[Discussion] LeEco Le 1s (X500/X501)
Wandy77
Eui 5.5.014S !
Le 1s package
Details Release
Date : 30-05-2016 Package : S1_x500-OS-OP-DHXOSOP5501405251S-5.5.014S
Size 1.2 GB
Lien de téléchargement ICI
Step-by-step Tutorial
1. Download the update package to your PC, and rename as “update”.
2. Connect phone to PC via USB type C
My computer-> click Le1s-> Phone storage
3. Drag and drop the update.zip file to the root directory of the phone.
4. Safely eject device from your PC
5. Start System update-> Settings-> Local update-> Continue - See more at: http://forum.le.com/...h.wtDq4dDg.dpuf
Et elle a quoi de mieux que la 5.8 ???
j ai telecharge  est renomme en update ,mais l installation n a bouti pas, car le fichier fait 1.11 go , pas 1.2 go comme ecrit .
C'est une Rom stock, à uploader si vous avez une Rom stock installée
@@romumu72
Here's a quick preview of LeecoDrypt v4.0.
(LDT.txt is log file)
° Full support for EUI 5.8 (MM)
° Entire Mod Written from scratch
° Licensed My Code (Now let's see who dares to call it copy)
I'll be releasing it soon, stay tuned.
Cheers.
changelog V4
### LeecoDrypt ###
[05:02:06] LeecoDrypt Engine v4.0
[05:02:06] Firing up..
[05:02:06] Device: Letv Letv X500
[05:02:06] Architecture: aarch64
[05:02:06] RAM: 2662 MB
[05:02:06] MAX CPU freq:2158Mhz
[05:02:06] MIN CPU freq:403Mhz
[05:02:06] Current CPU freq:2158Mhz
[05:02:06] CPU Cores: 3
[05:02:06] Kernel version: 3.10.72+
[05:02:06] ROM version: DBXCNOP5841905173D release-keys
[05:02:06] Android version: 6.0
[05:02:06] SDK: 23
[05:02:06] /system free space: 326.3M
[05:03:18] Remounting /data and /system - RW
[05:03:18] Set SElinux permissive..
[05:03:18] Correcting permissions..
[05:03:19] Init.d init..
[05:03:19] Running 001 gear..
[05:03:19] 001 - ***Cleaning gear***
Cleaning trash..
Cleaning cache..
[05:03:20] 001 - ***Cleaning gear*** - OK
[05:03:21] Running 002 gear..
[05:03:21] 002 - ***Kernel gear***
Applying optimized kernel parameters..
kernel.random.read_wakeup_threshold = 1536
kernel.random.write_wakeup_threshold = 2048
vm.vfs_cache_pressure = 100
vm.min_free_kbytes = 18432
vm.extra_free_kbytes = 24576
vm.compact_memory = 1
vm.drop_caches = 3
vm.oom_kill_allocating_task = 1
vm.dirty_ratio = 36
vm.dirty_background_ratio = 15
vm.dirty_writeback_centisecs = 500
vm.dirty_expire_centisecs = 200
vm.panic_on_oom = 0
vm.overcommit_memory = 1
vm.overcommit_ratio = 100
vm.laptop_mode = 2
vm.block_dump = 0
vm.oom_dump_tasks = 0
vm.min_free_order_shift = 4
vm.page-cluster = 3
vm.scan_unevictable_pages = 0
fs.file-max = 173030
fs.leases-enable = 1
fs.lease-break-time = 10
fs.inotify.max_queued_events = 71874
fs.inotify.max_user_instances = 256
fs.inotify.max_user_watches = 16384
kernel.panic = 0
kernel.panic_on_oops = 0
kernel.pid_max = 4194303
kernel.sched_latency_ns = 9000000
kernel.sched_min_granularity_ns = 2000000
kernel.sched_wakeup_granularity_ns = 2500000
Tuning kernel scheduling..
Turning debugging OFF..
[05:03:22] Running 003 gear..
[05:03:22] 003 - ***GPU gear***
Remounting /system - RW
Forcing GPU to render UI..
[05:03:22] 003 - ***GPU gear*** - OK
[05:03:22] Running 004 gear..
[05:03:22] 004 - ***Battery gear***
Tuning Android power-saving..
[05:03:24] 004 - ***Battery gear*** - OK
[05:03:24] Running 005 gear..
[05:03:24] 005 - ***VM gear***
Tuning LMK..
LMK cost fine-tuning..
LMK debugging disabled
[05:03:24] 005 - ***VM gear*** - OK
[05:03:24] Running 006 gear..
[05:03:24] 006 - ***CPU gear***
[05:03:24] Running 007 gear..
[05:03:24] 007 - ***GPS gear***
[05:03:24] Running 008 gear..
[05:03:24] 008 - ***Thread gear***
[05:03:24] 008 - ***Thread gear*** - OK
[05:03:24] 009 - ***Network gear***
Writing optimized network parameters to sysctl
Executing optimized network parameters via sysctl
net.ipv4.tcp_congestion_control = cubic
net.ipv4.tcp_rfc1337 = 1
net.ipv4.tcp_window_scaling = 1
net.ipv4.tcp_sack = 1
net.ipv4.tcp_fack = 1
net.ipv4.ip_no_pmtu_disc = 0
net.ipv4.tcp_timestamps = 0
net.ipv4.tcp_no_metrics_save = 1
net.ipv4.tcp_moderate_rcvbuf = 1
net.ipv4.tcp_synack_retries = 2
net.ipv4.tcp_fin_timeout = 36
net.ipv4.conf.all.rp_filter = 2
net.ipv4.conf.default.rp_filter = 2
net.ipv4.conf.all.accept_redirects = 0
Set larger net-buffer sizes..
