zerck Posté(e) 30 décembre 2012 Share Posté(e) 30 décembre 2012 (modifié) EUROSKANK - Compilation de CM7 source code Built By: FuZZ pris sur r.cyanogenmod.com Features: Android 2.3.7. "Andy got SKANK" bootanimation kanged by @rascarlo JellyBean fonts Kernel builty by Fuzz:Governors: smartassV2, SavagedZen, Ondemand, Interactive and many more.. Lockscreen flashlight - long pressing HOME button Stopwatch app KSM tweak Current CPU frequency Option for swap partition Swipe to clear Plus d'info : http://fitsnugly.eur...m7&device=bravo cherry picks in latest build (MAJ du 01.05.13) [Common] * "Andy got SKANK" bootanimation kanged by @rascarlo * Makes build more SKANKY! Wallpaper kanged by @rascarlo * Modify back key kill app timeout to 1.5 seconds * Use JellyBean fonts [Device] * block: Add Simple I/O scheduler * block: Add V® I/O scheduler * config: Enable KSM * config: Enable Compcache * config: Make ondemand as default governor * config: Make SIO as default I/O scheduler * config: Add BFQ hierarchical scheduling support * cpufreq: Add smartassV2 governor * cpufreq: Tweak smartassV2 governor * mm: Add Cleancache * mm: Add Frontswap * bravo: Implement integrated kernel building [Apps] * CMWallpapers: Shorten App name * CMWallpapers: Add new wallpapers * Contacts: Add individual contact call history and show groups yes/no setting on call log * DeskClock: Add Stopwatch app * Mms: auto-retrieval (for gingerbread) * Mms: Modify settings layout * Mms: Enable emojis support * Mms: Update smileys * Mms: Strip Unicode: Fix for specific Japanese characters * Music: Add option to start playback when A2DP headset gets connected * Music: Change the order of the menu * Protips: Add missing meme for all locales [CMParts] * Add ability to swap volume keys in selected orientation * Performance: Move memory related settings to Memory management * Performance: Memory management: Add KSM settings (requires kernel support) * Performance: Add I/O scheduler settings * Performance: More refactoring * Performance: Processor settings: Add current CPU frequency * Performance: Processor: Add ability to set max screen off CPU frequency * Add option to choose CmCircleBattery * Fix issues CmCircleBattery is not available for some locales [settings] * Add option to control cursor in text fields using volume keys [Tweaks] * bionic: merge from upstream * dalvik: merge from upstream * libcore: merge from upstream * system/core: merge from upstream [build] * Backport allow to change output directory * Backport integrated kernel building Avant installation: INFOS le script SEEDER ne fonctionne plus avec cette derniere versions (01.05.13) , Merci @Harm007 1-faire un backup dans le recovery au cas où, histoire de revenir sur une config qui marche si probléme. titanium backup pour les applis et les points d'accès wifi mybackup pour sms/mms -TELECHARGEMENT ROM CM7.2-20130501.2210-Desire PATCH A2SD A2SD.zip ou PATCH S2e (simple2ext ) plus simple pour les nouveaux qui flash leur Htc desire. (Merci a syd ;) ) C'est une application qui est spécialement conçu pour Cyanogen (CM7,CM9 ou CM10) et qui fonctionne très bien En plus, on peut choisir les éléments que l'on souhaite déplacer vers la SD-EXT. Ce qui n'est pas le cas du script A2SD . -Cela est beaucoup plus simple que de devoir mofier le zip de la ROM. Liens ===> https://play.google....ture=nav_result PATCH Eglpatch eglpatch.zip ==> cela force l'utilisation de l'accélération matérielle du GPU du Desire (adreno 200). ce patch sert à solliciter le composant graphique (GPU) pour tout ce qui est graphique. Le CPU est alors allégé de cette tâche : la rom gagne en fluidité lors des scrolls d'écran. valable avec n'importe quelle rom gingerbread (2.3.x) PATCH Seeder 2.0.0 (Permet une reduction de latence importante ) conseil : selon certain cela rend le telephone plus fluide sans l'installation du Eglpatch a vous d'essayez, mais je vous conseil de prendre ca en 1er choix . Version 2.0.0==>> Seeder-2.0.0.apk Version 2.0.0b1==>> Seeder-2.0.0b1.apk ===>Sur certaines versions d'Android, la machine virtuelle Java (et d'autres composants) souvent lise des données aléatoires provenant du dispositif de blocage / dev / random. Sur les nouvelles constructions, ce problème a été résolu, mais l'épuisement de la réserve d'entropie d'entrée semble encore ralentir beaucoup d'appareils. Plus d'infos sur Seeder 2.0.0 le post ===>http://forum.frandro...