watimica06 Posté(e) 24 août 2013 Share Posté(e) 24 août 2013 (modifié) Centralisation Des Mods Samsung GT-I9505 Frandroid, XDA et moi ne pourront être tenus responsable des conséquences sur vos téléphones. Toujours effectuer un backup avant d'installer un mod, attention il y a toujours un risque de BRIQUE. [MOD]3Minit Framework For Jellybean 4.2.2. DEODEXED roms only. Framework modifié regroupant plein d'option ci-dessous. Select Am pm sizeShow/Hide day on statusbarShow/Hide date on statusbarSelect date styleDay and date as uppercaseSelect center/right aligned clockSet any color time and dateFull battery notification on/offLow battery notification on/offUsb connection sounds on/offShow/hide No notification titleShow/hide ongoing titleshow/hide ongoing itemsSet statusbar to any color and transparencySet dropdown to any color and transparencyAny color batteryAny color wifi/data iconsAny color statusbar iconsAny color toggle iconsAny color toggle button backgroundAlarm icon on/offBluetooth icon on/offVibrate/Mute icons on/offLock screen button on statusbar on/offCarrier text on/offCustom carrier textAny color carrier textAny color battery textAny color/transparency dropdown headerAny color Header buttonsShow next alarm on dragbarAdd on button to dropdown header choose None/Recents/Clear/LockscreenToggles text on/offToggles indicator on/offAny color toggles textSet statusbar any imageSet dropdown any imageHex color setterSelect from 20 different battery typesSelect Time and date sizeOption to size dropdown clock tooSelect brightness slider text colorFast ShutdownFast RebootFast auto boot into recoveryLong press back kills app(multiwindow moved to menu key) orLong press menu kills current appSet any mid battery valueSet any low battery valueSet any mid battery colorSet any low battery colorShow/Hide batteryShow/Hide blocking mode iconAirplane mode icon is now coloredLong press volume buttons skips tracksWallpaper scrollingDrop down clock has its own colorDrop down date has its own color3 New toggles added:TorchPower OffReboot menu with (Reboot, Recovery, Download modes)Pressing home on lockscreen toggles torch (with on/off toggle in settings) can also be set to long pressOption to have 5 or 6 quicksetting toggles displayedAny color battery on/offToggle control (turn unused toggles on/off)Toggles order shortcut addedYou can now set data/wifi data arrows to stockChoose between 5 different 4g imagesAny no notification title text colorAny On going title text colorAny notification title text colorAny clear button text colorSet S View screen time outAny color S View timeAny color S View dayAny color S View dateAny color S View ap/pmAny color S View missed call textAny color S View sms notification textAny color S View playing track titleQuick pin unlockMulti widgets on secure lockscreenCamera on secure lockscreenHide lockscreen carrier textStock look setting (one click revert)No notification title backgroung colorOn going title backgroung colorLatest items title background colorAdded (so far many more to come) button actionsMenu long press {Default, Kill app, Multiwindow, Launch any app, Torch, Disable, Screenshot, Recent apps}Back long press {Default, Kill app, Launch any app, Torch, Disable, Screenshot, Recent apps}Home long press {Default, Kill app, Multiwindow, Launch any app, Torch, Disable, Screenshot}Home long press on lockscreen {Torch, Press and release torch, Disable}Donate version 3.0+ onlyCompletely re-writtenIme switcher on/offAdded date style (01/01/13)Space before am/pmHeader clock sizeHeader clock am/pm sizeHeader clock show and hide am/pmAny image toggle buttons background (5kb <) tested with image size(H92 W50 pixels)Any color dragbar imageDonate version 3.2 onlyAny image/color/transparency clear button in dropdownDragbar background ang color/transparencySmart eye icon on/offLoud volume warnings on/off3 Screen off effects {none, crt, fade}Resizable navigation barNotifications background any color/transparencyOn going notifications background any color/transparency [MOD] JKay Deluxe v0.5.2.1 alpha For XXUBMH1, XXUBMGA.Acces au parametre et aux applications acceleré. Petit, simple et rapide sans consomation de batterie. Requis CMW recovery [MOD][AROMA]CodexHD™ v4 Ultimate Regroupent de divers application Samsung et Sony ainsi que divers application d'autre constructeur permetant une meilleur optimisation et une meilleur exérience?? A TESTER System Apps ProBAMAsus SuperNote not works on i9003AirAccpet With GestureHovering ControlsOG youtube downloaderYouTube Popup Player3G and Wifi MeterWhatsup ModdedLG Pro Keyboard not works on i9003EyeSpyWallpaperPickerSystem Apps SamsungS4 launcher","Install S4 launcher/weather 5 x 4 cells widgetsSamsung Calculator > Calculator S4Samsung Memo > Install Memo S4Samsung Paper ArtistSamsung Smart ViewSamsung Voice RecorderSamsung HealtSystem Apps XPERIAHonami launcherHonami Media > Instal Xperia i1 Honami Z Ultra MEDIA APPS :: not works on android 4.3Honami Keyboard > Install Xperia KeyboardHonami NoteHonami Widget > Install Clock/OnOffTools/RecentCalls/Weather/Photos/Contact/MusicHonami TrackIDHonami Sketch > App by sony for drawing sketchSystem Apps ExplorerRoot File Explorer > JrummyRootBrowserFreeES File ExplorerMI File ExplorerCM File ExplorerSystem Apps MusicSamsung Music PlayerApollo Music PlayerSystem TweaksPimp My RomTweak ProBAM init.d > Speedups/Drop garbage in caches/Defrags database files/Zipalign/Renice on appsSystem n7100 onlyCMSPen not works on i9003SPen Helper not works