M.A.J Android 4.4 Kit Kat en développement !
Bonjour à tous, je vous apporte une bonne nouvelle !
D'après Motorola la mise à jour 4.4 Kit kat pour nos Motorola Razr i verra bien le jour car celle-ci est en développement.
Par contre aucune date, comme d'habitude il va falloir être patient.
Je tiens cette information du forum xda-developers.com dont voici le lien :
http://forum.xda-developers.com/showthread.php?p=47222540
Voici le résumer de la conversation, également jointe en *.PDF :
Hi guys!
I've just talked with the Morotola's brazilian support and they confirmed to me that we are going to receive the Android 4.4 KitKat upgrade, they just don't know when. Below, is my transcription of the chat in english (sorry if it's not perfect) and, attached, the PDF in portuguese (Brazil).
Motorola Support Chat Transcription
Michele: Hi, my name is Michele. How can I help you?
Carlos: Hello Michele, good morning
Michele: Good morning!
Michele: How you're doing?
Carlos: Fine
Carlos: I have a Motorola RAZR i (XT890) and would like to know if it will receive any update for an Android version newer than the current one, the 4.1.2?
Carlos: For example, for the Android 4.4?
Carlos: If yes, when? Any prediction?
Michele: The device will receive the 4.4 upgrade, but we don't an official date for lauching it, Carlos.
Michele: I have an important advice for a better performance of your device. I recommend that you shutdown your phone at least once for each 24 hours. By shutting it down, the memory will be clean, your cache will be empty and any fail situations in PA (app processor) will be released, giving you a better performance in general.
Carlos: Ok, acknowledge.
Carlos: Ok. Can you tell me if this version is already in internal testing?
Michele: I don't know, Carlos, because this updates was lauched this week in USA.
Carlos: I see
Carlos: Is there any way for being notified when this upgrade is ready, or just waiting?
Carlos: Like, when it's available?
Michele: As soon as it get available we will lauch in our website, social networks and your will receive it in your device.
Carlos: Ok!
Carlos: It was just that, Michele
Michele: It was a pleasure to help you today, I would like you to participate a survey about my assistance. I would be very thankful for any comment or sugestion that you could offer to us, your opinion is very important to me. For the survey to be available, its important that you click in "Disconnect" and only after that, click "Close". The Motorola thank you for the contact and will be available for any other doubt that you may have, we wish you to have a nice day and an excellent weekend!
Carlos: Thank you very much for the information and have a nice day!
Carlos: Sure, no problem
Michele: ^^
Carlos: kss!
Michele: Kisses, Bye!
Michele disconnected.
Hope that you liked it!
Cheers!
Ah se serais géniale mais j'y crois plus trop
Avec le root et le bootloader déverrouiller tu pourra faire en sorte d'avoir une réelle vie privée.
Modifié par Renaf
Ah çà sent très bon tous çà
pardon, mais comment ?
ce que je vois jusqu'à présent, c'est google+ qui s'invite partout (picasa par exemple), google now qui propose de faire des messages automatiques aux proches quand on quitte le boulot ...non merci
en revanche si le root + bootloader deverouillé permet de supprimer les trucs comme ça alors pourquoi pas ...
Pas forcément les supprimer mais gérer les permissions et congeler les applis par exemple après tu peux aussi supprimer toute les applis google et installer des applis alternative ....
mais j'ai envie de dire que malheureusement si tu veux profiter pleinement de ton smartphone t'es obliger d'avoir google après à toi de faire attention a se que tu met comme info dans ton téléphone et / ou de protéger tes informations et tes photos avec des applis faite pour (root ou non root faut voir se qui est proposer sur le playstore) etc ....
Et pour se qui est de la géolocalisation tu peux ou non autoriser via les paramètres si google peux te localiser mais la aussi si tu veux profiter pleinement de ton smartphone tu autorise
Faut quand même dire que google c'est android si tu enlève google de ton smartphone j'ai envie de dire y a plus d'intérêts à avoir un smartphone et pis dans tous les cas google ou non à partir du moment ou ta un smartphone ta plus de vie privé ( ton opérateur te pique toute tes infos et dès que tu installe une applis qui a un peu trop d'autorisation c'est pareille ; a partir du moment ou tu allume ton smartphone après l'achat de celui ci et que tu fais la première configuration c'est loupé pour avoir ta vie privé et pis la synchronisation c'est pareille une fois que le réseau fonctionne hop c'est pompage d'info lool )
Ben avec le razr i pour être rooter faut déverrouiller le bootloader l'un ne va pas sans l'autre voir les tutos ....
LBE sécurity Master est un bon logiciel qui justement controle bien tout sur ton mobile pour savoir qu'elle applis fait quoi recherche cette applis sur xda par exemple
Modifié par Renaf
Bonjour, sur le fameux topic de xda, il est aussi dit, que d'autres personnes du support répondent qu'elles n'en savent rien etc!
Concrètement motorola n'a strictement rien dit, le support n'a donc aucune information réelle!
Donc pas de joie trop rapide. ;)
Tout à fait.
Une "information" provenant d'un "conseiller" du support technique n'a jamais eut la moindre valeur. Ces personnes n'en savent que dalle et tant qu'il n'y a pas une communication par les voies officielles il ne faut pas prendre cela pour argent comptant.
Vaut mieux oublier cette idée, motorola n'a prévus des mises à jours que pour leurs nouveaux smartphones, on a pas eu de mise à jour non plus vers une 4.2..
CM est largement plus probable de voir le jour contrairement a kitkar sur nos razr i
  • Like 2
Mis à jour vers 4.4 confirmée par Moto sur ces modèles :
  • Droid RAZR M (including the developer edition model)
  • Droid RAZR HD
  • Droid RAZR MAXX HD
  • Atrix HD
  • Electrify M
Pas de date de prévue pour le moment... et pas d'info concernant le Razr I.
http://www.androidauthority.com/
  • 4 weeks later...
Rien n'est encore perdu et le fait que le razr M y est est un point positif, mais comme dit ça ne garantie strictement rien. C'est juste une note d'espoir sup. Il n'y avait aucune chance que le razr i soit mis à jour si le razr M ne l'était pas, ça laisse juste une possibilité donc.
  • 2 months later...
Youhou !!!
mais je ne comprends pas très bien la capture de gadzio...A-t-on des détails sur le déploiement?
C'est en tout cas une excellente nouvelle, avec CyanogenMod, il y a de quoi redonner un peu d'intérêt à notre Razr i !
La capture confirme que android 4.4.2 est prévu pour le razr i c'est tout.
Va voir là en gros:
https://motorola-global-portal-fr.custhelp.com/app/software-upgrade-news/g_id/1977/#gs=eyJndWlkZUlEIjoxOTc3LCJxdWVzdGlvbklEIjoxMCwicmVzcG9uc2VJRCI6OCwiZ3VpZGVTZXNzaW9uIjoiVlBoTnhZTmwiLCJzZXNzaW9uSUQiOiJqa0RleFlObCJ9
Et tu auras:
MOTOROLA RAZR i
Le logiciel de cet appareil sera mis à niveau vers la version KitKat (Android 4.4.2)
Vérifiez si vous possédez le dernier logiciel Motorola.
Modifié par Burn2
  • 2 months later...
David Schuster
18:57
 1
Répondre
RAZR i is making good progress and is going into the final testing phase which precedes the carrier lab testing cycles. I will give you guys an update when we are close to entering some of the carrier labs. Thanks for being patient....
  • 2 months later...
