Posté(e) (modifié)
PARANOIDANDROID v3.15
AOSPA
Android 4.2.2
CM10.1 HYBRID
INSTRUCTIONS,
1. UPDATE RECOVERY
2. FACTORY RESET
3. INSTALL ROM, GAPPS
4. INSTALL FIXes (If NFC broken, & try both zips)
4. WIPE CACHE & DALVIK CACHE
5. REBOOT
PA 3+ UPDATES DO NOT NEED A FACTORY RESET,
BUT YOU NEED TO INSTALL GAPPS ASWELL.
Changelog 3.15 :
-Official Android 4.2.2 changelog
-New Mali Drivers (Credits to CM)
-Home Button Recents Fixed
-Battery Circle option added
-PIE disable option added
-New pie toggle icons
-Bluetooth audio sampling increase
-Compiled using NEON Optimizations
-QuickSettings Updated
-Koush's new SuperUser implementation integrated
-Updated HybridPreferences
-SlimISP_ZH.bin Camera fw support (CM Upstream)
-General overall updates, & fixes
Known issues:
-Camera Crash on first Flash-Shot. Restarting Cam makes it go away.
-Home button on Screen-Off takes user to Home, instead of on-screen-running app.
-FM Radio: unsupported. Use Spirit FM Radio from Play Store instead.
-TV Out: unsupported, will never work (proprietary, undocumented).
-No exFAT support (proprietary, Microsoft).
op_rom0god3.pngop_gappsf6otw.pngop_fixf1p4b.pnguntitled-11cbkj.pnguntitled-29ej2n.png
TUTORIAL
DONATIONS,
to molesarecoming
to D4rKn3sSyS
to jaybob413
to aaronpoweruser
to gokussjx
CREDITS,
AOSP/Google, Cyanogenmod, Goo, XDA, Krebsmilk, giannisgx89, imilka, beerbong, Liquid,
AOKP, our users, supporters and donators, everyone who's helped us in the past,
heartfelt thanks to all of you!
LINKS,
Website: www.paranoid-rom.com
Github: www.github.com/paranoidandroid
Gerrit: review.paranoid-rom.com
BANNERS,
Source XDA : http://forum.xda-dev...d.php?t=1745003
Modifié par M4dm4rtig4n
Posté(e) (modifié)
Perso j'était dessus pendant quelques mois avec mon Galaxy note et rien à redire dessus.
Je viens de la mettre en dual boot sur mon S3 pour tester et pour l'instant tout ce passe plus ou moins bien ^^
Actuellement je cherche à savoir si il est possible de custom la navbar afin de mettre le dock directement dedans et de par la même occasion le supprimer de mon accueil.
Avec l'écran du Galaxy Note c'était le must de pouvoir choisir de mettre ou pas certaine application en mode tablette pour une meilleur visibilité.
Après un rapide test, dommage qu'en mode smartphone, on ne puisse pas supprimer la barre du bas avec les 3 boutons qui, du coup, fait doublon.
(peut-être n'ai-je pas trouvé non plus)
Tu peut dans les "Hybrid properties", onglet interface tu met à 0 le "Nav. bar" et hop disparition des 3 boutons.
Je suis dessus depuis ce matin, j'ai mis un moment moi aussi pour virer la nav bar.
Si certains ont trouvé pour mettre le % de la batterie dans la statut bar je suis preneur.
Aussi, j'aimerais avoir l'appli SMS avec un fond noir, ce fond blanc pique les yeux !
A part ça super rom, ça change !
Envoyé depuis mon GT-I9300 avec Tapatalk
Posté(e) (modifié)
L'appli SMS avec fond blanc est l'appli SMS de Google et il me semble qu'il n'est pas possible de changer les couleurs en mode "sombre".
Si tu veut un fond sombre tu sera obligé de passer par une application tierce comme Go SMS ou Handcent SMS.
(qu'on me corrige si je dis de la m**** ^^).
Et je ne m'encombrerai pas de ces usines à gaz ^^ Parfois on trouve des gapps en black là j'ai rien vu pour l'instant.
Petite combine pour activer le menu développeur : allez dans à propos du téléphone et tapez 7 fois sur "numéro de build"
Ainsi on peut activer le debogage usb et modifier les vitesses d'animation et transition :-D
Nickel ! Dès que je le recharge, je fais la modif, merci :)
Tu peux utiliser des thèmes, ça rajoute même le circle battery :)
Super, tu aurais des liens vers des thèmes compatibles stp ? Merci :-)
J'ai fais un topic qui épinglé un plus haut. C'est fais pour ça mais après tout, attend son avis :-)
OK merci j'irai voir.
Sinon c'est un peu l'horreur question batterie cette PA !
Bah change de kernel ou calibre la :)
Ça sert plus à rien depuis un moment les calibrages ;-)
Y'a quoi de compatible sur cette rom pour les kernels.
J'avais siyah sur la workship, il est pas mal pour les réglages audio déjà.
Mais je veux pas underclocker pour gagner en autonomie ^^
Bah c'est une cm10.1 donc, siyah, neak et Abys si je ne m'abuse...
J'ai téléchargé mais pas encore installé le dernier siyah. Peux tu me confirmer que c'est bien le 1.6.8 qu'il faut pour cette rom ?
Je vais quand même tester avant de basculer sur cyano ou retourner sur la workship.
Mais j'aimerais bien rester sur du 4.2!!
1.6.8? Non non la mise a jour c'est 1.8.9
http://d-h.st/dfI
