pratikmore Posté(e) 4 septembre 2013 Auteur Share Posté(e) 4 septembre 2013 please dont worry after small time i will upload build 2 but i cant correct front camera :) why front camera is not working....only one issue is remaining... 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 after last install i will upload beta2 but we have not front camera, works about this late :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
navet94 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 Both of you, many thanks. You are awesome. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 friends its may be problems :) its beta test ! for fr gps go to the system/etc/gps.conf and change ru to fr ofc 1st download epo its more time its not as 4.1 just wait :) gps is working but at my street rain and i dont know... sensivity =15-20 metrs and test after antutu =8458 at my fly jb android 4.2 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
navet94 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 friends its may be problems :) its beta test ! for fr gps go to the system/etc/gps.conf and change ru to fr ofc 1st download epo its more time its not as 4.1 just wait :) gps is working but at my street rain and i dont know... sensivity =15-20 metrs and test after antutu =8458 at my fly Screenshot_2013-09-04-21-14-16.png jb android 4.2 Do you change the problem with the SIM card ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 sorry i have not understand where is problems with sim cards, i have not this problems but late if any problems may be u can add etc/mddb file from wiko its as vote... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
navet94 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 sorry i have not understand where is problems with sim cards, i have not this problems but late if any problems may be u can add etc/mddb file from wiko its as vote... Ok, thx for your answer. I will test your beta 2 and I will tell you if I have any problem ;) 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 i just start it at english for 1st boot and i havent problems with start as eng and ru Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
navet94 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 i just start it at english for 1st boot and i havent problems with start as eng and ru Same problems with SIM card. I test my wife's SIM card too (which is a B&YOU card, like me) and same problem :( I will test to change the lib with the wiko's lib, later. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Damien Compagnon Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 Dans le build.prop de PRATIKMORE, fmradio.driver.chip=1 alors que les buildprop wiko donnent fmradio.driver.chip=3 mediatek.wlan.module.postfix=_mt6620 doit être transformé en mediatek.wlan.module.postfix=_mt6628 mediatek.wlan.chip=MT6620 serait plutot mediatek.wlan.chip=MT6628 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KevinVauth Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 (modifié) Alors je vi[color=red][b]ent[/b][/color] de mettre cette dernière version de QUS1 : All Wipe Install : ok 1er boot : reboot au choix de la langue, alors au bout de quelques rebout j'enleve la carte sim et nikel je peut configuré android. 2eme boot Avec carte SIM : Reboot a la saisie de code pin.... donc impossible de testé avec la sim. Modifié 4 septembre 2013 par hell_warrior Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 (modifié) pin cod at my sim off may be problem here? may be after i removed some libs its bad for pin code :( Modifié 4 septembre 2013 par qus1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KevinVauth Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 pin cod at my sim off may be problem here? Yes at the pin code I have a problem, I was not against trying without code. but otherwise it is very fluid, it looks really good Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 just now me need back libs for pincods, search now Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KevinVauth Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 just now me need back libs for pincods, search now Good luck, but there remains much finally, well done Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 guys i will upload beta2 new and who downloaded my build beta 2 i will upload rar file just add this libs at way /system/lib and no problem with start as i think sorry because i havenot pin i dont know about this problem Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KevinVauth Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 Thank you man Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 rar libs please u can test, i cant test without pin and dont know lib for pin just add all libs :D and reinstall rom if all right then i upload correct build Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KevinVauth Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 rar libs please u can test, i cant test without pin and dont know lib for pin just add all libs :D and reinstall rom if all right then i upload correct build Je suis désolé je pourrais tester que ce soir vers 00H30 heure francaise Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 navet u can test it Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
navet94 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 navet u can test it Yes i'm on it ;) Give me 30 minutes, maybe less Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 or easy method this is rom build 2 with libs build 2.1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
navet94 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 (modifié) or easy method this is rom build 2 with libs build 2.1 I download your version and modify the beta 2 with your libs.I will try both versions and ask you if it's work ;) "My modified version" installed, first boot --> same problem :( :( :( Install your modified version --> ok, first boot --> same problem, problem with my SIM card. I will try to remove my pin code --> pin code removed --> it's works !!!! The problem comes with a SIM card with a pin code ;) Modifié 4 septembre 2013 par navet94 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 (modifié) i think this problem only one then both build can be install :) Modifié 4 septembre 2013 par qus1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
navet94 Posté(e) 4 septembre 2013 Share Posté(e) 4 septembre 2013 (modifié) So, as I said in my precedent post : Remove the pin code does the phone works normally. If I add a pin code and restart the phone, the phone reboots like other time ... So the problem comes with a SIM card which has a pin code. Edit : As Di Caprio said : "Gentlemen, you had my curiosity. But now you have my attention." So I start my shitty laptop and I will compare your both rom to Pratikmore and yours, QUS1. I know that Pratikmore's rom works on my Peax so maybe I can find something ;) Modifié 4 septembre 2013 par navet94 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
