rodyh Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 (modifié) Fusion Version actuelle : v1.0.0 (06/05/2011) Premier patch (11/05/2011) Lien pour le forum XDA Welcome to our latest creation, Virtuous Fusion. It is the first fully functional, properly scaled Sense 3.0 ROM for the G2/DZ. Before going any further, it is important to note that Fusion is a different product than base Virtuous. The "Fusion" ROM will exist until Sense 3.0 has natively become available on our devices, if ever. Virtuous proper will continue to be updated and maintained as it always has been, following official HTC releases. Fusion was made possible by the amazing work of Flemmard and Diamondback, who reverse engineered the m10 format and built an encoder/decoder. The two of them also made the specific adjustments necessary to this particular ROM's applications. It was also a collaborative effort across the DHD and G2/DZ communities. Cappychimp and I worked closely throughout the entire process, with support from numerous others. Thank you to everyone involved. Screenshots Features * Fully functional and properly scaled Sense 3.0. * Based on components from Sniper911's leaks of Rider (1.27.1010.0), Kingdom (0.81.651.0) and DZ Sense GB 2.30.405.1. * All device hardware should be fully functional, including wifi, bluetooth, camera, camcorder, etc. * Kernel 2.6.35.10 from the Gingerbread leak for G2/DZ. * Market-sourced applications (Gmail, Maps, Voice, etc) automatically installed on first boot into /data/app for easy removal. * Deodexed (as leaked) and zipaligned. * Bloatware and unnecessary applications removed. * Massive APNS list. Installation 1. You must be perm rooted with and Clockwork Recovery installed (i.e. s-off). 2. Perform a nandroid backup of your current ROM, in case you change your mind or encounter issues. 3. Apply the zip via Clockwork Recovery. It has not been tested with any other recovery. 4. Expect the first boot to take anywhere from 6-10 minutes. The lengthy first boot time is due to the dexopts process and installation of /data/apps. Subsequent reboots should be significantly quicker. 5. After initial install, allow a few minutes for all ROM-provided applications to appear. Some are installed post-boot using package manager. Known Issues * There are some remaining graphical glitches. Most of them are minor but feel free to report them. * Landscape mode does not work for Rosie, even with the keyboard extended. * Non-HTC widgets function but are not scaled perfectly; they may appear small and offset to the left. HTC provides plenty of awesome widgets, so I suggest using those. Credit and Acknowledgements Thank you to the following people for their help putting this ROM together: Flemmard, Diamondback, Cappychimp, eViL D:, siulimagic, rafyvitto, 911Sniper and all the testers who subjected their devices to test builds in order to provide essential feedback. Disclaimer As with any modification (ROM, patch, etc), you run the risk of damaging your device. While unlikely, it is important to consider this possibility before proceeding. I take no responsibility for any such damage, data loss or otherwise. Téléchargement : ICI (MD5: 356380f8efcc7a993d3dd4c06c5574b7) Patch (11/05/2011) : ICI (faire un backup de votre rom !!!!) Kernel GingerBread Sense : ICI (Dernière MAJ : 15/05/2011) (MD5 :b3bfab04efde24c03cf1f298d26b4b7b) Modifié 22 juin 2011 par rodyh Citer
rodyh Posté(e) 7 mai 2011 Auteur Posté(e) 7 mai 2011 (modifié) Liste des correctifs : (11/05/2011) Voici le premier patch "semi" officiel fait par benjamminzIS (lien forum XDA) Téléchargement du patch : ICI C'est un fichier zip flashable contenant la plupart des "fix" sortis à ce jour pour la ROM fusion. Il y a par exemple un fix pour le voice command pour corriger des soucis avec google search ou skype, ... Je vous tiendrai au courant pour les autres patchs à venir dans cette partie ! EDIT : Il semblerait que le patch ne soit pas parfait, donc attention, ca reste un patch beta ! :) Sauvegardez votre ROM avant de le mettre ! MERCI ! Modifié 11 mai 2011 par rodyh Citer
