Du@lcore Posté(e) 25 décembre 2012 Share Posté(e) 25 décembre 2012 (modifié) * Paid apps aren't included in my rom (Beautiful widget and Nova launcher Prime if you want to get them from market ;) ) Du@lcore - Developer of the Rom rixsta - Official Themer [list][*]Based on official XXDMF2 [*]Kernel XXDMF2 [*]Modem DXDMF1 [*]Bug free and battery friendly [*]AOSP Status bar and Icon [*]Blue Battery % and AOSP Toggles [*]Ink effect mod with finger [*]Latest Simplistic framework with 24 toggles [*]Toggles control app by LegendK95 [*]Multi Window Control app included [*]Zipaligned [*]Deodexed [*]Rooted with SuperSu included [*]Ultra slim (0% bloatware only nice features from Samsung) [*]Init.d support [*]Build.prop tweaks [*]Extended power menu[/list] [list][*]Call Recorder [*]Call Delay After call (0ms) [*]Exchange Security Disabled for Email app [*]Unlimited contacts can be added sms [*]Enable sub symbols on Stock Samsung keyboard [*]Dialer search matches numbers in contacts and call logs along with contacts [*]Better GPS lock [*]Disabled conversion SMS to MMS [*]No increasing ringtone [*]All supported languages enabled (also for for Samsung Keyboard) [*]Shutter Sound menu enabled to camera [*]Large APN list [*]Other mod I forgot to mention[/list] [list][*]Adobe Flash Player (optional in aroma) [*]Es file explorer (optional in aroma) [*]Adfree (optional in aroma) [*]Facebook (optional in aroma) [*]Nova Launcher (optional in aroma) [*]Titanium Backup (optional in aroma) [*]Lot of AOSP apps (optional in aroma) [*]4 different styles - AOSP Look - Black AOSP Look - Pure White Look - Red Glow Look - Stock Touchwizz Look (optional in aroma) [*][color="Gray"]If you don't want these apps, just delete them with Titanium Backup [*]If you choose Nova launcher as your default launcher freeze Touchwizz launcher with Titanium Backup for better battery life and performance ! (Requires TB Pro)[/color][/list] CHANGELOG : (22/06/2013) Du@lNote 12.0 - XXDMF2 : - Updated base to Latest XXDMF2 official firmware - Updated kernel to XXDMF2 - Updated Modem to DXDMF1 - Updated build.prop - Some bug fixes - Other things I forgot to mention HOW TO HAVE THE BEST RESULT WITH SF 3.5.1 : - Change signal colors (set them to #ff009dcd for AOSP colors and tick "always use custom signal colors") - Go to "expanded statusbar" and tick "hide no notifications text", "hide Ongoing Label" and "Hide Notifications Label" - Go to "Statusbar Toggles" then "Toggles Colors" and set color to | Blue AOSP : #ff33b5e5 | Grey/White (for toggles off) : #ffb1bcc1 Be careful ! I am not responsible if you brick your device !! :D XDA File Server (please hit the thanks button and rate my thread with 5 stars) If you like my work please consider a donation (buy me a beer or a coffee :D) MD5 [center]Waiting for upload[/center] - Go to "mount and storage" and choose "Format system" - Wipe everything you want (if you want a clean install but this step is optional) - In case of problem with my rom do a factory reset in recovery and wipe cache partition before install - Install zip with recovery - Reboot and enjoy ! (And don't forget to hit the thanks button) For a clean install, use the Super Wipe Script from HERE (Be careful this script will erase all your data and format your internal SD so do a backup of your files on your external SD ;) ) - Go to mount and storage => format system - Install rom without wipe anything - Enjoy B3311 6KT71366TU180034U B3311 1XU1458108495145U B3311 76N6390298427013N praveen6585 6N890502JB9659817 Nutsonfire 31707551S15946019 nonobouli 4EV69146KX094064J killawatts 83769040E96483726 rixsta 5VS515037N9131734 Mauro 2YF5508265518825Y Many thanks to all donators, it is very appreciated ! - Thanks to Samsung for official firmware - Thanks to LegendK95 for simplistic framework - Thanks to my mate rixsta for his awesome theme (Member of Du@lNote team as official themer) - Thanks to Avetny for AOSP theme - Thanks to Wanam for his work - Thanks to All devs here - Thanks to Xda community for other stuff If you want to support this Rom, feel free to use this banner in your signature Modifié 27 juin 2013 par Du@lcore 7 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
norton10100 Posté(e) 26 décembre 2012 Share Posté(e) 26 décembre 2012 C'est parti pour le téléchargement et le test..... retour d'expérience dès que possible ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Fred@ Posté(e) 26 décembre 2012 Share Posté(e) 26 décembre 2012 @ Du@lcore J'ai posté sur xda avant d'avoir vu ce post. Ma question: Peux-tu stp, nous donner le md5 du zip de la rom? Je ferais un retour dès que je l'aurai installé. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Du@lcore Posté(e) 31 décembre 2012 Auteur Share Posté(e) 31 décembre 2012 Desole pour la reponse tardive je te mets le md5 demain mais entre nous tu peux y aller c est le serveur xda dc peu de risque d avoir un mauvais DL ^^ Sinon pour info j ai oublié un fichier dans le xbin pour que le root soit fonctionnel donc flashez ca juste apres l install de la rom : http://forum.xda-developers.com/attachment.php?attachmentid=1594117&d=1356557579 Et si j ai de bons retours de votre part je pourrais ameliorer la rom en fonction de vos souhaits ;) Et en complement d info, au lieu de vous jeter sur la omega testez donc une rom made in france ;) elle est au moins equivalente a la omega en terme de perf ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jose Posté(e) 31 décembre 2012 Share Posté(e) 31 décembre 2012 (modifié) salut du@lcore :) tous a fait d'accord avec toi pour l'omega :) ( trop chargé a mon gout ). je testerais ta custom , je cuisinais moi même pour le forum a l’époque ( mes liens signature ) mais uniquement sur le gs1 j'ai arrêter de distribuer ensuite par manque de temps ... cela dit pourrais tu traduire le changelog en français pour que ce sois plus clair ( du moins ce qui et possible ) :) vu que l'ont a un français en cuisine autant en profité merci d'avance :) Modifié 31 décembre 2012 par jose Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Du@lcore Posté(e) 4 janvier 2013 Auteur Share Posté(e) 4 janvier 2013 CHANGELOG : Du@lNote AOSP - XXDLL4 : - Completly rebuild from XXDLL4 firmware - AOSP themed - Smoother and better battery life - Rooting permissions fixed - Latest Samsung Boot Animation - Skip music tracks with volume buttons long press - Call Recorder - Large APN list - Unlimited contacts for sms & mms - No sms to mms conversion - Added exit menu to stock web browser - Other mods I forgot to mention Nouvelle release !! Je suis en train d'upload ça devrait être dispo vers 14h ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Du@lcore Posté(e) 4 janvier 2013 Auteur Share Posté(e) 4 janvier 2013 La rom est en ligne ! Merci de donner vos retours si vous la testez ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
norton10100 Posté(e) 4 janvier 2013 Share Posté(e) 4 janvier 2013 Dessus depuis plus d'une semaine.... tourne niquel, pas eu de soucis majeur (vi quelques arrêt de programme) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kennylocco Posté(e) 4 janvier 2013 Share Posté(e) 4 janvier 2013 J'imagine que cette Rom ne possède pas les applis SNote etc... :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Snott Posté(e) 5 janvier 2013 Share Posté(e) 5 janvier 2013 Bien sur que si elle est basée sur une rom stock, enfin ce serait incompréhensible que ce ne soit pas le cas Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ducat998 Posté(e) 5 janvier 2013 Share Posté(e) 5 janvier 2013 Ben alors pas beaucoup de retour sur cette rom, etant sur omega j'aurais aimé avoir plus de retours, elle apporte quoi en plus ou moins par rapport au omega ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blito Posté(e) 5 janvier 2013 Share Posté(e) 5 janvier 2013 (modifié) effectivement marche nickel; par contre je n'ai que le numéro de téléphone et pas le nom (message non enregistré sous le nom), alors que mes contact ont été importés,????? beau travail sinon! EDIT: Compte gmail supprimé et réinstaller, resynchro des contacts et youpi tout marche! Bonne realease Modifié 5 janvier 2013 par blito Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
-iNSiGhT- Posté(e) 5 janvier 2013 Share Posté(e) 5 janvier 2013 (modifié) Hello!! Également sous Oméga, je cherche une ROM bien "débloatée"... @DualCore, tu as enlevé uniquement les apk des bloatwares ou réalisé un nettoyage en profondeur comme pour la WickedROM ? Ton thème AOSP à l'air sympa et en plus est compatible Simplistic Framework. Par contre, pourquoi l'icône batterie et l'heure sont grises alors que ton thème est bleu ? Merci. Envoyé depuis mon GT-N7100 avec Tapatalk Modifié 5 janvier 2013 par -iNSiGhT- Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Du@lcore Posté(e) 5 janvier 2013 Auteur Share Posté(e) 5 janvier 2013 Hello, Oui j'ai gardé toutes les appli Samsung utiles comme Snote, Kies, etc... Mais j'ai viré les videohub et compagnie ! Sinon pour l'icone de batterie je pourrais la changer dans une prochaine version c'est juste que tout en bleu ça faisait trop à mon gout ^^ Et je suis en train de voir pour inclure le lockscreen AOSP de Jelly Bean pour une prochaine version ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
El_Diablo_77 Posté(e) 5 janvier 2013 Share Posté(e) 5 janvier 2013 Ah m**** c'est un dév français???!!! Je savais pas du tout o_O Et bien félicitations à toi, bienvenu aussi et du coup je vais m'intéresser un peu plus à cette rom ;o) Merci, bonne continuation et à bientôt eheh Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Du@lcore Posté(e) 5 janvier 2013 Auteur Share Posté(e) 5 janvier 2013 Ah m**** c'est un dév français???!!! Je savais pas du tout o_O Et bien félicitations à toi, bienvenu aussi et du coup je vais m'intéresser un peu plus à cette rom ;o) Merci, bonne continuation et à bientôt eheh T avais pas vu le "made in France" dans le titre ^^ Bon j avoue j ai fait le feignant sur la trad mais bon je suis plus souvent sur Xda qu ici ;) D ailleurs si certains d entre vous touchent un peu en mod ou autre on peut bosser ensemble si vous voulez ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
