est sur base CM (cyanogenmod) et pas AOKP (android open kang project). CM et AOKP sont des rom différentes toute deux basées sur AOSP AOSP est la base google, les rom custom comme CM, AOKP ou ARHD prennent pour base l'AOSP et ajoute leur modif. Alors ce sera AOSP Elle est enorme cette rom. La rom tw est très bonne mais l'affichage est grossié... un vrai telephone de malvoyant. Je l'utilise depuis 3 jrs. Aucun fc reboot ou autre bug. Tt fonctionne pour moi( photo, video...) Duré de vie la baterie est au moin aussi bonne. Et bon sang que c'est bien fait les parametre paranoid. Incroyable que ce soit aussi parfait une cm10 après un petit moi d'existance du note 2. :) J'hésite à la mettre, j'avais ça sur mon note 1 (d'ailleurs mon frere tourne toujours dessus), mais comme samsung a fait de très gros éffort sur TouchWizz je pense que je vais rester sur une Omega en ésperant qu'ils arriveronts à modifier le Framework de TouchWizz afin d'ajouter les options de PA Modifié 5 novembre 2012 par Alienex 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sinji Posté(e) 5 novembre 2012 Share Posté(e) 5 novembre 2012 Bakup instal test. Restaure le back up. La dernière etape est moin sur.;) J'ai procédé comme suit mais j'ai pas restauré. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
carmelo42 Posté(e) 8 novembre 2012 Share Posté(e) 8 novembre 2012 Ah d'accord ;-) Merci ! Envoyé depuis mon Nexus 7 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alienex Posté(e) 9 novembre 2012 Auteur Share Posté(e) 9 novembre 2012 Sinon tu telecharge titanium backup tu fais une sauvergardes des données utilisateur (pas les données systeme) et ensuite tu fais ton backup depuis titanium backup. Je fonctionne comme ca depuis mon tout premier telephone android (Nexus one :wub:) et il y en as eu plein dautre après. Ca marche à tous les coups Envoyé depuis mon doux GT-N7100 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sinji Posté(e) 10 novembre 2012 Share Posté(e) 10 novembre 2012 (modifié) A suprimer Modifié 13 novembre 2012 par sinji Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
xalulama Posté(e) 23 novembre 2012 Share Posté(e) 23 novembre 2012 bonsoir pour ceux qui vont trainer sur le post de la rom sur xda vous verrez qu'ils y proposent des applications pour compenser l'absence des apllis liées au s-pen. voila bonne soirée a tout le monde 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
xalulama Posté(e) 24 novembre 2012 Share Posté(e) 24 novembre 2012 bonjour a tout le monde ce matin sur xda mise a jour dispo http://forum.xda-developers.com/showthread.php?t=1970335 voila bon flash a tout le monde a plus Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sinji Posté(e) 25 novembre 2012 Share Posté(e) 25 novembre 2012 vraiment une tuerie cette rom.. a essayé au moin une fois;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alienex Posté(e) 26 novembre 2012 Auteur Share Posté(e) 26 novembre 2012 bonjour a tout le monde ce matin sur xda mise a jour dispo http://forum.xda-dev...d.php?t=1970335 voila bon flash a tout le monde a plus Ce n'est pas la même version faite par Imilka de Paranoid Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
-iNSiGhT- Posté(e) 15 décembre 2012 Share Posté(e) 15 décembre 2012 Note 2 acheté hier (marre d'attendre l'arlésienne Nexus4), je vais rempiler vite fait pour cette Paranoid!!! THE ROM! Et d'autant plis sur le 5,5"... la ROM stock n'est pas mauvaise,loin de là, mais quand on est habitué a l'AOSP, c'est dur TW... Envoyé depuis mon GT-N7100 avec Tapatalk 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
-iNSiGhT- Posté(e) 16 décembre 2012 Share Posté(e) 16 décembre 2012 ParanoidAndroid installée hier ! Et c'est toujours un plaisir d'utiliser cette ROM !! Parce que Gmail, les navigateurs etc en mode téléphone, ça fait juste "téléphone pour mal-voyant" pour reprendre une expression lue plus haut... Et c'est hyper fluide !! Et dire qu'ils n'ont pas les sources Exynos... Envoyé depuis mon GT-N7100 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
