[ROM][CM10.1] Bean Stalk [Build 1.275]
Like what you see? Click the thanks button or Donate to scott.hart.bti by clicking HERE
Feature List.... Its a long one and growing every day!
  • CM based
  • Lockscreen background options (Colour fill, Custom image, Transparent)
  • Customizable Lockscreen text color
  • Lockscreen rotation
  • Option to enable all widgets
  • Minimize lockscreen challenge
  • Use widget carousel
  • Slider Short cuts
  • Static Lockscreen short cuts
  • Lockscreen button actions
  • LCD Density
  • Scroll elasticity options
  • Default App grip option
  • Custom Carrier label
  • Dual Pane options
  • Customizable boot animation (off, default, set your own bootanimation)
  • Status bar colour and transparency
  • Clock and date options which includes colour, location, style
  • Signal Styles which include colour and text instead of icons, alternate GB signal layout, hide signal icons
  • Breathing SMS option
  • Battery styles - Includes specific colours and styles. Also includes battery bar
  • Do not disturb option
  • Show notification count
  • Pie controls (need to have lockscreen background set to something other then default to work correctly (don't ask why) )
  • Fully customizable navigation bar - Includes style, layout, colour, nav rings, pretty much everything you can think of.
  • Quick settings colour settings, tiles per row, Quick pull-down, text colour
  • Notification short cuts, behaviour, drawer style (customizable colours), toggle colours, long press quicksettings icon to enable/disable toggles
  • Keyboard and input method options which include disable full screen keyboard and auto rotate
  • Kill app back button with customizable time-out values
  • High end graphic effects option
  • option to disable/enable vibrate on expand for notifications alerts
  • Low battery warning customizable options
  • Recents RAM bar fully customizable with colour styles
  • Clock widget for LockClock including extra options to fully customize every feature of the lockclock
  • Build.prop MOD options to enable/disable tweaks as preferred
  • Less frequent Notification sounds options
  • CRT screen off/on options to specify how the animation shows
  • Enable/disable wake up on charge option
  • Superuser fully embedded into the build and accessed from settings menu
  • CM Performance options and features
  • About BeanStalk option with links to github source and Facebook for beanstalk. Also links to my twitter and donate.
  • insane amount of edits/tweaks/fixes to make this build absolutely fly
  • option to use a fully themable MMS packages. You can access from MMS - settings - theme settings
  • Numerous other options hiding throughout the build
Known Issues:
- Hmm you tell me!
Downloads:
BeanStalk Build 1.275
GAPPs:
GAPPs
Instructions
Coming from another ROM
  • Wipe Cache / Factory Reset
  • Install ROM
  • Install Gapps from link above
  • Reboot
Thanks
This is a build composed off of the CM10.1 builds and I have added a lot of features on top of it. So you get speed, stability, and ultra customization ability. Many of the additional code additions came from slim ROM and also Derteufels build and have been modified to work with my current set-up. A huge thanks to Derteufel and the Slim ROM guys for their work and dedication. Also a big thanks to everyone involved with CM as that is the building stone in this project. Thanks to skyliner33v for the boot animation and upcoming wallpapers!
Sources
  • SlimROM source can be found HERE
  • DerTeufel's source can be found HERE
  • Beanstalk source can be found HERE
Modifié par Adamentys
Changelog :
Build 1.275 :
* New dialer
* Make contacts aware of blacklist settings
* Option to hangup and dial back from incallscreen
* Prompt when MMS storage is full
* Third part installing while HALO is active has been fixed
* Make shut down receivers a priority
* Specify notification types for auto hide status bar
* BeanStalk battery style and BeanStalk percent style. Thanks skyliner!
* Specify notification types for QS quick pull-down check
* Make Go to sleep tile/widget act just like the power button
* HALO - Keep apps in recents
* Recents RAM circle
* halo can save last position now
* activate qs and notifications toggle for nav ring
* Add an option to allow a (subtle) notification vibration during calls
* Add option to hide music controls in lock screen
* add reset option to clock colour and clean-up
* Changed the way that date format selector is shown
* Allow user to trigger a volume rescan
* Introduce Privacy Guard Manager
* Removed unnecessary tweaks and set some options at boot (similar to CM set-up)
Édit : arf ce matin bootloop, impossible d'utiliser mon téléphone, je retire pith,
Envoyé depuis mon Galaxy Nexus avec Tapatalk
Pareil hier oblige de full wipe... Je comprends pas
Envoyé depuis mon Galaxy Nexus en utilisant Tapatalk 4 Beta
C'est le kernel ak243 intégré à la rom qui pose problème, flashez le ak256 et plus de soucis :) .
  • 1 month later...
