Franckydiam Posté(e) 17 mars 2016 Share Posté(e) 17 mars 2016 (modifié) http://forum.xda-developers.com/honor-7/development/rom-6-0-x-yodarom-v1-0-mm-rooted-ads-t3338179 Specification : Base ROM: Beta ROM MM 6.0 PLK-L01C432B320_Firmware_Europe_Android6_0_EMUI4_0 Android: 6.0 Kernel: Stock, Recovery: TWRP by sminki Features: fast, clean, smooth rooted and busybox installed, removed unnecessary (for me, i like clean ROM's) apps/files from Huawei/Google, added total commander, updated some apps, adfree hosts file, changed default theme, cust partition is in installer, everything installs automatic ... some things that i don't remember Changelog : v4.0 - 02 April 2016 updated base ROM to B330 Official Release, updated hosts file, updated supersu to v2.71, fixed ADB connection, v4.0D - fixed bluetooth v4.0D - Xposed now is installing from AROMA installer, v5.0 - 07 April 2016 back to stable supersu v2.65, updated hosts file, moved Gmail to AROMA installer, moved Google Keyboard to AROMA installer, moved Google App to AROMA installer, added Adaway to AROMA installer, Know bugsSometimes after installation SuperSU is gone or not working - try to install supersu from market or install ROM one more time v6.0 - 12 April 2016 added Camera Toldo compression MOD to AROMa, update-script fixes, added Viper4Android, - thanks to zhuhang - oryginal thread added init.d support, root and busybox are now one menu in AROMA, set SELinux: Permissive, v7.0 - 19 April 2016 updated busybox installer to latest version by osm0sis, root installation changed (boot with patched sepolicy), update to SuperSU v2.71 - now it works ok, updated Huawei Backup App, updated google apps (gmail, drive, maps etc...), added Xposed Ready in AROMA (Xposed now works on odex ROMs!), no more Deodex version of YodaROM, enabled net speed in status bar - thanks to AleAndroid96, enabled 4G button in quick settings - thanks to AleAndroid96, changed defult theme to SpectrumPure.r4 - thanks to paulobrien, updated hosts file, + Xposed installation guide in first post !* v8.0 - 28 April 2016 kernel changed to YodaKernel v1.0 - changelog in second post, updated some google apps, back to oryginal default theme (theme app now works ok), updated hosts file, Kernel changelog:v1.0 - 28 April 2016 kernel update do latest version 3.10.101, compiled with Linaro 4.9.3 Toolchain, added Smartass2 and Wave governors v9.0 - 19 May 2016 kernel update to YodaKernel v1.1, updated hosts file, updated some google apps, update to SuperSU v2.72, added MultiWindow - works nice more info here added TouchPlus - dosn't work for me, more info here rebuild my kitchen, and reduced ROM zip size - no changes to end user, Kernel Changelog v1.1 - 19 May 2016 added hyper governor, v10.0 - 24 Juillet 2016 - update SuperSU to v2.76, - updated base ROM to B370 Official Release, - removed xposed ready option - new xposed works fine with enabled theme engine - multiwindow disabled by default, - to enable go to /system/build.prop and change false to true in ro.huawei.multiwindow= Merci à Ryrzy Modifié 24 juillet 2016 par Franckydiam 8 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Benjy61 Posté(e) 3 avril 2016 Share Posté(e) 3 avril 2016 As tu installé cette Rom ? Si oui, qu'en pense tu par rapport à la ROM Stock ? Aurais-tu quelques screen à nous montrer ? Merci d'avance. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adamentys Posté(e) 3 avril 2016 Share Posté(e) 3 avril 2016 Des screens, pour quoi faire ? Ce n'est qu'une ROM Stock Rooté avec quelques optimisations. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Franckydiam Posté(e) 4 avril 2016 Auteur Share Posté(e) 4 avril 2016 Hello, j'ai sauté le pas, installation de la rom YodaROM v4.0-Xposed-Deodex-Root. Tout à l'air de bien fonctionner, rapide, fluide, Xposed opérationnel, je continue de tester... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Franckydiam Posté(e) 4 avril 2016 Auteur Share Posté(e) 4 avril 2016 Bon, au niveau Xposed, juste que tous les modules ne marchent pas, comme GravityBox par exemple :( Je poursuis B) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adamentys Posté(e) 4 avril 2016 Share Posté(e) 4 avril 2016 (modifié) Ouais, GravityBox non fonctionnel, du coup, j'ai tout testé pour centrer l'horloge mais pas moyen... Je vais aussi créer un Zip pour 3minit battery et ainsi pouvoir changer l'icône batterie comme je veux. En fait, pour le moment, tout ce que je faisais avec les thèmes Huawei, je le fais avec Xposed, donc pas grand intérêt... J'ai juste ajouté l'appui long sur vol+ et vol- pour passer la musique. Modifié 4 avril 2016 par Adamentys Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Franckydiam Posté(e) 4 avril 2016 Auteur Share Posté(e) 4 avril 2016 Une "liste" de modules fonctionnels à débuté sur xda, en espérant qu"elle s'étoffe... B) http://forum.xda-developers.com/honor-7/help/list-xposed-modules-honor-7-t3350362 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adamentys Posté(e) 4 avril 2016 Share Posté(e) 4 avril 2016 (modifié) J'ai vu ça oui. Par contre, sur la V4.0D j'ai un problème avec Snapchat, impossible de me connecter malgré le changement de mot de passe... Si tu utilises Snapchat, est-ce que ça fonctionne pour toi ? Modifié 4 avril 2016 par Adamentys Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Franckydiam Posté(e) 4 avril 2016 Auteur Share Posté(e) 4 avril 2016 Désolé, je n'utilise pas Snapchat :huh: Je suis à la recherche d'un module qui fasse l'"Advanced Power Menu", il y en bien un avec se nom d'ailleurs mais à priori marche pas...dommage pour Gravity Box mais d'après le dev de Yoad, il y a peu de chance qu'il marche un jours avec cette rom :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adamentys Posté(e) 4 avril 2016 Share Posté(e) 4 avril 2016 Dommage pour Snapchat... Cette histoire me gonfle. Ah bah c'est certains, Gravity Box ne fonctionnera jamais sur notre H7, il est prévu pour Android pure à l'origine et fonctionne sur quelques surcouches comme LG UX ou Sense mais que partiellement. Il faudrait tester les modules pour MIUI, EMUI en est assez proche, ça doit pouvoir fonctionner. J'ai déjà testé Plak et il ne veux même pas se lancer. Le problème des téléphones Huawei/Honor, c'est qu'il n'y a pas du tout de communauté derrière, donc pas de modules Xposed dédiés à EMUI et encore moins de ROM's AOSP. Ça me manque vraiment ça, je vais à mon avis revendre mon H7 sous peu. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Franckydiam Posté(e) 4 avril 2016 Auteur Share Posté(e) 4 avril 2016 Dommage pour Snapchat... Cette histoire me gonfle. Pour Snapchat j'ai aperçu ceci :SnapPrefs http://forum.xda-developers.com/xposed/modules/app-snapprefs-ultimate-snapchat-utility-t2947254fonctionnel sur H7 xposed peut-être que ça peu t'aider ? B) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adamentys Posté(e) 4 avril 2016 Share Posté(e) 4 avril 2016 (modifié) Ça ne changera malheureusement rien au fait que je ne puisse pas me connecter Modifié 4 avril 2016 par Adamentys Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jules10 Posté(e) 6 avril 2016 Share Posté(e) 6 avril 2016 (modifié) Il faut se connecter à Snapchat AVANT d'installer Xposed. Les dernières versions de Snapchat détectent Xposed et empêche la connexion à l'application pour éviter d'utiliser Snapprefs. Dans ton cas, desinstalle Xposed via TWRP, connecte toi à Snapchat, et réinstalle ensuite Xposed. Par contre, si tu as le malheur de te déconnecter de ton compte snapchat par la suite, il faudra repasser par cette étape... Modifié 6 avril 2016 par Jules10 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adamentys Posté(e) 6 avril 2016 Share Posté(e) 6 avril 2016 (modifié) En installant une vieille version de Snap, ça doit aussi passer je pense. Modifié 6 avril 2016 par Adamentys Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Franckydiam Posté(e) 7 avril 2016 Auteur Share Posté(e) 7 avril 2016 v5.0 - 07 April 2016 back to stable supersu v2.65, updated hosts file, moved Gmail to AROMA installer, moved Google Keyboard