ablackswan Posté(e) 24 décembre 2012 Share Posté(e) 24 décembre 2012 (modifié) This is my port of CyanogenMod 10.1 for ZTE Blade. It is unofficial and unsupported by the CyanogenMod team. This ROM is mainly for developers/testers/advanced users - people who are aware that this ROM is incomplete. I'm really not interested in hearing whining about non-working things (and questions when they will be fixed), actually I couldn't care less if you have issues with this ROM. cm-10.1-20130724-KonstaKANG-blade.zip https://hotfile.com/...-blade.zip.html md5:3bc42f767f9a85462ad76895f00f0b4f gapps-jb42-20130307-KonstaKANG.zip https://hotfile.com/...taKANG.zip.html md5:8545baba12c25aab6c849595eb96827d cm-10.1-20130514-KonstaKANG-blade.zip https://hotfile.com/...-blade.zip.html md5:209ba7e9bfd07c09a66d7d26527aecd4 gapps-jb42-20130307-KonstaKANG.zip http://www.mediafire...ss5khtjf9a5v4s9 md5:8545baba12c25aab6c849595eb96827d You'll need at least 160mb system partition for the ROM and gapps to fit. Both gen1->gen2 and G2 TPTs are available at Amphoras' TPT Helper. Working: Wifi RIL (mobile network & data) GPS Bluetooth (& bt-tethering?) Audio (playback/input/routing/headphones/etc) Camera (photos, camcorder & panorama) Hardware acceleration and OpenGL rendering Hardware video decoding & encoding SD card USB-storage & adb USB-tethering Wifi-tethering Browser Touchscreen/multi-touch Sensors LEDs hardware vsync events (thanks to daemond) Not working: Sources: Device Proprietaries Kernel Thanks: CyanogenMod team & everyone who's been working on CM10.124.7. changelog: CM10.1.2 (patched 'master key' exploit) 3.7. changelog: fix native bluetooth tethering (thanks to zeelog) reclaim some RAM from triple buffer (thanks to plaguedbypenguins) CM10.1.1 14.5. changelog: backport low memory killer from 3.4 kernel (thanks to plaguedbypenguins) faster wifi reconnection after deep sleep (thanks to plaguedbypenguins) 19.4. changelog: rewrite device settings add option to disable button backlight included total of two wallpapers (AOSP and CyanogenMod default wallpapers) 29.3.2013 changelog: updated Effem and other FM related updates (thanks to daemond) possible fix for texture corruption on some rare occasions (thanks to daemond) increase PIE controls trigger area and allow PIE controls without enabling expanded desktop change default cpu governor to smartassv2 more Ad-Hoc changes (1,2,3) compiled using AOSP gcc 4.7 toolchain 24.3.2013 changelog: included daemond's Effem (FM Radio) app fixed audio routing and FM Radio volume control issues (thanks to C3C0) backported bluetooth UHID driver - added support for bluetooth input devices (thanks to plaguedbypenguins) pie controls (1,2,3,4,5) semi-working Ad-Hoc support (open networks) (1,2,3,4,5,6) phone: Make going to call log after call optional (1) am: Allow more hidden apps on devices with lots of RAM (1) + limit max background processes Use jpegOptimized bootanimations (1) new Apollo (merged) 6.3.2013 changelog: FM radio with RDS support (thanks to daemond) qcom-fm: audio: add support for FM feature (1,2,3) FM Radio: avoid deadlock when disabling RDS (1) update KGSL from CAF, fixes GPU out of memory issues (i.e. white textures, thanks to daemond) disable camera hdr disable hw acceleration on lockscreen fix navbar height option bring back Apollo music player Apollo: Fetch album art from media provider if present (1) new Superuser (merged) 20.2.2013 changelog: framework: fix rotation of electron beam animation (1) removed couple of non-standard/useless features (e.g. persistent notification when headphones are plugged in) 15.2.2013 changelog: Android 4.2.211.2.2013 changelog: reverted commits (1,2) that caused 'Process system isn't responding' issue on every reboot10.2.2013 changelog: included czech and portuguese (pt_PT) dictionaries surface texture enhancements (thanks to daemond) call statistics (merged) 29.1.2013 changelog: hardware vsync events (thanks to daemond) fixed some audio routing issues (thanks to daemond) fixed messed up u/v plane alignment in some videos (thanks to daemond) Custom lock screen background (1,2) option to toggle dimming of the notification shade (1,2) Lien du post original http://www.modaco.co...01-android-421/ Modifié 25 juillet 2013 par ablackswan 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
