barbac666 Posté(e) 16 novembre 2012 Share Posté(e) 16 novembre 2012 (modifié) Source et download: http://forum.xda-dev...d.php?t=1995801 Fake Call: "No panic"- Fake/Spoof Incoming Calls at your will.- Due to being coded at system level, fake calls are basically identical to real ones.- You can choose from who, delays, pic, ringtone and much more.- Uses own QuickToggle to trigger the timer to start the incoming fake call.- More features and details here.Smart3G: "Gimme moar juice!"- Automatically manage your 2g/2g3g connection:- It auto switch to 2g when 3g is not needed and switches back when needed.- When 3G is "needed" you can also choose to switch to 2G on screen OFF and back on Screen ON.- Now it automatically switch on Low Battery and when charging aswell.- Optional Force 3G Only network mode.- More features and details here.InCall Blocker: "This is a phone afterall..."- You can silently block incoming calls for:- ALL- RESTRICTED- UNKNOWN- NON CONTACT- ALL CONTACT- SINGLE CONTACT- You can choose Pickup/Hangup mode instead of normal Reject.- Blocked Calls appear in Call Log.- White list mode.- Optional StatusBar Icon, Notification and associated QuickToggle.- AutoHide your phone number to Non Contacts.- More details here.PowerKey while screen off chooser: "For the light!"- Longpressing the Power Button while screen is off will trigger one of the following features.- Default / Torch / FakeCall / SilentRecorder.- You can either longpress again to turn them off or just turn on the screen.- The chooser is enabled only with the included kernel.Quick Toggles ™: "The original ones..."- You can enable/disable/resize/rearrange any toggles, including system and temp ones;- You can remove text labels and enable haptic feedback;- Pull Quick Toggles with just one finger if no ongoing or no clearable notifications. Wifi : onclick ON/OFF ; onLongclick wifi settings; Bluetooth: onclick ON/OFF ; onLongclick bluetooth settings; Mobile Data: onclick ON/OFF ; onLongclick data usage; 2G3G: onclick 2G/2G3G ; onLongclick Smart3G settings; Optional Force 3G Only network mode; Screen Suspend: onclick alwaysON/OFF ; onLongclick display settings; GPS: onclick ON/OFF ; onLongclick location settings; NFC: onclick ON/OFF ; onLongclick nfc settings; Hot Reboot: onLongClick Hot reboot; (requires SystemUI as root) Sync: onclick ON/OFF ; onLongclick sync settings; Wifi Hotspot: onclick ON/OFF ; onLongclick Tethering settings; Built-in Torch: onclick ON/OFF ; onLongclick Brightness popup; Rotation Lock; onclick Locked/Unlocked; onLongclick force Landscape/Portrait; Force USB Fast Charge; ADB over Wi-Fi: onclick ON/OFF ; onLongclick developer options; (requires SystemUI as root) Ringer Mode: Silent/Normal/Vibrate; Screenshot: onclick Collapse + Screenshot; onLongclick Screenshot; InCall Blocker: onclick goes through all the blocking modes; onLongclick InCall Blocker settings; Fake Call: onclick trigger the timer ON/OFF to start the Fake Call; onLongclick Fake Call settings; Hide NavBar: onclick Hide/Unhide the Navigation Bar; USB Tethering: onclick ON/OFF ; onLongclick Tethering settings;- System Monitor - Cpu speed/temp - Battery temp;- Network Speed Monitor;More Features:- Power Key shutter and Volume Keys zoom for Google Camera- Softkeys Fade Mod- Custom Lockscreen Wallpaper (normal/dimmed)- % Textbattery + Icon / Text Only / Circle battery / Hide- Nfc polling mode (S-On Locked/S-On Unlocked/S-Off). Disable Nfc sounds (vibrate instead)- Expandable Volume Overlay + unlink notification volume- Remember Volume levels when plugging Headset and auto-adjust them- Navigation Bar resizable (portrait/landscape or portrait only)- Full screen caller - consistent Answer with SMS- Custom Lockscreen Targets- Clear all recents and Sleep Button (longpress for PowerMenu)- Speaker volume boost- Keyboard customization (size and rows) (QWERTY only)- Sim Toolkit (Stk) Compatible- Volume Rocker Wake- Volume Rocker Music Control- Volume Rocker Cursor Control- Longpress Back to kill foreground app- T9 Dialer + Landscape + optional vibration on remote call connect/disconnect- Mms with Unicode support - Inverted version available- Quick PIN Unlock- Led notification support for missed calls- Extended Power Menu- Expanded Desktop Mode with and without StatusBar- onclick and onLongClick actions to StatusBar Clock/Date- H+ UI Support- Rom settings backup support- 3G Only network mode- Go