[TUTORIEL] Rooter son tattoo, recovery, custom ROMs
JoOoSs
Quand je fait le recovery, je n'ai pas de message not found, mais avec le root persistant oui (je viens de réessayer, donc normalement je ne me suis pas trompé en écrivant).
Mais juste avant la commande mount j'ai un autre message d'erreur, je te mets une copie ici:
# export PATH=/system/bin# insmod /data/local/bin/tattoo-hack.ko
export: /data/local/bin/tattoo-hack.ko: bad variable name
# mount -o rw,remount /dev/block/mtdblock5 /data
mount: not found
Si je continue:
# mount -o rw,remount /dev/block/mtdblock3 /system
mount: not found
# chmod 755 /data/local/bin/flash_image
chmod: not found
# /data/local/bin/flash_image boot /sdcard/Mainfram3.boot.02.img
flashing boot from /sdcard/Mainfram3.boot.02.img
mtd: erase failure at 0x00000000 (Input/output error)
mtd: skipping write block at 0x00000000
mtd: erase failure at 0x00020000 (Input/output error)
mtd: skipping write block at 0x00020000
mtd: erase failure at 0x00040000 (Input/output error)
mtd: skipping write block at 0x00040000
mtd: erase failure at 0x00060000 (Input/output error)
mtd: skipping write block at 0x00060000
mtd: erase failure at 0x00080000 (Input/output error)
mtd: skipping write block at 0x00080000
mtd: erase failure at 0x000a0000 (Input/output error)
mtd: skipping write block at 0x000a0000
mtd: erase failure at 0x000c0000 (Input/output error)
mtd: skipping write block at 0x000c0000
mtd: erase failure at 0x000e0000 (Input/output error)
mtd: skipping write block at 0x000e0000
mtd: erase failure at 0x00100000 (Input/output error)
mtd: skipping write block at 0x00100000
mtd: erase failure at 0x00120000 (Input/output error)
mtd: skipping write block at 0x00120000
mtd: erase failure at 0x00140000 (Input/output error)
mtd: skipping write block at 0x00140000
mtd: erase failure at 0x00160000 (Input/output error)
mtd: skipping write block at 0x00160000
mtd: erase failure at 0x00180000 (Input/output error)
mtd: skipping write block at 0x00180000
mtd: erase failure at 0x001a0000 (Input/output error)
mtd: skipping write block at 0x001a0000
mtd: erase failure at 0x001c0000 (Input/output error)
mtd: skipping write block at 0x001c0000
mtd: erase failure at 0x001e0000 (Input/output error)
mtd: skipping write block at 0x001e0000
mtd: erase failure at 0x00200000 (Input/output error)
mtd: skipping write block at 0x00200000
mtd: erase failure at 0x00220000 (Input/output error)
mtd: skipping write block at 0x00220000
mtd: erase failure at 0x00240000 (Input/output error)
mtd: skipping write block at 0x00240000
mtd: erase failure at 0x00260000 (Input/output error)
mtd: skipping write block at 0x00260000
error writing boot: No space left on device
Mince, je viens de le faire y'a 5 secondes pour voir si il démarrait. Et il a démarré... Ouf!
EDIT: Par hasard, JoOoSs, aurais-tu garder ton ancien tuto du root, parce que chez moi il marchait très bien mais avec celui-c c'est la grande galère? ...
Modifié par flocmwa
Oui je sais bien que ça vient pas du tuto, pour ça je te fais entièrement confiance.
C'est possible qu'un tatto soit plus difficile à rooter qu'un autre? Parce que j'ai d'abord suivi scrupuleusement ton tuto mais avec des erreurs (même quand j'ai réessayé)...
Bonjour, je suis dans le meme cas que flocmwa je crois que j'ai toutes les erreurs qu'il a eu... je ne sais plus quoi faire, mon tattoo a juste été débrander j ai mis la rom origine htc au lieu de la rom bouygues sinon je n'ai rien modifié sur le portable... j'espère trouver une solution...
Oui certains Tattoo réagissent bizarrement aux commandes, je vérifierais encore ce soir le tuto, je te ferais recommencer du début avec plus d'assistance dans les commandes.
Tu as réussi quoi au fait dans le tuto ? Recovery ? Root persistant ?
J'ai pas de problème pour la copie des fichiers, j'ai un problème pour le root non permanent à la commande "cat" (mais je suis quand même #), j'ai un problème pour le recovery (je pense parce que le root non permanent renvoie des erreurs) et pour le root persistant je bloque a la commande "insmod".
En revanche, quand j'utilise la méthode décrite par gazzz33, j'ai un problème seulement au root persistant...
Merci de ton aide JoOoSs :)
Modifié par flocmwa
@flocmwa : Déjà la commande CAT doit marcher déjà tester sur un membre du forum et présente dans plusieurs tutos sur le net je vois pas ce qui n'a pas marché.