SKMBlake Posté(e) 24 décembre 2012 Share Posté(e) 24 décembre 2012 Je l'ai testée, excellente rom, même si elle rame un peu au départ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MzelleXD Posté(e) 25 décembre 2012 Share Posté(e) 25 décembre 2012 Bonjour, Avant de tester la ROM j'ai une petite question :) : Est-ce que cette ROM va avoir des mises à jour ou c'est la version finale ? ^_^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MadMozel Posté(e) 25 décembre 2012 Share Posté(e) 25 décembre 2012 C'est la toute première version, encore en test, donc il n'y a pas tout qui est fonctionnel! Prends la CM10 4.1.2 qui elle est finalisé! :) 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
SKMBlake Posté(e) 25 décembre 2012 Share Posté(e) 25 décembre 2012 En effet, Youtube a de graves problemes et bug beaucoup par ex Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MzelleXD Posté(e) 25 décembre 2012 Share Posté(e) 25 décembre 2012 @Mad-Mozelle D'accord :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nabux Posté(e) 25 décembre 2012 Share Posté(e) 25 décembre 2012 Bonjour, j'ai quelques problèmes avec mon blade auxquels je n'ai pas de solution. J'ai utilisé plusieurs ROMs ( CM7-CM9-CM10 & 10.1) ces derniers mois et j'ai toujours les mêmes problèmes récurrents:la rotation de l'écran ne fonctionne plus, l'appareil photo affiche une erreur de connexion et j'ai une énorme perte d'autonomie en 3G. De plus, Impossible de faire de hard reset avec mon téléphone et repartitionner ( le logo android tourne en boucle quand tentative de Vol+, menu et power on). Que faire? Merci d'avance Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
GrégoryCuyle Posté(e) 25 décembre 2012 Share Posté(e) 25 décembre 2012 Ce sujet est dédié a CM10.1, crée plutôt un nouveau sujet si a un souci avec ton blade. Sinon, pas mal que android 4.2 soit porté sur notre blade chéri, ce fait plaisir de voir qu'il y a encore des développeurs motivés par ces vieux appareils :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
shangalisto Posté(e) 26 décembre 2012 Share Posté(e) 26 décembre 2012 Et on peut espérer que la prochaine version le sera aussi même si ça risque de devenir de plus de en plus compliqué ^^ (Bien qu'au final, Jelly Bean s'en sort très bien face à Gingerbread malgré une consommation de la RAM plus élevée sans que ça soit spécialement nécessaire mais bon) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MadMozel Posté(e) 1 janvier 2013 Share Posté(e) 1 janvier 2013 MAJ du 01.01.2013: cm-10.1-20130101-KonstaKANG-blade.zip http://www.mediafire...kqwptn6q9atq64r md5:2980c60848869a66072c869fba8a7def Merged commits not mentioned in the changelog. 1.1.2013 changelog: backported USB gadget driver from msm-3.0 kernel (thanks to WaylandACE)fixed native USB tethering fixed issues with apps failing because of borked usb0 interface (e.g. network speedtest apps) [*]switched to wpa_supplicant_8 [*]added power hal and boostpulse support to ondemand governor [*]Quick Settings: Swipe to switch (1) [*]Add persistent notification when headphones are plugged in (1) [*]CyanogenMod clock widget - Chronus (merged) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
azertyblazer Posté(e) 3 janvier 2013 Share Posté(e) 3 janvier 2013 Bonjour à tous ! J'ai mis ma cm10.1 dans un dossier :00- Roms J'ai lancé le recovery (version 5.0.2.7), fais une sauvegarde, wipe data/factory, wipe cache...... J'installe la rom et ça m'affiche "installation aborded!" Pouvez-vous m'aider svp Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MadMozel Posté(e) 3 janvier 2013 Share Posté(e) 3 janvier 2013 (modifié) 1)Le fichier zip ne doit pas être dans un dossier mais a la racine de la SD, ni décompressé! (Qu'avez vous tous a mettre dans un dossier? :emo_im_foot_in_mouth: ) 2)Ton recovery est peut être aussi trop vieux pour IC/JB, mets-le a jour avec le 6.0.1.2 de KonstaT: ClockworkMod Recovery 6.0.1.2 In a flashable from CWM zip MD5:77D9D03E44C57F85415B34692F277539 Modifié 3 janvier 2013 par Mad-Mozelle Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
