tymal77 Posté(e) 10 mars 2019 Share Posté(e) 10 mars 2019 I switched to the S10+ from the S8. The S8 worked perfectly fine with my car radio, but with the S10+ I am having a weird glitch with bluetooth. When I first pair the phone to my car, it will work correctly. Once I turn off my car and turn it back on, my phone will only allow the car to play call audio until I unpair completely and then re-add it. If I go into the bluetooth settings for my car and try to turn on media audio, the switch will immediately move back to disabled. I don't think this is an issue with my car radio as it works perfectly fine after I un-pair and re-pair. It almost seems like after I turn off my car, my phone revokes the original permissions I gave it to allow media audio. This is a minor inconvenience but I would love to be able to play music and podcasts without having to go mess with my phone settings every time I drive. Has anyone else experienced this? I can't find anything on Google about it. Thanks in advance! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ultrix Posté(e) 10 mars 2019 Share Posté(e) 10 mars 2019 This is a French-speaking forum. Please post in French language only. Ceci est un forum francophone. Merci de poster en Français seulement. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ace60 Posté(e) 10 mars 2019 Share Posté(e) 10 mars 2019 Bonjour, J'ai le même problème que lui quelqu'un aurait une piste ? En gros le BT se bloque en appel seulement ce qui empêche la musique ... Il faut faire sauter le BT puis le remettre 🙄 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