Je t'explique : la commande cat permet en gros d'éviter de taper le chemin complet jusqu'au fichier SU : /data/local/bin/su. Mais seulement de taper "su" et en fait ça exécute directement le fichier.
Je te conseille si le cat ne marche pas :
Tu reprends le tuto à partir de la partie où y'a le cat.
Dès que t'arrive au CAT, tu fais à la place:
chown root.root /data/local/bin/su
chmod 4755 /data/local/bin/su
Et tu arrêtes cette partie du tuto parce que ça remplace la fin de cette partie ;)
Ensuite, dès que je mets "su" dans mes commandes, tu le remplaces par /data/local/bin/su et c'est bon!
@Ichigo66630 : C'est parce que ton téléphone est connecté en mode "Disque amovible", choisis HTCSync.
Merci de ton aide JoOoSs, quand je suis dans la root non permanent à partir de la commande "chown", je n'ai pas d'erreur mais je n'ai plus le #, je sais pas si c'est normal.
Ensuite, pour le root permanent, quand je tape "/data/local/bin/su", j'ai "not found" :(
salut j'ai essayé le root de mon tattoo:
à l'étape du root persistant la dernière commande
ne marche pas, j'ai cette erreur :
error opening /sdcard/Mainfram3.boot.02.img: No such file or directory
je précise ces quelques points
- j'ai eu une erreur sur le "cat /data/local/bin/su > /system/bin/su", j'utilise donc "/data/local/bin/su" à la place de "su"
- à l'étape du root persistant, je devais réutiliser cette méthode pour avoir le root
$ cd /data/local/bin
$ while 'true' ; do ./m7 ; done
il me mettait que je n'avais pas les droits d'accès
- Les commandes ls et insmod ne marchait pas ("not found") pour le root persistant, j'ai résolu ce problème avec
# export LD_LIBRARY_PATH=/system/lib
J'en suis donc bloquer à la dernière étape du root persistant.
Si en attendant on peut me préciser ce qu'il ne faut surtout pas faire!
EDIT: j'ai réessayé sur un autre PC et la commande "/data/local/bin/su" m'a donné le ROOT
je n'ai pas eu besoin de faire les EXPORT pour que le "insmod" fonctionne, mais j'ai toujours le problème cité plus haut
Merci d'avance
Modifié par carbodrache
Bonsoir,
Tout d'abord, merci pour le tuto. :)
J'ai enlevé le son de démarre de mon Tattoo. Je remarque que le petit son du robot est malheureusement aussi enlevé (dommage).
Si je souhaite remettre le son au démarre de mon Tattoo, comment dois-je y procéder ?
Edit : Une autre question... Si je veux à tout moment retirer toutes traces des commandes effectuées pour accéder au mode root de mon Tattoo, est-ce possible ? En gros, remettre tout par défaut comme si je venais de l'acheter (paramètre d'usine).
Merci. ;)
Modifié par XavierBL
par rapport à mon dernier message, j'ai trouvé mon erreur le fichier n'était pas présent :/
mais j'ai une nouvelle erreur:
mtd: read error at 0x00000000 (Cannot allocate memory)
mtd: read error at 0x00020000 (Cannot allocate memory)
mtd: read error at 0x00040000 (Cannot allocate memory)
mtd: read error at 0x00060000 (Cannot allocate memory)
mtd: read error at 0x00080000 (Cannot allocate memory)
mtd: read error at 0x000a0000 (Cannot allocate memory)
mtd: read error at 0x000c0000 (Cannot allocate memory)
mtd: read error at 0x000e0000 (Cannot allocate memory)
mtd: read error at 0x00100000 (Cannot allocate memory)
mtd: read error at 0x00120000 (Cannot allocate memory)
mtd: read error at 0x00140000 (Cannot allocate memory)
mtd: read error at 0x00160000 (Cannot allocate memory)
mtd: read error at 0x00180000 (Cannot allocate memory)
mtd: read error at 0x001a0000 (Cannot allocate memory)
mtd: read error at 0x001c0000 (Cannot allocate memory)
mtd: read error at 0x001e0000 (Cannot allocate memory)
mtd: read error at 0x00200000 (Cannot allocate memory)
mtd: read error at 0x00220000 (Cannot allocate memory)
mtd: read error at 0x00240000 (Cannot allocate memory)
mtd: read error at 0x00260000 (Cannot allocate memory)
error reading boot: No space left on device
mtd: write error at 0x00000000 (Cannot allocate memory)
mtd: re-read error at 0x00000000 (Cannot allocate memory)
mtd: write error at 0x00020000 (Cannot allocate memory)
mtd: re-read error at 0x00020000 (Cannot allocate memory)
mtd: write error at 0x00040000 (Cannot allocate memory)
mtd: re-read error at 0x00040000 (Cannot allocate memory)
mtd: write error at 0x00060000 (Cannot allocate memory)
mtd: verification error at 0x00060000 (Cannot allocate memory)
mtd: wrote block after 1 retries
Et là j'ai pas d'idée
