[MODS][THEME][MORE] 3Minit Framework 3.0 [GT-I9505][GT-I9500]
SOURCE XDA : http://forum.xda-dev...d.php?t=2276611
3Minit Framework Info
For Jellybean 4.2.2. DEODEXED roms only
Current free version 2.5
3Minit Setting 2.6 free will be released after 05 August
3Minit Setting 3.0 free will be released after 16 August
Current donate version 3.0
This framework is still up and coming I will continue to update with more mods when I can so keep an eye out.
Screen Shots
Available Settings
Select Am pm size
Show/Hide day on statusbar
Show/Hide date on statusbar
Select date style
Day and date as uppercase
Select center/right aligned clock
Set any color time and date
Full battery notification on/off
Low battery notification on/off
Usb connection sounds on/off
Show/hide No notification title
Show/hide ongoing title
show/hide ongoing items
Set statusbar to any color and transparency
Set dropdown to any color and transparency
Any color battery
Any color wifi/data icons
Any color statusbar icons
Any color toggle icons
Any color toggle button background
Alarm icon on/off
Bluetooth icon on/off
Vibrate/Mute icons on/off
Lock screen button on statusbar on/off
Carrier text on/off
Custom carrier text
Any color carrier text
Any color battery text
Any color/transparency dropdown header
Any color Header buttons
Show next alarm on dragbar
Add on button to dropdown header choose None/Recents/Clear/Lockscreen
Toggles text on/off
Toggles indicator on/off
Any color toggles text
Set statusbar any image
Set dropdown any image
Hex color setter
Select from 15 different battery types
Select Time and date size
Option to size dropdown clock too
Select brightness slider text color
Fast Shutdown
Fast Reboot
Fast auto boot into recovery
Long press back kills app(multiwindow moved to menu key) or
Long press menu kills current app
Set any mid battery value
Set any low battery value
Set any mid battery color
Set any low battery color
Show/Hide battery
Show/Hide blocking mode icon
Long press volume buttons skips tracks
Wallpaper scrolling
Drop down clock has its own color
Drop down date has its own color
3 New toggles added:
Torch
Power Off
Reboot menu with (Reboot, Recovery, Download modes)
Pressing home on lockscreen toggles torch (with on/off toggle in settings) can also be set to long press
Option to have 5 or 6 quicksetting toggles displayed
Any color battery on/off
Toggle control (turn unused toggles on/off)
Toggles order shortcut added
Donate version 2.3+ only
You can now set data/wifi data arrows to stock
Choose between 5 different 4g images
Any no notification title text color
Any On going title text color
Any notification title text color
Any clear button text color
Donate version 2.4+ only
Set S View screen time out
Any color S View time
Any color S View day
Any color S View date
Any color S View ap/pm
Any color S View missed call text
Any color S View sms notification text
Any color S View playing track title
Donate version 2.5+ only
Quick pin unlock
Multi widgets on secure lockscreen
Camera on secure lockscreen
Hide lockscreen carrier text
Stock look setting (one click revert)
No notification title background color
On going title background color
Latest items title background color
Donate version 2.6+ only
Added (so far many more to come) button actions
Menu long press {Default, Kill app, Multiwindow, Launch any app, Torch, Disable, Screenshot, Recent apps}
Back long press {Default, Kill app, Launch any app, Torch, Disable, Screenshot, Recent apps}
Home long press {Default, Kill app, Multiwindow, Launch any app, Torch, Disable, Screenshot}
Home long press on lockscreen {Torch, Press and release torch, Disable}
Donate version 3.0+ only
Completely re-written
Ime switcher on/off
Added date style (01/01/13)
Space before am/pm
Header clock size
Header clock am/pm size
Header clock show and hide am/pm
Any image toggle buttons background (5kb <) tested with i
Many more to come
Downloads
Please note when buying the app you are buying it for the framework it its current state. I don`t own the device so I cannot gaurantee future compatibility buy buying the app you are agreeing to this.
3Minit Settings app v2.5 free can be download from downloaded center above
Please do not make mirror links
Devs please do not port or use this framework in your rom
Installation Guide:
1. Connect device to computer and copy the framework to internal memory.
2. Reboot into custom recovery.
3. Flash firmware
4. Download and install settings app either from playstore or download center above
5. Your Done!
Changelog
3.0(29/07/2013)
Ime switcher on/off
space before am/pm
Header clock size
Any image toggle buttons background (5kb <) tested with image size(H92 W50 pixels)
Any color dragbar image
5 new battery types
Starts as stock look now
All new toggle control
Any color navigation bar back color
Any color navigation button colors
Fixed statusbar color when opening apps/recents etc
Fixed presitent smart pause
Added disable action to lockscreen long press
New look app
Many other thing I cant think off.
