kimo06 Posté(e) 18 novembre 2014 Share Posté(e) 18 novembre 2014 (modifié) Back to JB because of KitKat limitation with sd card Modifié 18 novembre 2014 par kimo06 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 18 novembre 2014 Auteur Share Posté(e) 18 novembre 2014 this is problem because symlink for system/xbin/su doesnt work true in updater-script will be fixed beta2 rom updater-script text symlink("/system/xbin/su", "/system/bin/su"); //removed set_metadata("/system/bin/su", "uid", 0, "gid", 0, "mode", 06755, "capabilities", 0x0, "selabel", "u:object_r:system_file:s0"); //added + copy file from system/xbin/su to system/bin/su and root is working 3 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cesar Matias Posté(e) 18 novembre 2014 Share Posté(e) 18 novembre 2014 Hello qus. Im superdragonpt from xda. Good job. I worked on KK port from LG pro + new KK kernel some months ago. If you need any help, i would be more than happy to help you. ( my rom didn't properly booted at the time, kernel related and selinux problems...) I didnt continue that work, becouse i start working on my wiko darkmoon kernel (mt6582) made from scratch. Regards Ps: I can give you acess to my private git repos... ;) 3 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 18 novembre 2014 Auteur Share Posté(e) 18 novembre 2014 (modifié) hi , kk from lg pro lite start too, but after re-size, its hard way for install + some problems high phone temperature (phone cant sleep), doesnt detect combo because lg with combo 6620, + memory is full because after resize for install needed 1.8gb for part /system my port more stability, because motorola more easy phone + doesnt need re-size + update for recovery if someone wanna create kernel for another 6577 its easy, because i created 3 kernels, u can see some source from my github at 1post if u or someone people at xda need help with create kernel, just pm me, if phone with kernel source 3.4.0, me need 1 hour for update kernel from 3.4.0 to 3.4.67 Modifié 18 novembre 2014 par qus1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cesar Matias Posté(e) 18 novembre 2014 Share Posté(e) 18 novembre 2014 Well i already made for zte v970: Keenel 3.4.0 and upstream to --> 3.4.5 --> 3.4.11 I have an 3.4.67 kernel made, not sure if its fully functional but it boots on jb 4.1/ 4.2 Yes i see that Moto's rom seems easier, good find. The LG is really big rom... I will post my source later, im on phone ;) Regards 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
haboub Posté(e) 18 novembre 2014 Share Posté(e) 18 novembre 2014 Any idea how i can hide button in screen with xposed framework !!!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
curtis91 Posté(e) 18 novembre 2014 Share Posté(e) 18 novembre 2014 hello where is the Burton Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ftacipher Posté(e) 18 novembre 2014 Share Posté(e) 18 novembre 2014 Le 18/11/2014 à 20:19, haboub a dit : Any idea how i can hide button in screen with xposed framework !!!! Install the module gravityBox(KK) and then go to navigation bar menu and modify the sizes (length, width...) to zero 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
haboub Posté(e) 18 novembre 2014 Share Posté(e) 18 novembre 2014 Thx a lot Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kevo Posté(e) 18 novembre 2014 Share Posté(e) 18 novembre 2014 Thxxx !!!!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
curtis91 Posté(e) 19 novembre 2014 Share Posté(e) 19 novembre 2014 Hello Qus CAmera front and back are ok , i m checkin symb link to sd Thank u Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 19 novembre 2014 Auteur Share Posté(e) 19 novembre 2014 check camera at snow street with blue effect bug Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
haboub Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 (modifié) How can i change The destination to sdcard1 ? I speak about a download file and pictures Modifié 20 novembre 2014 par haboub Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
themrlsk Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 Thank you for this ROM :) Fully working, expect the root's problem, i've desactivate the superuser app, installed the supersu apk, but nothing .. Can someone provide me a .zip to flash with CWM ? Thanks ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
haboub Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 Uninstall super user reboot and install super su from Google play ... Reboot Welcome Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
themrlsk Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 It's what i've done .. But i doesn't unstall it, just desactivate, if i want to unstall it i must have root access for es explorer? From app manager, i can juste desactivate it ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
haboub Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 Disactivated Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kimo06 Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 For me : checkroot said root OK. Can you verify that ? Then when installing SuperSU, it asks to uninstall superuser, say OK. Then reboot. It worked for me. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
themrlsk Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 Check root said no root I've tried your solution (uninstall superuser by supersu), i choose 'normal solution' and he try to uninstall but the result is 'Install fail', i try to reboot, but no root access again.. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kimo06 Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 (modifié) Thats because I had root since beginning, only not working because superuser. You really don't have root, it's different. How did you install beta1 ? Modifié 20 novembre 2014 par kimo06 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jul65 Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 (modifié) After testing with CWM recovery = no root With TWRP recovery = root Anyway, Qus1 will fix this problem he said ;) in beta2 If you really want this rom now, you have to install TWRP recovery and reinstall beta1 like I did ;) Then install SuperSU and then it will uninstall the other one Qus1: I tried the camera and i do not have this blue effect. Wich condition do we need to have it ? Modifié 20 novembre 2014 par Ju' Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Just Modeste Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 Je confirme, avec installation de la beta1 avec CWM, il est quasi impossible de mettre le root, par contre, avec TWRP, la réinstallation de la beta1 a activé directement le root. Au passage, TWRP installe opera et root explorer que CWM n'installe pas. --- google translate I confirm, with installation of the beta1 with CWM, it is almost impossible to root, but with TWRP, reinstalling the beta1 activated the root directly.Incidentally, TWRP install opera and root explorer, CWM does not install it. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
haboub Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 Hmmm me top i confirm Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kevo Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 (modifié) Why can not I install/flashing zip ? Like samsung launcher ? Pourquoi je n'arrive pas à installer/flashser des fichiers ZIP comme le lanceur du Samsung ? I have root ans beta1 Modifié 20 novembre 2014 par kevo Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kimo06 Posté(e) 20 novembre 2014 Share Posté(e) 20 novembre 2014 (modifié) Yes Juste Modeste is right, seems to be related with recovery. I use TWRP also. Qus1 said to use flashtools and we didn't. Modifié 21 novembre 2014 par kimo06 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
