EmotionUI 3.0 dispo
Kingu Prima
http://huaweinews.com/2014/11/honor-3c-b251sp02/
November 25, 2014
We think its right to call that the Honor 3C is Huawei’s most frequently updated smartphone in their whole lineup as of right now.  Honor 3C was receiving firmware updates like clockwork and now we have a whole new development firmware upgrade numbered as B251SP02. This firmware update comes as the first bug fix update after the EMUI 3.0 development firmware release which happened about 2 weeks ago as we covered right here – http://huaweinews.com/2014/11/honor-3c-emui-3-firmware/
B251SP02 development firmware update is also destined to China as usual and it includes EMUI 3.0 with bug fixes to the initial B246SP02 EMUI 3.0 firmware update. If you are running B246SP02 on your Honor 3C, we definitely recommend you to upgrade to this new version. Below are some of the bug fixes and improvements taken from the official changelog,
* Notification bar issues fixed
* Display auto brightness feature improvements
* 3G video call issues fixed
* Camera issues fixed
full translated changelog is available here – http://goo.gl/2Qe03q
Here are the details about B251SP02 firmware,
Model – Huawei Honor 3C H30-U10
Region – China (Unicom)
Firmware version – B251SP02 Development
Android version – 4.4
EMUI version – 3.0
Google Apps included – No
Languages included – English,Chinese,..
Release date – November 20, 2014
File size – 705.25MB
Please be careful when upgrading because Huawei says upgrading to B251SP02 requires you to be running previous EMUI 3.0 firmware B246SP02 on your Honor 3C. Otherwise there is a risk for bricking your precious gadget. If you update to this new firmware, please let us and other readers know of your ideas on comments below.
Download link and release page (Chinese, use Chrome to translate) – http://goo.gl/i6B55z
J'ai aussi acheté ce Honor 3C sur Amazon et pour 99 euros, je dois dire que c'est une affaire, y a rien de mieux...
je suis passé sous Android kitkat avec EMUI 2.3, puis j'ai installé le Google Play à part.
J'ai aussi téléchargé cette mise à jour vers EMUI 3.0 mais rien ne dit qu'elle soit en Français...
Si quelqu'un à une info...
Merci :)
PS : aprés avoir installé kikat, une mise à jour OTA est dispo, ne la faite surtout pas sinon l'appareil ne redemarrera plus (obligé de flasher avec la ROM 4.2.2)
Modifié par Razmote
Il a toujours pas de mise à jour ota vers la 2.3 KitKat ?
Tu es obligé de le faire manuellement ?
Elle bug ?
Et pour les langues au faite elles y sont toutes ? J'ai besoin du français indonésien arabe
Désolé je n'ai pas encore le tel entre les mains
Celui vendu sur Amazon c'est la version international c'est bien sa ?
Modifié par malikabyl
Non pas de mise à jour pour le moment, donc manuellement mais c'est très facile, suffit de copier un fichier sur carte SD.
Je sais pas si elle bug car je n utilise pas le phone c est pour un cadeau, pour le peu de test que j'ai fait, j'ai pas eu de soucis.
C'est une version multilangues, donc...
Idem pour celui qui est vendu sur Amazon.
Oui ça marche parfaitement avec Iroot, anciennement Vroot ;)
A lancer sur le PC et connecter le phone aprés :)
Ne pas oublier d'installer les pilotes du Honor 3C sous Windows.
Merci testerais plus tard.
j'ai déjà essayer avec vroot, il me dit succes, mais au redémarrage nada
peux-tu expliquer comment tu as fait pour mettre à jour sur 4.4 où trouves-tu la rom ?
peux-tu mettre un lien vers le tuto ?
faut-il avoir un phone déja rooté, faut-il un recovery modifiié ???
merci de ton aide...
Modifié par deancorsofr
Voila le lien du tuto :
http://techfugitive.blogspot.fr/2014/12/update-huwaei-honor-3c-to-kitkat.html
Et le lien pour télécharger la V2.3 EMUI
http://www.emui.com/plugin.php?id=hwdownload&mod=detail&mid=32
Pas besoin d avoir le phone rooté, il suffit de mettre le fichier d'upgrade téléchargé dans un dossier appelé dload, que lon crée à la racine de la carte SD, éteindre le phone puis appuyer sur volume + et - en même temps et bouton POWER, le phone démarre en mode recovery, le reste se fait seul.
Attentions aprés être passé sous Kitkat ne pas faire la maj OTA, sinon écran noir.
Voila :)
Modifié par Razmote
Ben tjs le même problème: je lance iRoot je root, message: root succesful
redémarrage du honor, re-test avec iRoot ou supersu: no root permission
Edit: je voulais passer à kitkat et tester iroot dessus, mais seur le tuto ils ont marqué:
  • Before flashing this firmware, first unlock your bootloader Here.
Note:  If you didn't unlock the Bootloader then it may cause Boot-loop or Soft-Brick.
Vous êtes sûr que le votre de amazon est une version international ?
moi j'ai: V 100R001C432B109
Modifié par melkhatt
Bonjour razmote, sur le lien que tu donne pour Dl la version 2.3, on est d'accord que c'est le 3eme lien? la version 4.10.16? car sur l'autre lien que tu donne pour le tuto, c'est la version 4.7.1?
Je suis désolé, je patauge un peu la.
Sinon, pour melkhatt, moi, ma version c'est la :  V100R001CHNC00B211
Voila :)
MERCI beaucoup je vais tester ce soir......
le bootloader doit il être dévérouillé ???
Ben c'est bizarre , sur xda:
  • International set: Comes with LOCKED bootloader. (Ref. Build number: H30-U10 V100R001C900B1XX)
  • China set: Comes with UNLOCKED bootloader. (Ref. Build number: H30-U10 V100R001CHNC00B1XX)
à priori tu as la version chinoise avec le bootloader débloqué, donc pas de problème pour les manips.
Et donc moi , une version international, je dois débloqué le bootloader, mais je n'ose pas vu que eux "..C900B1xx" et moi "..C432B2xx"
Je post pour informer qu'une nouvelle version de emui 3.0 (toujours en dev build) est sortie : http://www.emui.com/plugin.php?id=hwdownload&mod=detail&mid=32
Toujours aucune info si français ou non, si jamais quelqu'un peut tester je lui en serais reconnaissant.....
Sur xda on trouve les google apps à flasher pour kitkat
Bon alors, en ce qui me concerne, j'ai installé la version 4.10.16 sans soucis.
Y'a juste pas le play store qu'on peut trouver sur le net et les Gapps que je n'installe pas pour le moment.
Le probleme, c'est que je n'arrive pas a rooter cette version avec Iroot, donc, je cherche.
Salut..la methode de root proposée ne marche sur la version internationale..ma version est V100R001C432B109
marque root ok mais en fait le téléphone n'est pas rooté.
Par contre j'ai trouvé en cherchant un peu un super programme qui lui marche impecc..donc maintenant je suis root.
J'ai pu installer mes programmes préférés genre LBE security qui est vraiment indispensable et Titanium backup.
Maintenant j'attends une rom internationale récente car les roms chinoises je n'en veux pas. Je vais bien étudier le super tuto très bien expliqué sur Xda pour installer un recovery et ensuite flasher les zip..
Dac, je suis content pour toi :) et sinon, c'est quoi ton prog pour rooter? merci
Fais comme moi, cherche un peu et teste tout ce que tu peux trouver..j'ai recherché longtemps avant de trouver..j'ai même essayer des programmes en chinois, mais je le referai plus car trop dangereux ( on clique on ne sait sur quoi)..