-lag-reduction/ Ou Sinon a vous de voir je previens chez certain utilisateur il y'a des socusi d'installation Pour utilisateur confirmer. (Lire un peu le post pour voir soucis rencontre) [MOD]CrossBreeder Lag Reduce-Entropy/DNS Speedup/Tether boost/Clean Adblock!-14-2-13 v2 -------------------------------------------------------------------------------------------------------------------------------------- Procedure d'instalation de l'a2sd (micro sd CLASS 10 conseiller) , Merci a harm007 :P - Ouvrir le zip de la rom avec 7zip (par exemple) sans extraire quoi que ce soit ==> sur le zip de la rom, tu fais clic-droit et tu choisis 7zip / ouvrir une nouvelle fenetre s'ouvre avec le contenu du zip de la rom ==> surtout ne pas extraire le contenu du zip - Ouvrir A2SD.zip avec un autre 7zip ==> sur le zip de A2SD, tu fais clic-droit et tu choisis 7zip / ouvrir une nouvelle fenetre s'ouvre avec le contenu du zip A2SD.zip ==> surtout ne pas extraire le contenu du zip - extraire le s/répertoire system de A2SD pour le mettre dans le zip de la rom cyanogen (je confirme les éventuels écrasements de fichiers) ==> dans la fénêtre A2SD.zip, - tu fais clic gauche sur system (et tu maintiens cliqué) - tu le fais glisser jusqu'à la fenêtre du zip de la rom - tu lâches et tu confirmes le remplacement des fichiers - tu quittes les 2 fenêtres 7zip (croix rouge en haut à gauche des fenêtres) Procedure d'installation de eglpatch , merci a Harm007 :P Pour eglpatch, c'est plus simple. - mettre le fichier sur la carte sd du téléphone - passer en mode recovery - flash de eglpatch.zip - rebootes le tél ==> ce patch sert à solliciter le composant graphique (GPU) pour tout ce qui est graphique. Le CPU est alors allégé de cette tâche : la rom gagne en fluidité lors des scrolls d'écran. Installation: 1) Recovery (full wipe cache, dalvik-cache, system, data). 2) flasher la rom Install du zip. CM7.2.0-2012****.****-Desire ou celle modifier avant pour L'a2sd( MicroSd Class10) 3) Install Google Aps (en option), prendre "gapps-gb-20110828-signed" ( en option) Pour les 2 patch a vous de choisir selon 2membres, passer directement a l'etape 3.2( telephone plus reactif). 3.1)install de elgpatch.zip 3.2) ou install du Seeder 1.4.0.apk < ROOT Necaissaire 3.3) ou les deux patch 3.4) Ou le MOD CrossBreeder. 4) Reboot du telephone. 5) une fois dans le telephone Parametre>Cyanogen Mod>Performances>Processor>Méthodes disponibles SmartassV2. (en option,mais conseiller) infos :sert à changer la stratégie de changement de fréquence du CPU en fonction de sa charge 6) bonne utilisation de votre telephone . Infos supplementaire pour reglage: (Merci a harm007) Pour ce qui est du choix des option du lanceur : Paramètres systèmes / CyanogenMod / Interface / Gestion de l'alimentation / boutons du widget on trouve une liste de boutons à sélectionner. 2G/3G , bluetooth, gps, lampe poche , etc etc.... On peu accéder à ce switch via la barre de notification Aller dans :paramètres systèmes / CyanogenMod / Interface / Gestion de l'alimentation / ordre des boutons On va pouvoir choisir l'ordre des boutons dans la barre de notification.Pour les déplacer, tu les attrapes par la poignée à gauche Pour ce qui est du pourcentage de la batterie, On va dans :paramètres systèmes / CyanogenMod / Interface / Barre de notification On va trouver Batterie : sélectionne l'affichage que l'on desire. Screen Ecran : Modifié 5 mai 2013 par zerck 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