elloco054 Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 (modifié) OUCH ! je télécharge et installe directe !! je vous fais un retour dans la foulée ! Edit : Pas mal du tout le nouveau LockScreen qui fonctionne parfaitement bien ! D'ailleurs, comme indiqué, tout semble fonctionner correctement (wifi, 3g, 3D, téléphone, photo...) L'application eMail a été mise à jour Flashé sans wipe :) (j'ai dû réinstaller Gmail à cause de force close) Edit 2 : heu .... Force Close sur le clavier physique ... mais c'est peu etre à cause de mon non Wipe ? Modifié 7 mai 2011 par elloco054 Citer
kartouche Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 Il y a de grande chance oui, sinon, toujours en anglais ou espagnol uniquement la rom? Citer
elloco054 Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 (modifié) Bon ben Wipe + Réinstallation de la ROM et tout remarche Installation en Anglais (mais avant de Wipe tout était en FR !) donc je vais tenter Morelocale2 Edit : MoreLocale2 passe la rom en fr :) (widgets et menus) Modifié 7 mai 2011 par elloco054 Citer
falcom Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 Perso, j'ai du flasher deux fois. Mauvais wipe Au premiere demarrage elle est en anglais, mais juste a changer la langue dans les parametres, toutes les langues y sont. Citer
elloco054 Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 le dico reste en anglais par contre (pour la correction orthographique)... Citer
svapunk Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 mouai et il n'y a que l'anglais! Le reste va viendre bientôt je suppose! Rom très fluide tous bien sauf détail dico et track pad. Je retourne sur la cyano plus aboutie. Mais sa promet que du bon! Citer
elloco054 Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 par contre j'ai flashé la Sony Font ... mais ca n'a rien changé ... mon ancienne police me manque :P Citer
spinose Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 l installe est en anglais mais apres t as toute les langues pour l instant rien a redire Citer
Chookie Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 par contre j'ai flashé la Sony Font ... mais ca n'a rien changé ... mon ancienne police me manque :P Comment flasher une police? Tu les a trouvé où les fonts? (désolé du HS) Citer
rodyh Posté(e) 7 mai 2011 Auteur Posté(e) 7 mai 2011 (modifié) Nan pas d'OC pour le moment ni de TP wake ! faudra attendre un peu pour avoir tout ça ! Ce sera suivi par rmk, il se focalise sur cette ROM la virtuous "fusion" et sur virtuous "normale" (basée sur les versions officielles de htc) En esperant avoir des kernels un jour sur cette rom :) Modifié 7 mai 2011 par rodyh Citer
Kazushi Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 tant pis je la teste quand meme ^^ ça doit valoir le coup :P Citer
Kazushi Posté(e) 7 mai 2011 Posté(e) 7 mai 2011 bon bah j'repasse sur virtuous 1.0.2 x) c'est une rom basé sur gingerbread et j'aime pas la façon d'ont défile la liste d'application de gingerbread :D Citer
elloco054 Posté(e) 9 mai 2011 Posté(e) 9 mai 2011 (modifié) Shiyro> j'ai trouvé le fichier ZIP avec la police dans le post sur la virtuous 1.0.2 :) (je crois). Mais j'ai quand meme modifié la police grace à l'apps Absolute System Root Tools Rom utilisée depuis quelque jour : Plutot content. conso batterie normal, tout le hardware est pris en charge, lockscreen génial et original (impossible d'entendre que ca ressemble a du Apple :P ). On perd juste le correcteur orthographique qui souligne en rouge les fautes... Et il y a toujours cette satannée barre d'application récente qui met 3 plombes à s'ouvrir (toutes les ROM Sense avec ce truc inutile !) Avec la virtuous 1.0.2 on pouvait la remplacer par une barre de switch, qui s'affichait instantanément! Modifié 9 mai 2011 par elloco054 Citer
rodyh Posté(e) 9 mai 2011 Auteur Posté(e) 9 mai 2011 bon bah j'repasse sur virtuous 1.0.2 x) c'est une rom basé sur gingerbread et j'aime pas la façon d'ont défile la liste d'application de gingerbread :D Euh, je comprends pas, quel liste (ou genre de liste) de défilement tu n'aimes pas ? Car tu peux configurer le défilement : Grille ou Liste. Citer
