Les codes secrets du Galaxy S
kainomed
repris de XDA forum... http://forum.xda-developers.com/showthread.php?t=721111
i9000 Secret Codes to play with
If you know other codes please post them ...
*#*#4636#*#* for battery and other general setttings like GSM/CDMA
*#*#8255#*#* for Gtalk service monitor
*#*#7780#*#* for factory data reset
*#*#34971539#*#* for information about phone camera (be very careful hitting options here)
*#*#7594#*#* change the "Power" button action in your phone.
*#*#197328640#*#* service mode
*#197238640# service mode
*#0*# testing mode
*#06# view IMEI number
*#1234# display phones current firmware
*#*#1472365#*#* gps test
*#0011# network mode/cell info/power info
*#*#0*#*#* screen test menu
*#7465625# engineering mode
*#9900# Sysdump screen.. some sort of way to dump ram and other logs to sd card
by izmenar
on sait jamais... ca peut servir... ;)
des explications sur les codes là... (tjr en english)
http://forum.gsmhosting.com/vbb/f258/samsung-galaxy-s-working-codes-1046184/
Modifié par kainomed
Tu as aussi les codes génériques des telephones Samsung:
#1234# = Firmware Version.
*#2222# = H/W Version.
*#8999*8376263# = All Versions Together.
*#8999*8378# = Test Menu.
*#4777*8665# = GPSR Tool.
*#8999*523# = LCD Brightness.
*#8999*377# = Error Menu.
*#8999*327# = EEP Menu.
*#8999*667# = Debug Mode.
*#92782# = PhoneModel. (Wap)
#*5737425# = JAVA Mode.
*#2255# = Call List.
*#232337# = Bluetooth MAC Adress.
*#5282837# = Java Version.
#*4773# = Incremental Redundancy.
#*7752# = 8 PSK uplink capability bit.
#*7785# = Reset wakeup & RTK timer cariables/variables.
#*7200# = Tone Generator Mute.
#*3888# = BLUETOOTH Test mode.
#*7828# = Task screen.
#*#8377466# = S/W Version & H/W Version.
#*2562# = Restarts Phone.
#*2565# = No Blocking? General Defense.
#*3353# = General Defense, Code Erased.
#*3837# = Phone Hangs on White screen.
#*3849# = Restarts Phone.
#*3851# = Restarts Phone.
#*3876# = Restarts Phone.
#*7222# = Operation Typ: (Class C GSM)
#*7224# = !!! ERROR !!!
#*7252# = Operation Typ: (Class B GPRS)
#*7271# = CMD: (Not Available)
#*7274# = CMD: (Not Available)
#*7337# = Restarts Phone. (Resets Wap Settings)
#*2787# = CRTP ON/OFF.
#*2886# = AutoAnswer ON/OFF.
#*3737# = L1 AFC.
#*5133# = L1 HO Data.
#*7288# = GPRS Detached/Attached.
#*7287# = GPRS Attached.
#*7666# = White Screen.
#*7693# = Sleep Deactivate/Activate.
#*7284# = L1 HO Data.
#*2256# = Calibration info? (For CMD set DEBUGAUTONOMY in cihard.opt)
#*2286# = Databattery.
#*2527# = GPRS switching set to (Class 4, 8, 9, 10)
#*2679# = Copycat feature Activa/Deactivate.
#*3940# = External looptest 9600 bps.
#*4263# = Handsfree mode Activate/Deactivate.
#*4700# = Please use function 2637.
#*7352# = BVMC Reg value (LOW_SWTOFF, NOMINAL_SWTOFF)
#*2558# = Time ON.
#*3370# = Same as 4700.
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep.
#*7462# = SIM Phase.
#*7983# = Voltage/Freq.
#*7986# = Voltage.
#*8466# = Old Time.
#*2255# = Call Failed.
#*5187# = L1C2G trace Activate/Deactivate.
#*5376# = DELETE ALL SMS!!!!.
#*6837# = Official Software Version: (0003000016000702)
#*7524# = KCGPRS: (FF FF FF FF FF FF FF FF 07)
#*7562# = LOCI GPRS: (FF FF FF FF FF FF FF FF FF FF FF FE FF 01)
#*2337# = Permanent Registration Beep.
#*2474# = Charging Duration.
#*2834# = Audio Path. (Handsfree)
#*3270# = DCS Support Activate/Deactivate.
#*3282# = Data Activate/Deactivate.
#*3476# = EGSM Activate/Deactivate.
#*3676# = FORMAT FLASH VOLUME!!!
#*4760# = GSM Activate/Deactivate.
#*4864# = White Screen.
#*5171# = L1P1.
#*5172# = L1P2.
#*5173# = L1P3.
#*7326# = Accessory.
#*7683# = Sleep variable.
#*8465# = Time in L1.
#*2252# = Current CAL.
#*2836# = AVDDSS Management Activate/Deactivate.
#*3877# = Dump of SPY trace.
#*7728# = RSAV.
#*2677# = Same as 4700.
#*3728# = Time 2 Decod.
#*3725# = B4 last off.
#*7372# = Resetting the time to DPB variables.
#*7732# = Packet flow context bit Activate/Deactivate.
#*6833# = New uplink establishment Activate/Deactivate.
#*3273# = EGPRS multislot. (Class 4, 8, 9, 10)
#*7722# = RLC bitmap compression Activate/Deactivate.
#*2351# = Blinks 1347E201 in RED.
#*4472# = Hysteresis of serving cell: 3 dB
#*2775# = Switch to 2 inner speaker.
#*9270# = Force WBS.