harm007 Posté(e) 30 décembre 2012 Share Posté(e) 30 décembre 2012 (modifié) Merci à zerck pour ce bon début... Ça va clarifier les autres fils de discussion. Cette rom est vraiment très fluide. Vos remarques seront les bienvenues. Dernière précision : hboot cm7r2 (car cette rom est issue d'une cyanogenmod7) Envoyé depuis mon HTC Desire avec Tapatalk Modifié 30 décembre 2012 par harm007 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 9 janvier 2013 Share Posté(e) 9 janvier 2013 (modifié) Sur une demande d'harm, je viens de faire un patch pDroid pour CM7.2-20121222.0052-Desire Il y en a aussi pour d'autres versions ou ROMs Box | Dropbox | GoogleDrive | SkyDrive Modifié 9 janvier 2013 par sydbarrett55 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
harm007 Posté(e) 10 janvier 2013 Share Posté(e) 10 janvier 2013 Merci syd. Malgré tous mes efforts, je n'ai jamais réussi à fabriquer ce type de patch... A+ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 10 janvier 2013 Share Posté(e) 10 janvier 2013 (modifié) Pourtant, je n'ai rien à faire, j'ai juste à lancer un EXE, choisir le zip de la rom dont je souhaite faire le patch, et cliquer sur un bouton et ça se fait tout seul. Le seul truc, c'est qu'il ne faut pas prendre la dernière version de PDroid Patcher v1.32 beta, les patchs créé avec ne fonctionne pas. Il faut utiliser PDroid Patcher v1.31 et là aucuns problèmes. Voici un lien, si tu veux : PDroidPatcher_1.31.zip Tu pourras essayer, tu verras qu'il n'y a pas plus simple. Si tu arrives à flasher la radio ou le Hboot. Tu sauras forcément créé un patch pdroid :P Modifié 10 janvier 2013 par sydbarrett55 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
harm007 Posté(e) 10 janvier 2013 Share Posté(e) 10 janvier 2013 (modifié) Je crois que j'ai été plus royaliste que le roi... Sur google play, l'appli pdroid référence le lien XDA pour patcher sa rom. http://forum.xda-dev...d.php?t=1357056 Il y est question de JDK, dotnet 2.0, et autres joyeusetés du même genre... J'ai essayé et ça n'a pas marché... Du coup, comme je préfère LBE Privacy Guard, je n'ai pas insisté. Plus généralement, je crois qu'il y a des outils très bien faits avec lesquels je ne suis pas très à l'aise. Par exemple, pour ce qui est de changer de splash screen, de radio ou de hboot, je n'ai jamais utilisé android flasher. J'ai toujours utilisé les commandes fastboot dans un "cmd.exe". Je dois avoir un comportement "à l'ancienne" : tout à la ligne de commande... (probablement les restes de SUN/Unix puis de linux...) Modifié 10 janvier 2013 par harm007 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 10 janvier 2013 Share Posté(e) 10 janvier 2013 (modifié) T'as pas des côtés Sado (SM) lol Pourquoi faire simple quand on peut faire compliqué xD Après, si on se s'en bien avec une technique, pourquoi en changer. Tous les chemins mènent à Rome ;) Je crois que j'ai été plus royaliste que le roi... Sur google play, l'appli pdroid référence le lien XDA pour patcher sa rom. http://forum.xda-dev...d.php?t=1357056 Justement sur le topic d'XDA, c'est PDroid Patcher v1.32 Beta 0.321 for Windows qui est indiqué. Et avec cette version, j'ai essayé de faire les patchs, ça fonctionne mais après Quand je flashe les fichiers obtenus sur le tél. le tél reste bloqué sur le bootanimation. C'est pour ça, que je t'ai dit qu'il fallait utiliser la version 1.31 et non 1.32 pour faire les patchs Modifié 10 janvier 2013 par sydbarrett55 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
harm007 Posté(e) 10 janvier 2013 Share Posté(e) 10 janvier 2013 J'ajouterai que avec la méthode "ligne de commande", on comprend mieux ce qu'on fait. En plus, j'ai obtenu cette méthode avant de découvrir android flasher. Du coup, je suis resté avec cette méthode. On ne change pas une équipe qui gagne... 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 11 janvier 2013 Share Posté(e) 11 janvier 2013 J'ai refait les 15 patchs pourcentage batterie pour la dernière version 20121222 Je suis en train uploder tout ça en ce moment même. S'il n'y a rien pour certains liens, c'est que je n'ai pas encore fini l'upload Box | Dropbox | GoogleDrive | SkyDrive et je remet le lien pour tous les patchs Pourcentage Batterie que j'ai fait pour différentes ROM et versions Pourcentage.Batterie.pour.ROM.Custom.Android Je remet une nouvelle fois, aussi, un récap de divers choses pour le Desire Divers liens pour ROM HTC Desire Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
