[ROM] MIUI pour Désire Z/G2 - Q'nD & Vision-nadoo 1.3.11 en français
Attention : Comme avec n'importe quelle modification (ROM, correction, etc.), vous courez le risque d'endommager votre dispositif. Cela est peut probable mais il est important de considérer cette possibilité avant d'entreprendre une quelconque modification sur votre androphone. Je décline toute responsabilité en cas de dommages, perte de données ou autre mésaventure pouvant survenir à votre matériel.
La suite ici pour la miui en francais traduite par droidworkshop :
ROM MIUI Desire Z/G2 1.3.25 version française
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
1.3.11 Miui changelog
Phone:
Time when no SIM card restoration of China belong to the default
If the incoming call log in the repair without number, the problem appears to be empty
Enable the proximity sensor repair, the phone call is answered can not be automatically lit black screen problem
Repair phone screen will not light up after hang up problem
SMS:
SMS collection logic optimization
Lock screen:
Lock screen repair can not click OK when the horizontal screen problems
Theme:
Add more pages to enter full screen mode, click Preview
Thumbnail will cover the repair wallpaper border problem
Details about top end repair sliding error resources
Heading the list of categories of resources error fixed
Optimization and global unified cache directory topics
Settings:
Add wallpaper wallpapers added to the options
Optimization settings in the ring setting and themes of the ring setting to get through
Music:
Added support for links to online MP3 Player (in text messaging, press a link, start the player)
New online music player automatically cache the next song
New player spectrum switch, by default, you can set off
Optimal rejection song CPU occupancy to reduce power consumption
Camera: (in MIUI network disk download)
Zoom slider fix the display of the camera do not support scaling, click on the zoom slider does not appear
Repair some models AF flash flashing problem
Effects model using the camera does not fix the entry into force BUG
Basé sur la traduction de mnlk2 membre de ce forum voici un Pack français pour :
QnD-MIUI-1.3.11-V1.0-EN par g4rb4g3
QnD-MIUI-1.3.11-V1.0-EN-patch-fr-signed.zip
- inclu le 4-Way Reboot Mod
- inclu le vision-keypad-fra_V.3 de Zura du forum.frandroid.com ainsi que le vision-keypad-ger que j'ai modifier pour le suisse romand les symboles ä ü ö vous donneront respectivement à è é. (ces 2 fichiers optimise l'utilisation du clavier physique du desire Z)
miui-vision-1.3.11-nadoo.zip par nadoo
miui-vision-1.3.11-nadoo-patch_fr-signed.zip
Anciennes versions :
Modifié par svapunk
  • Réponses 87
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
oui merci. il est a noter que l'anglais est quasiment absent sur la rom nadoo alors pas de panique c'est que du chinois :P au premier lancement!
Le patch fr effectue un wip cache/dalwik automatique grace au bon soin de mnlk2.
Avec un peut de tâtonnement vous devriez très vite vous retrouver en full french :emo_im_kissing:
En tous cas chez moi sa marche B)
Oui, je suis d'accord que ce n'est pas une histoire de changelog mais c'est ce qu'il m'intéressait de voir. Au passage, j'ai pu voir qu'il parlait aussi du rétro-éclairage (en effet, pas de rapport avec le changelog)
Modifié par kevinpato
@ svapunk, j'ai mis mon sujet à jours, si tu vois des erreur n'hésite pas à le signaler car je n'ai pas du tout suivis l'évolution de Miui ces derniers temps :D et je n'ai pas regrouper l'ancien Miui avec celui ne naboo pour éviter les confusions et autres
Je viens confirmer qu'elle est flashable avec la dernière version de clockwork recovery 3
edit : il semblerait que chez moi le framework-res ne soit pas traduit, par exemple les petites icones dans la barre de notification restent en chinois.
Modifié par kartouche
Pourtant tout le reste est traduit (je l'ai bien entendu déjà flasher)
edit : de toute façon, trop tard je suis de retour en virtuous, je voulais juste voir de moi même si ça marchait ... St Thomas toussa toussa
Salut svapunk,
Je suis d'autant plus interessé par ta ROM que j'utilisais jusqu'a présent QnD et que sont dévelopement est interompu.
Je poccede pour ma part la version Nord Americaine du telephone vivant aux USA et j'aimerais beaucoup reprendre ce que g4b4g3 avait commencé.
J ai bien recuperer la rom de nadoo et appliquer le patch US du N1 dans mon cas mais une partie reste en Chinois et le clavier ne s'allume plus une fois le telephone ouvert.
Pourrais tu expliquer comment mettre au point une telle ROM, ou comment toi tu t'y es pris?
Merci d'avance
Comme son nom l'indique ... le patch pour N1 est prévu pour le N1, forcément il posera des problèmes pour le clavier, l'éclairage etc ...
Le truc c'est qu'il faut adapter ce patch pour le DZ donc pas besoin de toucher à la rom d'origine (enfin à son portage).
Il faut donc prendre le patch a part et regarder quels fichiers sont spécifiques au N1 et les modifiers en conséquence.
Pour plus de détails je laisserais Svapunk s'exprimer ^^'
Jusque la pas de soucis j avais bien compris que les telephones etaient differents ;)
cependant le framework devrait etre semblable et quand a ce qui est des fichiers clavier j'ai bien installer les bons, j'arrive a un resultat pas trop muvais apres avoir le modifier le build.prop mais certains soft sont toujours en chinois, music, toggle dans la notification bar...