to AROMA installer, moved Google App to AROMA installer, added Adaway to AROMA installer, Know bugsSometimes after installation SuperSU is gone or not working - try to install supersu from market or install ROM one more time http://forum.xda-developers.com/honor-7/development/rom-6-0-x-yodarom-v1-0-mm-rooted-ads-t3338179 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Franckydiam Posté(e) 12 avril 2016 Auteur Share Posté(e) 12 avril 2016 v6.0 - 12 April 2016added Camera Toldo compression MOD to AROMa, update-script fixes, added Viper4Android, - thanks to zhuhang - oryginal thread added init.d support, root and busybox are now one menu in AROMA, set SELinux: Permissive, Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
adrianooo Posté(e) 12 avril 2016 Share Posté(e) 12 avril 2016 Pour installer la ROM que faut il faire exactement ? Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Franckydiam Posté(e) 12 avril 2016 Auteur Share Posté(e) 12 avril 2016 (modifié) Pour installer la ROM que faut il faire exactement ? Merci Si ce n'est déjà fait : 1- débloquer le bootloader (méthode officielle ou non-officielle) ensuite, préférence personnelle : télécharger Honor7 Multi-Tool http://forum.xda-developers.com/honor-7/general/honor-7-multi-tool-t3281176 2- rooter le tel 3- installer le TWRP_SMINKI_2.8.7.0_REPACK 4- depuis twrp, pour room Deodex - Xposed, installer en premier la version de base v6.0, reboot et ensuite installer la version v6.0D (voir tous les détails d'install sur http://forum.xda-developers.com/honor-7/development/rom-6-0-x-yodarom-v1-0-mm-rooted-ads-t3338179) -_- Modifié 12 avril 2016 par Franckydiam 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
adrianooo Posté(e) 12 avril 2016 Share Posté(e) 12 avril 2016 Merci si j'ai déjà la version B330 de base pas besoin de la reinstaller? Et du cou je pourrait plus faire les MAJ OTA ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Franckydiam Posté(e) 12 avril 2016 Auteur Share Posté(e) 12 avril 2016 Merci si j'ai déjà la version B330 de base pas besoin de la reinstaller? Et du cou je pourrait plus faire les MAJ OTA ? Dsl pour la réponse tardive, si tu es déjà en 330 rooter + twrp, tu peux installer directement une version de base + version "D" ensuite pour Deodex-Xposed. Pour les maj OTA suis pas sure que ça suive, mais moi comme je ne les reçois jamais (DOM), c'est pas un problème. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
adrianooo Posté(e) 15 avril 2016 Share Posté(e) 15 avril 2016 Pour rooter via la B330 on peut le faire avec multitool ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Franckydiam Posté(e) 15 avril 2016 Auteur Share Posté(e) 15 avril 2016 (modifié) Pour rooter via la B330 on peut le faire avec multitool ? C'est avec Multi-tool que j'ai rooter ma 330, avec succès, donc oui, (attention bootloader débloqué + antivirus désactivé) bien suivre ce qui est écrit, notamment l'installation des drivers, du recovery, du twrp pour installer ensuite Yoda Rom (la version "v6.0D" deodex + Xposed n'est pas vraiment utile vu qu'il n'y a quasiment pas de module Xposed pour le Honor7, je suis revenu à la v6 "normale" qui marche super bien) -_- Modifié 15 avril 2016 par Franckydiam Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
adrianooo Posté(e) 15 avril 2016 Share Posté(e) 15 avril 2016 Oui [color=red][b]sa[/b][/color] al'air très facile, la V6 c'est a dire la B330 officiel ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Franckydiam Posté(e) 15 avril 2016 Auteur Share Posté(e) 15 avril 2016 (modifié) Oui sa al'air très facile, la V6 c'est a dire la B330 officiel ? Yes la YodaRom V6.0 ! Specification Base ROM: MM 6.0 PLK-L01C432B330 Android: 6.0 Kernel: Stock, Recovery: TWRP by sminki -_- Modifié 15 avril 2016 par Franckydiam Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
adrianooo Posté(e) 15 avril 2016 Share Posté(e) 15 avril 2016 En suivant toute les etapes avec multitool [color=red][b]sa[/b][/color] nemarche pas Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
