lorant95 Posté(e) 15 septembre 2011 Share Posté(e) 15 septembre 2011 (modifié) Tout le monde connait la team RcMix et bien voilà ils remettent le couvert et ça va frapper fort! Voici une rom custom tirée du nouveau Htc Runnymede. http://forum.xda-dev...d.php?t=1261721 Pour ceux dont la plupart des termes paraissent obscurs, allez voir le lexique du forum : http://wiki.frandroid.com/wiki/Accueil Infos: Rom custom basé sur la leak Gingerbread 2.3.5 du HTC Runnymede,disposant de Sense 3.5 Changelogs: new base 1.05.401.4 android 2.3.5 Détails de la rom: v4.0loads of new tweaks (some tweaks needs use of data or wifi) multidevice supportIncredible s Droid incredible 2 Desire s MT4G Desire z (unknown as no one wanted to test) v3.3 Quciklaunch widget updated (thx liamstears bigt305) Tweaks text corrected quicksettings reboot fix secure sms readded adobereader fixed autowipe removed reboot after flash removed, for rom cleaner support status bar transparency added to tweaks, different levels v3.2 new base 1.05.401.4 Fixed Honeycomb lockscreen text bug Tweaks - Volume Key Screen On Tweaks - 5x5 Appdrawer Tweaks - Hide Navbar Text Tweaks - Volume Key Camera Shutter Button Fixed distortion for HTC videoplayer 720p playback quicklaunch resized thx liamsters build prop edits by JSLEnterprise Rom manager support v3.1 Wifi issues fixed Possible apps 2 sd fix (reports please) New tweaks, keylight settings, full 2D smooth hack by hamdir Sorry forgot to remove wipe v3.0 New base 1.02.40.1 Release keys Telus audio fix autoinstall Tweaks updated, new features Tweak: bliss rosie switch (all working) Tweak: hamdir supersmooth scrolling switch (not really needed as it is very smooth) RCMix3D kernel v7 (call recording version coming later) Liens:ATTENTION A CHAQUE INSTALLATION CELA FAIT UN FULL WIPP ! V3.0 http://www.multiupload.com/5K0BLC4C7K V3.1 http://www.filesonic...file/2682309574 V3.2 http://adf.ly/3QawJ V3.3 http://www.multiupload.com/264IM7OIY3 V4.0 http://www.multiupload.com/XSZS4E8W5L Installation de la rom: http://forum.frandro...une-rom-custom/ Crédits Capychimp et la RCTeam Modifié 14 novembre 2011 par lorant95 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
db77 Posté(e) 15 septembre 2011 Share Posté(e) 15 septembre 2011 (modifié) Merci lorant95 ;) Mais certains bugs sont corrigés avec la 1.1, donc tu devrais peut-être modifier la liste des bugs... non ? Ou au moins, mettre, à côté des bugs, un truc du style : corrigé avec la 1.1 Modifié 15 septembre 2011 par db77 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lorant95 Posté(e) 15 septembre 2011 Auteur Share Posté(e) 15 septembre 2011 Merci lorant95 ;) Mais certains bugs sont corrigés avec la 1.1, donc tu devrais peut-être modifier la liste des bugs... non ? Ou au moins, mettre, à côté des bugs, un truc du style : corrigé avec la 1.1 je viens de voir sur xda que la liste des bug a changée...encore ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
thanataus Posté(e) 15 septembre 2011 Share Posté(e) 15 septembre 2011 Yesss ... et le bluetooth ... il marche ? j ai testé 2 versions en 2.3.5 et j ai une une tonne de bug sur ma liste d APP ... je suis le seul? les app ne veulent plus se charger et mettent un message d erreur ... bon je suis un peu HS :emo_im_foot_in_mouth: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
titcrunch Posté(e) 15 septembre 2011 Share Posté(e) 15 septembre 2011 Rcmix c'est bien mais a part des portages, ils font quoi ? car toutes leur rom finisse par être remplacer par un nouveau portage sans correction de bug sur les anciennes, bref, ca fais pas très sérieux du coup Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
luigi Posté(e) 15 septembre 2011 Share Posté(e) 15 septembre 2011 Je suis assez d'accord avec toi c'est d'ailleurs pour ça que je suis partie des roms RCMix, ils sortent 4 roms par semaine, font 2 mise à jours pour régler les plus gros bugs et puis plus rien alors qu'elles pourraient être plus optimiser.... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MarcLejeune Posté(e) 15 septembre 2011 Share Posté(e) 15 septembre 2011 (modifié) le bluetooth et le modem fonctionne sur cette rom ?? Le bluetooth et le modem fonctionne bien sur cette rom! Merci Modifié 16 septembre 2011 par marcusdoc Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
