FadeFX Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 Hi, Can I afford to answer ? I'm not a specialist but I think I can give you my point of view ;) So, you say that the firmware ii5 have no sleep bug as opposed to the JC6, but I don't think so. Since I've flashed my Galaxy with the Galaxo 1.6.1, with the JB2 baseband, my life battery has increased a lot ;) with the firmware ii5 it lasted only 1 short day, now I can use my Galaxy 2 days during :D. Well, forgive me for my poor english writing ;) hmm, this could be caused by other issues. also it seems that not everyone is expiriencing this bug, if you do and mind some testing you could just try, there is no risk except some time to spend ;-) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LocoMan Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 Hi' date=' Can I afford to answer ? I'm not a specialist but I think I can give you my point of view ;) So, you say that the firmware ii5 have no sleep bug as opposed to the JC6, but I don't think so. Since I've flashed my Galaxy with the Galaxo 1.6.1, with the JB2 baseband, my life battery has increased a lot ;) with the firmware ii5 it lasted only 1 short day, now I can use my Galaxy 2 days during :D. Well, forgive me for my poor english writing ;)[/quote'] hmm, this could be caused by other issues. also it seems that not everyone is expiriencing this bug, if you do and mind some testing you could just try, there is no risk except some time to spend ;-) Ok, now I must let you in the Drakaz hands's ;) But, just one thing, please post your question on the english thread, it might be more practical, you know ? So, bye bye ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
FadeFX Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 sorry could not find english thread since the whole forum seems chinese for me (i know its french but...) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
korline Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 Just under this forum you can find : https://www.frandroid.com/forum/viewforum.php?id=44 This is a forum especially dedicated to english users ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LocoMan Posté(e) 30 mars 2010 Share Posté(e) 30 mars 2010 Je n'ai pas précisé le lien vers le forum anglais car il a déjà posté dessus ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
winni Posté(e) 31 mars 2010 Share Posté(e) 31 mars 2010 (modifié) Bonjour, il y a certaines personnes qui disent qu'avec la baseband II5 il n'y a plus le bug de la géolocalisation... Certains peuvent confirmer?? je testerai ce soir (si j'ai le temps) @+ testé à l'instant pas mieux... Modifié 31 mars 2010 par winni Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
59garfield Posté(e) 31 mars 2010 Share Posté(e) 31 mars 2010 1/ tu installes la JC6 avec ODIN 2/ tu copies le fichier RECTOOLS.TAR GZ sur la carte SD 3/ tu ouvres JC6 plusieurs fois jusqu'à ce que tu obtiennes 4 dossiers, (CSC, BOOTLOADER, PHONE et PDA) Tu renommes le PDA en SAMSUNG.tar et tu copies ce fichier sur ta carte SD 3 BIS/ si tu as en projet d'installer GALAXO 1.6.2 et bien copie le sans le dézipper sur ta carte SD 4/ tu copies le fichier recovery.img dans le répertoire tools de ton SDK 5/ fastboot 6/ ton recovery est normalement installé. Tu redémarres avec VOL BAS + APPELER + RACCROCHER. Tu as les écritures vertes et là tu fais un nandroid BACKUP 7/ un petit coup de wipe 8/ apply any zip from SD 9/ restore GAPPS 10/ reboot OOPS !! pas vu KORLINE, je te laisse le main... Bonjour, Je ne comprends pas le 1 (tu installes la JC6 avec ODIN) je ne sais pas comment faire pour installer JC6 avec Odin ??? J'ai actuellement galaxo 1.6.1, avecla donut XXJB6, et lorsque je veux restorer Gapps, il me met restore aborted : see/sdcard/recovery.log. Pourtant je suis bien avec recovery 4.6.2?? Pouvez vous m'aidez, j'ai suivi different tuto, mais toujours meme probleme avec g apps. Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