2.6 (17/07/2013)
android.policy has been re-written all codes streamlined
Home long press on lockscreen {Torch, Press and release torch}
2.5 (11/07/2013)
Quick pin unlock
Fixed backup + restore
Toggle control now keeps your current toggle arrangment after changing the settings
2.4(30/06/2013)
Statusbar turns black when cover is closed
2.3 (28/06/2013)
Lockscreen torch can now be set to long press on home to toggle on/off
Fixed orange in data arrow when using coloured data arrows
2.2 (16/06/2013)
Any color battery can now be turn off for those who want to use there own custom battery.
Rearrange toggles shortcut added.
Setting toggle ,toggle text, toggle indicator colors and settings no longer requires SysytemUI resart.
Volume adjusting whilst in call fix included.
2.1 (13/06/2013)
Torch
Power Off
2 new BIG battery types added
Look for the new setting to activate them(They can be orderd in device settings)
Fixes:
Fixed notification and center clock overlap bug
Fixed Launcher fc when setting a wallpaper
Fixed semi transparent status bar Samsung brought in on MEA
Fixed Gps/Download icons now display correctly
Other fixes improvemants
2.0
Long press volume skips track(with on off toggle)
Some small app changes
Batterys have been resized
Wallpaper scrolling on/off
1.9
Show/Hide battery
Airplane mode icon is now colored
Ongoing items, Ongoing title, No notification title codes have been fully re-work and now have instant effect(without SystemUI restart)
When you have clear add-on button set clear button from dropdown is hidden(as it is not needed)
Ugly clear notification button has gone.
Navigation bar mod has been reworked and now works without SystemUI restart
1.8
Fast Shutdown
Fast Reboot
Long press menu kilss app
1.7
Select from 13 different battery types
Hex color picker fixes.
1.6
Hex color setter
1.5
Toggles text on/off
1.4
Alarm icon on/off
Carrier text on/off
Custom carrier text
1.3
Any color battery
Transparent notification items
Fixed know bug
1.2
1.1
Any color clock and date
Center/right aligned clock
Transparent dropdown panel
TESTER SUR ME2, ME3, MEA, MF8 et MGA : OK
Modifié par dada24
bon je viens d'essayer de l'installer ca m'a foutu mon tel en l'air, plus de barre de notification, malgré les recommendation du dev ( desinstallation de l'appli, flash du Framework, et reinstallation de l'appli ) impossible de recuperer un tel fonctionnel. je suis en train de telecharger une rom pour repartir de zero je reessaye derriere de l'installer je trouve le concept super interessant.
Faut pas oublier que c'est compatible que avec les roms custom ! Et d'ailleurs vu que c'est les mêmes createurs que les Roms Omega faut pas s'etonner que sa marche qu'avec la Omega !
Oui en effet je viens de voir qu'il faut une rom deodexed, j'avais pas vu donc si votre rom est pas deodexed votre tel deviens inutilisable (le temps de perdu pour pas avoir lu les prérequis assez bien ya des fois je suis con).
Vu que j'ai télécharger la oméga je vais l'installer ( je voulais éviter j'aime pas leur anim du début, et pour trouver une animation full hd valable c'est pas facile) mais sinon sur mes ancien s2 et s3 elle marchait bien.
je vous tiens au courant merci pour l'info en tout cas.
bonne journée
Non... Ca ne modifie pas que la statusbar, mais tout ton centre de notifications également...
Et il y a même des fonctions en plus comme par exemple allumer la lampe torche avec un seul bouton sur le lockscreen, etc...
Et il est très très souvent mis à jour ( 1x tous les 2 jours environ )
Je conseille vraiment à tout le monde pour personnaliser ton phone le plus profondément possible !
Par contre j'ai des problèmes d'installation
à chaque fois qu'il y a une mise à jour et que je dois télécharger le fichier pour le flasher, mon téléphone ne démarre plus... je dois tout recommencer à 0, flash d'une rom normale, root, recovery, omega etc...
C'est possible d'avoir de l'aide s'il vous plait ?
merci
Vérifie bien que tu prends la bonne version. Logiquement c'est la MEA mais regarde dans les paramètres de ton téléphone dans plus puis à propos de l'appareil puis version de la basebande.
Sent from my GT-I9505 using Tapatalk 4 Beta
