jeyy Posté(e) 14 juin 2013 Share Posté(e) 14 juin 2013 (modifié) source du topic >>>> http://forum.xda-dev...d.php?t=2291291Introduction About ProBAM ProBam v4.1 ROM basée sur les sources de la PAC MAN de @szl.kiev Screen shots la ROM ProBAM Reactor est un mix des meilleures romsParanoid 3 + AOKP + CM 10= ProBAMc'est une ROM All-In-One !!!!fonctionnalités incluses:2 secondes pour démarrer ! & 1 seconde pour redemarrer ou éteindre ! installeur Aroma !!Smart Stay (EyeSPY Modded Free version)Privacy Guard more informationsVibration Customization LED Colors , you can change led color while charging for example LED Fading/Blinking LED DisableS4 Launcher3G/wifi meterSamsung goodiesPimpmyromMain Features: AOSPA (Paranoid 3.68) Pandroid UI smooth/customizable Experience:HALO vertical gestures,Halo new themes multi colorsHalo+ , MultiWindow launcherPIE navigation controlsHybrid SettingsPer App DPINavBar HeightPer-App LayoutPer-App Color CyanogenMod 10.1.2 Hardware keys remappingLockscreen ring and notification shortcutsPower widgetUSB Mass StorageClock settingsQuiet HoursPower SoundsProfiles AOKP build 6Rom ControlRibbonWidgetDeep ControlPermissions maintenant PA, CM and AOKP mettent a jours leurs sources avec les fixes de googleFull change logs Quote: add full Gappsadd SELinux & SELinux mode toggle , more infoSettings: Make QS Tile Random Color off by defaultadd new Halo Sizefix Battery iconfix Battery chargefix Battery HaugeSignal strength: add more checks to signal strengthadd AutoHide StatusbarFix Random FC's in System UIfix low audiorebased fully on PAC source !Updated to CM 10.1.2Updated to PA 3.68Configuration fix for hdpi devicesMerge HALO new features/optionsNew HALO vertical gesturesHALO master switchFix HALO sizeFix PIE SizeFix SystemUI FCFix brightness lagFix Sms limit FC in SettingsFix HALO OverlyFix HALO memory leaksAdd new tiles style option, random color for flip tilesFloating window modeBattery Life Awesome !Reactor Speed!Roboto fonts from android 4.3Camera from android 4.3 as addonNew Privacy Guard optionsFix the privacy guard notificationFix Sound mute in BoefflaAppOTA Platform updaterAdded ROMStatsXperia Honami wallpaperskeyboard with gesture, moddedROM size decreased to half Changelog 4.1.1:* Focal (new Camera App)* Swipe Keyboard is build in now* Update PA to 3.69* Fix Background Error* Gesture Lockscreen* Still Android 4.2.2 (Your are not our Beta Testers) The TeamProBAM chiefcodexcjumoog @csec website content managed Wonderful man!Installation & instructions pour une 1ère install: Copy the downloaded ProBAM to your phone. Boot into your custom recovery Back up your ROM Enter custom recovery Make full wipe "included "system" Select Recommended kernel for first install Install the ROM install GAPPS package Reboot - the first boot can take up to 2 minutes Latest Stable Releaseserveur EU site du dev Addons/Mods !!OTA Updates:si vous n'arrivez pas a télécharger les OTA depuis le tel , faites le depuis son site (j'essaierai de mettre les liens ici sinon) :excl: si vous avez un kernel custom pensez a reflasher les modules après avoir fait une OTA :excl: mais dans tous les cas _____________________________________________________________________ Modifié 12 août 2013 par superjey 3 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 14 juin 2013 Share Posté(e) 14 juin 2013 (modifié) Merci Superjey :) Je vien de l'installer , bon faut le dire : c'est mieux que JellyBam cette ProBam , énormement de choix qui plus est en francais pour certain de ce que j'ai vu ,pour le moment je suis perdu y a trop de tweaks :D mais ca change des autres 4.2.2 . Modifié 14 juin 2013 par herveonex 3 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jeyy Posté(e) 14 juin 2013 Auteur Share Posté(e) 14 juin 2013 (modifié) bon c'est une tuerie cette ROM . je sais pas si j'aurais assez d'une vie pour la configurer. seul bémol: apn a créer soit même option "contole BAM/ barr de navigation" donne un FC le menu pie est limité comparé a celui de la sentinelleROM mais c'est comme ça sur les autres ROM aussi là j'essaie BAM moder pour installer le pack "Xperia Apps" mais mon recovery ne le flash pas il doit peu être falloir TWRP ou CWM je sais pas encore concernant l'autonomie je sais pas encore biensûr ... mais grosso merdo elle envoie du paté vu qu'elle regroupe tous les tweak quasiment des Android4.2.2 donc c'est un régal. le DT2W fonctionne parfaitement aussi PS: je galère aussi avec le menu halo si quelqu'un pouvais en faire un descriptif/tuto complet ce serait génio :) Modifié 14 juin 2013 par superjey 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) Tiré du post original : Halo Activer / Désactiver! Pour activer Halo tirer vers le bas le panneau de notification et vous verrez un cercle bleu avec une zone de texte, sélectionnez-la pour activer la fonction de Halo! Ensuite, regardez dans vos applications dessiner ou aller à playstore et télécharger l'application Halo pour des réglages supplémentaires, en ouvrant l'application, il peut sembler comme une page blanche pour vous, mais l'idée est de cerner les applications que vous souhaitez utiliser avec Halo à votre liste des applications choisies, puis appuyez sur le bouton de lecture pour les activer dans Halo! Voir cette vidéo sur la façon d'utiliser correctement> http://www.engadget.com/2013/06/11/p...