CM9- ICS (Burstlam-Tilal6991-KonstaT) (04/11/2012)
ROM développée par TomG
Alpha 7 de TomG:
http://depositfiles....files/rw0wbtqub
Alpha6 de TomG:
http://blade.windows....ANG-signed.zip
miroir:www.mediafire.com/?c6z9ubks1gffr4x
Alpha 5 de TomG
Multiupload.com - upload your files to multiple file hosting sites!
Md5sum: 02808399dde949b7496af2d1502c4b04
alpha5+multitouch
md5 11fe832543fa6bd610732244da3385f9
ROM développée par Burstlam(AOKP-CM9 Remix)
[4th Nov 2012] RC 7.1.0 Full Language: (only wipe dalvik cache in recovery mode needed if upgraded from ics rom)
Download : https://hotfile.com/...signed.zip.html
md5 : beb67d3fa594edfe837f5db5821a1abe
Change log
RC 7.1.0
Camera View Optimization patch from ganster41 (here)
- note : need more tests and see whether it did speedup the preview or not.
framework : surfaceflinger: Improve dithering method (1)
default enabled in build.prop
Phone : Forward-ports CM7 Advanced Phone Settings (1)
add back National Data Roaming
Mms: Fixes mms automatic retrieval (backport from jb)
[10 August 2012] RC 6.8.0 Full Language: (only wipe dalvik cache in recovery mode needed)
md5 : 131916a3a3d48b12e7d760fe874fb300
[30 June 2012] RC 6.6.9 Full Language: (only wipe dalvik cache in recovery mode needed)
md5 : 9f14f9eeebae18b9c15210444eee7e93
Change log
RC 6.6.9
- fix "Wifi does not reconnect after reboots"
- bluetooth tethering improvement and speed improve. you may share your wifi connection of blade with other device thr bluetooth.
tested with HQ mode youtube clips on Galaxy Nexus with bluetooth connection.
RC 6.6.7
- Kernel : Revert PMEM.C changes which breaks Camera
- Adhoc mode support
- ROMcontrol : add Weatherpanel to lockscreen
- Minor fixes needed by Linaro toonlchain
- Bluetooth toggles not working fix attempt #2 : update props and ramdisk settings.
- Fix Camera Reboots.
- Install Scripts : move Boot audios and extra Audios, CMwallpapers, LiveWallpapers to "extras" install option depends on System Partition Size.
RC 6.6.5 -6.6.6 Skipped (multiple FCs and hardware breaks due to aosp merge)
[16 June 2012] RC 6.6.4 Full Language: (no wipe need, just remove dalvik cache should be okay)
md5 : 62caec15623ecd2da715359e508ac7d1
RC 6.6.4
- Kernel : fixed to compile with Linaro GCC 4.7 toolchain.
- Compile with Linaro GCC 4.7 toolchain, more fixes is coming (more fixes from the linaro aosp should be coming)
- AOKP RomControl : slide widget on nav bar, fix weather service FC, music layout toggle
- Adopted TOMG works on OTA releasetool, non essential content will not be install if System Partition size was found below 210mb
(these optional items have been moved to "extras" folders inside the rom file.)
ROM développée par Tilal6269(ColdfusionX)
http://goo.im/devs/t...blade/ROMs/CFX/
28/06/2012
Added more settings to CFX Settings
Added hostapd binary to allow WiFi tethering with an external app
Significantly improved app opening times on cold boot
Added some more Gerrit patches
Synced with CM9 repos
More stuff
update-cm9-tilal6962-31/05/2012
Changelog:
Fix barcode scanning
Add lockscreen calender
Remove soft keys
Sync with CM repos
ROM dévloppée par KonstaT
cm-9-20121031-KonstaKANG-blade.zip
http://www.mediafire...7t1ua131atz770l
md5:fb64b09327c304ff25b934c00432a0da
31.10. changelog:
  • fixed Youtube HQ (thanks to Ganster)
  • fixed possible connection drops
  • fixed possible bluetooth issues
cm-9-20120929-KonstaKANG-blade.zip
http://www.mediafire...frc9f6bfotd89kl
md5:cb894686be12a837a39703fb39ab6ebb
29.9. changelog:
  • version bump to 9.1
  • Do not allow intents to initiate special char sequence handling (merged, fixes possible USSD issue)
  • I/O scheduler settings (1,2)
  • couple of small changes to volume key cursor control
cm-9-20120827-KonstaKANG-blade.zip
http://www.mediafire...p062ckt5ratlb8d
md5:3c366348f9551b1895b27f17e6fbf4bb
