[ROM] 4.2.2 Port for Fly 443/Wiko Cink Peax/Intex Aqua Wonder (Fully Working)
Autant pour moi :)
Pas de problème, c'est déjà gentil de proposer ;)
Sinon :
Backup of my actual ROM ==> done
Installation ==> OK
First Boot ==> OK
Pin ==> OK
I will test the GPS during my lunch time.
Can't test Wifi and Bluetooth because i have no equipments for testing.
By the way, nice work QUS1 :D
Modifié par navet94
yeas we can fix it as i think get me 5 min and i will write
delete this /system/app/OP02Plugin.apk
and this from build.prop
ro.operator.optr=OP02
ro.operator.spec=SPEC0200
ro.operator.seg=SEGA
Modifié par qus1
gps conf here etc/gps.conf if u have not just add from 4.1
for nice gps u need download epo and after search :) but i dont how it works at my home in window, late if any problem with search i can check this
Modifié par qus1
ho ok lol, I am sorry :D
Good job, I think I stayed in this rom;)
GPS : ok ^^ I scratched a little layer on the gps and niquel 7s to fix me
 TWRP ;)
Ou ClockWorkMod aussi ;)
GPS ==> OK, j'ai rajouté à l'arrache un gps.conf trouvé sur le net.
1er fix en 1 minute :
Reboot du tel et attente de 10 minutes, re-test du GPS, fix 7 sec :
Une précision de ouf, je fix toujours avec 10m et ça descend rapidement entre 4 et 6m.
Dans 1H, j'ai fini le taf et je vais tester sur un trajet de 30 min ;)
GPS ==> OK, I add a gps.conf find on the net.
1st fix in 1 minut :
Reboot Peax and wainting 10 minutes, re-test GPS, fix 7 sec :
Great accuracy, I always fix with a precision of 10m and it decrease fastly between 4 and 6m
In 1H, i leave my job and so i will test the GPS with a 30min journey ;)
Modifié par navet94
front camera its one big problem now, and i have not idea for fix it, more time bootloop if change the libs i know we can add libcameraprofile and change libcameraservice, and we have front camera after change lib/hw/camera camera here but frontcamera fc...
Modifié par qus1
Très intéressant ça, tu l'as trouvé où ? :) Je vais tester la beta 3 je crois d'ici peu de temps :)
Après je sais que pour le GPS.conf, il y a des fichiers beaucoup plus succints et aussi efficaces (comme ceux dans les roms 4.1.2 de Superdroid, Gaston ou Spanish).
Mais j'étais dans la rue avec uniquement mon tel donc j'ai fait ça à l'arrache et force est de constater que ça fonctionne :)
Très bon ROM ! Franchement elle tourne super bien, bon grâce à morelocale2 on traduit certaines choses en français, ce qui est bien, mais tout est loin d'être en français... Le tél semble chauffer par contre, je crois que ça avait été signalé (proco qui tourne peut être trop à fond)
Essaie d'installer MTK gouvernor, active le service en mode hybrid et reboot :
http://forum.xda-developers.com/showthread.php?t=2186957
En mode Ondemand ca marche aussi pas mal, mais faut d'abord règler les paramètres du mode. perso je met les mêmes valeurs que celles entre parenthèses, sauf pour le powersave bias que je met à 4. Après on peut voir l'utilisation des deux proc avec la visu graphique de l'appli.
hello,
crash when go to setting->display->scenes = Unfortunately settings has stopped
No problem for me.
Pour moi ça marche. essaie de faire un full wipe avant l'install..
OK !
My test :
GPS ok (i'v added this files into system/etc http://damcomp.free.fr/divers/gps.zip)
fluid and stable
Wifi + bluetooth ok (i can pair my joypad :) no more reboot. )
wifi signal is weak, like other 4.1.1 from wiko...  there is only the [mention d'application hors charte] rom that allows me to have a good signal outside the room of my box is located (freebox)
No more 3G icon after i remove this few lines in buildprop
radio FM is working
There is the same problem with audioeffect. (the sound makes some..waves.)
no front camera
Everything else work for the moment
I'll test battery drain this night.
full wipe /cache /data etc -->done
crash  clavier xperia
encore plein de tuc en chinois / many things in chiness
hum...
avec la  patrikrom j'essaye celle de qus1  /this crash  with patrikrom i try  qus1 rom
Modifié par salocain