-multitasking/ Pour désactiver Halo, double tapez et maintenez le Halo Cercle Icône de message et faites-le glisser jusqu'à un cercle rouge avec la croix en haut de l'écran pour le désactiver! Pour déplacer Halo à une partie différente de votre écran, double tapez et faites glisser à l'emplacement désiré et relâchez et il flottera plus! Envoyé depuis mon HUAWEI MT1-U06 avec Tapatalk Modifié 15 juin 2013 par herveonex Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) Cette ROM m'a l'air a peu près parfaite (pour moi) ! J'utilise actuellement carbonRom donc : Y a-t-il toutes les options de la rom Carbon ? J'ai vu dans la description sue cette ROM est un mix entre J elly-Bam + Root-BOX + Slim + Carbon + Paranoid 3 + AOKP + CM 10. Le problème des xperia apps me dérange un peu car j'utilise l'appli Walkman ... et &**//&**&df**&& ca veut pas ce mettre en forme j’espère que c'est lisible Edit : Bon je vais l'installer, quelqu'un sait si il faut faire les wipes si on vient d'une autre ROM 4.2.2 ? Modifié 15 juin 2013 par nicolas@LOVE.android/4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 De Viperx donc 4.1.1 a celle la , il restait bloqué sans wipes complet . Envoyé depuis mon HUAWEI MT1-U06 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) D'accord je fait les wipes et je vous tient au courant. Edit : Cette ROM m'a l'air très fluide, je regrette juste que le launcher soit Nova Launcher (mais c'est un détail). Sinon j'ai jamais vu autant de tweak de ma vie réuni dans une même ROM ! Je vais passer un temps fou a les paramétrés ! On va voir a l'usage maintenant, je n'est pas encore essayer le son il parait qu'il y a un mod inclus...on verra. Je n'est pas encore bien compris comment marche le halo mais je vais m'y faire et comprendre grace au petit tuto que nous a fait Herveonex. Sinon les Gapps sont bien incluses. Modifié 15 juin 2013 par nicolas@LOVE.android/4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jeyy Posté(e) 15 juin 2013 Auteur Share Posté(e) 15 juin 2013 (modifié) Bon moi j'ai un soucis avec la luminosité ça commence.... Modifié 15 juin 2013 par superjey Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) C'est quoi ton souci exactement ? moi on dirais que ça va. Ah la la gros problème, lorsque j'essaye d'entrer dans Paramètre=>controle BAM=>barre de navigation C'EST LE DRAME ! "L'application Paramètres s'est arrêtée" !! Modifié 15 juin 2013 par nicolas@LOVE.android/4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 C'est juste la traduction du post sur xda, faudrait un vrai tuto pour tout comprendre . Oui ce FC je l 'ai aussi et il apparait aussi lors de certaines modif qui demande le redémarrage du one. Pour la luminosité je suis toujours à fond , même si ça tue l'autonomie, mais pas de souci avec . Envoyé depuis mon HUAWEI MT1-U06 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) En gros il y a plein de truc qui ne marche pas dans les paramètres BAM...On peut pas tout avoir ! Pour ce qui est des applis xperia, j'ai réussi a les flashés (par le recovery) la ça met a jour les apps...on va voir ca marche Edit : Bon la j'ai un vrai problème je peut installer AUCUNE appli qui ne vient pas du playstore, le bouton "installer" ne marche pas :mad: je comprend pas les sources inconnues sont activés...help Modifié 15 juin 2013 par nicolas@LOVE.android/4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 Pour ma part juste la barre navigation , pour les autres FC c'était avec Android tweaker Envoyé depuis mon ProBam by codexc @XDA avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 Oui c'est bien beau android tweaker mais ca vaut 3€, ca revient a ma question comment installer des applis qui ne viennent pas du playstore ? etant donner que : je ne peut installer AUCUNE appli qui ne vient pas du playstore, le bouton "installer" ne marche pas :mad: je comprend pas les sources inconnues sont activés selon ce que j'ai dit plus haut. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) Peut pas te dire la ! Mais je vrai passer sur la v1.1 . Envoyé depuis mon ProBam by codexc @XDA avec Tapatalk Édit Android tweaker c est la version free . Modifié 15 juin 2013 par herveonex Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) Ok mais a tu essayer d'installer une appli qui ne vient du play store ? Edit : J'avais pas vu la version free. Modifié 15 juin 2013 par nicolas@LOVE.android/4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) Nan , faudrait que je test ça Envoyé depuis mon ProBam by codexc @XDA avec Tapatalk Édit : test négatif , y a un blocage quelque part. Tu bloques ici Modifié 15 juin 2013 par herveonex Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alexismeee Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) Un retour que l'autonomie serait-il possible ? =) Modifié 15 juin 2013 par Nexus969 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) J'ai fait un tour sur XDA et j'ai retrousser mes manches pour trouver un endroit ou quelqu'un en parle et j'ai trouver ca : "When I start the apk from file manager the button Next is not active, I can only abort the installation with the button on the left next to it. Any overlay there blocking it? Here the solution, you can't install apks if halo is running "like any rom included halo" Just disable it by double tapping on halo circle then drag it to the cross and you can install apk files." en clair ca donne : Quand je veut installer un apk a partir d'un gestionnaire de fichiers, quand j'appuie sur le bouton Suivant il n'est pas actif, je peux abandonner l'installation avec le bouton sur la gauche à côté de lui. Toute superposition le bloque? Voici la solution, vous ne pouvez pas installer d'apks si Halo fonctionne "comme n'importe quelle ROM avec Halo" le désactiver en tapant deux fois sur le cercle Halo puis faites-le glisser sur la croix et vous pouvez installer les fichiers apk !! J'ai essayer ET CA MARCHE !! Edit : pour ce qui est de l'autonomie ( étant donné que quand j'ai installer la ROM j'était a peu près a 65-70%: Modifié 15 juin 2013 par nicolas@LOVE.android/4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jeyy Posté(e) 15 juin 2013 Auteur Share Posté(e) 15 juin 2013 ''C'est juste une traduction il faudrait un tuto complet'' Bin je t'en pris vas y .... Pour la luminosité le blem est présent en mode auto . Pour le problème des application je ne l'ai pas moi Ah la la gros problème, lorsque j'essaye d'entrer dans Paramètre=>controle BAM=>barre de navigation C'EST LE DRAME ! "L'application Paramètres s'est arrêtée" !! je le cite plus haut aussiJe vous ai mis le lien du dossier de téléchargement (et j'ai bien fait) pour la v1.1 je n'ai pas vu le change log autant ça règle quelques soucis qu'on cite Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) Tu as raison, le réglage auto garde la luminosité au max si on regarde bien, il faut se mettre e manuel... Le problème c'est que je crois avoir la version 1.1 Modifié 15 juin 2013 par nicolas@LOVE.android/4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jeyy Posté(e) 15 juin 2013 Auteur Share Posté(e) 15 juin 2013 (modifié) Chez moi ça garde la luminosité au mini c'est plus contraignant ProBam v1.1- Reall Battery Smooth !! - Amazing Fire speed ! - Tweaked GPRS/DATA - Update sony bravia add new lib - FIX APN Auto-Detect for DATA/MMS add many countries - FIX Browser zoom - ICJ - Update Gapps app for latest release - keyboard : FIX swipe in keyboard - keyboard : numbers added & more - keyboard : Swype is smoother than before. - Update media sounds collection lock/unlock for iphone - RedBlackPellet - Update framework/systemui xhdpi icons - RedBlackPellet - Add CM file manager - CM - Remove BamPapers/Wallpapers "FIX APN Auto-Detect for DATA/MMS add many countries" tu pouvais pas le faire avant non ! lol Modifié 15 juin 2013 par superjey 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) A oui c'est sur que c'est plus contraignant. c'est bizarre même si je met luminosité mini et j'appuie sur auto, ça augmente. T' a la version 1.1 ? Edit : j'ai essayer d'installer LMT Pie Controls qui me venait de SentinelROM mais ca ne marche pas :mad: . Modifié 15 juin 2013 par nicolas@LOVE.android/4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jeyy Posté(e) 15 juin 2013 Auteur Share Posté(e) 15 juin 2013 pour le FC dont on parle je pense que ça vient du fait qu'on active pas la barrte dans un 1er temp Just Go to Settings > PA prop > swipe right > interface > drag Nav bar to 0% ce qui serait donc logique A oui c'est sur que c'est plus contraignant. c'est bizarre même si je met luminosité mini et j'appuie sur auto, ça augmente. T' a la version 1.1 ? non je la télécharge là, vous avez upgradé sans wipe et sans soucis? Edit : j'ai essayer d'installer LMT Pie Controls qui me venait de SentinelROM mais ca ne marche pas :mad: . raaa je comptais le faire aussi mais donc ce n'est pas la peine alors.. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 15 juin 2013 Share Posté(e) 15 juin 2013 (modifié) C'est déjà à 0 % chez moi. A non j'ai compris il faut au contraire augmenter. Edit : marche pas pk je peut plus mettre de screenshots ? Modifié 15 juin 2013 par nicolas@LOVE.android/4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jeyy Posté(e) 15 juin 2013 Auteur Share Posté(e) 15 juin 2013 met toi en plein cagnard tu vas comprendre surtout que chez toi il doit pas en manquer là :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