fredchris92 Posté(e) 31 mars 2010 Share Posté(e) 31 mars 2010 (modifié) 1/ tu installes la JC6 avec ODIN 2/ tu copies le fichier RECTOOLS.TAR GZ sur la carte SD 3/ tu ouvres JC6 plusieurs fois jusqu'à ce que tu obtiennes 4 dossiers, (CSC, BOOTLOADER, PHONE et PDA) Tu renommes le PDA en SAMSUNG.tar et tu copies ce fichier sur ta carte SD 3 BIS/ si tu as en projet d'installer GALAXO 1.6.2 et bien copie le sans le dézipper sur ta carte SD 4/ tu copies le fichier recovery.img dans le répertoire tools de ton SDK 5/ fastboot 6/ ton recovery est normalement installé. Tu redémarres avec VOL BAS + APPELER + RACCROCHER. Tu as les écritures vertes et là tu fais un nandroid BACKUP 7/ un petit coup de wipe 8/ apply any zip from SD 9/ restore GAPPS 10/ reboot OOPS !! pas vu KORLINE, je te laisse le main... Bonjour, Je ne comprends pas le 1 (tu installes la JC6 avec ODIN) je ne sais pas comment faire pour installer JC6 avec Odin ??? J'ai actuellement galaxo 1.6.1, avecla donut XXJB6, et lorsque je veux restorer Gapps, il me met restore aborted : see/sdcard/recovery.log. Pourtant je suis bien avec recovery 4.6.2?? Pouvez vous m'aidez, j'ai suivi different tuto, mais toujours meme probleme avec g apps. Merci Effectivement, tu en as un peu de partout, JB6 avec 1.6.1 avec recovery 4.6.2 !!!!!! Dans un premier temps, tu télécharges ODIN puis DONUT (1.6), version JC6, tu trouveras les liens sur le forum sans trop de problème. Ensuite tu installes cette version via ODIN en remplissant chaque case correspondante, le PDA JC6 dans PDA, le PHONE JC6 dans PHONE ...etc.... par contre n'installe pas le CSC, ca t'évitera d'apprendre le russe. Une fois cette installation terminée, ton tél sera en version DONUT version JC6. A ce moment, tu télécharges la version galaxo 1.6.2 et le recovery 4.6.2 et tu suis le tuto. Modifié 31 mars 2010 par fredchris92 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
59garfield Posté(e) 31 mars 2010 Share Posté(e) 31 mars 2010 1/ tu installes la JC6 avec ODIN 2/ tu copies le fichier RECTOOLS.TAR GZ sur la carte SD 3/ tu ouvres JC6 plusieurs fois jusqu'à ce que tu obtiennes 4 dossiers' date=' (CSC, BOOTLOADER, PHONE et PDA) Tu renommes le PDA en SAMSUNG.tar et tu copies ce fichier sur ta carte SD 3 BIS/ si tu as en projet d'installer GALAXO 1.6.2 et bien copie le sans le dézipper sur ta carte SD 4/ tu copies le fichier recovery.img dans le répertoire tools de ton SDK 5/ fastboot 6/ ton recovery est normalement installé. Tu redémarres avec VOL BAS + APPELER + RACCROCHER. Tu as les écritures vertes et là tu fais un nandroid BACKUP 7/ un petit coup de wipe 8/ apply any zip from SD 9/ restore GAPPS 10/ reboot OOPS !! pas vu KORLINE, je te laisse le main...[/quote'] Bonjour, Je ne comprends pas le 1 (tu installes la JC6 avec ODIN) je ne sais pas comment faire pour installer JC6 avec Odin ??? J'ai actuellement galaxo 1.6.1, avecla donut XXJB6, et lorsque je veux restorer Gapps, il me met restore aborted : see/sdcard/recovery.log. Pourtant je suis bien avec recovery 4.6.2?? Pouvez vous m'aidez, j'ai suivi different tuto, mais toujours meme probleme avec g apps. Merci Effectivement, tu en as un peu de partout, JB6 avec 1.6.1 avec recovery 4.6.2 !!!!!! Dans un premier temps, tu télécharges ODIN puis DONUT (1.6), version JC6, tu trouveras les liens sur le forum sans trop de problème. Ensuite tu installes cette version via ODIN en remplissant chaque case correspondante, le PDA JC6 dans PDA, le PHONE JC6 dans PHONE ...etc.... par contre n'installe pas le CSC, ca t'évitera d'apprendre le russe. Une fois cette installation terminée, ton tél sera en version DONUT version JC6. A ce moment, tu télécharges la version galaxo 1.6.2 et le recovery 4.6.2 et tu suis le tuto. Re a tous, Je viens ENFIN de reussir la maj en CJ6 a partir de la JB2 !! voici ce k j'ai fais (desole si je recapitule les etapes, mais bon une piqure de rappel...) INSTALLER LE RECOVERY ET PREPAREZ ANDROID 1) branchez android 2/ montez usb pour acceder à la SD 3/ dans la SD, supprimer les fichier (recovery.log ; RECTOOLS ;update ; SAMSUNG) qui correspondaient à la maj galaxo 1.6.1. ET installez ceci : - installez SAMSUNG (fichier PDA de la JC6 renommé en SAMSUNG) - installez RECTOOLS.tar (dossier se trouvant dans dossier RECOVERY 4.6.2) - installez update.zip (fichier zip galaxo_1.6.2 renommé en update) 4/ copier/coller fichier [recovery.img] dans le dossier [tools] du SDK, 5/ preparer l'invite de commande [touche windows+R ; tapez cmd et entrer] 6/ tapez [cd (chemin du dossier SDK/tools] SANS LES CROCHETS !!! 