rodyh Posté(e) 9 mai 2011 Auteur Posté(e) 9 mai 2011 Bon je vais faire quelque retours sur cette ROM ! Il reste encore pas mal de bugs graphiques, du au fait que toute les applications ont du être retravaillée pour être dans la résolution de l'écran de notre téléphone. Certains widget ne marchent pas. Il y a des petits ralentissements de temps en temps, mais bon Sense n'a jamais été (pour moi) une Home/Launcher très rapide/fluide. Je trouve que Sense s'améliore de plus en plus face à la concurrence des Home alternatifs comme ADW Launcher, Go Launcher ou Launcher Pro Le lockscreen est vraiment sympa avec les applications que l'on peut mettre en favoris dedans. La ROM consomme très peu je trouve ! J'espère que l'on va avoir des fix prochainement, pour les bugs graphique et corriger certains soucis avec des widget. Et aussi et surtout ajouter des fonctionnalités comme le Trackpad wake Et aussi et surtout un kernel ! afin de faire de l'overclock, que je considère comme nécessaire avec Sense pour que ca soit ultra fluide (surtout avec 7 widgets (ou plus) dans les 7 écrans du home). et bien sur pour downcloacker le tel au max quand il est en veille. Citer
Kazushi Posté(e) 9 mai 2011 Posté(e) 9 mai 2011 Euh, je comprends pas, quel liste (ou genre de liste) de défilement tu n'aimes pas ? Car tu peux configurer le défilement : Grille ou Liste. en mode grille la version de gingerbread n'est pas un défilement comme celle de froyo, ça fais sous forme de " page " tu glisse un coup tu as une " page " qui descend je sais pas si j'me suis bien expliquer Citer
spinose Posté(e) 9 mai 2011 Posté(e) 9 mai 2011 passe sous launcher pro ou ADW launcher et t'aura un défilement comme tu aimes (sans htc sense) Citer
rodyh Posté(e) 9 mai 2011 Auteur Posté(e) 9 mai 2011 en mode grille la version de gingerbread n'est pas un défilement comme celle de froyo, ça fais sous forme de " page " tu glisse un coup tu as une " page " qui descend je sais pas si j'me suis bien expliquer ok ok j'ai compris ! Tu veux un defilement de la grille comme pour la liste quoi, sans pages .... je croyais que tu voulais la liste et pas la grille ! Oui ca vient du launcher Sense donc on peut pas trop changer ca je pense (enfin un developpeur doit pouvoir). donc pas d'autres choix pour toi à part mettre un launcher alternatif ! Citer
Znuf Posté(e) 9 mai 2011 Posté(e) 9 mai 2011 passe sous launcher pro ou ADW launcher et t'aura un défilement comme tu aimes (sans htc sense) Mais du coup, on perds un peu l'interet de la rom. Citer
rodyh Posté(e) 9 mai 2011 Auteur Posté(e) 9 mai 2011 Bin un peu mais pas forcément, tout dépend de ce que chaque personne recherche. Si la ROM est de bonne qualité ne consomme pas de batterie, sans bugs, ca peut être très intéressant. Pour la ROM Virtuous 1.0.2 par exemple, je n'utilise pas Sense mais un Launcher alternatif car je trouve la ROM bien meilleure qu'une Cyanogen de base ou autre. Maintenant il y a des ROMS comme la Pyromod basée sur Cyano mais optimisée que je prefere presque utiliser à la Virtuous 1.0.2 (j'hésite encore). Et la pour le moment bin je suis sur Virtuous Fusion et j'utilise Sense qui je trouve est devenu vraiment intéressant, comme je le disais plus haut, Sense avec son Home en 3.0 rattrape un peu son retard face à des Home alternatifs ! Mais il y a encore un peu de travail comme accepter les widgets scrollables des développeurs, mais j'ai peur que ca soit impossible à moins de fournir un API ou autre pour que les dev codent leur applis afin que ca soit compatible. D'ailleurs la j'ai pas mal de soucis avec certains widget de développeurs tiers comme Plume, Atoma RSS pour ne citer qu'eux, mon tel reste bloqué un moment avant d'être réutulisable voir il reboot quand j'essaye d'ajouter le widget. Bref pour en revenir a cette ROM, c'est franchement inattendu ce portage de Sense 3.0 mais ya encore du boulot !!!!!!! Citer
spinose Posté(e) 9 mai 2011 Posté(e) 9 mai 2011 j’étais assez bluffé le premier jour ou j'ai utilisé la ROM, (j’étais en France donc pas de data), mais depuis que je suis revenu chez moi, je trouve que les applications mail, agenda mettent beaucoup de temps a s'ouvrir comme beaucoup de virtuous, dè.s que je rentre dans le market, hop ma connexion data disparaît j pensais que ça allais devenir ma daily, mais je vais revenir à la trollogen en attendant un update améliorant la fluidité Citer
