dada24 Posté(e) 19 mai 2013 Share Posté(e) 19 mai 2013 (modifié) 'Discreet Blue' MDM - ™ Toscha42 (v 0.4) [GT-I9505] Source xda : http://forum.xda-dev...d.php?t=2271332 Components themed so far: framework-res Optical elements of UI, like check-boxes, radio-buttons, tabs, bars etc. SystemUI Icons in status bar. Black status bar. Status bar clock in blue. Settings 'Over-colored' icons reduced in color. Contacts Contact pictures eliminated. Reduced line height for more contacts per page. Dialer Keyboard. File Manager Icons. Alarm Clock Backgrounds deleted. SMS / MMS Style of bubbles. Calculator Keyboard. Calendar Changed from brown look to grey. 11.05.13: v0.2 - Small cosmetics for icons.. - Icons size increased for connectivity status. - Version 0.2 now available as flashable zip-file 'Discreet Blue by Toscha42 v0.2'. - On special request SystemUI.apk with transparent status bar, flash only after the theme. 12.05.13: v0.3 - Settings dialogue - icon size fitted to suit display resolution.. - Download Update, the theme has to be installed first. 14.05.13: v0.4 - Bugfixing. - Icon cosmetics. - Download 'Discreet Blue by Toscha42 v0.4'. 15.05.13: Partial update - Bugfixing in settings. - Contacts and dialer themed. - Alarm clock themed. 24.05.13: v0.5 - Migrated onto vrtheme (Villain's Theme Flasher), though not longer restricted to XXUAMDM. - Download 'Discreet Blue by Toscha42 v0.5'. 30.05.13: v1.0 - Completely migrated onto vrtheme (Villain's Theme Flasher). The theme will run on all stock ROMs (odexed and de-odexed) and - most likely - also on Samsung-based Custom ROMs (not tested though). - Download 'Discreet Blue by Toscha42 v1.0'. - There's also a version available for those desperately in need for transparent status bar and notification bar. Flash only after you flashed the theme. 31.05.13: v1.01 - Some small inconsistencies corrected. - Download 'Discreet Blue by Toscha42 v1.01'. Delta-update only, v1.0 needs to be installed before. 01.06.13: v1.02 - Battery as percentage also in blue. - Delta-Update 1.01 included. Downloads: 'Discreet Blue by Toscha42 v1.02', Delta-Update only, v1.0 needs to be installed first. For those preferring a transparent status bar: 'Discreet Blue by Toscha42 v1.02 SystemUI transparent', Delta-Update only, v1.0 needs to be installed first. 02.06.13: v1.03 - Alarm clock icon (status bar) resized. - Text colors in S-Planner (calendar) adopted to theme. - Delta-Update 1.01 & 1.02 included. Downloads: 'Discreet Blue by Toscha42 v1.03'; Delta-Update only, basic theme v1.0 needs to be installed first. Installation : - copier le zip sur la mémoire téléphone (sd ou interne) - lancer le en recovery - choisir install zip - selectionner le zip dans la mémoire du téléphone (sd ou interne) - lancer le flashage - puis rebooter le téléphone TESTER SUR MDN : OK Currently not supporting MEA-ROM! Modifié 9 juin 2013 par dada24 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
raphoudu57 Posté(e) 19 mai 2013 Share Posté(e) 19 mai 2013 Merci du partage! Pourrais tu préciser dans ton titre pour quel type de s4 il est compatible :) Merci a toi Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dada24 Posté(e) 19 mai 2013 Auteur Share Posté(e) 19 mai 2013 voila c'est fait 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
