[REF] ROM OFFICIELLE pour XPERIA ARC
J'ai relancer Flashtool et j'ai l'impression de bloquer ...
Voici le log actuel :
20/050/2012 09:50:09 - INFO - <- This level is successfully initialized
20/050/2012 09:50:09 - INFO - Flashtool Version 0.8.2.0 built on 2012-05-31 19:51:15
20/050/2012 09:50:09 - INFO - You can drag and drop ftf files here to start flashing them
20/050/2012 09:50:14 - INFO - Device connected in flash mode
20/050/2012 09:50:40 - INFO - Selected arc_233_fr_nue.ftf
20/050/2012 09:50:40 - INFO - Preparing files for flashing
20/050/2012 09:50:46 - INFO - Device disconnected
20/051/2012 09:51:18 - INFO - Please connect your device into flashmode.
20/051/2012 09:51:50 - INFO - Device connected in flash mode
20/051/2012 09:51:50 - INFO - Opening device for R/W
20/051/2012 09:51:50 - INFO - Reading device information
20/051/2012 09:51:50 - INFO - Phone ready for flashmode operations.
20/051/2012 09:51:50 - INFO - Start Flashing
20/051/2012 09:51:50 - INFO - Flashing loader
20/051/2012 09:51:55 - INFO - Loader : S1_Loader_Root_773f - Version : R4A066 / Bootloader status : NOT_ROOTABLE
20/051/2012 09:51:55 - WARN - This file is ignored : simlock.ta
20/051/2012 09:51:55 - INFO - Flashing kernel.sin
20/051/2012 09:51:57 - INFO - Flashing fota0.sin
20/051/2012 09:51:58 - INFO - Flashing fota1.sin
20/051/2012 09:51:59 - INFO - Flashing amss_fs.sin
20/051/2012 09:51:59 - INFO - Flashing adsp.sin
20/052/2012 09:52:02 - INFO - Flashing amss.sin
20/052/2012 09:52:12 - INFO - Flashing apps_log.sin
20/052/2012 09:52:12 - INFO - Flashing system.sin
20/054/2012 09:54:16 - INFO - Flashing userdata.sin
20/054/2012 09:54:18 - INFO - Flashing cache.sin
20/054/2012 09:54:19 - INFO - Ending flash session
20/054/2012 09:54:19 - INFO - Flashing finished.
20/054/2012 09:54:19 - INFO - Please wait. Phone will reboot
20/054/2012 09:54:19 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
20/054/2012 09:54:20 - INFO - Device connected in flash mode
Et maintenant je fais quoi ?
et c'est reparti, je n'arrive plus, comme hier, a le connecter . Je n'est plus la led à coté du chargeur.
Mais si jamais ça reviens quelle Rom me préconises tu ?
Merci pour la ROM j'avais pas vu ton message précédent. (n'empèche que le téléphone ne se reconnecte plus pour l'instant)
Ok c'est bon la led repasse en vert !
Il suffisait juste d'enlever la batterie quelques secondes et de la remettre ...
Je vais donc maintenant essayer la nouvelle ROM ...
Hallelujia !!!!
En effet il y avait un souci de ROM (note pour tout les copains prendre la bonne ROM pour le arc s) , je pense aussi que la batterie n'était pas au top car a l'allumage j'ai constaté qu'il ne me restait que 1%.
Un grand grand grand merci a Alex971 et D4RKsteph ! Vous des grands hommes ! Pour tout ceux qui ont des galères avec le xperia ces mecs là sont là pour vous (presque à croire que ce sont eux qui ont créés ces téléphones !)
MERCI !!!
En fait le problème était double : problème de rom + batterie vide... Ça peut arriver même à ceux qui ont la bonne rom, mais un recovery installé car si la batterie est vide, le recovery empêche le chargement du tel éteint et la seule solution est le flash d'une rom officielle pour récupérer cette option.
Sinon j'ai jamais créé de tel ^^
Ah il est où ce lien, car ça m'intéresserait d'essayer... Car perso je suis pas sur que l'on puisse contourner ce soucis de chargement tel éteint qui va avec le recovery installé (car depuis le temps que ce problème existe, si il y avait une solution je suis étonné qu'elle ne soit pas inclus dans les recovery aujourd'hui)
  Le 23/09/2012 à 09:42, Xquicky a dit :
Bonjour à tous.
J'ai remarqué que la rom de la dernière mise à jour du arc (4.1.B.0.587) n'est pas disponible dans la liste des roms sur la première page de ce topic. Quelqu'un disposerait de la rom nu française ?
Merci !
désolé je n'ai pas mon ARC actuellement en réparation pour la fissure, donc je n'ai pas la version francaise de la .587
néanmoins j'ai trouvé ceci pour toi: http://forum.xda-developers.com/showthread.php?t=1836071 ;)
je me pose une question. J'ai un arc S en version Android 4.0.4, numéro build 4.1.b.0.587...
J'aimerais le rooter, donc apparement il faut le flasher de 4.0.4 vers 4.0.3.
Quels fichiers dois je télécharger (hormis flashtool) ?
Je vois bien cela: -ROM FRANCAISE 4.1.A.0.562en version ICS 4.0.3 de l'ARC S
Mais comment repasser en 4.0.4 ?
Bonjour à tous je voudrais savoir si je peux de mon arc (en 2.3.4 build 4.0.2.A.0.62) flasher avec flashtools une rom ics qui sont en première pages, car j'étais en 0.42 root j'ai branché sur pc compagnion et m'a fait la mise à jour en 0.62 mais pas en ics :( .
Merci de votre réponse.