El_Diablo_77 Posté(e) 5 janvier 2013 Share Posté(e) 5 janvier 2013 Tout comme toi je suis plus sur XDA qu'ici et donc je n'avais que survolé les sujets d'ici ;o) Ton offre pourrait m'intéresser...Mais rien n'est moins sûr, tout dépend du temps que j'aurais...J'ai fait partie d'une team il y a quelque temps ;o) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
El_Diablo_77 Posté(e) 7 janvier 2013 Share Posté(e) 7 janvier 2013 Bon ben installé et désinstallé aussitôt malheureusement...J'ai pas du tout accroché avec le thème et les modifs apportées à la rom (ajouts de programmes surtout...). Tant pis...Peut être la prochaine...Pourquoi ne pas faire ta rom thème stock et faire ton thème dans un zip? Au moins tu laisses le choix à l'utilisateur ;o) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Du@lcore Posté(e) 7 janvier 2013 Auteur Share Posté(e) 7 janvier 2013 Tu pourrais être plus explicite stp ?!? J'ai pas rajouter grand chose comme appli tu as titanium backup, facebook, nova launcher, adfree et es explorateur de fichiers installés de base dans le dossier system, le reste étant les mods qui sont inclus dans la plupart des roms (MWControl, Simplistic toggles, SpenBoard,etc...) Je te trouve un peu dur en jugement surtout pour le temps que j'y passe GRATUITEMENT... D'ailleurs j'ai tellement peu de retours que ça ne me donne même plus envie de mettre à jour la rom malgré le fait d'être ouvert à vos propositions... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
norton10100 Posté(e) 7 janvier 2013 Share Posté(e) 7 janvier 2013 Les gens sont sur un peu toutes les ROM... et ont peur de changer pour tester ! Fini l'époque où tout le monde installait pour se faire une idée personnelle et ne plus suivre celle des autres ! Perso rien à reprocher à ta ROM... je garde ;-) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DavidFuentes Posté(e) 7 janvier 2013 Share Posté(e) 7 janvier 2013 Du@lcore, j'aime beaucoup ta ROM perso. Simple, sans fioriture, fluide, bonne autonomie, bon équilibre entre les applis inutiles nettoyées et le rajout d'autres indispensables et qui plus est, FRANCAIS !!! Un peu de chauvinisme que diable !!! Merci pour ta Rom et pour le temps que tu nous donnes. ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blito Posté(e) 7 janvier 2013 Share Posté(e) 7 janvier 2013 Effectivement rom très agreable et surtout sans bug.... Continue!!! Envoyé depuis mon GT-N7100 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
El_Diablo_77 Posté(e) 8 janvier 2013 Share Posté(e) 8 janvier 2013 @Du@lcore: j'ai été dur?! j'ai été franc à la limite mais dur je vois pas....J'ai rien dit de méchant, j'ai juste dit que j'avais pas accroché (choix perso) et encore je te donne un conseil alors je vois pas pourquoi tu le prends mal comme ça..... Je te trouve un peu dur en jugement surtout pour le temps que j'y passe GRATUITEMENT ça c'est un argument que je trouve ridicule....je te l'ai dit, j'ai été dév aussi tout comme d'autres ici (je pense à jose notamment) et jamais je n'ai fait cette réflexion ridicule....si tu le fais, c'est parce que tu le veux et tu aimes ça tout comme moi à l'époque et non pas pour être payé....la seule différence c'est que jamais je n'ai osé le faire remarquer... 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Du@lcore Posté(e) 8 janvier 2013 Auteur Share Posté(e) 8 janvier 2013 Ba écoute commencer ton post par "installé - désinstallé aussitot" n'est pas très agréable et ne donne pas envie aux autres de tester tu en conviendras... Je suis ouvert aux critiques mais lorsqu'elles sont constructives tu dis que c est trop chargé en applis donc je te repose la question : lesquelles ? Dire que "j'ose" utiliser comme argument que je fais ca gratuitement... Oui et ? C'était pas pour réclamer quoi que ce soit, je te remercie j'ai un travail je gagne ma vie c'est juste un hobby comme tu dis. Je voulais juste un peu plus de détail sur ton avis. Je pense que ce qui est gratuit mérite d'autant plus d'attention. (Bonne ou mauvaise) Mais ce n'était pas contre toi, c est plutot que je trouve que Frandroid devient plus un supermarché de la rom qu'une communauté de développement (ce qui était le cas il y a quelques années avant que les devs francais migrent vers Xda) Je suis peut etre vieux jeu mais c est mon ressentit du moment ^^ Peace ;) 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kennylocco Posté(e) 8 janvier 2013 Share Posté(e) 8 janvier 2013 Salut, Moi je l'est installer depuis ce matin et ravi pour le moment de cette Rom :) J'attends avec impatience les futurs évolutions :lol: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