7/tapez [fastboot flash recovery recovery.img] MAIS n'appuyez pas sur ENTRER !!! SANS LES CROCHETS !!! 8/ activez dans parametre de android, deboguer usb 9/ brnchez android au PC 10/ eteindre et lancez mode fastboot (touche ON + APPEL) 11/ dans mode fastboot, appuyer sur entrer du PC avec l'invite de commande cmd Il doit y avoir 2 OK sur le PC 12/ redamarrez en mode recovery (volume bas + ON + appel) 13/Vous devez etre en recovery 4.6.2 , 14/ selectionnez Nandroid Backup 15/ puis wipe data/Reset factory 16/ puis apply any zip from sd, et choisir update.zip 17/ puis restore G apps 18/ reboot et voili voila :D PS : je n'y suis pas arrive du 1er coup !! Alors, si comme moi j'avais une erreur lors de la restauration de G apps, (restore aborted : see/sdcard/recovery.log), recommencez l'installation au niveau du 16. Bon courage. Je test, et je mets mon avis sur la JC6 ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ancelin Posté(e) 31 mars 2010 Share Posté(e) 31 mars 2010 Oui mais tu as quoi comme bande de base aussi?? Si tu ne passes pas par odin tu ne remet pas bien à jour ton téléphone. Tu a bande de base JB2 avec rom JC6 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
59garfield Posté(e) 31 mars 2010 Share Posté(e) 31 mars 2010 Oui mais tu as quoi comme bande de base aussi??Si tu ne passes pas par odin tu ne remet pas bien à jour ton téléphone. Tu a bande de base JB2 avec rom JC6 slt, Oui, c'est ca !! c'est pas bon ? bande de base XXJB2 build XEJC6 Il faut que la bande de base soit aussi XEJC6 ? Zut, faut que je recommence :| Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
59garfield Posté(e) 31 mars 2010 Share Posté(e) 31 mars 2010 Re, OK je viens de refaire correctement la maj en 1.6.2 avec bande de base JC6. :D Tout s'est bien passée. Merci encore de votre aide, et vivement la version 2 :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ricco Posté(e) 31 mars 2010 Share Posté(e) 31 mars 2010 Je suis en 1.6.2, ça fait 2 jours que je perd le net pendant la journée. Il faut que je passe en mode avion pour la retrouver. Ce matin j'ai perdu le bluetooth et j'ai du rebooter pour le retrouver. Ca arrive à d'autres ? Pour le net c'est seulement le fameux bug des dns Bouygues ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LocoMan Posté(e) 31 mars 2010 Share Posté(e) 31 mars 2010 Ce matin j'ai perdu le bluetooth et j'ai du rebooter pour le retrouver. T'as du aller loin pour le trouver celui là :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Maurice06 Posté(e) 1 avril 2010 Share Posté(e) 1 avril 2010 (modifié) Depuis 1.6, quand on active la localisation, il y a un message comme quoi Google récupère des infos "anonymement" même si aucune application ne se localise (comprendre: Gmaps éteint). De mémoire, on n'avez pas ce message en 1.5. ça pourrait donc venir de là: Google nous suit à la trace, ce qui bouffe de la batterie Modifié 1 avril 2010 par Maurice06 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Graaou Posté(e) 2 avril 2010 Share Posté(e) 2 avril 2010 (modifié) Juste pour remonter un petit souci. Depuis la 1.6.2 plusieurs interlocuteurs se plaignent de très mal m'entendre. et aujourd'hui c'est moi qui entendait mal quelqu'un ( voix robotic ), en le rappelant depuis un fixe c'était beaucoup mieux. C'est a peu près depuis l'installe mais j'en suis pas sûr et c'est peut-être un problème d'appareil. Je voulais savoir si d'autres ont des problèmes au niveau du téléphone? ( je suis chez bouygues) Modifié 2 avril 2010 par Graaou Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bbTGV Posté(e) 3 avril 2010 Share Posté(e) 3 avril 2010 J'ai aussi des soucis avec l'appli téléphone, mais je ne pense pas que cela vienne de Galaxo mais plutôt du Galaxy vivement une nouvelle mise à jour du kernel. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
