PAC
PAC ALL IN 1
PAC est un mélange des roms AOKP, PARANOIDANDROID et CM10!!!!
" Pourquoi choisir quand on peut utiliser tout à la fois !? "
SOMMAIRE :
- [ROM][JB][TC] PAC [ Paranoid + Aokp+ Cm10.1 ] [Update 14-12-2012]
- [DEV][ROM][4.2.2] PAC-Rom 20.0.0 [AOKP][CM][PA]
PAC ROM 22.0.0
CARACTÉRISTIQUES :
* Linaro Optimized Kernel
* All in One Rom [CM, AOKP and PA]
* PhoneUI
* Latest Version 20.1.0
* Some Features from AOKP
* All Feautures from PA
* All Features from CM
* Ofcourse JellyBean 4.2.2
CE QUI MARCHE :
* HW Acceleration
* Sound
* Sensors
* Auto Brightness
* Display
* Touch
* Project Butter
* Tablet/Hybrid UI
* Bluetooth
* WiFi
* GPS
* Themes (for AOKP, CM)
* AOKP Settings
* Ril (Call, SMS, Microphone)
* Data
* Youtube LQ/HQ
* Camera
* ParanoidSettings
* In-Browser-Video Player
* PIE Control and its Settings
* PA 3.10 Color Control and Layout Changer
SCREENSHOTS ET VIDÉO :
VIDÉO DE LA ROM
SCREENSHOTS
CHANGELOG:
23.03.2013
* Improved Stability and Smoothness
* Fixed all remaining bugs in last Rom version (related to framework)
* Added 3 new Gov's (lagfree, smartassh3, galaxyics)
* barely Improve Battery Performance and Life
* Last PA Sources
* Last CM Sources
* Fixed USB Debugging and ADB
* See Full Changelog (v.21.0.0-xx.x.x) here
03.03.2013
* Improved performance and stability
* Current highest CPU Clock Speed is 787 Mhz now!
* You may see a new governeur from GalaxyICS (USE IT, i recommend to)
* Updated CM Source (partially, sry xD)
* Updated Pie Control, no ui bugs anymore
* Fixed the strange HIGH Ram consumption part
* See Full Changelog here
21.02.2013
* Fixed almost anything in Rom Control (So only one Feature remains broken, am/pm style)
* GNex 4 Wallpapers
* updated to Android 4.2.2
* Improved Touchscreen
* Updated PA to 3.00
* 1 more thing is remaining broken: the add button for custom tiles
* Improved Touchscreen and Stability
* Fixed some other things i cant remember (like CRT animation)
ATTENTION!!
Changement de la taille du Lockscreen ne fonctionne pas bien!
Le multi utilisateur ram
Pas toute les fonctionnalités de l'AOKP ont été mise dans cette rom
DOWNLOADS :http://tinyw.in/HieQ
Kernel Sauce: https://github.com/O....amsung_msm7x27
Sources : http://forum.xda-dev...d.php?t=2141770
PAC 14/12/2012
SCREENSHOTS :
TUTO :( j'ai traduit le même tuto présent sur xda mais apparemment je n'est pas la permission de le poster... C'est pourquoi j'ai simplement fait un copier coller, j'espere que vous comprenez l'anglais
1] Comment avoir un nouveaux mode de bureaux?
2] Comment changer l'apparence d'une applications?
BUGS :
1) Native USB tethering
2) Native Wi-Fi tethering
3) Google Now
CHANGELOGS :
Date 14-12-2012
fixed bluetooth
fixed camcorder
fixed HQ playback of youtube
Date 27-11-2012
[font='lucida sans unicode', ', ', 'lucida grande', ', sans-serif} ']Another Fix for volume & music track using volume rocker button when display off (15 steps)[/font]
[font='lucida sans unicode', ', ', 'lucida grande', ', sans-serif} ']MMS CM10 base - AOKP style
AOKP nightly
SystemUI: Fix/Update Cog Circle battery mod
Add alpha settings to Circles lockscreen rings
CM10 Nightly
PA 2.55
Fixed AOKP toggles (all available now)
Fixed AOKP navigation bar targets (7 now)
Provide haptic feedback on long pressing keys in lockscreen.
Default device volumes not initialised
AudioService: Don't adjust volume when vol-downing to vibrate or silent
Merge "PT-BR: Added missing translations" into jellybean
Framework: Fix Profiles Insecure lock screen not working
Remove duplicated and unneeded code
shorter debug out
Notification: add option to show connected wifi network
Suppress String resources build warnings
WeatherPanel: Add toast
SystemUI: Cog Circle Mod Battery
Lockscreen: Add Circles Lockscreen to AOKP
SystemUI:Widgets fix & Class Move
Lefty Mode for NavBar
SystemUI : Fix NPE on Rotate
NavRing: Long press actions.
TransportControl: Remove unnecessary check
Fix volume track skip control with 3rd party applications[/font]
[font=Arial, Helvetica, sans-serif]Date 1-11-2012[/font]
[font='lucida sans unicode', ', ', 'lucida grande', ', sans-serif} ']Fixed issues that you got with last build
so camera will work well as well as all settings of rom control and paranoid setting work well[/font]
[font=arial, helvetica, sans-serif][font=Arial, Helvetica, sans-serif]Date 28-10-2012[/font][/font]
[font='lucida sans unicode', ', ', 'lucida grande', ', sans-serif} ']new camera hal by Wayland
Compiled with latest sources of Paranoid , AOKP and CM10[/font]
[font=Arial, Helvetica, sans-serif]Date 15-10-2012[/font]
[font='comic sans ms', cursive]Fixed camera with preview ( thanks to lagloose for CameraHAL
Jellybean 4.1.2
Paranoid 2.21
latest changes from CM team and AOKP team
New crt-off animation ( thanks to evilisto)
fixed Calculater FC[/font]
[font=Arial, Helvetica, sans-serif]Date 5-10-2012[/font]
[font=Arial, Helvetica, sans-serif]Fixed notification sound bug . now its loud enough[/font]
[font=Arial, Helvetica, sans-serif]Fixed CRT-OFF Animation[/font]
[font=Arial, Helvetica, sans-serif]BLN Fix - need to test as I'm not using this so test and tell whether its work fine or I need to fix it again[/font]
[font=Arial, Helvetica, sans-serif]notification blur fixed - [/font]http://forum.xda-dev...96&d=1349437356
[font=Arial, Helvetica, sans-serif]Paranoid 2.17[/font]
[font=Arial, Helvetica, sans-serif]and latest changes of CM10 , AOKP and PARANOID[/font]
[font=Arial, Helvetica, sans-serif]DOWNLOADS :[/font]
http://api.viglink.c..._13600016908464
[font=Arial, Helvetica, sans-serif]Wipe data
wipe cache partition[/font]
[font=Arial, Helvetica, sans-serif]Wipe dalvick
install from sdcard[/font]
[font=Arial, Helvetica, sans-serif][/font][font=Arial, Helvetica, sans-serif]Si vous êtes sur l'ancienne version et souhaitez mettre a jours la rom vous n’êtes pas obliger de faire les wipes ( sauf wipes cache partition AVANT de flasher la nouvelle version ) [/font]
PATCH : N'oublier pas mount système avant de flasher les patchs!!
bln fix : http://forum.xda-dev...87&d=1350304909
Gapps : https://hotfile.com/...taKANG.zip.html
Lien direct vers xda : http://forum.xda-dev...d.php?t=1911478
Bientôt: peut être une nouvelle version ![]()
Modifié par Teoandro, 26 May 2013 - 16:26.
Retour en haut