azertyblazer Posté(e) 3 janvier 2013 Share Posté(e) 3 janvier 2013 Ok je vais voir Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Le Dam Posté(e) 3 janvier 2013 Share Posté(e) 3 janvier 2013 Ok je vais voir J'aurais répondu : Ok, je vais voir, merci Mad-Mozelle ;) ...surtout quand tu remarques que la réponse a pris plus de temps que ta question (et que c'est la deuxième fois que notre protégée te répond sans remerciement)... Enfin rien de grave non plus, bienvenue parmi nous :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MadMozel Posté(e) 3 janvier 2013 Share Posté(e) 3 janvier 2013 (modifié) Merci DamDam c'est gentil, mon ange gardien Frandroidien! :P :D Je n'attends pas de remerciement a chaque fois mais bon, ca fait toujours plaisir! ^_^ Modifié 3 janvier 2013 par Mad-Mozelle Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kaobalt Posté(e) 3 janvier 2013 Share Posté(e) 3 janvier 2013 Bon, moi j'ai trouvé un blade avec l'écran je vais pouvoir réparer le mien qui n'a plus de micro et me lancer dans l'installation de cette petite rom bien sympa ... j'ai quand meme manqué un bon bout de chemin depuis ma rom M95 ... :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mickajo Posté(e) 4 janvier 2013 Share Posté(e) 4 janvier 2013 Oh oui! :P Sinon, j'ai passé ma periode de flasher une ROM tous les deux jours (là ça doit faire bien 2 mois que je suis sur la même :P). La 4.2 dépasse déjà la 4.1.2? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MadMozel Posté(e) 4 janvier 2013 Share Posté(e) 4 janvier 2013 Pas encore, non! :P Mais a la finale, elle devrai oui! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Le Dam Posté(e) 4 janvier 2013 Share Posté(e) 4 janvier 2013 Dans ce cas, j'attends aussi :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mickajo Posté(e) 4 janvier 2013 Share Posté(e) 4 janvier 2013 (modifié) Pas encore, non! :P Mais a la finale, elle devrai oui! Mais y a t-il un réel intérêt? La majorité des nouveautés de la 4.2 nécessitent un armv7 ou un Gyroscope (photosphère). :/ Meilleure autonomie, fluidité? :P Mon Blade va avoir droit à une retraite bien méritée, son remplaçant va très vite arriver, mais j'aimerais lui offrir une jolie fin :emo_im_kissing: :P Modifié 4 janvier 2013 par mickajo Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MadMozel Posté(e) 4 janvier 2013 Share Posté(e) 4 janvier 2013 Mais y a t-il un réel intérêt? La majorité des nouveautés de la 4.2 nécessitent un armv7 ou un Gyroscope (photosphère). :/ Meilleure autonomie, fluidité? :P Mon Blade va avoir droit à une retraite bien méritée, son remplaçant va très vite arriver, mais j'aimerais lui offrir une jolie fin :emo_im_kissing: :P Perso, je préfère la 4.1 a la 4.2, mais la 4.1 est fini tandis que l'autre non! Meilleure autonomie: pas assez testé pour me faire une idée! Meilleure fluidité: vu qu'elle est encore instable, pour le moment non, mais faut voir une fois finalisée! Après je vois pas de différence! :P Pour l'APN, j'ai mis le 4.2 sur ma 4.1 et a part la galerie qui est bien plus fluide, la Photosphère, c'est pour faire joli, j'en vois pas trop l'utilité, ca ne change pas grand chose! :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bolido Posté(e) 4 janvier 2013 Share Posté(e) 4 janvier 2013 mais la 4.1 est fini J'ai rêvé ou il y a un légère mise à jour de la 4.1 qui est sortie fin décembre ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MadMozel Posté(e) 4 janvier 2013 Share Posté(e) 4 janvier 2013 J'ai rêvé ou il y a un légère mise à jour de la 4.1 qui est sortie fin décembre ? Non, tu ne rêves pas, il y a eu une (toute dernière et exceptionnelle) MAJ le 27 Décembre, car KonstaT estimait que ca valait le coup, mais je n'ai pas trop compris pourquoi, mais elle est terminé! ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bolido Posté(e) 4 janvier 2013 Share Posté(e) 4 janvier 2013 Tu l'as installé ? Le changelog n'est pas très clair pour Moi..... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MadMozel Posté(e) 4 janvier 2013 Share Posté(e) 4 janvier 2013 Oui, j'ai la dernière version du 27 et pas vu de différence avec celle d'avant! Moi non plus les changelog ne sont pas très clair! :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
