[ROM] [ICS] CLASSICNERD - BUTTA HD [03/06]
GauthierBenat
CHANGELOG :
Maj du 03/06/2012
* Flash corrigé
* Netflix corrigé
* Décodage HD matériel corrigé
Maj du 28/05/2012
* Stock OC to 1.512ghz
* Updated wifi modules
* Build kernel along side the rom
* Updated props
* few more updates
Maj du 05/05/2012
* Décodage Hardware des vidéos fonctionnel
* Updated to 4.0.4 base
* Netflix support
* Browser tweaks
* Launcher haptic feedback restored
* Updated adreno libs
* Updated wifi
* Fixed Audio screen off distortion
* MTP Mount working.
* Tweaked animation/transitions in framework.
* Modded Browser source.
* Unlimited Browser tabs.
* Custom Wallpapers included in Launcher now.
* Increased heap, cut transitions/animations in half or more in Launcher2
* Battery mAh changed to 6000 from 1000 to better match the touchpad (it's 6300, some are seeing better battery performance)
* Classicnerd Bootanimation (thanks MindSplit)
* Reduced transition times by half in Launcher
* Slashed animation times for quicker feel
* Classicnerd init.d tweaks included in source now.
* Removal of all uImage and TGA files from /boot during flash.
* Classicnerd default in boot menu.
* Calculator has unlimited numbers.
* Unlocked Dock menu in Settings.
* Tweaked SystemUI.
* Scrolling tweaks moved from 4 pages to 2 pages.
* Fixed Chown in System/tools (thanks to AOSP Android for the fix)
* Enable EAP-PWD configuration in wifi settings (AOSP).
* Touchscreen fixes (thanks Dees_troy)
* Incredible Ramdisk tweaks included in source (Thanks MiSfit)
* Added open source FileManager to build environment.
* Screenbrightness default set to 30%.
* Allow non-market apps to default install.
* Updated most Framework commits by AOSP. (thanks to android)
* Changed Snap velocity in Launcer2 (thanks Jean-Babtiste Queru(Android)).
* Fixed potential memory leak on error (Hossein Mohtasham).
* Added Polling Mechanism to battery service (Daniel Fages).
* Battery icons custom charge animations (thanks joker)
* More.....
BUGS CONNUS :
* L'appareil photo et le micro ne fonctionnent pas
* Reboot sur le Recovery
INSTALLATION :
1) Pré-Requis à télécharger
* ClassicNerd Butta HD v4.04.5.zip
* gapps20120429 : Gmail, Maps...
2) Redémarrez sur le recovery
3) Faites un Backup de votre Rom précédente (au cas où) via le menu Backup and Restore
4) Faire les Wipes :
**Si vous venez d'une autre ROM :
Wipe Factory Reset + Wipe Cache Partition + Wipe Dalvik Cache (situé dans le menu advanced)
**Si vous venez de la version précédente de la ROM :
5) Flasher dans l'ordre :
* gapps20120429
6) Reboot et Enjoy !
Et si vraiment vous ne comprenez rien, voici le tout, en vidéo :
(bon, par contre, faudra comprendre l'anglais)
ADD-ONS : (à flasher depuis le recovery)
* Patch Azerty pour le clavier bluetooth (merci GoBZH)
* Application pour accès direct au monde ClassicNerd
GOODIES :
* Fonds d'écrans
* Boot Animations
* Banners
* Apps
SOURCES : CLASSICNERD et REVTV
Modifié par crap's
Merci d'avoir créer le topic, après faudra bien le développer quand tu auras du temps, genre tuto d'installation, add-on, bug constatés, les différents liens et quelques screenshots...
Au besoin si t'as pas d'idée, inspire toi des différents topics sur les rom CM7 que Nanok ou moi avions fait.
Merci en tout cas.
Salut à tous j'ai installé pour la première fois ICS hier, et je me suis lancé vers cette version car j'avais beaucoup apprécié xronified.
Je ne suis pas un power user, et je laisserai donc le test aux habitués du forum.
Je vais juste apporter quelques pierres à l'édifice en vous donnant mon avis perso, sachant que je n'ai pas essayé l'ICS de cyanogen (honte à moi....)
Tout d'abord, on dirait qu'il y a 4 versions différentes, mais je ne peux pas vous en dire plus :
Perso, j'ai mis la version va0.0.2, plus gapps_ics_4.0.3_v11.zip
Et bien franchement, ça dépote sur notre touchpad préféré, la fluidité est excellente, malgré un fond animé avec de l'eau et des feuilles et la qualité graphique est superbe.
Aucun problème de wifi, il ne décroche pas et le signal est aussi bon que sur CM7.
La navigation internet est très fluide, pas de souci de ce coté là.
Je n'ai pas encore testé le Bluetooth, mais je ne pense pas avoir de souci avec.
On retrouve bien évidement les quelques pb connus de ICS sur Touchpad (pas de décodage hardware des vidéos, pb avec la caméra, etc...)
Par contre je n'ai pas rencontré les problèmes dont certain parle sur CM9 :
1) J'ai une seule appli galerie et elle marche très bien.
2) Je n'ai pas eu de blocage de l'écran tactile en sortie de veille.
3) Aucun arrêt ou redémarrage à la fin d'une charge.
4) Aucun souci avec ChainFire3D, j'ai installé sans pb les drivers Nvidia et autres, et j'ai testé Pinball HD for Tegra, et il tourne largement mieux que sur CM7, aucun ralentissement à l'horizon (ouf...)
5) L'autonomie me parait plus que correct pour l'instant (environ 2 heures à manipuler avec wifi et environ 35% d'utilisé).
Bref, je suis très satisfais de cette version, qui est bien basée sur ICS, il n'y a aucun doute la dessus.
Quelques applis ne démarrent pas tout de même (Cut the Rope par exemple), mais je mets ceci sur le compte d'ICS, et non pas de la version choisie (Android n'a pas le même savoir faire que Apple en matière de rétro compatibilité).
Voilà, j'espère avoir apporté quelque chose au post, et continue à vous suivre régulièrement, longue vie à FRANDROID.com...... :P
Merci à toi Nounet, je te conseille d'installer de ce pas la Buttah, tu verras elle tourne encore mieux !
La dernière version est la Buttah = va0.0.4
La SE (special édition) = va0.0.3
Merci à toi, je l'installerais demain matin.
PS: test Bluetooth ok, ça marche nickel.
Bonne soirée.
Et pour ceux qui étaient sous cm9 avant et qui ont installe cette rom, on pourrai a avoir votre avis? (batterie etc...)
Si on est sous cm9 et qu'on veut passer sur cette rom, comment procéder?
Modifié par rzae
moi perso j'étais sur cm9 et je suis passer sur cette rom
franchement la cm9 je la trouve instable et et niveau fluidité c'était pas top
j'ai donc flasher la classicnerd et la on dirait carrément une version final (j'exagère a peine) encore quelque petit bug et des fc
pour flasher cette rom j'ai mis sur la page 1 un lien avec un doc qui explique en détail les manip à faire
il faut désinstaller moboot et cm9 (repartir de zéro) et flasher d'abord moboot et le cwm en passant par le pc
puis une fois installer lancer le recovery ensuite wipe wipe wipe et flash de la rom + gapps
Bonjour à tous, je viens de mettre la nouvelle version (buttah), mais n'étant pas un power user, je ne saurais vous dire les différences avec la v2, en plus, sans chancelog, pas evident. Les changements doivent être au niveau de la programmation.
La fluidité est tjr présente, et chainfire 3d fonctionne tjr, donc ca me va lol
Bonne journée à tous.