elmartin7 Posté(e) 4 avril 2010 Share Posté(e) 4 avril 2010 Merci beaucoup pour galaxo 1.6.2, est un gros travail, je ne vois qu'une seule langue par défaut n'est pas l'espagnol!, S'il vous plaît mettez en espagnol! pardon pour la traduction. en ce qui concerne Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chris7777 Posté(e) 5 avril 2010 Share Posté(e) 5 avril 2010 (modifié) Bonjour, Je viens de me rendre compte (après avoir lu les messages précédents) que ma version de BUILD est bien Donut.XXJB6 mais ma bande de base est I7500XXII5. Comment remédier à cela ? J'étais auparavant sur galaxo 1.5 puis j'ai fait la mise à jour directement à partir du recovery 4.6.1 : (nandroid, wipe , update.zip et enfin restore G.APPS) PS : Pas de Windows seulement GNU/Linux Modifié 5 avril 2010 par chris7777 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ancelin Posté(e) 5 avril 2010 Share Posté(e) 5 avril 2010 (modifié) Bonjour,Je viens de me rendre compte (après avoir lu les messages précédents) que ma version de BUILD est bien Donut.XXJB6 mais ma bande de base est I7500XXII5. Comment remédier à cela ? J'étais auparavant sur galaxo 1.5 puis j'ai fais la mise à jour directement à partir du recovery 4.6.1 : (nandroid, wipe , update.zip et enfin restore G.APPS) PS : Pas de Windows seulement GNU/Linux En faite il faut passer par un logiciel qui s'appel ODIN, mais qui n'est disponible que sous windows. Alors il faut que tu trouve une machine en windows quelque part (Une Vm peux poser des difficultés avec les port USB... peut être un Xenapp...) 1)Il faut que tu fasse donc un nandroid backup en passant par le récovery de ton tel 2) Trouver un windows 3)télécharger ODIN (aucune installation) 4)mettre les drivers de ton tel sur windows pour qu'il soit reconu par ODIN (Déja plus dur...) 5) Télécharger la mise à jour officiel (ou plus ou moins) de la version JC6 de samsung 6)flasher le tel 7)Wipe 8) Reflasher le récovery (qui va être supprimé) 9) wipe 10) Nandroid restore Mais si tu est en récovery 1.6.1 il vaut mieux mettre le 1.6.2 et reflacher pour galaxo 1.6.2. Sinon pour faire un backup du tel et des appli, APN , sms, ... prend Titanium Backup Aprés, certain on des probleme (moi avec) avec la géolocatisation qui bouff la batterie du tel, si tu est dispo pour nous dire si avec la bande de basse II5 tu n'as pas de problème de batterie ça serai cool. Tu trouvera sur le site plein de tuto pour Odin et les drivers USB... Celui de makime est à mon avis trés bien fait http://makimeubt.free.fr/Android/tuto/bidouilles/Tuto%20Android.html j'espère t'avoir mis sur la voix. Modifié 5 avril 2010 par ancelin Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
korline Posté(e) 5 avril 2010 Share Posté(e) 5 avril 2010 (modifié) Pas possible de mettre a jour la bande de base sans Windows. Le seul moyen de la flasher est de passer par Odin, et c'est un logiciel uniquement Windows. Edit : Grillé :) Modifié 5 avril 2010 par korline Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chris7777 Posté(e) 5 avril 2010 Share Posté(e) 5 avril 2010 merci pour les conseilles, en ce qui concerne la tenue de la batterie je dirais qu'elle est similaire à la 1.5 voir même un peu en dessous. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
muitommy Posté(e) 5 avril 2010 Share Posté(e) 5 avril 2010 bonjour, si les avis quiconque, le lecteur de musique dans cette ROM ne prend pas en charge id3v2? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Le_Poilu Posté(e) 6 avril 2010 Share Posté(e) 6 avril 2010 (modifié) Dites, c'est normal que le bouton de l'Appareil photo ne marche plus avec la Galaxo 1.6.1 (JB2)? Modifié 6 avril 2010 par Le_Poilu Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TerryFX Posté(e) 6 avril 2010 Share Posté(e) 6 avril 2010 (modifié) étant revenu ponctuellement sous 1.6.1 baseband JB2 pour la confection du thème buuf, je viens de tester à l'instant et je te confirme que le bouton latéral fonctionne très bien, tant pour lancer l'APN que pour prendre les photos. pour mémoire, je rappelle d'ailleurs que je ne rencontre strictement aucun de tes problèmes sous galaxo 1.6.1/JB2 (ni sous 1.6.2/JC6 d'ailleurs), mis à part le bug des notifs sdcard...possible que quelque chose ai mal tourné pendant ton installation initiale. je pense donc qu'il y aurait pas mal à gagner pour toi à refaire une réinstall complète, flash odin compris, et en retéléchargeant l'archive JB2 au passage (on sait jamais). certes c'est toujours un peu long et désagréable à faire, mais je pense que ça vaudrait le coup ;) Modifié 6 avril 2010 par TerryFX Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