Home after a phone call- Forces phone to sleep after a missed call- Allow only one lockscreen widget to avoid bars/plus/swipe- National data roaming only- Center statusbar clock- Longpress recents go to last task- One click default app picker- Hide incoming sms/mms text subject/body on statusbar notification- Start lockscreen widgets maximized- Disable lockscreen camera- Disable proximity sensor in call- Disable Safe Headset volume warning- Disable StatusBar clock- Disable beep on volume adjust- Disable Ime Switcher- Disable USB Debugging notifications- Disable GoogleNow swipe gesture- Deodex / init.d support / adb root- Custom 4.2.2 Kernel:- Stock kernel with some useful features, aimed to be stable.- No SoD or reboots with this one. Source GIT.- Color Control (Ezekeel)- Sound Control (Ezekeel)- Fsync Control (Ezekeel)- Optional WiFi PM Fast- Row i/o sched (Qualcomm)- Fast Charge (Chad Froebel) Toggle / Widget- Voltage Control (Michael Huang)- Slightly overclocked GPU- CIFS- Compatible with Trickster MOD and PGMFULL WIPE EST PREFERABLE Modifié 25 août 2013 par bArbAc™ 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Reloop59520 Posté(e) 16 novembre 2012 Share Posté(e) 16 novembre 2012 j 'hesite a installer mais envie de passer en 4.2 pour tester la rapidité, j' attends les retours, bon test sinon a tous Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
trokpa Posté(e) 17 novembre 2012 Share Posté(e) 17 novembre 2012 Allez j'y vais. Jai que ça à faire. :) Envoyé depuis mon Galaxy Nexus avec Tapatalk Téléchargement effectué. Souhaitez moi bonne chance :) Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jrb95 Posté(e) 17 novembre 2012 Share Posté(e) 17 novembre 2012 (modifié) Pour l'instant, je n'ai rien constaté de différent, sauf la navbar qui se cache sans libérer d'espace écran, et le pourcentage de batterie dans la statubar. Modifié 17 novembre 2012 par jrb95 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
trokpa Posté(e) 17 novembre 2012 Share Posté(e) 17 novembre 2012 Pas mal. Stable, fluide, économe. Seul hic la navbar disparait OK mais quand on la sollicite et que l'on a besoin du bouton Menu il n'est pas là. Il faut fermer lappli et revenir via multitâche pour le récupérer. Pour le reste pas mal sauf les raccourcis dans la barre de notif dont je ne comprends pas l'intérêt avec 4.2. Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AirOne70 Posté(e) 17 novembre 2012 Share Posté(e) 17 novembre 2012 Le 17/11/2012 à 20:22, trokpa a dit : sauf les raccourcis dans la barre de notif dont je ne comprends pas l'intérêt avec 4.2. C'est expliqué dans la liste des features. Elle est présente en attendant une gestion des Quick Settings (Lorsqu'on pourra personnaliser les Quick Settings). Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
trokpa Posté(e) 17 novembre 2012 Share Posté(e) 17 novembre 2012 Non mais ça jai compris. C'est juste que certains font doublons. C'est ça que je ne comprends pas. Mais c'est pas grand chose. Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AirOne70 Posté(e) 17 novembre 2012 Share Posté(e) 17 novembre 2012 Il n'a pas voulu ce compliquer la vie et a tous mis.. Vous avez des lag avec le Lockscreen ? (Il ne se verrouille pas au moment même où on appuie sur le bouton Power, et pareil dans l'autre sens (ne se réveille pas aussitôt)) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
trokpa Posté(e) 17 novembre 2012 Share Posté(e) 17 novembre 2012 Pas de soucis pour moi à ce niveau là. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AirOne70 Posté(e) 18 novembre 2012 Share Posté(e) 18 novembre 2012 (modifié) Les Quick Settings commencent à être gérés ! La case Utilisateur sera prochainement retirée. Modifié 18 novembre 2012 par AirOne70 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
patou75 Posté(e) 18 novembre 2012 Share Posté(e) 18 novembre 2012 Honnêtement je préférais comme avant moi, même si ça prend 0.5 seconde de temps en plus , le fait d'aller dans le centre de notification puis appuyer sur le bouton quick setting c'est chiant Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AirOne70 Posté(e) 18 novembre 2012 Share Posté(e) 18 novembre 2012 (modifié) Il faut s'y faire.. Il n'y a qu'un appui à faire en plus, il te permet de laisser la place aux notifications et tu as d'avantages d'infos avec les Quick Settings. (Le raccourci avec les 2 doigts n'est pas pratique du tout je trouve, c'est juste là pour montrer qu'ils y ont pensés.) Modifié 18 novembre 2012 par AirOne70 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