niminh Posté(e) 11 janvier 2013 Share Posté(e) 11 janvier 2013 Merci pour tout. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 14 janvier 2013 Share Posté(e) 14 janvier 2013 (modifié) Mildwild vient de sortir une nouvelle version de sa ROM Mildwild CM basé sur Cyanogen 7.2 et Euroshank, et d'après les retours, les membres ont l'air d'être très satisfait. Je poste ici car il n'y a pas de topic sur Mildwild CM et qu'elle est basée sur Euroshank MildWild CM-7.0 JG Stable Based on CyanogenMod7.2 and Euroskank CM7.2 by: FuZZ_ Build from the latest CM7.2 Builds Je me tâte à la tester, et si je trouve la motivation, je reviendrai vous dire ce que j'en pense Modifié 14 janvier 2013 par sydbarrett55 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
harm007 Posté(e) 14 janvier 2013 Share Posté(e) 14 janvier 2013 (modifié) @ syd : merci pour l'info. Je l'ai testée ce week-end et elle est aussi rapide que la version Euroskank. Elle intègre un A2SD de manière native. Par rapport à la version Euroskank, MildWild a : - intégré un thème JellyBean (d'où le nom JG : Jellybean Gingerbread) - supprimé Thème Chooser : on ne peut plus intégrer certains thèmes De plus, il a scindé sa rom en deux parties. MildWild précise que les futures mises à jour se feraient par de petits fichiers zip à installer. Requirement a full factory reset/wipe everything! +battery stats. sorry but this is the last full wipe for my rom. in future only get small updates flash zip`s La procédure d'install est : - transférer les deux fichiers à la racine de la carte SD (pas dans un sous-répertoire) - passer en mode recovery - full wipe (reset factory, wipe data, wipe cache + dalvik, wipe battery stats) - installer le 1er zip (taille classique d'une rom) - booter puis attendre quelques minutes (boot complet) - retourner en mode recovery - installer le 2ème zip (taille plus faible) - booter - terminer le paramétrage de la rom (compte google, ...) Elle présente quelques force close sans gravité lorsque l'on va dans le paramétrage de : - l'envoi des stats anonymes de cyanogenmod - la luminosité de l'écran (boutons du widget) - ... Personnellement, elle me convient. @syd : pour répondre à ta question posée sur xda (pourquoi 2 zip et pas 1 seul) (http://forum.xda-dev...&postcount=4733) J'ai posé la même question à MildWIld et voilà sa réponse : (http://forum.xda-dev...&postcount=4658) J'ai "surligné" la question et la réponse qui lui correspond. Quote: Originally Posted by harm007 I used CM7.2 euroskank for several months. http://fitsnugly.eur...m7&device=bravo And when I saw that MildWild CM-7.0 was based on it, I tried and I can say that MW CM-7.0 is really a great ROM. @mildwild : - thanks for all your work - is it possible to add Theme Chooser in the ROM? - there are two parts and it is necessary to reboot between each flash : in simple words, can you explain why? - Best regards. the rom only works with this method (system deceive) I support no Theme chosser. (i´am the theme chooser )you can test it. at your own riskSa réponse rejoint ce qu'il a écrit dans son premier post et que j'ai cité plus haut (rom scindée en deux parties). Modifié 14 janvier 2013 par harm007 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 14 janvier 2013 Share Posté(e) 14 janvier 2013 (modifié) Ah, moi, il m'a répondu différemment !!! LOL http://forum.xda-dev...&postcount=4735 En passant, ça fait quelques temps qu'on a pas eu de nouvelles Euroshank (22/12/2012) En fait, c'était pas la fin du monde mais la fin d'Euroshank :P Modifié 14 janvier 2013 par sydbarrett55 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