[05:03:24] Running Lead Engine..
/data: 11276963840 bytes trimmed
/cache: 430243840 bytes trimmed
vm.max_map_count = 196536
[05:04:35] END start
Fix permissions and zipalign..
FStab onboard..
Checking all filesystems
FStrim init..
Trim /system
/system: 354828288 bytes trimmed
Trim /data
/data: 0 bytes trimmed
Trim /cache
/cache: 0 bytes trimmed
Optimizing DataBases..
[05:04:40] Applying kernel configuration..
vm.drop_caches = 3
vm.dirty_ratio = 36
vm.panic_on_oom = 0
vm.laptop_mode = 2
vm.block_dump = 0
vm.page-cluster = 3
kernel.panic = 0
Sleep, sync and free RAM
             total       used       free     shared    buffers     cached
Mem:          2662       1237       1425          0          0        297
-/+ buffers/cache:        939       1722
Swap:          511          0        511
[05:04:51] END end
[05:04:35] Init sleeper daemon
Sleeper daemon is active.
[05:04:54] LDT status - OK
Modifié par wandy77
Le 5.8 est en beta comme MIUI 8
nous attendons la version final afin de travailler dessus
concernant MIUI 8 beta, c'est dispo avec la rom vazarg pour x600
Perso je peux ajouter la langue FR sur les rom MIUI RN2 ou LeTV/LeEco All devices
Modifié par wandy77
Merci @
Je reste pour le moment sur la ROM espagnole v3. Mais la batterie qui tient une journée et les notifications qui n'arrivent pas toutes c'est assez gênant. Est-ce mieux avec EUI 5.8? MIUI je sais que tout fonctionne sauf le FP.
Envoyé de mon Redmi Note 3 en utilisant Tapatalk
Moi ,j ai installe le EUI 5.8, mais pour installer  google play ,ça ne marcher pas ,quelqu un a deja installer google play avec EUI 5.8 ? comment faire pour reussir?
Salut @@fibrice
Tu en pense quoi de ce casque à 31€
Description:
LeVR COOL1 is designed based on visual optics system, special for Letv super mobile phone. Metal sprayed coating, color harmonization, clear division of functional area. PMMA material aspherical lens, controls dispersion effectively. Adjustable interpupillary distance and diopter, suits for different people. Anti-fog coating lens, gives you a clear image all the time.
Main Features:
Letv LeVR COOL1 3D VR head-mounted glasses
3D game and video private theater
Perfect for Letv One / Letv One Pro
With Sharp liquid crystal panel
Solve the problem of delayed image, delayed time reduce to 20ms, only half the time of other product
Provides you rich resource, no need to download the video, click and play, you can enjoy video anywhere anytime
You can custom your own desktop according to your interest
Details:
Lens Effective Aperture: 38mm
Focal Length: 45mm
Distance of Exit Pupil: 12mm
Horizontal Field Angle ( FOV ): 90 Degrees
Dioptre Adjustable Range: 1,000 - 8,000
IPD Adjustable Range: 58 - 70mm
Antifogging Coating Lens
Dioptre synchronized regulation
Super Phone screen custom position ( For Letv 1, Letv 1 Pro )
Dimension: 190 x 100 x 110mm
Weight: 330g
Specifications
General
Brand: Letv
Model: LeVR COOL1
VR Glasses Type: VR Glasses
Compatible with: Smartphones
Material: Glass,PC
Color: Black
Dimension and Weight
Product weight: 0.330 kg
Package weight: 0.600 kg
Product size (L x W x H): 11.00 x 14.50 x 20.00 cm / 4.33 x 5.71 x 7.87 inches
Package size (L x W x H): 11.50 x 16.00 x 22.00 cm / 4.53 x 6.30 x 8.66 inches
Package Contents
Package Contents: 1 x LeVR COOL1 3D VR Glasses
Modifié par wandy77
Les casques VR sont juste des bouts de plastique avec des verres de plus ou moins bonne qualité. Le cardboard de Google est a 2€... Mais pour tous ces casques là, il faut un téléphone avec gyroscope... Donc pas fait pour le 1s
Dispo pour ce soir,  la rom Letv_X500_1S_MIUI8_6.6.24 FR
Je souhaite recueillir vos info à tous les niveaux
Le nunchuk doit certainement remplacer le gyroscope
Une autre version LeTV VR à 213€ http://www.gearbest.com/virtual-reality/pp_280343.html
3eme version LeEco VR
A couple of the first viewers to ever experience 1080p, 360º, real-time VR
source
Modifié par wandy77
@ je vais partir sur un Le 2 pro ou Le Max 2 ou un Oppo F1 Plus ... je ne sais pas encore mais quitter LeTv me ferai mal au cœur :P
Le problème est que vendre ce genre de smartphone en France ne doit pas étre facile ..
Modifié par djaquilexe