27.8. changelog:
  • fixed panorama mode in camera
  • added option for circle battery (Settings -> System -> Status bar -> Battery status style -> Circle)
  • moved volume key cursor control to framework, works now with third party keyboards (Settings -> Language & input -> Volume key cursor control)
cm-9-20120808-KonstaKANG-blade.zip
http://www.mediafire...7xy49pm194aoeob
md5:930e55eeaaa23b47d7c4e3f52b786bb4
8.8. changelog:
  • added hot reboot option to power menu
  • improved partition info (EXT info should now work with all a2sd methods)
cm-9-20120722-KonstaKANG-blade.zip
http://www.mediafire...zh1caeup1cacimy
md5:0eaf70829b479381b918a725a736eb3d
22.7 changelog:
  • updated option to reverse volume key logic on cursor control
cm-9-20120706-KonstaKANG-blade.zip
http://www.mediafire...xtqeg9980gkivxh
md5:a72582642254f3b410692c1ce52d1722
6.7. changelog:
  • added MIUI-style battery bar (Settings -> System -> Status bar -> Battery status style -> Status bar, thanks to Spitemare)
  • added option to hide alarm icon in status bar (Settings -> System -> Status bar -> Show alarm icon)
  • Mms: fixes battery drainage while receiving Mms with data connection off (1)
  • removed Apollo, back with stock ICS music player
cm-9-20120704-KonstaKANG-blade.zip
http://www.mediafire...98p849bbl5z8ex0
md5:fe3753958a3c174e215f61c60f016e6b
gapps-ics-20111125-2.zip (56.4Mb)
Md5sum:2a305ff4cc9711f89d9b19bdea241455
gapps - ics - 20111128 - blade . zip (34.9Mo)
su-bin-3.0.3.2-efghi-signed.zip
Md5sum:26d08a253f1883c13561d173094d70b9
Gen1-to-Gen2-TPT-v10-stock.zip
MD5: ae0207cd88429a062d8b1770b3acd2c4
Cyanogen semble s'engager à porter CM9 (ICS) à la soixantaine de téléphone déjà pris en charge par la team( ...y compris le Blade ...enfin j'espere...)
cyanogen (cyanogen) sur Twitter
Koushik Dutta (qui a travaillé sur les recovery (ies)) a déjà une photo d'un des bébés custom en 4.0.1 daté du 15/11/11
Koushik Dutta - Google+
edit:
Une vidéo posté par TomG(les bases sont là mais il reste encore beaucoup à faire)
Modifié par Kader
  • Réponses 1,4k
  • Vues 298,4k
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Most Popular Posts
  • orochimaru94
    orochimaru94
    RC 5.9 - Kernel Change : include airplane mode fix. mdp update port back from higher linux version - Repo Sync update with CM9 and AOKP projects - some HWUI acceleration fixes, improved lag issue.
  • En effet, c'est pas le bon lien! J'ai regardé sur le wiki mais le lien vers la RLS6 est mort! :( J'ai la RLS6 sur le pc, je vais essayer de remettre un lien des que j'aurai trouvé comment! :emo_im_
  • Pour Wahaz: Alors voila les liens pour mettre la CM9 ICS KonstaKang: Le TPT: Gen1-to-Gen2-TPT-KonstaKANG.zip http://www.mediafire...xo48gggql67b5kd md5:c5201d683b1b760f9b5dd94d3be4ef19 La Rom:
  • Auteur
Deux mois à patienter,la priorité est donnée aux Samsung et HTC (allez savoir pourquoi.... :) ) mais si wbaw en outsider(cyanogen n'a toujours pas fait appel à ses services) se met à leur griller la "priorité" avec une rom pour le blade,les délais vont vite s'écourter :P .
Je ne pense pas que la concurrence de codeurs indépendants puisse influer la vitesse de développement de CM9 (surtout que le Blade .... voilà, quoi .... on serait dans la section HTC encore, on pourrait les chatouiller, mais là ...).
Il faudrait surtout que ZTE lâche un peu de lest (mais déjà que pour Gingerbread, ils se sont fait tirer l'oreille ....). Si le Skate passe en 4.0, ça peut le faire .... sinon, ben on passera après les autres (le chinois est patient) ....
Mais, pour le moment, la CM9 est le seul accès envisageable pour Ice Cream Sandwich sur le Blade. Et c'est déjà bien :P
Tu sous entends quoi par "Il faudrait surtout que ZTE lâche un peu de lest"? Il ne veulent pas que la communauté propose de nouvelle version?
