[16-FEB] Simplistic Framework V3.5.1 *Want More? You got it!*{LL4/7, MA5/6/7, MB2}
Introduction:
Si vous voulez l'application de contrôle faite un don ici vous la receverez par mail:
Donate to get the donation version!
Les modifs du mod :
  • General UI Customizations
  • Full integration with my MultiWindow Complete Control App/Other MultiWindow Hacks
  • Lockscreen options
  • Touchwiz Launcher Customizations
  • Customize Power Menu
  • General Status Bar Customizations
  • Status Bar Clock Options
  • Status Bar Battery Options
  • My fully customizable 27 toggles coded from scratch.
  • Control Hardware Keys
  • A LOT more options and new features!
- General UI:
  • Home button double click disable
    This will make it very fast
  • Long press back to kill enable/disable, with a toggle to jump between MultiWindow or Killing Process
  • Choose app to launch on home double click
  • Home double button delay control
    To make the home button fast, but keep double click!
  • Battery Full Notification and Screen WakeUp Enable/Disable
  • Holding Volume Keys on Screen Off skips song/FM station
- Full integration with MWC app, and a shotcut if it's installed
- TouchWiz Launcher
  • Enable/Disable Page Indicators on Homescreen and AppList.
  • Enable/Disable Wallpaper Scrolling
- Lockscreen
  • Original JellyBean Lock Enable/Disable
  • My own implementation of Ink Effect without the SPen (Enabled by default)[Thanks for criskelo for the inspiration]
  • Holding home button on lockscreen will activate fast torch!
  • Delay of the fast torch on the lockscreen
  • Ink Effect with ANY Color of your choosing, no predefined colors or anything, you choose which color you want through a color picker.
- Power Menu
  • Added recovery and download mode reboot buttons
  • Control the items in the power menu, add/remove anything from the power menu!
  • Screenshot, Negative colors toggles added!
- General Status Bar
  • Ability to turn off the "No Notifications" text.
  • Fully Black Status Bar by Default
  • Brightness Bar at Notification Panel Enable/Disable
  • Status Bar Color and Transparency Control in Homescreen
    Choose ANY color and any transparency level for the statusbar!
  • Enable transparency on water lockscreen.
    Color will be applied to all lockscreens, this will make transparency also apply for water lockscreen
  • Next alarm on StatusBar
  • Enable/Disable sound/alarm/bluetooth/blocking mode icons.
- Phone Application
  • Call Recording, Increasing Ringtone, Change delay after call hang up.
- Status Bar Clock
  • 12H/24H Clock
  • Center Clock/ Right Clock/ No clock
  • Add AM/PM to the clock
  • Add small weekday to the clock
  • Clock color
  • Enable/Disable Clock leading zero
- Status Bar Battery
  • Custom Battery!! Read more in the 3rd post!
  • Choose Battery between Samsung, green circle battery, lucid battery, text battery, aosp battery, thin aosp battery or no battery!
  • Small text percentage (like Samsung one) fully customizable, you can choose normal color and color at charging.
- Toggles
Available toggles:
  • WIFI Toggle
  • Data Toggle
  • Assistive light (Torch)
  • Sound Controls
  • Auto Rotation
  • WIFI Hotspot
  • Bluetooth
  • Secure Mode
  • Lock Now
  • Power toggles which let's you shutdown, reboot, recovery or download
  • Airplane mode
  • GPS
  • Sync
  • Screen Timeout (has an unlimited toggle so that screen doesn't turn off)
  • Media Scanner Toggle
  • USB Tethering
  • Power Saving
  • Driving Mode
  • Multi Window
  • Blocking Mode
  • Smart Stay
  • Smart Rotation
  • Allshare
  • ScreenShot
  • NFC
  • SBeam
Toggles Support MultiDPI!
You can choose how many toggles you want to be shown without having to scroll [Also available in the free toggles app).
You will be able to add/remove any toggle, change positions and..
- Enable/Disable Haptic Feedback
- Enable/Disable scrolling animation!
-Toggles now can be removed completely
-You can now Enable/Disable the Text or Indicators for the toggles
- Many more!
V3.5 -> V3.5.1
  • Fixes for Simplistic Control FCs
  • Fix for bootloop issues
  • AOSP Lockscreen handle is now centered in all DPIs
  • You can now choose any color for the off toggles
  • Space added between small text battery and signal indicators
  • Expanded View Transparency has been changed to Notification Section transparency, which only changes the transparency of the notification box.
  • Duplicate Accessibility in the Power Menu has been fixed.
  • MWCC Shortcut updated to support the new app.
V3.0.1 -> V3.5
Bug Fixes:
  • Torch Toggle Fix on Landscape which caused SystemUI FC
  • Toggles have been massively optimized (due to the removal of some junk code)
  • Fix "Hide Blocking Mode Notification and Icon" Option
  • Next Alarm Landscape Fix
  • Clock Fixes
  • PIN Unlock Bug is fixed, where the clock would be cut in half and would need a reboot to fix
  • AOSP Lockscreen ring is now centered in all DPIs
  • Fix for volume changing when skipping songs on screen off (also with FM support), should now support all players
New Features:
  • Added Modes to WiFi and Bluetooth Toggles (With or without dialog)
  • Toggles Section Fixes for sorting, and many improvements
  • 2G/3G/Auto Toggle added
  • Ability to change colors of Toggles (Label, On, Off, Background)
  • Power Toggle Recode, removing that stupid dialog I created :P
  • Signal (Wifi and Network) AOSP Layout by default with Samsung green as connected color
  • Ability to change Signal Indicators Colors
  • Notification Panel Transparency (experimental)
  • No restart required when changing statusbar color/transparency
  • No restart required when changing statusbar transparency on ripple
  • Custom Battery Overhaul, read battery section in the second post for instructions on how to create batteries. The batteries you make now can also be uploaded to the Play Store, and people can download them, install, and choose the custom battery they like.