#*7878# = FirstStartup. (0=NO, 1=YES)
#*3757# = DSL UART speed set to. (LOW, HIGH)
#*8726# = Switches USBACM to Normal.
#*8724# = Switches USBACM to Generator mode.
#*8727# = Switches USBACM to Slink mode.
#*8725# = Switches USBACM to Loop-back mode.
#*3838# = Blinks 3D030300 in RED.
#*2077# = GPRS Switch.
#*2027# = GPRS Switch.
#*0227# = GPRS Switch.
#*0277# = GPRS Switch.
#*8370# = Tfs4.0 Test 0.
#*8371# = Tfs4.0 Test 1.
#*8372# = Tfs4.0 Test 2.
#*8373# = Tfs4.0 Test 3.
#*8374# = Tfs4.0 Test 4.
#*8375# = Tfs4.0 Test 5.
#*8376# = Tfs4.0 Test 6.
#*8377# = Tfs4.0 Test 7.
#*8378# = Tfs4.0 Test 8.
#*8379# = Tfs4.0 Test 9.
#*22671# = AMR REC START.
#*22672# = Stop AMR REC. (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673# = Pause REC.
#*22674# = Resume REC.
#*22675# = AMR Playback.
#*22676# = AMR Stop Play.
#*22677# = Pause Play.
#*22678# = Resume Play.
#*77261# = PCM Rec Req.
#*77262# = Stop PCM Rec.
#*77263# = PCM Playback.
#*77264# = PCM Stop Play.
#*22679# = AMR Get Time.
*#8999*364# = Watchdog ON/OFF.
*#8999*427# = WATCHDOG signal route setup.
*2767*226372# = Camera Reset. (deletes photos)
*2767*3855# = E2P Full Reset.
*2767*2878# = E2P Custom Reset.
*2767*927# = E2P Wap Reset.
*2767*226372# = E2P Camera Reset.
*2767*688# = Reset Mobile TV.
#7263867# = RAM Dump. (On or Off)
je pense aussi... ;)
il serait bien utile que les modos créer des sous sections comme sur XDA
- ROMs
- Applications samsung market
- Jeux
- Gps
- Matériels
- Thèmes
etc...
Avant que le fil ne prend trop d'ampleur... :rolleyes:
C'est long et fastidieux mais plus facile pour l'utilisateur finale
  • 4 weeks later...
Hello à tous
Premier post... grâce au Galaxy S j'avoue, que j'ai réussi à obtenir avec une belle réduc en harcelant BT, en renouvellement de teléphone il y a 3 semaines.
Novice en android, c'est mon premier smartphone. Donc pour l'instant je suis sage dans son utilisation.
J'ai quand même fouillé un peu avec la découverte des codes : Sympa le 4636 qui permet de mettre le téléphone en GSM seul (donc exit la 3G).
J'ai aussi testé le code suivant : *#*#7594#*#* change the "Power" button action in your phone.
En effet cela permet qu'avec un appui long le téléphone s'éteigne directement sans passer par le mode : profil avion etc.
Sauf que... parce que ce serait trop simple... j'ai vécu une mésaventure à la suite de ce changement d'option.
J'ai éteint mon portable plusieurs heures après ce changement d'option. Mais quand je l'ai rallumé, le GS ne reconnaissait plus ma carte sim : le picto "absence de carte sim" était mis et il ne me demandait pas mon code pin (option cochée) à l'allumage.
Après plusieurs tests :"je retire la carte sim, je la remet", " je retire la carte sim, je la nettoie, je la remet", puis "je retire la carte sim et j'en met une autre à la place" et surtout après avoir testé ma carte sim dans un autre portable (là aucun problème) : verdict : ce n'est pas ma carte sim vieille de 11 ans qui a lâché... Après plusieurs cogitations et recherches sur internet (et ce forum), je me dis : "mon superbe GS est out"
Et puis j'ai eu l'idée de rechanger l'option du bouton Power. Ce que j'ai fait.
Après avoir éteint puis rallumé le GS : ma carte sim était reconnue sans problème !!!!
Donc je ne connais absolument pas la cause de ce comportement mais je préférais prévenir au cas où d'autres vivraient la même chose. J'espère que cela leur évitera l'angoisse que j'ai vécu pendant 50 mn !!!
En tout cas, mille merci à ce forum et à toute l'aide apportée !
  • 2 months later...
Bonjour tout le monde.
Merci pour cette liste de codes. C'est certainement très utile, mais je m'y perds.
Alors, dans l'ordre :
  • Samsung Galaxy S i9000
  • je suis passée jeudi dernier sur la dernière version de Froyo. (tout allait bien)
  • J'ai installé AutoTask Killer il y a 1h.
  • et pintade que je suis, je me suis amusée à tout désactiver.
Résultat : le téléphone est dans les choux. mais j'ai réussi à avoir accès au clavier.
Donc, ma question est la suivante :
Dans le fourgon des codes listés ci-dessus, y en a-t-il un qui pourrait resoudre mon problème et lequel ?
(je n'ai pas créé de nouveau sujet étant donné que c'est en priorité un code que je recherche. Cependant comme ce n'est quand meme pas la section pour résoudre les problème je comprendrais que vous me tapiez sur les doigts pour avoir pollué un topic qui n'est pas là pour ça... :) )
EDIT : Veuillez m'excuser pour le dérangement. il a suffi que je clique sur "envoyer la réponse" et j'ai trouvé seule la solution à mon problème. Pardon du dérangement. o/
(en fait il fallait maintenir augmenter le volume et Home alors que le téléphone est allumé... je n'avais pas compris ça. du coup, j'ai pu désinstaller l'appli qui me faisait des misères.)
Modifié par Konekochan
  • 1 year later...
