eKimi Posté(e) 28 juin 2012 Posté(e) 28 juin 2012 (modifié) Une des meilleurs que j'ai pu tester avec mon S2 ! J'ai pas encore flashé mon S3, pas le temps mais une chose est certaine, ca sera cette ROM là ! TOPIC XDA (Source) : http://forum.xda-dev...d.php?t=1738527 Download : http://checkrom.com/threads/sgs3-checkrom-evohd-v5-5-xxdlib.962/ Change-log 5.5 Deodexed Zipaligned Rooted with SuperSu BusyBox Added KitchenPro Added kUtility Enabled hidden languages Kernel: Stock Hacked Modem: XXDLIB Multi CSC All Samsung Bloat Removed English as default language V3.5 dispo: http://download.chec...=950&height=420 CHANGELOG V3.5 Based on XXBLFB Firmware from Samsung Kernel: Stock Samsung LFB (Hacked) (Samsung Built love with Team induced chemistry ) Baseband: XXLFB Changed Superuser to SuperSu v0.93 No Wipe Scrolling Made Smoother Build.prop tweaks Hardware Acceleration Enabled (GPU UI Enabled) Multi CSC Deodexed Zipaligned BusyBox Larger Apn List Sd Card Speed Fix %Battery (Use settings>>Display>Battery percentage) Most of the Samsung widgets and app's removed! Fully optimized .png's Smooth animation's Installation Script cleanup/optimization Reduced Touchwiz Redraw Smooth Spinners Added Traditional Extended Power Menu Fixed the Cell Stand By issue Optimized Ram Bug Fixes Now with Stock Kernel its As Smooth as Butter Stock Animation Changed to Jelly Bean Animation All Share App added Battery Optimization Change Log V3.0: Base on XXALF6 Firmware from Samsung Kernel: Stock Samsung (Hacked) (Samsung Built love with Team induced chemistry ) Baseband aka modem set to: XXLF2 (Stock one is DXLEA, you can flash it from the Kitchen) Changed Superuser to SuperSu v0.92 No Wipe Scrolling Made Smoother Build.prop tweaks Hardware Acceleration Enabled (GPU UI Enabled) Multi CSC Deodexed Zipaligned BusyBox Larger Apn List Sd Card Speed Fix %Battery (Use settings>>Display>Battery percentage) Auto Brightness mod (10 Steps) Most of the Samsung widgets and app's removed! Fully optimized .png's Smooth animation's Hacked Stock Email App Reduced Home button Lag Reduced Touchwiz Redraw Smooth Spinners Added Hot-boot PowerMenu (4 Way reboot) Added 15 Toggles Added Quick Settings to control the toggles Fixed the Cell Stand By Optimized Ram DOWNLOAD : http://bit.ly/MXUs0Q Modifié 4 octobre 2012 par eKimi Citer
LuckystrikeS2 Posté(e) 29 juin 2012 Posté(e) 29 juin 2012 Plutôt pas mal. Elle consomme beaucoup moin de ram, la kitchen c'est toujours aussi bien, même si la il n'y a pas beaucoup de thème. Rien à redire, pour moi c'est la meilleur. Citer
Azdine57 Posté(e) 29 juin 2012 Posté(e) 29 juin 2012 Très bonne ROM comme sur S2... La Kitchen apporte beaucoup... Envoyé depuis mon GT-I9300 avec Tapatalk Citer
Neutre0 Posté(e) 30 juin 2012 Posté(e) 30 juin 2012 Mais que voie-je là ? Mais, c'est bien Check Rom ? Pfff... et le SGS II ? On dit qu'il y a beaucoup de Dev etc. sur Android, mais personne n'en parle, des gens qui quittent un modèle de téléphone, dès qu'il y a son successeur qui sort. Heureusement que CyanogenMod sont là-eux, j'ai compris leur vraie valeur maintenant. Et ne me dite pas qu'ils font ça juste parce qu'ils veulent rendre service aux gens et qu'ils le font bénévolement, parce qu'ils reçoivent des dons aussi... Je dis pas qu'ils gagnent des millions avec ça, mais c'est les dons des gens qui on espoir que CheckROM ne laissera pas tomber SGS II, mais ils se sont fait arnaquer. Citer
LuckystrikeS2 Posté(e) 30 juin 2012 Posté(e) 30 juin 2012 Tu n'a qu'à développer si tu n'est pas content. Si check trouve son bonheur sur le S3 et qu'il n'a pas le temps pour le S2 ce n'est pas de sa faute. 1 Citer
sinji Posté(e) 30 juin 2012 Posté(e) 30 juin 2012 Neutre reste sur s2 et son forum approprié. :))) Citer
Neutre0 Posté(e) 1 juillet 2012 Posté(e) 1 juillet 2012 (modifié) Tu n'a qu'à développer si tu n'est pas content. Si check trouve son bonheur sur le S3 et qu'il n'a pas le temps pour le S2 ce n'est pas de sa faute. Moi je quitte Android dans pas longtemps donc je m'en fou un peu (je ne pense pas qu'à mon c*l, comme certain), mais je penser à ceux qui ont fais des don(s) et qui attendent toujours la mise à jour... @sinji : Désolé, je me suis trompé de section :P :) Modifié 1 juillet 2012 par Neutre0 Citer
rhalim Posté(e) 1 juillet 2012 Posté(e) 1 juillet 2012 SUPER LE HS les gars, Screen Shot peut etre quelqu'un? Citer
Neutre0 Posté(e) 1 juillet 2012 Posté(e) 1 juillet 2012 (modifié) @rhalim : C'est bon HS => OFF. Voici les screenshoots : Modifié 1 juillet 2012 par Neutre0 Citer
