[ROM][JULE8]-=Virtuous Picasso v. 1.1.0=- [Honeycomb 3.1][Kernel: UNITY V5]
lien post original :
http://forum.xda-dev...d.php?t=1129826
Video review:
(merci a cfcoleman)
dddc3590470e6b3fce7868b449c894af.jpeg6084ee67223c72506e4c7023f6b1d629.jpeg6098fedb180136ad4128967656315d58.jpeg248a1d3b3f686ae3566e8968009c2298.jpeg
Based on Acer ROM 4.010.22_COM_GEN1 (Honeycomb 3.1)
Kernel:
UNITY V5
- Multilanguage
- Improved EXT4 performance
- Ultra Fast
- Virtuous CPU scaling scripts - READ MORE
- Deodexed
- Zipaligned
- 216-1200MHz default
- CIFS/TUN/USB WWAN
- TweetComb / FriendMe
- 3D Photo Browser
- Photo Editor
- Polaris Office
- Google Video Service (does not work in all countries)
- clear.fi
- LumiReader
- Memo
- Busybox / Superuser
- 3G modem support (Huawei)
- Nano text editor support
- Bash command shell support
- WP7 fonts
- and more
- Flash via ClockworkMod: https://market.andro...coveryInstaller
[TUTORIAL] How to Flash Virtuous Picasso Rom On the Acer Iconia A500:
(merci a cfcoleman)
V1.1.0 Full ROM:
http://www.multiupload.com/WA1WIJSKA2
faire un full wipe si premiere installation
Code:
v.1.1.0:
- New base 4.010.22_COM_GEN1
- New kernel UNITY V5
- Updated Maps
- Updated TweetComb
- Updated FriendMe
v.1.0.8:
- Newest kernel UNITY V2
- Fixed random reboots
- Other minor tweaks
v.1.0.7:
- Back to Asus 3.1 base
- New custom kernel UNITY V1 with OC support (1600MHz max)
- Enabled 1080p video out
- Remoived eBook
- Removed PressReader
- Updated AcerSync
- Removed Asus DLNA
- Added Acer DLNA
- Updated Clearfi
- Updated nemoPlayer
- Updated 3D Photo Browser
- Added SocialJogger
- Added Asus Reader
- Replaced clock font
- Added Acer weather widget
- Other minor fixes & tweaks
v.1.0.6:
- Improved media_profiles
- Added Asus buttons
- Fixed 3G modems support
- Added CIFS/TUN modules
v.1.0.5:
- New base: leaked Acer update Acer_A500_3.019_COM_GEN1 (Honeycomb 3.1)
- New kernel: 2.6.36.3-00005-g5dff38c
v.1.0.4:
- Fixed 3G support
- Updated TweetComb
- Improved ramdisk
- Improved updater-script
- Other minor fixes & system tweaks
v.1.0.3:
- Updated kernel
- Added Memo from SGT 10.1
- Added Aurora & Bluesea live wallpapers from SGT 10.1
- Added DoubleClock widget from SGT 10.1
- Added Photo Editor from SGT 10.1
- Added Ebook from SGT 10.1
- Fixed hardware decoding H264, etc
- Added symlinks to external_sd & usb_storage
v.1.0.2:
- Added SketchMemoPlus
- Updated Layar
- Removed Asus PCSync
- Added Magic Smoke Live wallpapers
- Added AcerSync
- Added link to Adobe Flash Player
- Added ApInAp (with English & Rusian translations)
- alot ROM cleanups - Updated PolarisOffice from Asus Transformer
- Updated ES File Explorer -
v.1.0.1:
- Speed up animation
- Ported Camera app from Acer (with storage select)
- Updated Clearfi - Other minor tweaks & cleanups
v.1.0.0:
- Initial release
Introduction to the new Overclocking Daemon
mon anglais etant un peu limite vous trouverez sur le post original comment overclocker le processeur jusqu’à 1600 MHZ
donc si un membre peut faire une traduction exacte sa serait cool merci d'avance
More Info & GPL:
Acer: http://www.acer.com/
Kernel: http://gitorious.org/picasso-hc-kernel
All credits & thanks to:Google, Virtuous Dev Team (rmk, Flemmard, Diamondback, Chrisch1974, m-deejay, seo), sc2k, Dexter_nlb, Roach2010, DC13 and others (i forgot)
Modifié par grandiosa
  • Réponses 228
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
En effet, cette ROM allie le meilleur des deux mondes .... Ainsi je retrouve Photo Browser 3D, par exemple !