nono931 Posté(e) 16 septembre 2011 Share Posté(e) 16 septembre 2011 a quoi sert le kernel qu ils ont mit c obligatoire de le prendre ou pas?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lorant95 Posté(e) 16 septembre 2011 Auteur Share Posté(e) 16 septembre 2011 a quoi sert le kernel qu ils ont mit c obligatoire de le prendre ou pas?? je sais pas sincèrement je tourne sans et ça fonctionne bien ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lorant95 Posté(e) 16 septembre 2011 Auteur Share Posté(e) 16 septembre 2011 Post 1 mise à jour pour la v1.2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MarcLejeune Posté(e) 16 septembre 2011 Share Posté(e) 16 septembre 2011 (modifié) Avec plus d'attention, j'ai constater que je n'arrivais pas a utiliser le modem, c'est que moi? ou c'est pour tout le monde ? Je viens d’installer la v1.2 et le widget " lancement rapide" ne fonctionne pas chez vous aussi ? Avec la v1.2 le modem fonctionne que avec des adresse https, les adresse http me donne une erreur 403. Alors c'est déjà sa, je peu lire mes e-mail, mais sa s’arrête la ! Le modem fonctionne en Full internet dans les nom des point d'acces Modifié 1 octobre 2011 par marcusdoc Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lorant95 Posté(e) 16 septembre 2011 Auteur Share Posté(e) 16 septembre 2011 je ne me sert pas du modem mais j'essayerais. après installation de la v1.2 je comprends pourquoi le full wipe ! on peu désormais bien plus la paramétrer Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Drain Posté(e) 18 septembre 2011 Share Posté(e) 18 septembre 2011 des retour sur la 1.3 ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lorant95 Posté(e) 19 septembre 2011 Auteur Share Posté(e) 19 septembre 2011 des retour sur la 1.3 ? Désolé je viens seulement de voir la v1.3 car pas la de tout le W.E. post 1 mis à jour. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MarcLejeune Posté(e) 21 septembre 2011 Share Posté(e) 21 septembre 2011 a quoi sert le Kernel ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sirtagada Posté(e) 22 septembre 2011 Share Posté(e) 22 septembre 2011 C'est le noyau de ta rom, ce qui la fait fonctionner. Juste une petite question : Elle est en portage/développement mais est-elle quand même fonctionnelle à quasi 100% si il y a juste le bluetooth ou la luminosité automatique qui ne fonctionnent pas c'est pas la mort mais au moins la wifi la 3g et tout ca ;) Merci d'avance ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
luigi Posté(e) 22 septembre 2011 Share Posté(e) 22 septembre 2011 Ouai elle est fonctionnelle, mais Sense 3.5 faut aimer. Sent from my HTC Desire HD Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sirtagada Posté(e) 23 septembre 2011 Share Posté(e) 23 septembre 2011 Bea justement j'aime bien l'interface ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
corben Posté(e) 24 septembre 2011 Share Posté(e) 24 septembre 2011 bon j'ai fait un crochet par cette rom hier, mon ressenti est que .... - jolie rom - problème camera et BT - pas mal de ralentissement - sense 3.5 apporte pas grand chose de plus que la 3.0 donc je retourne sur virtuous unity qui est plus abouti mais je garde cette rom à l'oeil Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lorant95 Posté(e) 25 septembre 2011 Auteur Share Posté(e) 25 septembre 2011 Je ne trouve pas que l interface change beaucoup, je veux dire que cela n'est pas aussi flagrant qu sur le bliss Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
titcrunch Posté(e) 25 septembre 2011 Share Posté(e) 25 septembre 2011 en même temps rien ne change a part le dock et le nouveau widget lol Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lorant95 Posté(e) 26 septembre 2011 Auteur Share Posté(e) 26 septembre 2011 en même temps rien ne change a part le dock et le nouveau widget lol +1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Neoleo Posté(e) 27 septembre 2011 Share Posté(e) 27 septembre 2011 Le bouton "personaliser" lance Internet... Peut on le réassigner à son utilité d'origine? Merci. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lorant95 Posté(e) 27 septembre 2011 Auteur Share Posté(e) 27 septembre 2011 Le bouton "personaliser" lance Internet... Peut on le réassigner à son utilité d'origine? Merci. oui dans paramètre puis tweaks rc mix3D puis option sense Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Neoleo Posté(e) 28 septembre 2011 Share Posté(e) 28 septembre 2011 Merci! ,) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