patou75 Posté(e) 18 novembre 2012 Share Posté(e) 18 novembre 2012 Le 18/11/2012 à 20:50, AirOne70 a dit : Il faut s'y faire.. Il n'y a qu'un appui à faire en plus, il te permet de laisser la place aux notifications et tu as d'avantages d'infos avec les Quick Settings.(Le raccourci avec les 2 doigts n'est pas pratique du tout je trouve, c'est juste là pour montrer qu'ils y ont pensés.) +1 pour les 2 doigts ! Ça serait cool dans les temps à venir que CM AOKP etc ajoutent une feature permettant d'accéder directement au panel par exemple lorsqu'on slide vers le bas la status bar à gauche/centre/droite Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
napster_666 Posté(e) 18 novembre 2012 Share Posté(e) 18 novembre 2012 Sur la N7 si on glisse la barre en partant de la gauche on a la barre de notif normal et si on pars de la droite la nouvelle. Il aurais du faire pareil pour le nexus Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
trokpa Posté(e) 18 novembre 2012 Share Posté(e) 18 novembre 2012 Le 18/11/2012 à 21:10, NaP-KiLLeR a dit : Sur la N7 si on glisse la barre en partant de la gauche on a la barre de notif normal et si on pars de la droite la nouvelle.Il aurais du faire pareil pour le nexus Exact. J'adore cette fonction Envoyé depuis mon Nexus 7 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 19 novembre 2012 Auteur Share Posté(e) 19 novembre 2012 Bon petit retour, la meilleur ROM en 4.2 pour l'instant. Fluide, rapide, quick setting personnalisé, pourcentage batterie, etc......... Le dev met a jour régulièrement, bref je reste dessus en attendant CM, bon après si elle évolue toujours dans ce sens pourquoi pas rester dessus..... depuis mon Nexus Prime Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Reloop59520 Posté(e) 19 novembre 2012 Share Posté(e) 19 novembre 2012 une petite question, est ce qu' il y a photosphere avec cette rom ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 19 novembre 2012 Auteur Share Posté(e) 19 novembre 2012 Le 19/11/2012 à 20:13, Reloop59520 a dit : une petite question, est ce qu' il y a photosphere avec cette rom ? Oui bien sur..... depuis mon Nexus Prime Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 19 novembre 2012 Share Posté(e) 19 novembre 2012 Bon je vais tester celle la... mais j'espère que ça va pas me redoutée le merdier sur la sdcard... ou du moins une fois installé, quelqu'un sait ou il faut mettre ses anciens backups pour qu'ils soient vu par CWM?! Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AirOne70 Posté(e) 19 novembre 2012 Share Posté(e) 19 novembre 2012 Le 19/11/2012 à 19:49, BARBAC a dit : Bon petit retour, la meilleur ROM en 4.2 pour l'instant.Fluide, rapide, quick setting personnalisé, pourcentage batterie, etc......... Le dev met a jour régulièrement, bref je reste dessus en attendant CM, bon après si elle évolue toujours dans ce sens pourquoi pas rester dessus..... depuis mon Nexus Prime Tu as essayé la FNV ? Envoyé depuis mon Galaxy Nexus. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 19 novembre 2012 Auteur Share Posté(e) 19 novembre 2012 Oui, j'ai pas accroché. depuis mon Nexus Prime Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 19 novembre 2012 Share Posté(e) 19 novembre 2012 Ahah... justement c'est finalement celle que je m'apprête de flasher... Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 20 novembre 2012 Share Posté(e) 20 novembre 2012 Bon pas si mal cette catalism mais un truc bizarre : la barre de nav'. Ça vous fait ça aussi ? Envoyé depuis mon Galaxy Nexus avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
barbac666 Posté(e) 20 novembre 2012 Auteur Share Posté(e) 20 novembre 2012 Le 20/11/2012 à 00:29, Emic37 a dit : Bon pas si mal cette catalism mais un truc bizarre : la barre de nav'. Ça vous fait ça aussi ? Envoyé depuis mon Galaxy Nexus avec Tapatalk Oui c'est nickel. Idée du dev que je trouve génial. Comme sur les galaxy S, quand tu utilise pas les boutons ils s'éteignent depuis mon Nexus Prime Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Reloop59520 Posté(e) 20 novembre 2012 Share Posté(e) 20 novembre 2012 je me lance ce soir, est ce qu' un kernel specifique est necessaire ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