On assiste maintenant à une accélération dans le développement des ROMS alternatives ... Voilà bien un atout non négligeable pour notre chère Iconia Tab !
Ne reste plus maintenant qu'à corriger quelques petits bugs ou manques et ajouter au sein de la ROM quelques logiciels indispensable pour profiter au mieux de la tablette ...
Par exemple, serait-il possible d'améliorer la compatibilité vidéo ? Cela permettrait ainsi à Asus MyNet de pouvoir lire les vidéos stockés sur un serveur DLNA ...
En attendant, si quelqu'un se sert de cette application (qui détecte beaucoup mieux ma Freebox Server) et a réussi à lancé un logiciel vidéo externe, je suis preneur !
vous pensez qu'il serait possible d'avoir un tuto pour l'install de cette rom?
je n'y comprend rien du tout ... :(
1- ROOT -> http://forum.xda-dev...d.php?t=1055354
2- RECOVERY: ACER RECOVERY INSTALLER via le Market -> https://market.andro...coveryInstaller
3- ROM 1.0.2 -> http://forum.xda-dev...d.php?t=1129826 a mettre a la racine d'une carte Micro SD que tu mettras par la suite dans ta tablette, démarres en recovery (POWER + Volume Down), tu fais un Wipe DATA et ensuite tu installe la ROM via le menu Install ZIP
Modifié par Killer
Je me pose 2 questions sur ces ROM custom.
La rom vient d'un portage d'un rom custom pour asus, donc si on veut la tablette la plus customisable ne doit on pas se diriger vers l'asus transformer ?
Quels sont les plus de cette ROM hormis la version 3.1 de honeycomb.
Peut on avoir plus d'image.
Eric
Eric
Images -> http://forum.xda-developers.com/showpost.php?p=14850147&postcount=2
La ROM intègre les pilotes pour pouvoir mettre une Clé USB 3G (Huawei) aprés tout le reste ne sont que des applications rajoutées.
sympa :)
simple, rapide et très très efficace !
encore merci ;)
Quelqu'un peut détailler finement toutes les opérations.
Je suis un peu nouveau chez Android et j'ai peur de flinguer ma tablette ! Mais j'ai bien envie de mettre un peu les mains dans le cambouis.
Alors ma tablette est rooté, j'ai telechargé la ROM et je l'ai mise sur la carte SD de ma tablette (j'ai n'ai pas décompressé l'archive) et j'ai installé ACER Recovery installer sur le market.
Ensuite...j'aimerais que quelqu'un m'explique étape par étape.
Deja pour le démarrage en recovery, j'ai essayé la manip (bouton bas du volume + power ) et la tablette démarre normalement...Est ce que j'ai loupé une étape ?
Merci a tous
a partir d'acer recovery il faut instaler le recovery indiqué et ensuite eteindre la tablet et maintenir power et vol - (enfin pour moi c'est volume moins c'est a dire appuyer comme si on baisse le volume)
et maintenir les 2 (power et volume) jusqu'a l'apparition de ligne blanche en haut a gauche (tablet horizontal).
ensuite suivre les indications.
(monter et descendre dans la colonne du recovery c'est avec le volume et pour faire votre choix c'est sur power)
instal zip from sdcard
choise zip
et instal et bien sur laisser faire.
voila !!!!!
Franchement impressionnant. Première fois que je root et que j'installe une rom et en 10 minutes même pas c’était fait. Et puis la surprise ultime, j'ai perdu aucune donnée, aucune appli... j'ai perdu 30 minutes à faire un back up pour des clopinettes lol. Meme les wigdets etaient à leurs places :)
Merci beaucoup pour cette rom qui pour l'instant m'a l'air très bien foutue (j'ai juste vu qu'on avait perdu le Dolby) et pour toutes les explications (ici et pour le root).
Une facilité monstre !
Je suis vraiment tout frais sous Android et j'ai eu peur pour rien ! C'etait d'une simplicité (merci Oxbo) !
Par contre j'suis décu...j'm'attendais a une meilleure gestion des vidéos 720p et c'est rageant. Certes c'est plus fluide mais j'ai de grosses saccades par moment ! Je devrais donc passer par l'encodage!