oni9003 [MOD]Update Fix (CM10.1 Only) jfltexx Tout est dans le titre.N'OUBLIER PAS DE FIXER LES PERMISSIONS -Modified DSP Manager + Library to work properly with i9505 (jfltexx)-smooth scrolling (framework.jar)-mediaprofile.xml optimized-GPU tweak (at init.d folder and build.prop) : only for CM kernel (nenamark2 60.2 fps)-reduced : bootanimation size / screen density (440) => looks better [MOD]Volume Boosting Sound Mod permettant de booster le son (2 niveau différent a télécharger + Stock) [KERNEL/MOD][AROMA] Kernel Chooser V0.4 Mod permettant de choisir via l'aroma installeur un Kernel (Stock,OC,etc...) [MOD][TWEAK-PACK]ComaDose Mod augmentant la vie de la Batterie, augmente la réactivité de la connection internet et des performances systemes et lock le gps.Beaucoup de tweak sont fournit a tester. Tweaks include-Crossbreeder V7.2.13 (Idcrisis link in the thanks section)wifi_wait (Kobridge)gps.conf (Exit_Only & g_ding)Memory tweaks (Modded Kobridge)Test screenstate Variant (screen off = deep sleep, Modded Phakker)Init.d test script (Exit_Only)NOS - Injection (modded) (Exit_Only)and moreInfromation About CrossBreeder-- This is a new take at Android lag reduction. It's lightweight and won't consume battery. Users have reported drastic improvements in usability and even benchmark scores. It will show noticeable improvements - Android devices from Donut to Froyo to Gingerbread to Honeycomb to ICS and Jellybean.- This is a combination of 5 different methodologies to reduce Android lag.- Removal of DNS lag . A lot of the lag in a lot of apps, apart from the GUI lag, is due to slow DNS querying, specially on the mobile network.- CrossBreeder now runs a caching, parallelising DNS client on the device. So now most of your DNS queries will be served from the cache and if not found, the query will be sent in in round robin fashion to multiple DNS servers including Google DNS, OpenDNS and your home router and the reply will be served to you, hot.- This speeds up network access and networked apps, like Browsers of course, and Tapatalk, Gmail and thousands of others drastically. And removes a lot of the lag where it was due to DNS querying. This will not increase your network or download speed but pages will load much faster.- This will future proof your devices as more and more apps start using HTML5 and/or reside completely as web pages or the like.- [MOD]Swap sdcard Permet d'installer la data des applications sur la carte sd. [MOD]3Way Reboot Ajoute un menu reboot au Power Menu. [MOD][ME2/ME3]Black Statusbar / Battery Full Notification disabled Toute est dans le titre. ONLY DEODEX [MOD][MFD]Extended Power Menu for SimBug Ajoute "hot reboot" au Power Menu. [MOD][MEA]Extended Power Menu Ajoute "hot reboot" au Power Menu. [MOD/PORT] Bravia Engine 2 & Sound Driver Ajoute le mod Bravia Engine 2 et les Driver Son du Xperia Z [MOD]Docs AOSP-a-Lizer Transforce l'UI de certaine application en UI ICS Contacts and DialerBrowserCalendar (Dark themed with Calendar with Textview (month) mod)Email (Inverted)CalculatorMMS (Inverted) [MOD] All in 1 Mods Inclue plusieur mod dont le Power Menu extented, le Transparent Multiwindw - CRT-OFF Mods- All Apk in MultiWindow- Transparent Multiwindw- Extended Power menu 4- Disable scrolling cache- Disable signature check [MOD][MDN/ME2/MEA/MF8] All Apps Multiwindow Permet d'utiliser toutes les applications en Multi-Fenêtre [MOD] Enable navigation bar 4.2.2 Ajoute la Nav Bar (peu utile) [MOD][MF8]SecSettings Torchlight Option Ajoute le Mod Lampe Torche. DEODEX ONLY. [MOD][MF2/MF4/MF8]7 apps lockscreen+INK effect+MIUI BatteryBar Ajoute 7 lockscreen, la batteryBar du célèbre MIUI et des effets sur le lockscreen Merci de partager, liker et signaler tout problème, merci. Modifié 24 août 2013 par watimica06 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LudoS20 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 Support topic ! Peut on flasher Jk sur une rom stock? si je suis en XXUBMGA Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
alex971 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 Bonsoir, Sujet déplacé et épinglé ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
watimica06 Posté(e) 7 septembre 2013 Auteur Share Posté(e) 7 septembre 2013 Support topic ! Peut on flasher Jk sur une rom stock? si je suis en XXUBMGA Oui, du moment que tu possède un recovery Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LudoS20 Posté(e) 7 septembre 2013 Share Posté(e) 7 septembre 2013 Sur leur topic ils parlent de cwm mais twrp est bon aussi? Envoyé depuis mon GT-I9505 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
watimica06 Posté(e) 10 septembre 2013 Auteur Share Posté(e) 10 septembre 2013 Sur leur topic ils parlent de cwm mais twrp est bon aussi? Envoyé depuis mon GT-I9505 avec Tapatalk Oui, du moment qu'il s'agit d'un recovery Custom Fonctionnel. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Johann Ridarch Posté(e) 19 septembre 2013 Share Posté(e) 19 septembre 2013 Puis-je flasher le MOD ComaDose sur une stock MGA ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ultra-config Posté(e) 20 décembre 2013 Share Posté(e) 20 décembre 2013 Centralisation Des Mods Samsung GT-I9505 Frandroid, XDA et moi ne pourront être tenus responsable des conséquences sur vos téléphones. Toujours effectuer un backup avant d'installer un mod, attention il y a toujours un risque de BRIQUE. Désolé mais c'etait trop tentant le risque de BRIQUE :D :D :D :D :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