  • Random Lockscreen Ink Color on each wakeup
  • AOSP Clear and Settings Buttons in the notification panel
  • Brightness Bar color change
  • Toggle IME Switcher notification and icon
  • Show/Hide StatusBar on Lockscreen
  • SPenBoard Shortcut added to Simplistic Control
  • Toggle Ongoing and Notifications label in the notifications panel (toggle them off for an AOSP look)
  • TW Launcher page loop option added (Credits to my buddy mirko)
  • TW Launcher rotation option added (Credits to my buddy mirko)
  • PIN Quick Unlock option, enabling this will remove the need of the OK button from the Pin Unlock, to make unlocking faster. (credits to CM)
  • My own FM Radio and Music Controls for Ripple and Circle Lockscreen (Music works for stock and google music)
  • Full date can now be added to the clock view in the statusbar
  • QuickLaunch bar under the toggles and brightness bar, allowing you to launch apps or perform actions (Lock, Power, Collapse, Recents) directly from the statusbar, supports up to 12 shortcuts.
  • CRT-OFF (Credits to AOSP Android for code, sorg for workaround) Added
  • Hardware Buttons Section added, allowing you to choose actions or launch an app for:
    - Back LongPress
    - Menu LongPress (some apps can consume this, and conflicts may happen)
    - Home DoubleClick
    Actions included are: Global Search, Launch Assistant (S-Voice, Google Now), Kill Current Process, Show/Hide Multiwindow
    Section also includes an option for controlling the delays of Home Double Click, and Home LongPress (Recents panel).
  • MW Toggle is reverted back to its default functionality.
Downloads:
V3.5 : Odexed and Deodexed LL4/7, MA5/6/7, MB2
XXDLJ2 (V2.6)
XXDLK7 (V2.6)
XXDLL4 (V3.0.1) - Odex and Deodex
Free toggles control application application limité
Quelques Screenshots:
Source :http://forum.xda-dev...d.php?t=2029712
Un merci ne coûte rien
Modifié par Alienex
  • Like 2
VOILA :lol:
Merci pour ce mod qui est bien alléchant Alienex.
Malheureusement, soit ça foire quelquepart, soit tu as oublié de préciser certains prérequis.
Chez moi, ça fait disparaitre la status bar et j'ai régulièrement des erreurs "system IU s'est arrêté".
Je suis sous Omega v7.3.
Comment me conseilles-tu de procéder pour annuler les changements opérés, ou éviter cette erreur?
Merci!
Sinon tu reinstalle omega 7.4 et ça devrait être bon
Oui, c'est ce que j'ai fait du coup. Merci :-)
Chez moi, ça fait disparaitre la status bar et j'ai régulièrement des erreurs "system IU s'est arrêté". Je suis sous Omega 7.4, ma version systeme est XXDLJ2.
Même problème chez moi Diwali, ça doit être incompatible avec les dernières versions d'Omega. Tu peux réinstaller la 7.4 sans full wipe et ça annulera le problème (pense à faire une sauvegarde de la disposition de ton bureau si tu utilises Touchwizz).
Oui c'est exact tu dois donner 2$ mini pour avoir l'appli après tu la reçoit par mail sur ton adresse paypall.
Il faut que tu télécharge l'appli dans le premier message..
Edit : Je l'ai reçu 12h après avoir fais le don et depuis il y as eu 2 mises à jours donc j'ai reçu deux autres mails
Modifié par Alienex
salut ici :)
pour ceux qui utilise ce mod je viens de tester la dernière version v3.0.1 pour la XXDLL4 sur la derniere custom de wanam la v2.3 en XXDLL5 et ça marche impeccable ( vu que les deux base XXDLL4 / XXDLL5 ont le même numéro de changelog )
Modifié par jose
Hello,
Jose, en lisant tes posts tu m'as convaincu de passer sur wanamlite (même si j'hésitais avec la Phoenix).
Tout ça pour dire que je me demande ce qu'apporte ce mod quand tu es sur Wanamlite, sachant que tu as déjà une bonne partie des choses. A part le lock screen, je ne vois pas. Peux tu éclairer ma lanterne stp ?
T'en qu'à faire, peux tu aussi me dire s'il n'y a pas des risques de conflits avec les mods déjà présents dans Wanamlite et, du coup, des manipulations à faire (ou ne pas faire) ?
D'avance merci :-)
salut ALSJ
donc ce mod t'apporte en plus l’effet d'encre avec le doigt directement pour déverrouiller de passer en lockscreen aosp , de changer l’icône de batterie et de réglé les toggle comme bon te semble de modifier la fenêtre qui te donne accès au mode recovery download reboot . ( du moins avec la versions payantes )
Tu trouvera ici les différents icônes batterie : http://forum.xda-dev...d.php?t=2081756
Modifié par jose
Merci Jose (rapide ! J'avais même pas vu hier soir)
C'est bien ce que je pensais, il y a finalement peu de modifs, sachant que j'ai déjà installé le zip pour personnaliser les toggles (GT-N7100_WanamLite.UBDLL3.23Toggles.zip).
Ce serait éventuellement pour le lock screen. C'est vrai que 2€, c'est pas hors de prix.
Tu penses qu'il n'y a pas de risque de conflits si je l'installe alors qu'il y a déjà le mod pour les 23 toggles ?