Je pense surtout que nous sommes pas capable de pondre une ROM avec juste les sources ( accès à l'hardware non connus )
Donc si zte nous donne pas un leak pour le skate ( même accès hardware que le zte ) on ne pourra pas faire notre ROM nous même :P
Ils ont des accords commerciaux avec les opérateurs (ils vendent en sous-marque, chez SFR par exemple) et ces derniers ne veulent rien entendre niveau mise à jour (ça demande plus de maintenance et ça tue le commerce: pour eux, changement de version = changement d'opérateur).
De plus, le contrat "moral" avec Google ne leur demande de diffuser les sources que pour le modèle mis à jour (même si on voit bien qu'en partant du Skate on arrive "très facilement" au Blade).
Et, enfin, ils peuvent diffuser quand ils veulent .... et si c'est important pour le modèle phare, ça l'est nettement moins pour les anciens terminaux (sans parler du coût de développement).
ICS est-il tellement mieux que GSF ?
S'il est plus gourmand, il ramera probablement sur le Blade, non ?
GSF, c'est une Rom custom .... Tu voulais parler de Gingerbread, certainement ...
Dans ce cas, justement, ICS devrait amener plus de rapidité dans les menus, justement (d'où l’intérêt pour Cyanogen dont la priorité est plutôt les jeux jusqu'à maintenant). Et une gestion de la batterie plus intelligente.
Il y aura toujours des fonctionnalités inaccessibles (genre gestion de la caméra frontale) qui permettront d'alléger un peu plus ...
Et pourquoi voudrais-tu qu'il ne soit pas compatible ? Le Gingerbread d'un Galaxy S2 est le même que le nôtre ...
Le seul soucis serait la résolution de l'écran sauf que, manque de bol, on a une résolution de moyen/haut de gamme (ben oui, ça fait pleurer mes amis qui essayent de frimer avec leur Galaxy Ace (je leur ait dit de consulter un orthophoniste, ils ont des soucis d'oreille, la phonétique, c'est redoutable .... je leur ai conseillé également un bon pharmacien pour la vaseline ..... et un psy pour la dépression ...), bonjour la consommation de mouchoir ....), donc ça passe ...
De toute façon, tant que tu conserves au moins un clavier fonctionnel, tu peux toujours revenir en arrière ....
Je l'utilise, et franchement aucun soucis avec. ;)
Bon, les touches sont pas énormes (faut dire j'avais celui qui imitait les HTC jusque là), mais ça passe avec de l'entrainement.
  • Auteur
une tentative de fallenangel32 qu'il considere comme une pré pré pré alpha pour blade:une ics.zip
http://www.multiupload.com/2V6KRH5VFZ
juste pour tester, est-il utile de le dire?
Modifié par Kader
bon test en cours avec mon second blade, on vera bien ce que ça donne...
Bon pas de bootanim pour moi, un message de bienvenue "unfortunately, Launcher has stopped"
Impossible de déverouiller...
Totalement inutilisable et pas à l'échelle du Blade.
Modifié par Francois53
Le clavier fonctionne parfaitement bien, les touches sont semblables à celle du clavier stock.
La ROM ICS que fallenangel32 décrit comme une pré-pré-pré alpha, n'en est même pas une. Il prend beaucoup de précaution, mais je confirme qu'elle n'est pas utilisable pour l'instant.
Sej7278 travaille le sujet, mais pour l'instant, il se bat avec le SDK qui nécessite une config de ouf (i7/750 avec 8Go de RAM).
  • Auteur
La fallenangel est encore trop loin; quand on voit la vidéo de TomG pas très véloce mais elle a tout d'une grande...
Comme codeur, fallenangel32 est à des années lumières de Tom_G ...
Intégrer un thème à une Rom existante, il sait faire .... plus, c'est plus compliqué ...
Et puis Tom_G bosse pour Cyanogen ...
  • Auteur
ça tâtonne...mais ça marche
#99
quelques screenshots...
ICS (4.0.1) in zte blade - Konstat Rom
http://www.mediafire...biwgvzodiglnii5
MD5:CED9AFC28119980CC6FB945DC9ED11C8
Pour passer en français :settings/language/français(France ou Belgique ....)
Le wifi fonctionne.
Attached patched wpa_supplicant. Unzip and replace the one in /system/bin/.
wpa_supplicant.zip
Edit je n'ai pas vu que c'était déjà sur l'autre topic ICS
Modifié par Kader
C'est surtout que ça n'a pas grand chose à voir avec la CM9 ... :P
Même si, à l'arrivée, ça devrait se ressembler beaucoup ...
Il y aura pas de CM8 D'abord ? :/
la cm8 c'était pour honeycomb, mais j'ai cru comprendre que c'était pas vraiment une réussite!
C'est surtout qu'il n'y en a pas eu...