eKimi Posté(e) 2 juillet 2012 Auteur Posté(e) 2 juillet 2012 Là j'avoue ne pas comprendre pourquoi tu t’excites comme ca... Tu sais, quand tu changeras de téléphone (car cela semble etre ton cas...) tu ne reviendras pas t'occuper du S2... Ou de moins en moins... Il faut comprendra ca... Quand les développeurs changent de téléphone, ils s’intéressent au nouveau... C'est normal... Il faut beaucoup d'argent et de ressource humaine pour pouvoir développer sur plusieurs plateforme en même temps... Surtout qu'a priori, le S2 est censé perdre en propriétaire face au S3 maintenant... Sinon, juste une question. Tu pars sur quelle plateforme ? 1 Citer
ElRey Posté(e) 6 juillet 2012 Posté(e) 6 juillet 2012 Juste une question, j'ai telechargé le battery circle mod sur la kitchen et je l'ai installé, mais je voulais savoir comment on pouvais l'appliquer après, car j'ai telechargé ça et le clavier, mais impossible de les mettre ... Citer
spritiman Posté(e) 9 juillet 2012 Posté(e) 9 juillet 2012 La V3 est là :http://download.checkrom.com/roms/android/galaxys2/checkrom/CheckROM_EvoHD_V3.zip?iframe=true&width=950&height=420 Juste une question, j'ai telechargé le battery circle mod sur la kitchen et je l'ai installé, mais je voulais savoir comment on pouvais l'appliquer après, car j'ai telechargé ça et le clavier, mais impossible de les mettre ... Il me semble qu'il faille utiliser CWM pour installer les deux zip qui doivent ce trouver dans un dossier checkrom ou download. Je sais plus je l'ai eu il y as un boue de tant sur mon S2. Bon courage Citer
cédric Posté(e) 10 juillet 2012 Posté(e) 10 juillet 2012 V3.5 dispo: http://download.checkrom.com/roms/android/galaxys2/checkrom/CheckROM_EvoHD_V3_5.zip?iframe=true&width=950&height=420 CHANGELOG V3.5 Bug Fixes Now with Stock Kernel its As Smooth as Butter Stock Animation Changed to Jelly Bean Animation All Share App added Battery Optimization Every thing else is the Same as v3 Citer
Azdine57 Posté(e) 10 juillet 2012 Posté(e) 10 juillet 2012 Par contre on est revenu en arrière concernant le walpaper... Impossible de l'avoir en panoramique... Envoyé depuis mon GT-I9300 avec Tapatalk Citer
spritiman Posté(e) 12 juillet 2012 Posté(e) 12 juillet 2012 installation faite de la v3.5 trop content de retrouver cette rom (c'était ma préféré sur le S2) Citer
eKimi Posté(e) 15 juillet 2012 Auteur Posté(e) 15 juillet 2012 Le topic à été mis à jour avec du retard ! Mais voici la nouvelle version de la Check Rom ! Citer
spritiman Posté(e) 15 juillet 2012 Posté(e) 15 juillet 2012 Merci pour la maj du topic, mais par contre pour le titre c'est pas plutôt v3.5 et non v2 3.5 Encore merci. Sinon installé depuis 3 jours et pas de souci, rom fluide, super stable et avec une bonne autonomie. Citer
eKimi Posté(e) 15 juillet 2012 Auteur Posté(e) 15 juillet 2012 Par contre, peux tu me dires ce qu'ils ont supprimé comme widget ? Citer
spritiman Posté(e) 15 juillet 2012 Posté(e) 15 juillet 2012 (modifié) alors aucune idée, je n'ai rien vue de significatife. En meme temps je l'ai installé en no wipe depuis la stock :lol: , donc je pense avoir gardé toute les appli et widget... sinon elles sont recuperable sur le kitchen trés facilement. @+ Modifié 15 juillet 2012 par spritiman 1 Citer
crocodyle Posté(e) 28 juillet 2012 Posté(e) 28 juillet 2012 salut à tous, j'avais cette rom en v6 sur mon sgs2 cette rom est elle aussi bien que sur sgs2 ? stable, aucun bug, kitchen pro etc ? merci d'avance Citer
Azdine57 Posté(e) 28 juillet 2012 Posté(e) 28 juillet 2012 Oui elle et pareille je regrette juste ses rares mises à jour... Galaxy S3 GT-I9300 Memoire: 16Go + 32Go ROM: Android Revolution HD 2.1.0 LG8 Modem: I9300XXLG8 Kernel: Stock LG8 Citer
crocodyle Posté(e) 28 juillet 2012 Posté(e) 28 juillet 2012 autre question: j'avais la magnifique checkrom sur mon sgs2 et je viens de me procurer le sgs3, naturellement j'installe cette rom... mais pas de jkay, le drame ! ya t il moyen de se procurer cette appli sur sgs3 ? merci d'avance Citer
spritiman Posté(e) 28 juillet 2012 Posté(e) 28 juillet 2012 Non désolé, ça n'existe pas sur s3 et c'est bien dommage. @+ Citer
Azdine57 Posté(e) 28 juillet 2012 Posté(e) 28 juillet 2012 (modifié) autre question:j'avais la magnifique checkrom sur mon sgs2 et je viens de me procurer le sgs3, naturellement j'installe cette rom... mais pas de jkay, le drame ! ya t il moyen de se procurer cette appli sur sgs3 ? merci d'avance Il n'y a pas de jkay... Tu veux quoi comme mods ? Galaxy S3 GT-I9300 Memoire: 16Go + 32Go ROM: Android Revolution HD 2.1.0 LG8 Modem: I9300XXLG8 Kernel: Stock LG8 Modifié 28 juillet 2012 par Azdine57 Citer