harm007 Posté(e) 15 janvier 2013 Share Posté(e) 15 janvier 2013 @syd : je crois savoir que tu es en tête de liste des donateurs MildWild. Tu dois avoir des privilèges particuliers... MDR Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zerck Posté(e) 15 janvier 2013 Auteur Share Posté(e) 15 janvier 2013 (modifié) @Syd tu pense que c'est utile que je fasse un post pour la rom de mildwild je suis plutot pour , car la Euroshark n'est plus suivi on dirrait ...( bon même si on sait que syd t'es un pe ViP avec mildwild lol :P ) @Harm007 L'a2sd marche toujours sur le rom de MildWild CM-7.0 JG , car tu dis en Native c'est à dire ???? Modifié 15 janvier 2013 par zerck Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
harm007 Posté(e) 15 janvier 2013 Share Posté(e) 15 janvier 2013 (modifié) Quand je dis "A2SD natif", je veux dire que l'A2SD est intégré dans la rom. Il n'y a pas besoin de faire la manip spéciale comme avec les rom cyanogenmod ou euroskank. Pour revenir à la MildWild CM-7.0, certains utilisateurs rencontrent des problèmes de bootloop lorsqu'ils restaurent une sauvegarde nandroid. A suivre... [Edit] Je viens d'essayer et je confirme : bootloop juste après la restauration de la sauvegarde nandroid. L'écran de boot MildWild tourne en boucle... Je reste fidèle à Euroskank + A2SD + patch egl + Seeder (la machine marche ==> n'y touchez pas) Modifié 15 janvier 2013 par harm007 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 15 janvier 2013 Share Posté(e) 15 janvier 2013 (modifié) VIP de Mildwild, MDR !!!! C'est juste que je le suis depuis la toute première version de Mildwild et que je l'ai aidé sur cetains trucs. J'étais pas mal actif sur le Forum d'XDA, et j'ai été le premier à lui payer une bière. Après je me lui ai pas donné grand chose, mais c'était pour le geste Un Topic pour la ROM Mildwild, non, je l'ai déjà fait. Mais pour Mildwild CM, oui, ça serait bien je pense ps: c'était une boutade, je sais que tu parlais de Mildwild CM, lol Modifié 15 janvier 2013 par sydbarrett55 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zerck Posté(e) 16 janvier 2013 Auteur Share Posté(e) 16 janvier 2013 (modifié) @syd Oui c'est sur la t'es plus que VIP il a bu un verre avec mdr , oui faudrais faire le post quand je passerais sur mildwild 7.0 JG car j'avou que la euroshank +egl+seeder+a2sd Je suis fan aucun bug rapide fluid que le bohneur et comme dis Harm007 (la machine marche ==> n'y touchez pas) :) :) :) :) :) :) :) @Harm007 (la machine marche ==> n'y touchez pas) (la machine marche ==> n'y touchez pas) je pense que je vais suivre ce conseil c'est valable pour tous ..... je laisse les autres test , une fois super stable je prend car je sens qu'il va y avoir une MAJ ds pas lgtps ... Modifié 16 janvier 2013 par zerck Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 16 janvier 2013 Share Posté(e) 16 janvier 2013 Pareil, je suis aussi avec Euroshank avec la version du 14/12/2012 J'ai voulu essayer la 22/12/2012, mais j'ai eu un souci avec mes patchs donc je suis revenu sur la 14/12 De toutes façons, il ne doit pas y avoir énormément de différences Sinon, j'ai tout pareil que vous Euroshank + egl + seeder à une différence près que j'utilise simple2ext pour l'a2sd et pis je commençais à en avoir marre de flasher à tout va. J'ai fait ça depuis le 1 août 2011 et je crois que ça suffit, lol ça m'arrivera surement encore, mais plus comme avant Sinon, Mildwild à encore une autre ROM que je n'ai jamais testé : MildWild MW-5.5 Based on Redux2 TEST Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zerck Posté(e) 16 janvier 2013 Auteur Share Posté(e) 16 janvier 2013 J'avoue flash tous le tps son tel c'est la flem un peu car ça prd 1heure a chaque fois le tps de tous remettre de re test voir si ça bug ... moi je flash pas autant que toi & harm007 , je suis plus novice que vous B) . oui j'ai vue aussi Mildwild y fais trop de ROM lol on a trop de choix :) :) :) . Et a test entre la Mildwild mw5.5 & Mildwild Cm7.0 JG . Je prend la 7.0 , mais bon c'est pas encor l'heure lol.. Je crois que lon va créer un Post de tte les rom mildwild .... ^_^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TheLapin Posté(e) 17 janvier 2013 Share Posté(e) 17 janvier 2013 (modifié) Quelques petits bugs ou amélioration que je voudrais avec la Euroskank. Si vous avez des solutions - souvent, quand j'allume le tel par power, l’écran s'allume puis s’éteint. il faut rappuyer deux fois sur power pour avoir l'écran de verrouillage (pénible) - il manque la gestion des profils audio en widget et/ou dans la barre de notif - j'aimais bien le systeme de Sense avec les paramètres dans la barre de notif (sur la runny 3D) - pas d'EAP-SIM (dispo sur la runny 3D, il faudrait que j'essaye de patcher le wpasupplicant de la runny pour voir si ca permettrait de le reactiver) - la batterie (smartassv2) me permet de tenir juste la journée (plus de 2 jours d'autonomie avec la runny) mais bon, la batterie a 3 ans donc ce serait peut etre temps de la changer - pouvoir ajouter des applis dans les dossiers a la manière de App organizer : on ouvre le dossier, on appuie sur menu et on coche les applis a ajouter au dossier) Ensuite, mes manques par rapport a Sense : le gestionnaire de contacts, le widget des notes, l'agenda Par contre, couplé a Holo launcher pro, la fluidité n'a franchement rien à voir Qu'est que vous appelez un seeder ? Modifié 17 janvier 2013 par TheLapin Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 17 janvier 2013 Share Posté(e) 17 janvier 2013 Seeder, c'est une application à installer qui d'après ce que j'ai cru comprendre éviterait des lags. Enfin, j'ai pas très bien compris. Le problème de l'écran noir sur l'écran du code PIn, ça m'est déjà arrivé, mais je n'est aucunes idée du pourquoi ?? Tu peux toujours essayer un wipe cache et Dalvik cache. Pour ce qui est de créer un Sujet pour toutes les ROM MildWild, ça parait être une bonne idée au départ, mais je ne pense pas que ce soit judicieux Car bien que ses ROM soit toutes des Gingerbread, elle ne sont pas basé sur les mêmes sources Donc, pour si retrouver, au bout d'un moment, ça va être l’anarchie ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TheLapin Posté(e) 18 janvier 2013 Share Posté(e) 18 janvier 2013 Ce n'est pas un écran noir sur le code PIN, c'est lorsque je reveille le tel par power que l'ecran s'allume et s'éteind aussitot Mais je n'arrive pas a déterminer la repro exacte. Je vais tenter un wipe mais pas sure que ca règle les choses Pour l'autonomie, je n'ai pas la dernière radio ni le RIL corrigé, je ne sais pas si ca peux influer. Vous avez quoi vous ? Il y a aussi le kernel CronMod 1.6 qui semble être moins gourmand, vous avez essayé ? (Remarque : j'ai utilisé Torque, celui-ci pompe la batterie meme si l'appli est killé car il ne libère pas l'acceléromètre qui pompe un max. Si vous avez une solution) J'ai craqué, et racheté une batterie (officiel a 40€, ça fait un peux mal mais bon) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
t-minik Posté(e) 18 janvier 2013 Share Posté(e) 18 janvier 2013 pour info concernant la batterie, j'aurais du faire un post la dessus. ma batterie d'origine est morte il y a un moment : - j'en ai acheté une 1ere sur ebay 10euros >> retour et remboursement car elle ne renvoyais pas les infos température / tension / capacité comme l'origine - j'en ai acheté une 2eme chez un vendeur dit sérieux qui me confirmais que c'etait de l'originale HTC >> retour pour les mêmes raisons. - une 3eme sur HTC accessories (le site officiel donc !) >> même topo, mais ce coup ci, je l'ai gardé, l'autonomie est pas aussi bonne qu'avec l'originale quand elle était encore en forme. - comme j’étais pas rassuré par cette batterie j'en ai commandé une sur mugen power qui sont réputées fiables et "calibrable". on verra bien, mais au final ça m'aura coûté un rein ces histoires. je vous ferai un retour sur la mugen power. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 18 janvier 2013 Share Posté(e) 18 janvier 2013 T'aurais mieux fait de racheter un Tél, lol Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
